  4. IoBroker defekt nach Stromausfall.
    2.0k
7 Beiträge 3 Kommentatoren 994 Aufrufe 2 Beobachtet
  • mfuhrM Offline
    mfuhrM Offline
    mfuhr
    Hallo Community.
    Mein IoBroker Webinterface ist nicht mehr erreichbar nach einem Stromausfall könnt Ihr mir weiterhelfen?
    Meine Konfiguration:
    IoBroker Installation in einem Lxc Container auf Proxmox.
    IpAdresse anpingbar.
    node -v gibt V12.21.0 zurück
    nodejs -v gibt V12.21.0 zurück
    npm -v gibt 6.14.11 zurück
    Ausgabe des IoBroker Status Befehls:
    root@IoBrokerProd:/opt/iobroker# iobroker status
    Cannot read system.config: null (OK when migrating or restoring)
    Cannot find view "system" for search "host"
    iobroker is running on this host
    Objects type: file
    States type: file
    Bei tail /opt/iobroker/log/iobroker.current.log
    root@IoBrokerProd:/opt/iobroker/log# tail iobroker.current.log
    2021-03-23 12:57:42.619  - info: host.IoBrokerProd connected to Objects and States
    2021-03-23 12:57:42.813  - info: host.IoBrokerProd added notifications configuration of host
    2021-03-23 12:57:42.821  - error: host.IoBrokerProd Cannot find view "system" for search "instance"
    2021-03-23 12:57:42.821  - error: host.IoBrokerPro```
    d Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-03-23 12:57:42.867  - info: host.IoBrokerProd Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-03-23 12:57:42.869  - error: host.IoBrokerProd Cannot find view "system" for search "host"
    2021-03-23 12:57:42.893  - error: host.IoBrokerProd Cannot find view "system" for search "state"
    2021-03-23 12:57:42.893  - error: host.IoBrokerProd Cannot find view "system" for search "instance"
    2021-03-23 12:57:42.893  - error: host.IoBrokerProd Could not collect system.host.IoBrokerProd states to check for obsolete states: Error: Cannot find view "system"
    2021-03-23 12:57:42.893  - error: host.IoBrokerProd _design/system missing - call node iobroker.js setup
    MOD-Edit: Code in code-tags gesetzt!
    Kann mir da jemand weiterhelfen? Ich möchte ungern alles neu bauen, vor allem ist meine Sicherung schon etwas älter.
    Mario
    • mfuhrM mfuhr
      Hallo Community.
      Objects type: file
      States type: file
      Mario
      @mfuhr sagte in IoBroker defekt nach Stromausfall.:
      dann ist wohl die Obects.db hin:
      https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616505579254
      mfuhrM 2 Antworten Letzte Antwort
        mfuhrM Offline
        mfuhrM Offline
        mfuhr
        Danke vorab für deine Hilfe, ich werde mich mal durch hangeln und schauen ob die angegebene Lösung für mich funktioniert.
          mfuhrM Offline
          mfuhrM Offline
          mfuhr
          Hallo, hat alles funktioniert, der IoBroker läuft wieder.
          Ich hätte zu der Hilfe noch einen Nachtrag.
          Nach dem zurück spielen der Objekte und Stats gehörten die Dateien dem Benutzer Root der Start des IoBroker Dienstes funktionierte dann nicht, ich habe nach dem zurückspielen der Konfigurationsdatei noch folgendes gemacht.
          chown iobroker:iobroker states.json
          chown iobroker:iobroker objects.json
          anschließend habe ich noch ...
          chmod 777 states.json
          chmod 777 objetcs.json
          Ausgeführt.
          Mit Linux Rechten kenne ich mich nicht besonders aus, vielleicht war 777 etwas too much, läuft aber damit.
          • mfuhrM mfuhr
            Ausgeführt.
            @mfuhr
            Dann schmeiß den
            iobroker fix
            noch hinterher.
            Und meld dich nicht als root an! (Außer das System gibt keine gescheite user her (docker auf synology)).
            Dann hast du auch nicht so'n Hantier mit den Rechten.
            mfuhrM 1 Antwort Letzte Antwort
            • mfuhrM mfuhr
              Ausgeführt.
              diese Hilfe ist bereits "hundertmal" getestet worden.
              Wenn du damit Probleme hattest, ist entweder bei deiner Installtion etwas krumm, oder du hast es nicht richtig durchgeführt.
              Möglich, weil ....
              root@IoBrokerProd:
              du als Root unterwegs bist, was du icht solltest
                @mfuhr
                Dann schmeiß den
                iobroker fix
                noch hinterher.
                mfuhrM Offline
                mfuhrM Offline
                mfuhr
                Danke, habe ich ausgeführt scheint alles zu funktionieren.
