  4. Wasserzähler (Funk 868) auslesen.
diehl868funkwasserzähleroms
220 Beiträge 23 Kommentatoren 91.1k Aufrufe 24 Beobachtet
    @hg6806 sagte in Wasserzähler (Funk 868) auslesen.:
    sudo chmod 777 /var/log/mosquitto
    sudo chmod g+s /var/log/mosquitto
    Schwachsinn.
    sudo apt remove --purge mosquitto mosquitto-clients
    sudo apt update
    sudo apt install mosquitto mosquitto-clients
    hg6806H Offline
    hg6806H Offline
    hg6806
    #86
    pi@raspberrypi:~ $ sudo journalctl -xe
    -- Subject: A start job for unit packagekit.service has begun execution
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- A start job for unit packagekit.service has begun execution.
    -- The job identifier is 1750.
    Mär 28 19:19:53 raspberrypi PackageKit[17498]: daemon start
    Mär 28 19:19:53 raspberrypi dbus-daemon[430]: [system] Successfully activated service 'org.freedesktop.PackageKit'
    Mär 28 19:19:53 raspberrypi systemd[1]: Started PackageKit Daemon.
    -- Subject: A start job for unit packagekit.service has finished successfully
    -- A start job for unit packagekit.service has finished successfully.
    Mär 28 19:19:53 raspberrypi sudo[17306]: pam_unix(sudo:session): session closed for user root
    Mär 28 19:20:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:21:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:22:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:23:28 raspberrypi sudo[17919]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl status mosquitto.service
    Mär 28 19:23:28 raspberrypi sudo[17919]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    Mär 28 19:23:28 raspberrypi sudo[17919]: pam_unix(sudo:session): session closed for user root
    Mär 28 19:23:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:23:56 raspberrypi dhcpcd[476]: eth0: Router Advertisement from fe80::464e:6dff:fe3a:e01c
    Mär 28 19:24:01 raspberrypi dhcpcd[476]: eth0: Router Advertisement from fe80::464e:6dff:fe3a:e01c
    Mär 28 19:24:05 raspberrypi dhcpcd[476]: eth0: Router Advertisement from fe80::464e:6dff:fe3a:e01c
    Mär 28 19:24:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:24:59 raspberrypi PackageKit[17498]: daemon quit
    Mär 28 19:24:59 raspberrypi systemd[1]: packagekit.service: Main process exited, code=killed, status=15/TERM
    -- Subject: Unit process exited
    -- An ExecStart= process belonging to unit packagekit.service has exited.
    -- The process' exit code is 'killed' and its exit status is 15.
    Mär 28 19:24:59 raspberrypi systemd[1]: packagekit.service: Succeeded.
    -- Subject: Unit succeeded
    -- The unit packagekit.service has successfully entered the 'dead' state.
    Mär 28 19:25:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:26:36 raspberrypi bash[526]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
    Mär 28 19:26:40 raspberrypi sudo[18395]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/journalctl -xe
    Mär 28 19:26:40 raspberrypi sudo[18395]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    Wirft wieder Fehler:
    ^Cpi@raspberrypi:~ $ sudo apt remove -purge mosquitto mosquitto-clients
    E: Befehlszeilenoption »p« [aus -purge] kann in Kombination mit den anderen Optionen nicht interpretiert werden.
    pi@raspberrypi:~ $ sudo apt update
    Holen:1 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
    Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
    OK:3 https://deb.nodesource.com/node_12.x buster InRelease
    Holen:4 http://archive.raspberrypi.org/debian buster InRelease [32,9 kB]
    Holen:5 http://packages.microsoft.com/repos/code stable/main armhf Packages [19,7 kB]
    Holen:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [19,2 kB]
    Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [19,8 kB]
    Holen:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
    Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [372 kB]
    Es wurden 13,5 MB in 2 min 34 s geholt (87,6 kB/s).
    Aktualisierung für 31 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    pi@raspberrypi:~ $ sudo apt install mosquitto mosquitto-clients
    mosquitto ist schon die neueste Version (1.5.7-1+deb10u1).
    mosquitto-clients ist schon die neueste Version (1.5.7-1+deb10u1).
    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 31 nicht aktualisiert.
    1 nicht vollständig installiert oder entfernt.
    Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
    Möchten Sie fortfahren? [J/n] J
    mosquitto (1.5.7-1+deb10u1) wird eingerichtet ...
    Job for mosquitto.service failed because the control process exited with error code.
    See "systemctl status mosquitto.service" and "journalctl -xe" for details.
    invoke-rc.d: initscript mosquitto, action "start" failed.
    ● mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
       Loaded: loaded (/lib/systemd/system/mosquitto.service; disabled; vendor preset: enabled)
       Active: activating (auto-restart) (Result: exit-code) since Sun 2021-03-28 19:42:17 CEST; 22ms ago
         Docs: man:mosquitto.conf(5)
               man:mosquitto(8)
      Process: 20998 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
     Main PID: 20998 (code=exited, status=1/FAILURE)
    dpkg: Fehler beim Bearbeiten des Paketes mosquitto (--configure):
     »installiertes mosquitto-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
    Fehler traten auf beim Bearbeiten von:
     mosquitto
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    pi@raspberrypi:~ $
    • hg6806H hg6806
                 man:mosquitto(8)
       mosquitto
      pi@raspberrypi:~ $
      #87
      @hg6806
      sudo apt dist-upgrade
      sudo apt reboot
      hg6806H 1 Antwort Letzte Antwort
        @hg6806
        sudo apt reboot
        hg6806H Offline
        hg6806H Offline
        hg6806
        #88
        Ausgeführt.
        Danach nochmal versucht zu installieren:
        Vorgeschlagene Pakete:
          apparmor
        Die folgenden NEUEN Pakete werden installiert:
        0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen noch 0 B von 210 kB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 461 kB Plattenplatz zusätzlich benutzt.
        Vormals nicht ausgewähltes Paket mosquitto wird gewählt.
        (Lese Datenbank ... 106872 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../mosquitto_1.5.7-1+deb10u1_armhf.deb ...
        Entpacken von mosquitto (1.5.7-1+deb10u1) ...
        Vormals nicht ausgewähltes Paket mosquitto-clients wird gewählt.
        Vorbereitung zum Entpacken von .../mosquitto-clients_1.5.7-1+deb10u1_armhf.deb .        ..
        Entpacken von mosquitto-clients (1.5.7-1+deb10u1) ...
        mosquitto-clients (1.5.7-1+deb10u1) wird eingerichtet ...
        Job for mosquitto.service failed because the control process exited with error c        ode.
           Loaded: loaded (/lib/systemd/system/mosquitto.service; disabled; vendor prese        t: enabled)
           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-03-28 21        :07:44 CEST; 35ms ago
                   man:mosquitto(8)
          Process: 2358 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (        code=exited, status=1/FAILURE)
         Main PID: 2358 (code=exited, status=1/FAILURE)
        Trigger für man-db (2.8.5-2) werden verarbeitet ...
        Trigger für systemd (241-7~deb10u6+rpi1) werden verarbeitet ...
         mosquitto
        pi@raspberrypi:~ $
        • hg6806H hg6806
          Ausgeführt.
            apparmor
                     man:mosquitto(8)
           mosquitto
          pi@raspberrypi:~ $
          #89
          @hg6806
          sudo netstat tulpen
            @hg6806
            sudo netstat tulpen
            hg6806H Offline
            hg6806H Offline
            hg6806
            #90
            @thomas-braun sagte in Wasserzähler (Funk 868) auslesen.:
            sudo netstat tulpen
            pi@raspberrypi:~ $ sudo netstat tulpen
            Aktive Internetverbindungen (ohne Server)
            Proto Recv-Q Send-Q Local Address           Foreign Address         State
            tcp        0      0 localhost:9000          localhost:60132         VERBUNDEN
            tcp        0      0 localhost:60462         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47692         VERBUNDEN
            tcp        0      0 localhost:48182         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48012         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60736         VERBUNDEN
            tcp        0      0 localhost:60400         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47712         VERBUNDEN
            tcp        0      0 localhost:47630         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60042         VERBUNDEN
            tcp        0      0 localhost:47712         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47690         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60074         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60116         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60044         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48078         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48014         VERBUNDEN
            tcp        0      0 localhost:48048         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48320         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60354         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60246         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60208         VERBUNDEN
            tcp        0      0 localhost:47656         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47762         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47630         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47656         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47676         VERBUNDEN
            tcp        0      0 localhost:60356         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60346         localhost:9000          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:1883 Wemos6-Brunnen.fr:60878 VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48348         VERBUNDEN
            tcp        0      0 localhost:47618         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48184         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48016         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60104         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48150         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47646         VERBUNDEN
            tcp        0      0 localhost:47970         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60120         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60492         localhost:9000          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:2001 homematic-ccu2.fr:51303 VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60762         VERBUNDEN
            tcp        0      0 localhost:60598         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47702         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:47628         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48348         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60522         VERBUNDEN
            tcp        0      0 localhost:48124         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60180         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60632         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47940         VERBUNDEN
            tcp        0      0 localhost:47814         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:47716         localhost:9001          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:1883 Wemos14-Ring-off.:65231 VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60540         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47704         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47970         VERBUNDEN
            tcp        0      0 localhost:60732         localhost:9000          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:1883 Wemos4-CurrentSen:56464 VERBUNDEN
            tcp        0      0 localhost:60092         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47766         VERBUNDEN
            tcp        0      0 localhost:47764         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48316         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47626         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60566         VERBUNDEN
            tcp        0      0 localhost:60032         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60736         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:48044         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60106         VERBUNDEN
            tcp        0      0 localhost:60522         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:48152         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60598         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47986         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60464         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60384         VERBUNDEN
            tcp        0      0 localhost:60206         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47688         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60300         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48110         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60386         VERBUNDEN
            tcp        0      0 localhost:60072         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60182         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48182         VERBUNDEN
            tcp        0      0 localhost:47792         localhost:9001          VERBUNDEN
            tcp        0   1296 Pi4-4GB-ioBroker-18:ssh IdeaPad5.fr:49816 VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60130         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48184         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48152         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:45888 homematic-ccu2.fri:2001 VERBUNDEN
            tcp        0      0 localhost:60182         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60120         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60382         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47702         VERBUNDEN
            tcp        0      0 localhost:47938         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60766         VERBUNDEN
            tcp        0      0 localhost:60386         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47644         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60346         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48154         VERBUNDEN
            tcp        0      0 localhost:47942         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60462         VERBUNDEN
            tcp        0      0 localhost:48012         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60630         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47938         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60128         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48048         VERBUNDEN
            tcp        0      0 localhost:48150         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48216         VERBUNDEN
            tcp        0      0 localhost:60242         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60344         VERBUNDEN
            tcp        0      0 localhost:47700         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60570         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60062         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60764         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60596         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47984         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48106         VERBUNDEN
            tcp        0      0 localhost:47888         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47928         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48016         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60210         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:1883 Wemos3-4xRelais-R:52931 VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60432         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47644         VERBUNDEN
            tcp        0      0 localhost:60130         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:48180         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48214         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60734         VERBUNDEN
            tcp        0      0 localhost:60460         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48350         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:51652 149.154.167.220:https   VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60178         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47988         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47616         VERBUNDEN
            tcp        0      0 localhost:47886         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:42756         localhost:43039         VERBUNDEN
            tcp        0      0 localhost:60632         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47968         VERBUNDEN
            tcp        0      0 localhost:47790         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60046         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47812         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60046         VERBUNDEN
            tcp        0      0 localhost:60342         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48076         VERBUNDEN
            tcp        0      0 localhost:60358         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48180         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60302         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60300         VERBUNDEN
            tcp        0      0 localhost:47930         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:47658         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60570         VERBUNDEN
            tcp        0      0 localhost:60524         localhost:9000          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:56716 165.254.239.130:https   VERBUNDEN
            tcp        0      0 localhost:60762         localhost:9000          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:51654 149.154.167.220:https   VERBUNDEN
            tcp        0      0 localhost:60734         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60400         VERBUNDEN
            tcp        0      0 localhost:60108         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47928         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:47940         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60208         localhost:9000          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:51656 149.154.167.220:https   VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47674         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47654         VERBUNDEN
            tcp        0      0 localhost:48078         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:47654         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60568         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60032         VERBUNDEN
            tcp        0      0 localhost:47704         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60566         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47658         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47816         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60070         VERBUNDEN
            tcp        0      0 localhost:60210         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47884         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47812         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47942         VERBUNDEN
            tcp        0      0 localhost:60404         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47930         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60108         VERBUNDEN
            tcp        0      0 localhost:60568         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60244         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60344         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60090         VERBUNDEN
            tcp        0      0 localhost:47678         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47966         VERBUNDEN
            tcp        0      0 localhost:48154         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60600         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48318         VERBUNDEN
            tcp        0      0 localhost:60060         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60356         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60526         VERBUNDEN
            tcp        0      0 localhost:47674         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60402         VERBUNDEN
            tcp        0      0 localhost:48046         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48212         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47618         VERBUNDEN
            tcp        0      0 localhost:47762         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60118         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60494         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60428         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47984         VERBUNDEN
            tcp        0      0 localhost:48110         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60538         VERBUNDEN
            tcp        0      0 localhost:47766         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60596         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60494         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60242         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48346         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60030         VERBUNDEN
            tcp        0      0 localhost:60496         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60430         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60044         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60430         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60304         VERBUNDEN
            tcp        0      0 localhost:60058         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60536         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60058         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47764         VERBUNDEN
            tcp        0      0 localhost:60432         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47714         VERBUNDEN
            tcp        0      0 localhost:48212         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48122         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48106         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47794         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60244         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60460         VERBUNDEN
            tcp        0      0 localhost:47626         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47642         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60496         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48108         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47628         VERBUNDEN
            tcp        0      0 localhost:47794         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47910         VERBUNDEN
            tcp        0      0 localhost:47692         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47700         VERBUNDEN
            tcp        0      0 localhost:60304         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60492         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48316         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47716         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:1883 Wemos7-Garagentor:57189 VERBUNDEN
            tcp        0      0 localhost:60132         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47646         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47792         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47678         VERBUNDEN
            tcp        0      0 localhost:60302         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48124         VERBUNDEN
            tcp        0      0 localhost:60030         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:48076         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:47968         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60536         VERBUNDEN
            tcp        0      0 localhost:47966         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48320         VERBUNDEN
            tcp        0      0 localhost:60402         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48080         VERBUNDEN
            tcp        0      0 localhost:48214         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48120         VERBUNDEN
            tcp        0      0 localhost:48120         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60074         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47714         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48350         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47886         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60094         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47790         VERBUNDEN
            tcp        0      0 localhost:47816         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60342         VERBUNDEN
            tcp        0      0 localhost:47616         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60538         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60382         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60404         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47688         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48122         VERBUNDEN
            tcp        0      0 localhost:60094         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:48318         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60062         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:40272 AVR3311.fritz.bo:telnet VERBUNDEN
            tcp        0      0 localhost:60246         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47690         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:48216         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60206         VERBUNDEN
            tcp        0      0 localhost:48108         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60116         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60732         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:56636 HP9E427C.fritz.box:ipp  CLOSE_WAIT
            tcp        0      0 localhost:60384         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60118         VERBUNDEN
            tcp        0      0 localhost:60464         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:43039         localhost:42756         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60764         VERBUNDEN
            tcp        0      0 localhost:47884         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60428         VERBUNDEN
            tcp        0      0 localhost:47910         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60524         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60180         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60358         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48044         VERBUNDEN
            tcp        0      0 localhost:60630         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60042         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47888         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60060         VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60092         VERBUNDEN
            tcp        0      0 localhost:9001          localhost:48046         VERBUNDEN
            tcp        0      0 localhost:60526         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60106         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60628         VERBUNDEN
            tcp        0      0 localhost:60090         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47642         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60128         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:48080         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60070         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60072         VERBUNDEN
            tcp        0      0 localhost:60540         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47986         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60600         VERBUNDEN
            tcp        0      0 localhost:48346         localhost:9001          VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-1:1883 Wemos5-Solar-Heiz:51895 VERBUNDEN
            tcp        0      0 localhost:48014         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9001          localhost:47814         VERBUNDEN
            tcp        0      0 localhost:60628         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47988         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:60766         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60104         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:60178         localhost:9000          VERBUNDEN
            tcp        0      0 localhost:47676         localhost:9001          VERBUNDEN
            tcp        0      0 localhost:9000          localhost:60354         VERBUNDEN
            tcp        0      0 Pi4-4GB-ioBroker-:37744 SMA3003923419.fritz:502 VERBUNDEN
            tcp6       0      0 Pi4-4GB-ioBroker-1:8082 Samsung-Tab-S-Wan:51042 VERBUNDEN
            Aktive Sockets in der UNIX-Domäne (ohne Server)
            Proto RefCnt Flags       Type       State         I-Node   Pfad
            unix  2      [ ]         DGRAM                    18043    /run/user/1000/systemd/notify
            unix  2      [ ]         DGRAM                    17707    /tmp/.vncserver-license/0.521
            unix  2      [ ]         DGRAM                    23684    /tmp/dhcpcd-pi/libdhcpcd-wpa-741.0
            unix  2      [ ]         DGRAM                    23685    /tmp/dhcpcd-pi/libdhcpcd-wpa-741.1
            unix  3      [ ]         DGRAM                    6853     /run/systemd/notify
            unix  2      [ ]         DGRAM                    6863     /run/systemd/journal/syslog
            unix  18     [ ]         DGRAM                    6869     /run/systemd/journal/dev-log
            unix  7      [ ]         DGRAM                    6875     /run/systemd/journal/socket
            unix  4      [ ]         DGRAM                    16991    /var/run/wpa_supplicant/wlan0
            unix  2      [ ]         DGRAM                    17218    /var/run/wpa_supplicant/p2p-dev-wlan0
            unix  3      [ ]         STREAM     VERBUNDEN     21893    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     23622    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     18358
            unix  3      [ ]         STREAM     VERBUNDEN     20797    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     23631
            unix  2      [ ]         DGRAM                    15561
            unix  3      [ ]         STREAM     VERBUNDEN     20817    /run/systemd/journal/stdout
            unix  3      [ ]         DGRAM                    15565
            unix  3      [ ]         STREAM     VERBUNDEN     15555
            unix  3      [ ]         STREAM     VERBUNDEN     23646
            unix  3      [ ]         STREAM     VERBUNDEN     18361
            unix  3      [ ]         STREAM     VERBUNDEN     20776
            unix  3      [ ]         STREAM     VERBUNDEN     23645
            unix  3      [ ]         STREAM     VERBUNDEN     20978    @/dbus-vfs-daemon/socket-mPTQyEWg
            unix  3      [ ]         STREAM     VERBUNDEN     22615    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     23548
            unix  3      [ ]         DGRAM                    15564
            unix  3      [ ]         STREAM     VERBUNDEN     23618
            unix  3      [ ]         STREAM     VERBUNDEN     21866    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     22589    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     23581
            unix  3      [ ]         STREAM     VERBUNDEN     22659    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     23574
            unix  3      [ ]         STREAM     VERBUNDEN     23621
            unix  3      [ ]         STREAM     VERBUNDEN     22668    /run/user/1000/bus
            unix  3      [ ]         DGRAM                    15566
            unix  3      [ ]         STREAM     VERBUNDEN     23619    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     23567
            unix  3      [ ]         STREAM     VERBUNDEN     14831    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     15729    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     18377
            unix  3      [ ]         STREAM     VERBUNDEN     22320
            unix  3      [ ]         STREAM     VERBUNDEN     23549
            unix  3      [ ]         STREAM     VERBUNDEN     22319
            unix  3      [ ]         STREAM     VERBUNDEN     21998    /var/run/dhcpcd.unpriv.sock
            unix  3      [ ]         STREAM     VERBUNDEN     21860    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     25070
            unix  3      [ ]         STREAM     VERBUNDEN     22631    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     23547
            unix  3      [ ]         STREAM     VERBUNDEN     23967
            unix  3      [ ]         STREAM     VERBUNDEN     20811    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     25068
            unix  3      [ ]         STREAM     VERBUNDEN     23966
            unix  3      [ ]         STREAM     VERBUNDEN     18381
            unix  3      [ ]         STREAM     VERBUNDEN     25071
            unix  3      [ ]         STREAM     VERBUNDEN     25069
            unix  3      [ ]         STREAM     VERBUNDEN     23546
            unix  3      [ ]         STREAM     VERBUNDEN     23647
            unix  3      [ ]         STREAM     VERBUNDEN     18378
            unix  3      [ ]         STREAM     VERBUNDEN     22712    /run/user/1000/bus
            unix  3      [ ]         DGRAM                    15563
            unix  3      [ ]         STREAM     VERBUNDEN     21935    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     22318
            unix  3      [ ]         STREAM     VERBUNDEN     23569
            unix  3      [ ]         STREAM     VERBUNDEN     23969
            unix  3      [ ]         STREAM     VERBUNDEN     22321
            unix  3      [ ]         STREAM     VERBUNDEN     22651    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     23968
            unix  3      [ ]         STREAM     VERBUNDEN     17174
            unix  3      [ ]         DGRAM                    18045
            unix  3      [ ]         STREAM     VERBUNDEN     22206
            unix  3      [ ]         STREAM     VERBUNDEN     17176
            unix  3      [ ]         STREAM     VERBUNDEN     22157
            unix  3      [ ]         STREAM     VERBUNDEN     22720
            unix  3      [ ]         STREAM     VERBUNDEN     17175    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     22943
            unix  3      [ ]         STREAM     VERBUNDEN     17177    /var/run/dbus/system_bus_socket
            unix  2      [ ]         DGRAM                    15884
            unix  3      [ ]         STREAM     VERBUNDEN     16555
            unix  3      [ ]         STREAM     VERBUNDEN     22713
            unix  3      [ ]         STREAM     VERBUNDEN     16728    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     25982
            unix  3      [ ]         STREAM     VERBUNDEN     16725    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     16550
            unix  3      [ ]         STREAM     VERBUNDEN     22262
            unix  3      [ ]         STREAM     VERBUNDEN     15840
            unix  3      [ ]         STREAM     VERBUNDEN     15728    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     22159
            unix  2      [ ]         DGRAM                    15822
            unix  3      [ ]         STREAM     VERBUNDEN     15579
            unix  3      [ ]         STREAM     VERBUNDEN     22567
            unix  3      [ ]         STREAM     VERBUNDEN     15817    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     16638
            unix  2      [ ]         DGRAM                    15731
            unix  3      [ ]         STREAM     VERBUNDEN     15727
            unix  3      [ ]         STREAM     VERBUNDEN     22721    /run/user/1000/menu-cached-:0
            unix  3      [ ]         STREAM     VERBUNDEN     22259
            unix  3      [ ]         STREAM     VERBUNDEN     22944
            unix  3      [ ]         STREAM     VERBUNDEN     20543    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     15816
            unix  3      [ ]         STREAM     VERBUNDEN     20976
            unix  3      [ ]         DGRAM                    6855
            unix  3      [ ]         STREAM     VERBUNDEN     25981
            unix  3      [ ]         STREAM     VERBUNDEN     17388
            unix  3      [ ]         STREAM     VERBUNDEN     22158
            unix  3      [ ]         DGRAM                    6854
            unix  3      [ ]         STREAM     VERBUNDEN     22160
            unix  3      [ ]         STREAM     VERBUNDEN     16752    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     22708    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     16122    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     22204
            unix  3      [ ]         STREAM     VERBUNDEN     16855
            unix  2      [ ]         DGRAM                    15932
            unix  3      [ ]         STREAM     VERBUNDEN     25983
            unix  3      [ ]         STREAM     VERBUNDEN     22714
            unix  3      [ ]         STREAM     VERBUNDEN     22942
            unix  3      [ ]         STREAM     VERBUNDEN     18277    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     22261
            unix  3      [ ]         STREAM     VERBUNDEN     22205
            unix  3      [ ]         STREAM     VERBUNDEN     17083
            unix  3      [ ]         STREAM     VERBUNDEN     16726    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     22203
            unix  3      [ ]         STREAM     VERBUNDEN     15935
            unix  3      [ ]         STREAM     VERBUNDEN     22260
            unix  3      [ ]         STREAM     VERBUNDEN     19775
            unix  3      [ ]         STREAM     VERBUNDEN     17084    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     20818
            unix  3      [ ]         STREAM     VERBUNDEN     18229    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     15879    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     21257
            unix  3      [ ]         STREAM     VERBUNDEN     20921    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     18227    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     19417
            unix  3      [ ]         STREAM     VERBUNDEN     21656
            unix  3      [ ]         STREAM     VERBUNDEN     17471
            unix  3      [ ]         STREAM     VERBUNDEN     23420
            unix  3      [ ]         STREAM     VERBUNDEN     21071
            unix  3      [ ]         STREAM     VERBUNDEN     24806
            unix  3      [ ]         DGRAM                    18044
            unix  2      [ ]         DGRAM                    13307
            unix  3      [ ]         STREAM     VERBUNDEN     15842    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     24105
            unix  3      [ ]         STREAM     VERBUNDEN     21070
            unix  2      [ ]         DGRAM                    65296
            unix  2      [ ]         DGRAM                    19426
            unix  3      [ ]         STREAM     VERBUNDEN     25771
            unix  3      [ ]         STREAM     VERBUNDEN     22570    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     23422
            unix  2      [ ]         DGRAM                    18009
            unix  3      [ ]         STREAM     VERBUNDEN     22111    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     21302
            unix  3      [ ]         STREAM     VERBUNDEN     22653
            unix  3      [ ]         STREAM     VERBUNDEN     22569
            unix  3      [ ]         STREAM     VERBUNDEN     24804
            unix  3      [ ]         STREAM     VERBUNDEN     20880    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     16718
            unix  3      [ ]         STREAM     VERBUNDEN     21301
            unix  3      [ ]         STREAM     VERBUNDEN     21649
            unix  3      [ ]         STREAM     VERBUNDEN     17785
            unix  3      [ ]         STREAM     VERBUNDEN     23421
            unix  3      [ ]         STREAM     VERBUNDEN     21256
            unix  3      [ ]         STREAM     VERBUNDEN     21303
            unix  3      [ ]         STREAM     VERBUNDEN     19684
            unix  3      [ ]         STREAM     VERBUNDEN     15883    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     23748    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     22945
            unix  3      [ ]         STREAM     VERBUNDEN     20841    @/tmp/.X11-unix/X0
            unix  2      [ ]         DGRAM                    19420
            unix  3      [ ]         STREAM     VERBUNDEN     17271    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     21300
            unix  3      [ ]         STREAM     VERBUNDEN     23681
            unix  3      [ ]         STREAM     VERBUNDEN     24803
            unix  3      [ ]         STREAM     VERBUNDEN     21903
            unix  3      [ ]         STREAM     VERBUNDEN     21254
            unix  3      [ ]         STREAM     VERBUNDEN     23637    /run/user/1000/pulse/native
            unix  3      [ ]         DGRAM                    11542
            unix  3      [ ]         STREAM     VERBUNDEN     25772
            unix  3      [ ]         STREAM     VERBUNDEN     19418    /var/run/dbus/system_bus_socket
            unix  2      [ ]         DGRAM                    18027
            unix  3      [ ]         STREAM     VERBUNDEN     20919
            unix  3      [ ]         STREAM     VERBUNDEN     24106
            unix  3      [ ]         STREAM     VERBUNDEN     22915
            unix  3      [ ]         STREAM     VERBUNDEN     21069
            unix  3      [ ]         STREAM     VERBUNDEN     22652
            unix  3      [ ]         STREAM     VERBUNDEN     25773
            unix  2      [ ]         DGRAM                    16747
            unix  2      [ ]         STREAM     VERBUNDEN     17721
            unix  3      [ ]         STREAM     VERBUNDEN     62254
            unix  3      [ ]         STREAM     VERBUNDEN     16121
            unix  2      [ ]         DGRAM                    17705
            unix  3      [ ]         STREAM     VERBUNDEN     15280    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     16723
            unix  3      [ ]         STREAM     VERBUNDEN     22853
            unix  3      [ ]         STREAM     VERBUNDEN     21072
            unix  3      [ ]         STREAM     VERBUNDEN     25984
            unix  3      [ ]         STREAM     VERBUNDEN     24805
            unix  3      [ ]         STREAM     VERBUNDEN     16724
            unix  2      [ ]         DGRAM                    11538
            unix  3      [ ]         STREAM     VERBUNDEN     20879
            unix  3      [ ]         STREAM     VERBUNDEN     20610    /run/user/1000/bus
            unix  2      [ ]         DGRAM                    16730
            unix  3      [ ]         DGRAM                    11541
            unix  3      [ ]         STREAM     VERBUNDEN     22654
            unix  3      [ ]         STREAM     VERBUNDEN     23419
            unix  2      [ ]         DGRAM                    21245
            unix  3      [ ]         STREAM     VERBUNDEN     25770
            unix  3      [ ]         STREAM     VERBUNDEN     20819
            unix  3      [ ]         STREAM     VERBUNDEN     22572
            unix  3      [ ]         STREAM     VERBUNDEN     62255
            unix  3      [ ]         STREAM     VERBUNDEN     22666
            unix  3      [ ]         STREAM     VERBUNDEN     21608
            unix  2      [ ]         DGRAM                    11388
            unix  3      [ ]         STREAM     VERBUNDEN     18174    /run/systemd/journal/stdout
            unix  2      [ ]         DGRAM                    7120
            unix  3      [ ]         STREAM     VERBUNDEN     24107
            unix  3      [ ]         STREAM     VERBUNDEN     22918
            unix  2      [ ]         STREAM     VERBUNDEN     21147
            unix  3      [ ]         STREAM     VERBUNDEN     17227    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     17691    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     21655
            unix  3      [ ]         STREAM     VERBUNDEN     16834
            unix  3      [ ]         STREAM     VERBUNDEN     24108
            unix  3      [ ]         STREAM     VERBUNDEN     21255
            unix  3      [ ]         STREAM     VERBUNDEN     20767    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     17690
            unix  3      [ ]         STREAM     VERBUNDEN     22917
            unix  2      [ ]         DGRAM                    22578
            unix  3      [ ]         STREAM     VERBUNDEN     22916
            unix  3      [ ]         STREAM     VERBUNDEN     21241
            unix  3      [ ]         STREAM     VERBUNDEN     20920    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     15087    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     15058
            unix  3      [ ]         STREAM     VERBUNDEN     12323    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     23052
            unix  3      [ ]         STREAM     VERBUNDEN     23938
            unix  3      [ ]         STREAM     VERBUNDEN     20570    /run/user/1000/bus
            unix  3      [ ]         DGRAM                    22619
            unix  3      [ ]         STREAM     VERBUNDEN     23923
            unix  3      [ ]         STREAM     VERBUNDEN     23051
            unix  2      [ ]         DGRAM                    20571
            unix  3      [ ]         STREAM     VERBUNDEN     23680
            unix  2      [ ]         DGRAM                    15054
            unix  3      [ ]         STREAM     VERBUNDEN     23337
            unix  3      [ ]         STREAM     VERBUNDEN     23924
            unix  3      [ ]         STREAM     VERBUNDEN     23936
            unix  3      [ ]         STREAM     VERBUNDEN     21997    /var/run/dhcpcd.unpriv.sock
            unix  3      [ ]         STREAM     VERBUNDEN     22639    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     18285
            unix  3      [ ]         STREAM     VERBUNDEN     20569
            unix  3      [ ]         STREAM     VERBUNDEN     10883
            unix  3      [ ]         STREAM     VERBUNDEN     20777    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     20798    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     22610
            unix  3      [ ]         STREAM     VERBUNDEN     20781    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     18207    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     23037
            unix  3      [ ]         STREAM     VERBUNDEN     21809
            unix  3      [ ]         STREAM     VERBUNDEN     15860    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     66685
            unix  3      [ ]         STREAM     VERBUNDEN     23746
            unix  3      [ ]         STREAM     VERBUNDEN     18286
            unix  3      [ ]         STREAM     VERBUNDEN     18279    @/tmp/.X11-unix/X0
            unix  2      [ ]         DGRAM                    18663
            unix  2      [ ]         DGRAM                    14952
            unix  3      [ ]         STREAM     VERBUNDEN     66683
            unix  3      [ ]         STREAM     VERBUNDEN     24923
            unix  3      [ ]         STREAM     VERBUNDEN     20774    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     20608
            unix  3      [ ]         STREAM     VERBUNDEN     15818    /run/systemd/journal/stdout
            unix  2      [ ]         DGRAM                    62899
            unix  3      [ ]         STREAM     VERBUNDEN     22109    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     23338
            unix  3      [ ]         STREAM     VERBUNDEN     21708
            unix  3      [ ]         STREAM     VERBUNDEN     19776
            unix  3      [ ]         STREAM     VERBUNDEN     18114    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     23335
            unix  3      [ ]         STREAM     VERBUNDEN     23922
            unix  3      [ ]         STREAM     VERBUNDEN     66684
            unix  3      [ ]         STREAM     VERBUNDEN     24921
            unix  3      [ ]         STREAM     VERBUNDEN     20011
            unix  3      [ ]         STREAM     VERBUNDEN     23336
            unix  3      [ ]         STREAM     VERBUNDEN     18116    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     16733    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     24924
            unix  3      [ ]         STREAM     VERBUNDEN     20960
            unix  3      [ ]         STREAM     VERBUNDEN     20568
            unix  3      [ ]         STREAM     VERBUNDEN     18950
            unix  3      [ ]         STREAM     VERBUNDEN     66682
            unix  3      [ ]         STREAM     VERBUNDEN     22725
            unix  3      [ ]         STREAM     VERBUNDEN     20760
            unix  3      [ ]         STREAM     VERBUNDEN     14958
            unix  3      [ ]         STREAM     VERBUNDEN     22665    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     20792    @/tmp/.X11-unix/X0
            unix  3      [ ]         STREAM     VERBUNDEN     18018    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     22726
            unix  3      [ ]         STREAM     VERBUNDEN     20541
            unix  3      [ ]         STREAM     VERBUNDEN     15042
            unix  2      [ ]         STREAM     VERBUNDEN     62876
            unix  3      [ ]         STREAM     VERBUNDEN     21882
            unix  3      [ ]         STREAM     VERBUNDEN     15270    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     23703
            unix  3      [ ]         STREAM     VERBUNDEN     22727
            unix  3      [ ]         STREAM     VERBUNDEN     20540
            unix  3      [ ]         STREAM     VERBUNDEN     15269
            unix  3      [ ]         STREAM     VERBUNDEN     22728
            unix  3      [ ]         STREAM     VERBUNDEN     23937
            unix  3      [ ]         DGRAM                    22618
            unix  3      [ ]         STREAM     VERBUNDEN     23935
            unix  3      [ ]         STREAM     VERBUNDEN     14954
            unix  3      [ ]         STREAM     VERBUNDEN     18216    /run/systemd/journal/stdout
            unix  3      [ ]         STREAM     VERBUNDEN     19407
            unix  3      [ ]         STREAM     VERBUNDEN     22638
            unix  3      [ ]         STREAM     VERBUNDEN     23034
            unix  3      [ ]         STREAM     VERBUNDEN     24922
            unix  3      [ ]         STREAM     VERBUNDEN     16306    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     16727    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     23701
            unix  3      [ ]         STREAM     VERBUNDEN     23035
            unix  3      [ ]         STREAM     VERBUNDEN     14944
            unix  3      [ ]         STREAM     VERBUNDEN     22672    /run/user/1000/bus
            unix  3      [ ]         STREAM     VERBUNDEN     15306
            unix  3      [ ]         STREAM     VERBUNDEN     14953
            unix  3      [ ]         STREAM     VERBUNDEN     66686
            unix  3      [ ]         STREAM     VERBUNDEN     23036
            unix  2      [ ]         DGRAM                    18956
            unix  3      [ ]         STREAM     VERBUNDEN     21889
            unix  3      [ ]         STREAM     VERBUNDEN     17282    /var/run/dbus/system_bus_socket
            unix  3      [ ]         STREAM     VERBUNDEN     18047
            unix  3      [ ]         STREAM     VERBUNDEN     23050
            unix  3      [ ]         STREAM     VERBUNDEN     23702
            unix  2      [ ]         STREAM     VERBUNDEN     15305
            unix  3      [ ]         STREAM     VERBUNDEN     66681
            unix  3      [ ]         STREAM     VERBUNDEN     23921
            unix  3      [ ]         STREAM     VERBUNDEN     23704
            unix  3      [ ]         STREAM     VERBUNDEN     23049
            pi@raspberrypi:~ $
            • hg6806H hg6806
              sudo netstat tulpen
              pi@raspberrypi:~ $
              #91
              @hg6806
              Der mosquitto kollidiert mit dem Wemos-Kram.
              Da läuft schon irgendwas auf dem port.
              Und Server laufen ohne Desktop. Schalt den aus!
              hg6806H 2 Antworten Letzte Antwort
                @hg6806
                hg6806H Offline
                hg6806H Offline
                hg6806
                #92
                Habe in ioBroker MQTT Adapter installiert und einige Wemos angeschlossen
                D.h. weitere MQTT Adapter Instanz und neuen Port?
                  @hg6806
                  hg6806H Offline
                  hg6806H Offline
                  hg6806
                  #93
                  Was meinst du damit?
                  • hg6806H hg6806
                    #94
                    @hg6806 Damit meine ich den Zugriff via VNC auf den Desktop, der da zusehen ist. Das macht man nicht! Per SSH auf einen headless Server gehen.
                    • hg6806H hg6806
                      #95
                      @hg6806 mqttd und mosquitto können in der Grundeinstellung nicht auf dem gleichen System laufen. Entweder zwischen einem der beiden entscheiden oder den Port ändern.
                        hg6806H Offline
                        hg6806H Offline
                        hg6806
                        #96
                        OK, wenn ich jetzt unter mosquitto Port 1884 nehme, kann doch MQTT Adapter mit 1883 bleiben?
                        Wie sehe ich dann die Daten in ioBroker?
                          hg6806H Offline
                          hg6806H Offline
                          hg6806
                          #97
                          So, habe mal in ioBroker einen weitere MQTT Instanz installiert als Client mit Port 1884. bei der ersten Instanz also Broker hat er den Port 1883.
                          In /etc/wmbusmeters.conf steht die Zeile
                          shell=/usr/bin/mosquitto_pub -h 192.168.178.18 -p 1884 -u -t wmbusmeters/212009$
                          Geht aber auch nicht, die 2. MQTT Instanz bleibt gelb weil ihm der Broker fehlt.
                          Mir macht noch der Fehler bei der Mosquitto Installation Kopfzerbrechen wie oben gepostet.
                          • hg6806H hg6806
                            #98
                            @hg6806 Hi,
                            du hast -u in deinem Commando aber keinen Username angegeben. Lass das mal weg oder gib die richtigen Parameter an, wie weiter unten beschrieben :-)
                            Steht auch mit Sicherheit im logfile, was dem mqtt nicht gefällt..
                              @hg6806 Hi,
                              hg6806H Offline
                              hg6806H Offline
                              hg6806
                              #99
                              @ilovegym
                              Danke, habe die Zeile nun wie folgt drin:
                              shell=/usr/bin/mosquitto_pub -h 192.168.178.18 -p 1884 -t wmbusmeters/21200936/$
                              MQTT Client Instanz bleibt noch immer gelb.
                              Hier im Log.
                              mqtt.1	2021-03-29 11:12:07.834	info	(1432) Try to connect to mqtt://localhost:1884?clientId=iobroker.mqtt.1
                              mqtt.1	2021-03-29 11:12:07.315	info	(1432) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.21.0, js-controller: 3.2.16
                              Das Log von mosquitto kann ich nicht lesen/runterladen wegen Rechten
                              funktioniert irgendwie nicht
                              • hg6806H hg6806
                                @ilovegym
                                Hier im Log.
                                #100
                                sudo chmod 777 /var/log/mosquitto sudo chmod g+s /var/log/mosquitto
                                Das soll ja auch gar nicht so grobschlächtig funktionieren.
                                Schau dir an, wem das log file gehört und häng den user dann in die Gruppe rein.
                                  hg6806H Offline
                                  hg6806H Offline
                                  hg6806
                                  schrieb am zuletzt editiert von hg6806
                                  #101
                                  Geht wahrscheinlich mit sudo usermod -aG
                                  Aber in welche Gruppe? Ich bin ja user "pi"
                                  Früher war alles mit root einfacher...
                                  ? Thomas BraunT 3 Antworten Letzte Antwort
                                  • hg6806H hg6806
                                    #102
                                    @hg6806 einfach mal ein
                                    cat mosqitto.log
                                    .. was passiert dann?
                                    • hg6806H hg6806
                                      #103
                                      @hg6806
                                      nebenbei, hier mal was zum nachlesen:
                                      https://debian-handbook.info/download/stable/debian-handbook.pdf
                                        @hg6806
                                        hg6806H Offline
                                        hg6806H Offline
                                        hg6806
                                        #104
                                        @ilovegym
                                        Ja, wenn wäre mal was :-)
                                        Mosquitto scheint noch immer aus Port 1883 übertragen zu wollen. (Default)
                                        Habe jetzt in die mosquitto.conf "listener 1884" hinzugefügt und mosquitto neu gestartet.
                                        Über Status sieht es gut aus.
                                        Jedoch blinkt es im ioBroker MQTT Adapter zwischen gelb und grün.
                                        ? M 2 Antworten Letzte Antwort
                                        • hg6806H hg6806
                                          #105
                                          Dann muss der pi in die Gruppe mosquitto rein:
                                          sudo usermod -aG mosquitto pi
                                          Wobei da dann immer noch Gruppenrechte fehlen.
                                          Muss man mal schauen, wie man die sauber beim Schreiben vom log setzt. Ich nutze aber ja kein mosquitto, deswegen kann ich dir das so nicht sagen.
