  4. JavaScript
  5. [gelöst] Script nicht kompilierbar
    6.3k
15 Beiträge 4 Kommentatoren 733 Aufrufe 2 Beobachtet
  • S SumoMike
    ich möchte langsam mit JavaScript anfangen. Leider bekomme ich die Grundbefehle nicht kompiliert.
    Eine Neuinstallation von JavaScript hat auch nicht geholfen.
    Beispiel Script:
    setState('javascript.1.Script.Testpunkt', false );
    Den Datenpunkt habe ich vorab in der Testinstance (Instance 1) als Logikwert angelegt.
    Fehlermeldung:
    javascript.1	2021-01-30 17:25:36.577	error	(7919) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.1	2021-01-30 17:25:36.577	error	(7919) at runMicrotasks (<anonymous>)
    javascript.1	2021-01-30 17:25:36.577	error	(7919) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.1	2021-01-30 17:25:36.577	error	(7919) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.1	2021-01-30 17:25:36.576	error	(7919) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
    javascript.1	2021-01-30 17:25:36.576	error	(7919) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
    javascript.1	2021-01-30 17:25:36.576	error	(7919) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
    javascript.1	2021-01-30 17:25:36.576	error	(7919) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
    javascript.1	2021-01-30 17:25:36.575	error	(7919) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
    javascript.1	2021-01-30 17:25:36.575	error	(7919) at Object.createScript (vm.js:261:10)
    javascript.1	2021-01-30 17:25:36.575	error	(7919) at new Script (vm.js:88:7)
    javascript.1	2021-01-30 17:25:36.574	error	(7919) SyntaxError: Invalid or unexpected token
    javascript.1	2021-01-30 17:25:36.574	error	(7919) ^^
    javascript.1	2021-01-30 17:25:36.574	error	(7919) /*
    javascript.1	2021-01-30 17:25:36.573	error	at script.js.System.Datenpunkte_erstellen:280
    javascript.1	2021-01-30 17:25:36.573	error	(7919) script.js.System.Datenpunkte_erstellen compile failed:
    javascript.1	2021-01-30 17:25:36.570	info	(7919) Start javascript script.js.System.Datenpunkte_erstellen
    javascript.1	2021-01-30 17:25:35.275	info	(7919) Stop script script.js.System.Datenpunkte_erstellen
    Die Fehlermeldung ist bei allen Befehlen identisch. Wo liegt der Fehler bei meinen Instancen?
    Viele Grüße
    Sumo
    @sumomike sagte in Script nicht kompilierbar:
    was steht denn da?
    • S SumoMike
      Beispiel Script:
      Fehlermeldung:
      Viele Grüße
      Sumo
      liv-in-skyL Offline
      liv-in-skyL Offline
      @sumomike glaube auch nicht, dass der datenpunkt der fehler ist - das wäre ein warning
        SumoMike
        @Homoran
        Das steht im Script Log:
        17:56:38.019	info	javascript.1 (7919) Start javascript script.js.System.Datenpunkte_erstellen
        17:56:38.024	error	javascript.1 (7919) script.js.System.Datenpunkte_erstellen compile failed: at script.js.System.Datenpunkte_erstellen:280
        @liv-in-sky denke auch nicht, dass es am Datenpunkt oder Script liegt, weil es ein übernommenes Beispiel ist. Ich finde allerdings den Fehler nicht. Kann irgendetwas falsch einstellen/ installieren? Ich habe bisher nur im Blockly gearbeitet. Das funktioniert auch.
        liv-in-skyL paul53P HomoranH 3 Antworten Letzte Antwort
        • S SumoMike
          @Homoran
          liv-in-skyL Offline
          liv-in-skyL Offline
          @sumomike poste mal das ganze script - dann ist's leichter
          • S SumoMike
            @Homoran
            @sumomike sagte: compile failed: at script.js.System.Datenpunkte_erstellen:280
            Was steht im Skript "System.Datenpunkte_erstellen" in Zeile 280 und in den Zeilen davor ?
            • S SumoMike
              @Homoran
              interessant ist was in Zeile 280 des genannten Skripts steht
              • S SumoMike
                Beispiel Script:
                Fehlermeldung:
                Viele Grüße
                Sumo
                liv-in-skyL Offline
                liv-in-skyL Offline
                @sumomike nur zur vollständigkeit :-) - damit die frage mal jeder gestellt hat
                was steht um zeile 280 - plus/minus 5 zeilen
                  SumoMike
                  @Homoran @liv-in-sky @paul53 das Skript besteht nur aus diesen einen Befehl. Ab Zeile 2 steht nichts mehr drin.
                  paul53P HomoranH 2 Antworten Letzte Antwort
                  • S SumoMike
                    @sumomike sagte: das Skript besteht nur aus diesen einen Befehl.
                    Das Skript "System.Datenpunkte_erstellen"? Der Compiler denkt sich so etwas nicht aus.
                    Schau mal im Tab "Objekte" (im Experten-Modus) unter script.js.
                    • S SumoMike
                      Hast du noch ein Skript mit dieser Bezeichnung?
                      Vielleicht im Verzeichnis GLOBAL???
                        SumoMike
                        @paul53 ich habe alle Skripte gelöscht und JS neu installiert (nur noch eine Instance). Das Fehlerbild ist identisch. Auch Blockly Skripte schmeißen jetzt den Fehler.
                        Beispiel Blockly:
                        createState("Blockly_Datenpunkt", false, function () {
                        @Homoran Global ist auch geleert. Kann man den Skript Odner auch per ssh löschen? Mir fehlen sonst die Ideen in welche Zeile 280 der JS Dapter schauen kann.
                        • S SumoMike
                          Beispiel Blockly:
                          Dann machen wir es mal Schritt für Schritt:
                          Hast du ein Skript mit der Bezeichnung System.Datenpunkte_erstellen?
                          Mach es wie Paul gesagt hat:
                          @paul53 sagte in Script nicht kompilierbar:
                          • S SumoMike
                            Beispiel Blockly:
                            @sumomike
                            Tab "Objekte" im Experten-Modus: Gibt es unter "script.js" einen Ordner/channel "System"?
                              SumoMike
                              Problem gelöst. Ich habe den Browsercache geleert. Jetzt funktionieren die Blockly und JS-Skripte.
                              Den Zusammenhang verstehe ich allerdings nicht.
