  4. Bose sprach ausgabe
    5.4k
Bose sprach ausgabe
35 Beiträge 4 Kommentatoren 5.3k Aufrufe 4 Beobachtet
  • David G.D David G.
    @johny2410
    Hier ist der Export.
    Mein Appkey habe ich mit xxxxxx ersetzt.
      <variables>
        <variable type="timeout" id="timeout">timeout</variable>
        <variable type="timeout" id="timeout2">timeout2</variable>
      </variables>
      <block type="on" id="P)MbE7-)CU,Ie~9{Mg.#" x="-762" y="63">
        <field name="OID">0_userdata.0.Sprachausgabe.Zu_sprechender_Text</field>
        <statement name="STATEMENT">
          <block type="sayit" id="Xc~;GZD?XGl9=L{x?qN=">
            <field name="INSTANCE">all</field>
            <field name="LANGUAGE">de</field>
            <field name="LOG"></field>
            <value name="MESSAGE">
              <shadow type="text" id="K_Jt7a[/u7gsA:[dZ;/o">
                <field name="TEXT">gggg</field>
              </shadow>
              <block type="on_source" id="9mr8aFJ;V)R,jrmmDO1v">
              </block>
            </value>
            <next>
              <block type="timeouts_settimeout" id="9Cj1NeWGz_KD5dc9}11]">
                <field name="DELAY">1</field>
                  <block type="exec" id="-Hs@I63![jqDc)(?R6o)">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                    <field name="WITH_STATEMENT">FALSE</field>
                    <value name="COMMAND">
                      <shadow type="text" id="Eu*kfUv}Z3$L%i2S|+uk">
                        <field name="TEXT">mv /opt/iobroker/iobroker-data/sayit/sayit.0.say.mp3 /var/www/html</field>
                      </shadow>
                    </value>
                    <next>
                      <block type="timeouts_settimeout" id="c0kX0%rr)ee7)r%K=nBj">
                        <field name="NAME">timeout2</field>
                          <block type="exec" id="=(Uxiu)4n@vAW4~8yM:c">
                              <shadow type="text" id="1I$^f/Qa*aeoQjfCa`O;">
                                <field name="TEXT">curl -d \ "&lt;play_info&gt;&lt;app_key&gt;xxxxxxxxxxxxx;/app_key&gt;&lt;url&gt;http://192.168.99.33/sayit.0.say.mp3&lt;/url&gt;&lt;service&gt;service text&lt;/service&gt;&lt;reason&gt;reason text&lt;/reason&gt;&lt;message&gt;message text&lt;/message&gt;&lt;volume&gt;10&lt;/volume&gt;&lt;/play_info&gt;" http://192.168.99.24:8090/speaker</field>
                              </shadow>
                              <block type="text_join" id="37M^HRW9i67*5:1tD-4g">
                                <value name="ADD0">
                                  <block type="text" id="THF9pN,zFaoAxP9kIl(4">
                                    <field name="TEXT">curl -d \ "&lt;play_info&gt;&lt;app_key&gt;xxxxxxxxx&lt;/app_key&gt;&lt;url&gt;http://192.168.99.33/sayit.0.say.mp3&lt;/url&gt;&lt;service&gt;service text&lt;/service&gt;&lt;reason&gt;reason text&lt;/reason&gt;&lt;message&gt;message text&lt;/message&gt;&lt;volume&gt;</field>
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="get_value" id="+#ZjSj~6;Ti*1boSEaJF">
                                    <field name="OID">0_userdata.0.Sprachausgabe.Lautsaerke</field>
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="iK2UbN]TyKAs#i*1qhoC">
                                    <field name="TEXT">&lt;/volume&gt;&lt;/play_info&gt;" http://192.168.99.24:8090/speaker</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    Johny2410J Offline
    Johny2410J Offline
    Johny2410
    @david-g @david-g @david-g danke, ich habe es aus probiert. es funktioniert bis auf die ton ausgabe. da komt immer der log error datei ist zu kurtz. ist ich habe die mp3 datein auf meiner fritznas gespeichert. ich habe dein skript 1 zu 1 übernommen nur der trigger habe ich entfernt. weil ich nicht genau begriffen habe wofür der ist.
    • Johny2410J Johny2410
      David G.D Online
      David G.D Online
      David G.
      @johny2410
      Der Trigger überwacht einen Datenpunkt in den der Text für die Sprachausgabe geschrieben wird.
      Wenn dort zb "Waschmaschine fertig" eingetragen wird, wird das Script gestartet.
      Erst wird mit sayit die mp3 (Waschmaschine fertig) geschrieben, verschoben und dann abgespielt.
      Kann die Fritzbox die Daten per http bereitstellen? Dachte nur ftp. Dachte, dass mag die Bose nicht.
      Welcher Adapter meldet, dass die mp3 zu kurz ist?
      Den eigenen Appkey hast du?
      Johny2410J 1 Antwort Letzte Antwort
        @johny2410
        Johny2410J Offline
        Johny2410J Offline
        Johny2410
        schrieb am zuletzt editiert von Johny2410
        @david-g einen Appkey habbe ich. und es funktioniert auch alles nur halt kein ton.
        ich habe grade mahl versucht eine Datei von meinem Server abzuspielen genau das gleiche problem, kein ton.
        so wol als link per fritz.box und per Freigabe von meinem synology nas kein ton.
        habe es jetzt so modifieziert
          <variables>
          </variables>
          <block type="sayit" id="Xc~;GZD?XGl9=L{x?qN=" x="-412" y="113">
                <field name="TEXT">Post ist da</field>
              </shadow>
            </value>
            <next>
                      </shadow>
                    </value>
                    <next>
                              </shadow>
                              <block type="text_join" id="_*1t)3F`,vxAU0?!apgg">
                                <value name="ADD0">
                                  <block type="text" id="Q(h5wpOs0a9XMcteFZ7E">
                                    <field name="TEXT">curl -d \ "&lt;play_info&gt;&lt;app_key&gt;xxxxxxxx&lt;/app_key&gt;&lt;url&gt;http://192.168.178.29/sayit.0.say.mp3&lt;/url&gt;&lt;service&gt;post ist da&lt;/service&gt;&lt;reason&gt;es ligt ein paket in der postbox &lt;/reason&gt;&lt;message&gt;post ist da&lt;/message&gt;&lt;volume&gt;</field>
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="text" id=";);mx97{rVisnx7tz}ww">
                                    <field name="TEXT">30</field>
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="9cKsZZsE/wFhWlC0Z{Mg">
                                    <field name="TEXT">&lt;/volume&gt;&lt;/play_info&gt;" http://192.168.178.12:8090/speaker</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </xml>
        vielleicht kannst du mahl kucken (wen du ziet und lust hast) wo möglicher weise ein Fehler liegen könnte.
        Edit:
        es funktioniert so wie ich das jetzt modifiziert habe bis auf die ton aus Gabe
        David G.D 2 Antworten Letzte Antwort
            <variables>
            </variables>
                </shadow>
              </value>
              <next>
                        </shadow>
                      </value>
                      <next>
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </xml>
          Edit:
          David G.D Online
          David G.D Online
          David G.
          @johny2410
          Hast du mal eine xbelibige Datei aus dem internet probiert?
          Wo man so einfach drauf kommt.
          So hatte ich anfangs alles erst ans laufen gebracht. Dann hab ich eigene mp3s getestet.
          Welche Box hast du?
              <variables>
              </variables>
                  </shadow>
                </value>
                <next>
                          </shadow>
                        </value>
                        <next>
                                  </shadow>
                                    <value name="ADD0">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </xml>
            Edit:
            David G.D Online
            David G.D Online
            David G.
            @johny2410
            Was mir grad noch einfällt, was für eine Lautstärke ist eingestellt?
            MUSS zwischen 10 und 70 sein.
              @johny2410
              Johny2410J Offline
              Johny2410J Offline
              Johny2410
              @david-g erstmal vrohe Ostern. Die Lautstärke beträgt 30. Ich habe es mahl mit einem yt link probiert. Hat trotzdem kein Ton abgespielt.
              Ich habe die soundtouch 20 v3
              EditAC53E912-6BEA-40F0-8968-DF2EFBB17D74.png habe grade noch ein error gefunden im log. Mit nem mplayer
                David G.D Online
                David G.D Online
                David G.
                @johny2410
                Wird die mp3 denn erzeugt?
                Das macht der bei mir nicht bei jeder Einstellung.
                So hab ich es:
                Kannst du über die entsprechende URL aus deinem Skript eine funktionierende mp3 runterladen?
                EDIT:
                Hab grad mal oben deinen Code überflogen. Kann sein, dass beim Befehl für die Bose noch die IP meiner Box steht?
                  @johny2410
                  So hab ich es:
                  EDIT:
                  Johny2410J Offline
                  Johny2410J Offline
                  Johny2410
                  @david-g nein kann nicht sein. meine box reagiert drauf kommt aber nur kein ton. aber ich kucke noch mahl Sicherheits halber mahl.
                  Edit. Der Fehler den ich beim letzten post hatte ist weg. Aber das Problem ist trotzdem noch da
                    David G.D Online
                    David G.D Online
                    David G.
                    @johny2410
                    Kannst mir ja mal. Deine mp3 senden.
                    Dann schaue ich mal was meine Box macht.
                      David G.D Online
                      David G.D Online
                      David G.
                      @johny2410 said in Bose sprach ausgabe:
                      Meinst du Youtube? Klappt das?
                      Teste mal mit https://www.soundjay.com/transportation/train-crossing-bell-01.mp3
                      Evtl kommt die Box ja nicht mit dem Server von deiner Fritte zurecht (wie hast du den überhaupt eingerichtet, kenne ich gar nicht?).
                        David G.D Online
                        David G.D Online
                        David G.
                        @johny2410
                        Hab jetzt auch die to short Meldung bekommen.
                        Allerdings bei einem sehr langen Text.
                        Hast du mal was kurzes probiert, falls dein Text lang ist?
                        Oder die timeouts was verlängert? Evtl ist die Übertragung noch nicht fertig.
                          @johny2410
                          Johny2410J Offline
                          Johny2410J Offline
                          Johny2410
                          @david-g ich habe das alles schon mahl durch getestet, habe den fehler noch nicht gefunden. Ich glaube das ich das erstmal ruhen lasse. Und es noch mahl zu einem anderem Zeitpunkt wieder aufgreifen werde. Erst mahl danke für deine Hilfe und deinem Support. Und die Zeit die du dir genommen hast.
                            David G.D Online
                            David G.D Online
                            David G.
                            @johny2410
                            Glaube hab die Lösung von deinem Problem gefunden.
                            Hat der Server von deiner mp3 ein gültiges Ssl Zertifikat?
                            Hab grad gesehen, dass es bei den Objekten von sayit schon einen link zur mp3 gibt.
                            Diesen konnte ich im Browser auch öffnen. Die Bose hat ihn allerdings nicht genommen. Laufende Musik wurde abgesenkt, kam aber keine Meldung.
                            Hab dann noch eine weitere Instanz vom Web-Adapter installiert, dort die Verschlüsselung abgeschaltet und einen anderen Port (bei mir 8083 anstatt 8082) wie in Instanz 1 angegeben. Dann bei Sayit diese Instanz angegeben.
                            Nun erscheint in den Sayit nach einem Neustart und dem ersten generieren einer mp3 ein neuer Link.
                            Dieser klappt wieder in der Box.
                            Und im Skript auf jeden Fall den Timeout einbauen. Sonst wird die mp3 nicht fertig.
                              @johny2410
                              Johny2410J Offline
                              Johny2410J Offline
                              Johny2410
                              @david-g
                              ich habe mahl die timer auf 1-5 minuten gestelt. und habe meine http verschluselung von der web instans deaktiviert. habe noch nicht weiter angekuckt. aber beim spontanen versuch hat es erst mahl nicht geklapt
                                @david-g
                                David G.D Online
                                David G.D Online
                                David G.
                                @johny2410
                                Dann hab ich erstmal auch keine Idee mehr....
                                dhD 1 Antwort Letzte Antwort
                                  @johny2410
                                  dhD Offline
                                  dhD Offline
                                  dh
                                  @david-g
                                  ich bin auf der Suche nach einer Möglichkeit zur Sprachausgabe über meine Bose-Boxen auf diesen Beitrag gestoßen und wollte den Ansatz ebenfalls versuchen.
                                  Leider bekomme ich auf der Bose Webseite die Mittelung, dass das Developer Portal geschlossen wurde. Somit kann ich keinen Consumer Key erstellen.
                                  Funktioniert die Sprachausgabe bei euch noch oder ist der Ansatz mit dem schließen des Developer Portal hinfällig?
                                  Falls es noch funktioniert, kann mir jemand sagen, wie man an Consumer Key herankommt? Meine Recherchen haben da leider nichts ergeben...
                                  • dhD dh
                                    @david-g
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    @dh
                                    Bei mir klappt es noch.
                                    Grad getestet. Läuft nicht so oft.
                                      @dh
                                      dhD Offline
                                      dhD Offline
                                      dh
                                      @david-g
                                      Danke für die Antwort. Ich habe mich mal an den Bose Support gewandt, aber der konnte mir bisher nicht weiterhelfen. Wie immer kommt man nur beim low-level Support raus und hat keine Möglichkeit, mit jemandem zu reden, der sich mit den Sachen auskennt.
                                      Ich werde noch weiter versuchen, an den Consumer Key zu kommen. Falls ich Erfolg damit haben sollte, werde ich die Infos hier teilen.
