  4. Fehler beim Dapter installien Screenshot with PhantomJS
    4.1k
  • Weihnachtsangebot 2025! 🎄
    2.6k
13 Beiträge 4 Kommentatoren 1.6k Aufrufe
  • R Offline
    Raspi
    Moin Leute wollte diesen Adapter installieren,
    dabei bekomme ich diese Meldung, kann mir einer sagen was das soll?
    $ ./iobroker add phantomjs
    npm install iobroker.phantomjs –production --prefix "/opt/iobroker" (System call)
    npm
    WARN deprecated
    node-uuid@1.4.7: use uuid module instead
    Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architecture
    Try to install PhantomJS globally
    npm
    ERR! Linux 4.4.34-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.phantomjs" "--production" "--prefix" "/opt/iobroker"npm
    ERR! node
    v4.6.2npm ERR! npm v2.15.11
    npm ERR! code ELIFECYCLE
    npm ERR! phantomjs-prebuilt@2.1.13 install: node install.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the phantomjs-prebuilt@2.1.13 install script 'node install.js'.
    npm ERR! This is most likely a problem with the phantomjs-prebuilt package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node install.js
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs phantomjs-prebuilt
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls phantomjs-prebuilt
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! /npm-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.phantomjs: 1
    Benutze einen raspberry pi 2 mit Jessy
    • apollon77A Offline
      hast du ein Binary namens "node"? Probier mal auf Kommandozeile?
      Wenn nicht versuch mal
      sudo apt-get install nodejs-legacy
      dann nochmal versuchen
      • R Offline
        Raspi
        Habe versucht bekomme dabei die folgende Meldung
        root@raspberrypi:~# sudo apt-get install nodejs-legacy
        Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
        Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
        Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
        nicht erstellt wurden oder Incoming noch nicht verlassen haben.
        Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
        Die folgenden Pakete haben unerfüllte Abhängigkeiten:
        nodejs-legacy : Hängt ab von: nodejs (>= 0.6.19~dfsg1-3~) soll aber nicht installiert werden
        E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
        root@raspberrypi:~#
        ein versuch den adapter zu installieren ergab die selber Meldung wie oben
          Hast du ein Executable namens "node" ?! Ansonsten leg mal nennSymbolischen Link auf "nodejs" an
          • R Offline
            Raspi
            damit kann ich leider nicht viel anfagen, kannst du mir das bitte genauer erklären.
              wenn du an der Kommandozeile "node -v" eingibst was kommt?
              • a200A Offline
                a200A Offline
                a200
                Ich dachte immer PhantomJS würde schon aus Performance-Gründen nicht auf dem raspi laufen?!
                IoBroker auf QNAP TS-451, Raspi und NUC
                • R Offline
                  Raspi
                  das kommt daraus
                  root@raspberrypi:~# node -v
                  v4.6.2
                  root@raspberrypi:~#
                    hm … dann weiss ich nicht was es sen kann. Dachte das node Binary wäre nicht da ... sorry für die Verwirrung
                    Wer lesen kann ...
                    • BluefoxB Offline
                      BluefoxB Offline
                      @Raspi:
                      das kommt daraus
                      v4.6.2
                      root@raspberrypi:~# `
                      Fergus es. PhantomJS kann nicht auf dem raspi laufen.
                      • R Offline
                        Raspi
                        OK, das ist aber schade…
                        Aus welchen gründe geht das nicht ganz kurz und knap?
                        kann mir vielleicht einer weiter helfen in meinem Vorhaben:
                        Jemand Klingelt > IPCam macht snapshot > versand per mail
                        bis jetzt hab ich dies alles in iobroker node red realiesiert, das wenn jemand klingelt ich schon mal per Twitter / Mail Meldung bekommen.
                        ich möchte das nur noch per Bild dazu bekommen, wer auch geklingelt hat.
                        Ip Cam ist eine kleine Wlan Cam von ebay DIY Z6O6
                        Hat jemand eine Idee
                        • a200A Offline
                          a200A Offline
                          a200
                          @Raspi:
                          Jemand Klingelt > IPCam macht snapshot > versand per mail `
                          dafür brauchst du kein PhantomJS. PhantomJS ist in der Lage ganze Seiten zu rendern und als Bild ausgeben. Was du brauchst ist ein lokales Abspeichern des Bildes und dann Versand als Attachment. Ich kann dir da leider nicht weiter helfen, aber du solltest deine Vorgehensweise überdenken.
                          Schritt 1 wäre: Kannst du ein Bild von deiner Cam lokal speichern?
                          LG,
                          a200
                          • R Offline
                            Raspi
                            ich verweis mal das thema auf hier, hier habe ich detailiert beschrieben
                            http://forum.iobroker.net/viewtopic.php?p=42448#p42448
                            32.7k
                            82.4k
