  4. JSON zu Objekte
    5.6k
JSON zu Objekte
26 Beiträge 3 Kommentatoren 2.8k Aufrufe 2 Beobachtet
  • E ente34
    @kellerassel75
    Na ja, hast Du verpasste Anrufe heute?
    Sonst Zeile 18:
    if (1 || el_date === date)
    Kellerassel75
    schrieb am zuletzt editiert von Kellerassel75
    16:17:09.144 error javascript.0 (12519) script.js.test compile failed: at script.js.test:45
    Sorry mein Fehler { vergessen!
    Nun schreibt er mir die ganze Tabelle nach javascript.0.telefon.missed_today.json!
    Im Log steht:
    javascript.0	2021-01-31 16:17:09.150	error	(12519) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2021-01-31 16:17:09.150	error	(12519) at runMicrotasks (<anonymous>)
    javascript.0	2021-01-31 16:17:09.150	error	(12519) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2021-01-31 16:17:09.149	error	(12519) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2021-01-31 16:17:09.149	error	(12519) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
    javascript.0	2021-01-31 16:17:09.149	error	(12519) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
    javascript.0	2021-01-31 16:17:09.149	error	(12519) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
    javascript.0	2021-01-31 16:17:09.146	error	(12519) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
    javascript.0	2021-01-31 16:17:09.146	error	(12519) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
    javascript.0	2021-01-31 16:17:09.146	error	(12519) at Object.createScript (vm.js:261:10)
    javascript.0	2021-01-31 16:17:09.146	error	(12519) at new Script (vm.js:88:7)
    javascript.0	2021-01-31 16:17:09.145	error	(12519) SyntaxError: Missing catch or finally after try
    javascript.0	2021-01-31 16:17:09.145	error	(12519) ^
    javascript.0	2021-01-31 16:17:09.145	error	(12519) }
    javascript.0	2021-01-31 16:17:09.144	error	at script.js.test:45
    javascript.0	2021-01-31 16:17:09.144	error	(12519) script.js.test compile failed:
    E 1 Antwort Letzte Antwort
    • K Kellerassel75
      Im Log steht:
      ente34
      @kellerassel75
      Schon klar, mein Script filtert ja die verpassten Anrufe heute aus. Mit der "1||" bekommst Du wieder alle, um zu kontrollieren, ob alles soweit funktioniert.
      Alternativ kannst Du Dich auch selbst anrufen (nicht abheben!).
      • E ente34
        @kellerassel75
        Kellerassel75
        @ente34
        Gut! Er schreibt nun die Anrufe von heute! Das funktioniert!
        Aber ich wollte richtige Datenpunte - Zahlen nicht JSON!
        Also:
        Datenpunt letzter - caller
        Datenpunt letzter - date
        Datenpunt letzter - name
        Datenpunt vorletzter- caller
        Datenpunt vorletzter- date
        Datenpunt vorletzter- name
        Falko
        E paul53P 2 Antworten Letzte Antwort
        • K Kellerassel75
          @ente34
          Also:
          Falko
          ente34
          @kellerassel75
          wie bereits oben gesagt, in Zeile 19 hast Du das obj in der Hand ...
          • K Kellerassel75
            @ente34
            Also:
            Falko
            @kellerassel75 sagte: richtige Datenpunte - Zahlen nicht JSON!
            Du meinst Zeichenketten?
            @kellerassel75 sagte in JSON zu Objekte:
            Wieweit sollen sie zurück reichen?
              Kellerassel75
              Ich denke 4 Anrufe sollte reichen!
              • K Kellerassel75
                Hallo.
                Ich bin Falko und habe schon eine Menge Zeit hier verbracht.
                Ich bin vor einem Jahr von FHEM zu ioBroker gewechselt. Die Umstellung hat eine Weile gedauert.
                Mit Blockly komme ich schon ganz gut zurecht. Java ist schwer für mich.
                Ich versuche aus einer JSON Tabelle Werte in Objekte zu schreiben.
                Einige Beispiele aus diesem Forum konnte ich ganz gut nachstellen bei mir.
                Aber mit meiner Tabelle funktioniert das alles nicht.
                Hier mal meine JSON:
                [{"id":4097,"type":"2","caller":"****","called":"SIP: ****","callednumber":"****","name":"","numbertype":"sip","device":"","port":"-1","date":"23.01.21 23:01","duration":"0:00","count":"","path":"","sym":"x","external":"*****"},{"id":4096,"type":"2","caller":"******","called":"SIP: ****","callednumber":"*******","name":"","numbertype":"sip","device":"","port":"-1","date":"23.01.21 22:21","duration":"0:00","count":"","path":"","sym":"x","external":"******"},{"id":4083,"type":"2","caller":"*****","called":"SIP: *****","callednumber":"****","name":"","numbertype":"sip","device":"","port":"-1","date":"21.01.21 11:38","duration":"0:00","count":"","path":"","sym":"x","external":"******"}]
                Das ist die JSON von tr-064. Dort möchte ich gerne die caller, date und name in Objekte schreiben.
                Solange nur ein Anruf ist:
                Bekomme ich das hin. Sobald die"[ ]"dazu kommt und noch weitere Anrufe geht nichts.
                Beispiel:
                //Script zur Zerlegung der JSON Daten in einzelne Datenpunkte
                //Idee: Chaot
                // Umsetzung: paul53
                 var json = "tr-064.0.calllists.missed.json";
                var Nummer = "javascript.0.Nummer";
                var Datum = "javascript.0.Datum";
                var Name = "javascript.0.Name";
                on(json, function(dp) {
                   var obj = JSON.parse(dp.state.val);
                   setState(Nummer, parseFloat(obj.caller));
                   setState(Datum, parseFloat(obj.date));
                   setState(Name, parseFloat(obj.name));
                Wer kann helfen dass meine Objekte (jeder Anruf einzeln) erstellt werden.
                Vielen Dank!
                Falko
                @kellerassel75 sagte: Solange nur ein Anruf ist:
                Ist es wirklich so, dass es dann nur ein Objekt ohne Array-Klammern ist ?
                  Kellerassel75
                  Nein das habe ich so geändert!
                  • K Kellerassel75
                    ente34
                    @kellerassel75
                    Kannst Du es dann selber erweitern?
                    //Idee: Chaot
                    const MaxAnrufe = 4;
                       const i_end = obj.length < MaxAnrufe ? obj.length : MaxAnrufe;
                       for (let i=0; i<i_end; i++) {
                           const o = obj[i];
                           console.warn(o);
                           const dp_nummer = Nummer+"_"+i;
                           console.warn(dp_nummer);
                           setState(dp_nummer,o.caller);
                    //    setState(Nummer, parseFloat(obj.caller));
                    //    setState(Datum, parseFloat(obj.date));
                    //    setState(Name, parseFloat(obj.name));
                    for (let i=0; i<MaxAnrufe; i++) {
                        createState(dp_nummer);
                    • E ente34
                      @kellerassel75
                      //Idee: Chaot
                             const o = obj[i];
                             console.warn(o);
                      Kellerassel75
                      @ente34
                      Danke! Ich werde es Versuchen!
                      • K Kellerassel75
                        @kellerassel75 sagte: 4 Anrufe sollte reichen!
                        Vorschlag (nicht getestet):
                        const idJson = "tr-064.0.calllists.missed.json";
                        const path = "0_userdata.0.Telefon.verpasst-";
                        if(!existsState(path + '0.Nummer')) {
                            for(let i = 0; i < 4; i++) {
                                createState(path + i + '.Nummer', '', {type: 'string', name: 'Nummer', role: 'info'});
                                createState(path + i + '.Datum', '', {type: 'string', name: 'Datum, Uhrzeit', role: 'info'});
                                createState(path + i + '.Name', '', {type: 'string', name: 'Name', role: 'info'});
                        on(idJson, function(dp) {
                            let arr = JSON.parse(dp.state.val);
                            let anzahl = arr.length;
                            if(anzahl > 4) anzahl = 4;
                            for(let i = 0; i < anzahl; i++) {
                                setState(path + i + '.Nummer', arr[i].caller, true);
                                setState(path + i + '.Datum', arr[i].date, true);
                                setState(path + i + '.Name', arr[i].name, true);
                        E K 2 Antworten Letzte Antwort
                          ente34
                          Mir gefällt es ...
                            Kellerassel75
                            Danke passt!
                            Echt Super! Ich bin begeistert! Danke an alle!
                            Ich hätte nicht gedacht das ich so schnell Hilfe bekomme!
                            Ihr seid Super! Macht weiter so!
                            Ich werde hier noch viel lernen hoffe ich!
                            Falko
