  4. [Gelöst] Harmony auf neuen Host lässt sich nicht installieren
    5.9k
9 Beiträge 5 Kommentatoren 1.5k Aufrufe
  • Z Offline
    Z Offline
    Zippolighter
    Hi, habe gerade einen neuen Raspi3 Host aufgesetzt um einen zweiten Harmony Adapter zu installieren. (Erster Adapter auf Master)
    Erhalte aber immer folgende Fehlermeldung
    ` > $ ./iobroker add harmony
    npm install iobroker.harmony –production --prefix "/opt/iobroker" (System call)
    npm
    WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.2","npm":"2.15.11"})
    npm
    WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cd ... ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
    npm
    ERR! git clone –template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefined
    npm
    WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
    npm
    ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v4.8.2
    npm ERR! npm v2.15.11npm ERR! code ENOGIT
    npm ERR!
    not found: gitnpm ERR!
    npm ERR! Failed using git.
    npm ERR! This is most likely not a problem with npm itself.
    npm ERR! Please check if you have git installed and in your PATH.
    npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ERROR: host.iobroker1 Cannot install iobroker.harmony: 1
    ERROR: process exited with code 25 `
    Kann mir einer von den Linux Specs sagen, was ich falsch mache.
    Gruß Zippolighter
    • Z Offline
      Z Offline
      Zippolighter
      Habe gerade gefunden das der Harmony Adapter jetzt mehrere Hubs unterstützt. Demzufolge ist das Problem hinfällig.
      • etvE Offline
        etvE Offline
        etv
        ….habe das seslbe Problem, aber noch keinen Harmony Adapter installiert ;)
        Kann mir da wer helfen was da fehlt/falsch ist?
        Liebe Grüße
        Tom
        PS: anbei mein Errorlog -schaut aber gleich aus
        ! $ ./iobroker add harmony
        ! npm install iobroker.harmony –production --prefix "/volume1/iobroker" (System call)
        ! npm
        ! WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.4.2","npm":"2.15.0"})
        ! npm
        ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128:
        ! undefined
        ! npm
        ! ERR!
        ! undefined
        ! npm
        ! WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
        ! npm
        ! ERR! Linux 3.10.102npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/volume1/iobroker"
        ! npm ERR!
        ! node v4.4.2
        ! npm ERR! npm v2.15.0npm ERR! code ENOGIT
        ! npm ERR! not found: git
        ! npm ERR!
        ! npm ERR! Failed using git.
        ! npm ERR! This is most likely not a problem with npm itself.
        ! npm
        ! ERR!
        ! npm ERR! Please include the following file with any support request:
        ! npm ERR! /volume1/npm-debug.log
        ! ERROR: host.etv-nas-1 Cannot install iobroker.harmony: 1
        ! ERROR: process exited with code 25
        Mod-Änderung : Spoiler-Tags "repariert" - eric2905
        …ist schon sehr lange begeisterter ioBroker Nutzer! 1x zu Hause und 1x auf der Alm. ioBroker ist das 'Hirn' des Smarthome und steuert HomeMatic und Shellys, loggt was so passiert, zeigt es auf Tabletts schön an und ermöglicht mir via Cloud Adapter den Fernzugriff...
          Der übliche Fehler:
          @etv:
          ENOGIT `
          sudo apt-get install git
          Und alles wird gut :D
          • etvE Offline
            etvE Offline
            etv
            …oje...auf einer Synology dann also keine Chance....
            Danke trotzdem!
            Liebe Grüße
            Tom
            • etvE Offline
              etvE Offline
              etv
              oha…ev. doch eine Chance - sehe gerade, dass es GIT für die Syno gibt :D
              na dann probier ich halt mal rum!
              ....und schon drauf!!
              Perfekt, danke dir!
                badplay
                git gibt es wohl auch für synology
                aber auch auf der synology könnte man ja ubuntu als vm installiern via docker oder?
                auf qnap gibt es ja richtig linux station und eine vm umgebung sowie docker und lxc
                • etvE Offline
                  etvE Offline
                  etv
                  @badplay:
                  auf qnap gibt es ja richtig linux station und eine vm umgebung sowie docker und lxc `
                  …ja, danke hab ich gefunden - die Idee mit VM finde ich genial...da muss ich mich mal etwas einlesen, wie ich das am BEsten anstellen könnte.
                  Danke dir!
                  Liebe Grüße
                  Tom
                    MrLee
                    MoiN!
                    Habe ebenfalls iobroker auf meiner DS415+ installiert (nativ, Volume1) und kann den Harmony-Adapter nicht instlalieren (git not found).
                    Habe jetzt git via Web-Frontend installiert aber komme nicht weiter…wei muß ich den path anpassen damit ich installieren kann?
                    bis denne & Danke
                    Mr.Lee
