  4. [Gelöst] Hilfe: ioBroker startet nicht mehr
    6.6k
errorsfehlerhilfe
16 Beiträge 3 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • mrFenyxM mrFenyx
    @Thomas-Braun js-controller wurde neu installiert. Jetzt kommen diese werte raus:
    pi@home:/opt/iobroker $ iobroker status
    Objects type: file
    States  type: file
    pi@home:/opt/iobroker $ iobroker list instances
    + instance is alive
    Trotzdem geht da nichts...
    iobroker setup liefert das hier:
    object 0_userdata.0.example_state yet exists
    object 0_userdata.0 yet exists
    object alias.0 yet exists
    object system.certificates yet exists
    object system.repositories yet exists
    object system.config yet exists
    object enum.functions yet exists
    object enum.rooms yet exists
    object system.group.user yet exists
    object system.group.administrator yet exists
    object _design/system updated
    iobroker fix das hier:
    iobroker fix
    Execute the installation fixer script, this updates your ioBroker installation
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    @mrfenyx
    iobroker list adapters
    • wendy2702W Online
      wendy2702W Online
      @mrfenyx
      curl -sL https://iobroker.net/fix.sh | bash -
      • mrFenyxM Offline
        mrFenyxM Offline
        mrFenyx
        @Thomas-Braun
        + instance is alive
        pi@home:/opt/iobroker $ iobroker list adapters
        Da fehlt was....
        @wendy2702 danke für den Tipp, ist durchgelaufen, bringt leider nichts :(
        • mrFenyxM mrFenyx
          @Thomas-Braun
          + instance is alive
          Da fehlt was....
          @mrfenyx
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          iobroker install admin
          • mrFenyxM Offline
            mrFenyxM Offline
            mrFenyx
            @Thomas-Braun
            pi@home:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.20.1
            /usr/bin/node
            v12.20.1
            /usr/bin/npm
            6.14.10
            nodejs:
              Installed: 12.20.1-1nodesource1
              Candidate: 12.20.1-1nodesource1
              Version table:
             *** 12.20.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 10.23.1~dfsg-1~deb10u1 500
            Ok, jetzt habe ich admin & info aber alles andere ist...weg... :(
            • mrFenyxM mrFenyx
              @Thomas-Braun
              /usr/bin/nodejs
              v12.20.1
              /usr/bin/node
              v12.20.1
              /usr/bin/npm
              6.14.10
              nodejs:
                Version table:
              @mrfenyx
              Jetzt zückst du dein Backup und spielst das für so einen Fall angelegte Backup wieder ein.
              • mrFenyxM Offline
                mrFenyxM Offline
                mrFenyx
                na dann...warten wir es mal ab...restore in progress :D
                • mrFenyxM Offline
                  mrFenyxM Offline
                  mrFenyx
                  @Thomas-Braun @wendy2702 danke für eure Hilfe! Hoffe es klappt jetzt alles. Gute Nacht!
                  • mrFenyxM mrFenyx
                    wendy2702W Online
                    wendy2702W Online
                    @mrfenyx Bitte kurzes Feedback!
                    Gute Nacht
                    • mrFenyxM Offline
                      mrFenyxM Offline
                      mrFenyx
                      Alles im grünen Bereich!👍
