  4. ZZH! Stick läuft nicht mit dem Zigbee Adapter
    6.6k
27 Beiträge 4 Kommentatoren 5.1k Aufrufe 5 Beobachtet
  • N Neko
    @arteck Ich habe gerade noch folgendes Probiert, den 1.4.4 Adapter deinstalliert und den 1.1.1 installiert. Tradfri ist noch aus, trotzdem bekomme ich noch folgenden Meldungen:
    zigbee.0	2021-03-19 11:49:26.335	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0	2021-03-19 11:49:26.335	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2021-03-19 11:49:26.335	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
    zigbee.0	2021-03-19 11:49:26.335	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
    zigbee.0	2021-03-19 11:49:26.335	error	at new Promise (<anonymous>)
    zigbee.0	2021-03-19 11:49:26.335	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
    zigbee.0	2021-03-19 11:49:26.335	error	at Generator.next (<anonymous>)
    zigbee.0	2021-03-19 11:49:26.335	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
    zigbee.0	2021-03-19 11:49:26.335	error	(5545) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    zigbee.0	2021-03-19 11:49:26.333	error	(5545) Failed to start Zigbee
    zigbee.0	2021-03-19 11:49:26.081	info	(5545) Starting Zigbee...
    zigbee.0	2021-03-19 11:49:26.081	info	(5545) Try to reconnect. 1 attempts left
    zigbee.0	2021-03-19 11:49:16.079	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:6:65)
    zigbee.0	2021-03-19 11:49:16.079	error	at Generator.throw (<anonymous>)
    zigbee.0	2021-03-19 11:49:16.079	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:158:23
    zigbee.0	2021-03-19 11:49:16.079	error	(5545) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
    zigbee.0	2021-03-19 11:49:16.078	error	(5545) Failed to start Zigbee
    zigbee.0	2021-03-19 11:48:10.693	info	(5545) Starting Zigbee...
    zigbee.0	2021-03-19 11:48:10.653	info	(5545) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
    host.raspberrypi	2021-03-19 11:48:08.966	info	instance system.adapter.zigbee.0 started with pid 5545
    Kann es sein, dass dort vielleicht noch etwas mit Stick auf Betriebssystem Ebene nicht stimmt? Das der Serial Port nicht richtig konfiguriert ist oder sowas?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @neko sagte in ZZH! Stick läuft nicht mit dem Zigbee Adapter:
    Nein kann es nicht.
    Diese Meldung
    besagt eindeutig das es eine Kommunikation zwischen dem Koordinator und dem Adapter gegeben hat. Damit ist die serielle Schnittstelle aussen vor.
    Das blockieren der Schnittstelle ist darauf zurück zu führen das die Bibliothek die Schnittstelle nicht so schnell wieder frei gibt wie der Adapter versucht das ganze neu zu initialisieren.
    A.
    N 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      Nein kann es nicht.
      Diese Meldung
      A.
      N Offline
      N Offline
      Neko
      @asgothian
      Ok, und was kann man da machen?
      Viele Grüße,
      Neko
      • N Neko
        @asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @neko Ich würde an dieser Stelle die Vermutung äussern das der Stick nicht ok ist. Immerhin verweigert er systematisch den Aufbau eines Zigbee Netzes.
        A.
        N 2 Antworten Letzte Antwort
          A.
          N Offline
          N Offline
          Neko
          @asgothian Ja, ich fürchte es fast auch...
          Von Electrolama gibt es ein Skript um zu testen, ob der Stick richtig geflasht ist: https://gist.github.com/omerk/0ee0e447a9e36786b4ff71d8f8126a23
          Allerdings bekomme ich dieses nicht ans laufen. Ich bekomme immer die Meldung "ModuleNotFoundError: No module named 'serial'". Ich habe dann auch schon pyserial installiert, aber das änderte auch nichts. Irgendwie stoße ich da an meine Grenzen. 😞
          Viele Grüße,
          Neko
            A.
            N Offline
            N Offline
            Neko
            @asgothian Also, der Stick ist in Ordnung. Damit ich mir nicht meinen ganzen Raspberry zumülle, habe ich auf dem Windows Rechner Zigbee2MQTT installiert und in iobroker einen MQTT Server aufgesetzt. Mit diesem Setup konnte ich Sensoren pairen und Werte abgreifen.
            Mit anderen Worten, der Stick funktioniert, es muss ein Problem mit dem Raspberry oder iobroker sein.
            Viele Grüße,
            Neko
            • N Offline
              N Offline
              Neko
              Das soll jetzt mal jemand verstehen, ich steck den Stick wieder in den Pi, starte den Adapter, Adapter wird grün und er läuft.
              Ich hab keine Ahnung was sich geändert hat...
              Viele Grüße,
              Neko
              • N Neko
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @neko Prüf bitte welche version von zigbee-herdsman und zigbee-herdsman-converters auf den beiden Systemen installiert sind.
                A.
                  A.
                  N Offline
                  N Offline
                  Neko
                  @asgothian Wo finde ich die denn und welche beiden Systeme?
                  Viele Grüße,
                  Neko
                  • N Neko
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @neko Windows / zigbee2mqtt, Linux / iobroker sind die beiden Systeme.
                    wo der bei zigbee2mqtt ist weiss ich nicht. im ioBroker findest du die beiden in einem der Unterverzeichnisse von /opt/iobroker/node_modules.
                    Interessant sind jeweils die Dateien package.json in den jeweiligen Verzeichnissen (zigbee-herdsman/zigbee-herdsman-converters) um die Versionen heraus zu bekommen.
                    A.
                      A.
                      N Offline
                      N Offline
                      Neko
                      @asgothian Also wirklich weiter bin ich da nicht gekommen. Ich habe zwar die Dateien gefunden, aber ich weiß nicht wo ich die Version finde.
                      Vielleicht soviel, ich habe im ioBroker die installation direkt von Github mit der Version 1.4.5 und und hier die Zigbee2MQTT habe ich diese Datei verwendet: https://github.com/Koenkk/zigbee2mqtt/archive/refs/heads/master.zip
                      Ist das reines Interesse mit der Version oder warum fragst du?
                      Viele Grüße,
                      Neko
                      • N Neko
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @neko es geht um die Frage in wie weit eine Anpassung der Bibliotheken verantwortlich für die Probleme ist, sowohl zigbee2mqtt als auch der iobroker Adapter nutzen die gleichen Bibliotheken- damit sollte der Stick also in beiden Fällen laufen.
                        Wenn du die Dateien gefunden hast solltest du nach der in der Datei Package.JSON hinterlegten versions Nummer schauen. Wenn bei zigbee2mqtt neuere Versionen hinterlegt sind bitte den zigbee Adapter erneut von GitHub installieren.
                        A.
                          A.
                          N Offline
                          N Offline
                          Neko
                          @asgothian OK, mir war gar nicht klar, dass die Nummer in der json drinnen steht.
                          zigbee-herdsman iobroker: 0.13.81
                          zigbee-herdsman Zigbee2MQTT: 0.13.71
                          zigbee-herdsman-converters iobroker: 14.0.74-0
                          zigbee-herdsman-converters Zigbee2MQTT: 14.0.89
                          Ich habe den Zigbee Adapter gestern Nachmittag von GitHub neu installiert, das ist die neueste Version.
                          Viele Grüße,
                          Neko
