<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Gelöst] Harmony auf neuen Host lässt sich nicht installieren]]></title><description><![CDATA[<p dir="auto">Hi, habe gerade einen neuen Raspi3 Host aufgesetzt um einen zweiten Harmony Adapter zu installieren. (Erster Adapter auf Master)</p>
<p dir="auto">Erhalte aber immer folgende Fehlermeldung<br />
` &gt; $ ./iobroker add harmony</p>
<blockquote>
<p dir="auto">npm install iobroker.harmony –production --prefix "/opt/iobroker" (System call)</p>
<p dir="auto">npm</p>
<p dir="auto">WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":"&gt;=3.0.0"} (current: {"node":"4.8.2","npm":"2.15.11"})</p>
<p dir="auto">WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)</p>
<p dir="auto">npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)</p>
<p dir="auto">npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)</p>
<p dir="auto">npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5</p>
<p dir="auto">npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5</p>
<p dir="auto">npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)</p>
<p dir="auto">npm WARN addRemoteGit git+<a href="https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser" rel="nofollow ugc">https://github.com/swissmanu/ltx.git#cd ... ltx-parser</a> resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }</p>
<p dir="auto">ERR! git clone –template=/root/.npm/_git-remotes/_templates --mirror <a href="https://github.com/swissmanu/ltx.git" rel="nofollow ugc">https://github.com/swissmanu/ltx.git</a> /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror <a href="https://github.com/swissmanu/ltx.git" rel="nofollow ugc">https://github.com/swissmanu/ltx.git</a> /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefined</p>
<p dir="auto">WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package &lt;<a href="https://www.npmjs.com/package/@xmpp/xml" rel="nofollow ugc">https://www.npmjs.com/package/@xmpp/xml</a>&gt;</p>
<p dir="auto">ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"</p>
<p dir="auto">npm ERR! node v4.8.2</p>
<p dir="auto">npm ERR! npm v2.15.11npm ERR! code ENOGIT</p>
<p dir="auto">npm ERR!</p>
<p dir="auto">not found: gitnpm ERR!</p>
<p dir="auto">npm ERR! Failed using git.</p>
<p dir="auto">npm ERR! This is most likely not a problem with npm itself.</p>
<p dir="auto">npm ERR! Please check if you have git installed and in your PATH.</p>
<p dir="auto">npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log</p>
<p dir="auto">ERROR: host.iobroker1 Cannot install iobroker.harmony: 1</p>
<p dir="auto">ERROR: process exited with code 25 `</p>
</blockquote>
<p dir="auto">Kann mir einer von den Linux Specs sagen, was ich falsch mache.</p>
<p dir="auto">Danke</p>
<p dir="auto">Gruß Zippolighter</p>
]]></description><link>https://forum.iobroker.net/topic/5643/gelöst-harmony-auf-neuen-host-lässt-sich-nicht-installieren</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 03:15:31 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/5643.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Apr 2017 18:11:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Fri, 23 Feb 2018 11:00:39 GMT]]></title><description><![CDATA[<p dir="auto">MoiN!</p>
<p dir="auto">Habe ebenfalls iobroker auf meiner DS415+ installiert (nativ, Volume1) und kann den Harmony-Adapter nicht instlalieren (git not found).</p>
<p dir="auto">Habe jetzt git via Web-Frontend installiert aber komme nicht weiter…wei muß ich den path anpassen damit ich installieren kann?</p>
<p dir="auto">bis denne &amp; Danke</p>
<p dir="auto">Mr.Lee</p>
]]></description><link>https://forum.iobroker.net/post/134264</link><guid isPermaLink="true">https://forum.iobroker.net/post/134264</guid><dc:creator><![CDATA[MrLee]]></dc:creator><pubDate>Fri, 23 Feb 2018 11:00:39 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Mon, 10 Apr 2017 05:11:23 GMT]]></title><description><![CDATA[<p dir="auto"><s><a class="plugin-mentions-user plugin-mentions-a" href="/user/badplay" aria-label="Profile: badplay">@<bdi>badplay</bdi></a>:</s></p>
<blockquote>
<p dir="auto">git gibt es wohl auch für synology</p>
<p dir="auto">aber auch auf der synology könnte man ja ubuntu als vm installiern via docker oder?</p>
<p dir="auto">auf qnap gibt es ja richtig linux station und eine vm umgebung sowie docker und lxc `</p>
</blockquote>
<p dir="auto">…ja, danke hab ich gefunden - die Idee mit VM finde ich genial...da muss ich mich mal etwas einlesen, wie ich das am BEsten anstellen könnte.</p>
<p dir="auto">Danke dir!</p>
<p dir="auto">Liebe Grüße</p>
<p dir="auto">Tom</p>
]]></description><link>https://forum.iobroker.net/post/75800</link><guid isPermaLink="true">https://forum.iobroker.net/post/75800</guid><dc:creator><![CDATA[etv]]></dc:creator><pubDate>Mon, 10 Apr 2017 05:11:23 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Sun, 09 Apr 2017 18:18:57 GMT]]></title><description><![CDATA[<p dir="auto">git gibt es wohl auch für synology</p>
<p dir="auto">auf qnap gibt es ja richtig linux station und eine vm umgebung sowie docker und lxc</p>
]]></description><link>https://forum.iobroker.net/post/75778</link><guid isPermaLink="true">https://forum.iobroker.net/post/75778</guid><dc:creator><![CDATA[badplay]]></dc:creator><pubDate>Sun, 09 Apr 2017 18:18:57 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Sun, 09 Apr 2017 09:58:30 GMT]]></title><description><![CDATA[<p dir="auto">oha…ev. doch eine Chance - sehe gerade, dass es GIT für die Syno gibt :D</p>
<p dir="auto">na dann probier ich halt mal rum!</p>
<p dir="auto">....und schon drauf!!</p>
<p dir="auto">Perfekt, danke dir!</p>
]]></description><link>https://forum.iobroker.net/post/75738</link><guid isPermaLink="true">https://forum.iobroker.net/post/75738</guid><dc:creator><![CDATA[etv]]></dc:creator><pubDate>Sun, 09 Apr 2017 09:58:30 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Sun, 09 Apr 2017 09:56:48 GMT]]></title><description><![CDATA[<p dir="auto">…oje...auf einer Synology dann also keine Chance....</p>
<p dir="auto">Danke trotzdem!</p>
]]></description><link>https://forum.iobroker.net/post/75737</link><guid isPermaLink="true">https://forum.iobroker.net/post/75737</guid><dc:creator><![CDATA[etv]]></dc:creator><pubDate>Sun, 09 Apr 2017 09:56:48 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Sun, 09 Apr 2017 09:52:53 GMT]]></title><description><![CDATA[<p dir="auto">Der übliche Fehler:<br />
<s><a class="plugin-mentions-user plugin-mentions-a" href="/user/etv" aria-label="Profile: etv">@<bdi>etv</bdi></a>:</s></p>
<blockquote>
<p dir="auto">ENOGIT `</p>
</blockquote>
<pre><code>sudo apt-get install git
</code></pre>
<p dir="auto">Und alles wird gut :D</p>
<p dir="auto">Gruß</p>
<p dir="auto">Rainer</p>
]]></description><link>https://forum.iobroker.net/post/75735</link><guid isPermaLink="true">https://forum.iobroker.net/post/75735</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 09 Apr 2017 09:52:53 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Sun, 09 Apr 2017 09:49:08 GMT]]></title><description><![CDATA[<p dir="auto">….habe das seslbe Problem, aber noch keinen Harmony Adapter installiert ;)</p>
<p dir="auto">Kann mir da wer helfen was da fehlt/falsch ist?</p>
<p dir="auto">PS: anbei mein Errorlog -schaut aber gleich aus</p>
<blockquote>
<p dir="auto">! $ ./iobroker add harmony<br />
! npm install iobroker.harmony –production --prefix "/volume1/iobroker" (System call)<br />
! npm<br />
! WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":"&gt;=3.0.0"} (current: {"node":"4.4.2","npm":"2.15.0"})<br />
! npm<br />
! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror <a href="https://github.com/swissmanu/ltx.git" rel="nofollow ugc">https://github.com/swissmanu/ltx.git</a> /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128:<br />
! undefined<br />
! npm<br />
! ERR!<br />
! undefined<br />
! npm<br />
! WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package &lt;<a href="https://www.npmjs.com/package/@xmpp/xml" rel="nofollow ugc">https://www.npmjs.com/package/@xmpp/xml</a>&gt;<br />
! npm<br />
! ERR! Linux 3.10.102npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/volume1/iobroker"<br />
! npm ERR!<br />
! node v4.4.2<br />
! npm ERR! npm v2.15.0npm ERR! code ENOGIT<br />
! npm ERR! not found: git<br />
! npm ERR!<br />
! npm ERR! Failed using git.<br />
! npm ERR! This is most likely not a problem with npm itself.<br />
! npm<br />
! ERR!<br />
! Please check if you have git installed and in your PATH.<br />
! npm ERR! Please include the following file with any support request:<br />
! npm ERR! /volume1/npm-debug.log<br />
! ERROR: host.etv-nas-1 Cannot install iobroker.harmony: 1<br />
! ERROR: process exited with code 25</p>
</blockquote>
<p dir="auto"><strong><strong>Mod-Änderung : Spoiler-Tags "repariert" - eric2905</strong></strong></p>
]]></description><link>https://forum.iobroker.net/post/75734</link><guid isPermaLink="true">https://forum.iobroker.net/post/75734</guid><dc:creator><![CDATA[etv]]></dc:creator><pubDate>Sun, 09 Apr 2017 09:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] Harmony auf neuen Host lässt sich nicht installieren on Thu, 06 Apr 2017 18:14:31 GMT]]></title><description><![CDATA[<p dir="auto">Habe gerade gefunden das der Harmony Adapter jetzt mehrere Hubs unterstützt. Demzufolge ist das Problem hinfällig.</p>
]]></description><link>https://forum.iobroker.net/post/75439</link><guid isPermaLink="true">https://forum.iobroker.net/post/75439</guid><dc:creator><![CDATA[Zippolighter]]></dc:creator><pubDate>Thu, 06 Apr 2017 18:14:31 GMT</pubDate></item></channel></rss>
