Reparatur einer defekten Grundinstallation
deb https://deb.nodesource.com/node_12.x buster main deb-src https://deb.nodesource.com/node_12.x buster mainund jetzte nacheinander
sudo apt update sudo apt dist-upgrade sudo reboot -
sudo apt update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Get:3 https://deb.nodesource.com/node_12.x buster InRelease [4,584 B] Get:4 https://deb.nodesource.com/node_12.x buster/main armhf Packages [772 B] Fetched 5,356 B in 1s (4,627 B/s) Reading package lists... Done Building dependency tree Reading state information... Done 59 packages can be upgraded. Run 'apt list --upgradable' to see them. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_12.x buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done 59 packages can be upgraded. Run 'apt list --upgradable' to see them. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension Befehl 1 -
sudo apt update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Get:3 https://deb.nodesource.com/node_12.x buster InRelease [4,584 B] Get:4 https://deb.nodesource.com/node_12.x buster/main armhf Packages [772 B] Fetched 5,356 B in 1s (4,627 B/s) Reading package lists... Done Building dependency tree Reading state information... Done 59 packages can be upgraded. Run 'apt list --upgradable' to see them. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_12.x buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done 59 packages can be upgraded. Run 'apt list --upgradable' to see them. N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension Befehl 1@mb78 gut so - weiter!
lediglich:
@mb78 sagte in Reparatur einer defekten Grundinstallation:
hattest du beim Speichern einen Fehler?
das muss @Thomas-Braun gleich mit dir wieder wegputzen -
Die Datei darf nicht auf save.1 enden sondern muss nodesource.list heißen.
Bei dem Rückschritt auf node12 muss auch noch die genaue Versionsnummer reingezogen werden, bei einem upgrade auf node14 wäre das nicht erforderlich (deswegen hatte ich dir node14 parat gelegt). -
@mb78 Nee, lass das jetzt so. Ich glaube eh, du hast das irgendwie schon richtig gemacht.
apt policy nodejsliefert?
pi@raspberrypi:~ $ apt policy nodejs nodejs: Installed: 13.14.0-1nodesource1 Candidate: 13.14.0-1nodesource1 Version table: *** 13.14.0-1nodesource1 100 100 /var/lib/dpkg/status 12.20.1-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 10.23.1~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension -
pi@raspberrypi:~ $ apt policy nodejs nodejs: Installed: 13.14.0-1nodesource1 Candidate: 13.14.0-1nodesource1 Version table: *** 13.14.0-1nodesource1 100 100 /var/lib/dpkg/status 12.20.1-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 10.23.1~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extensionsudo rm /etc/apt/sources.list.d/nodesource.list.save.1 sudo apt install nodejs=12.20.1-1nodesource1 sudo apt update sudo apt dist-upgrade sudo reboot -
@mb78
Erfolgskontrolle:which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r && sudo apt update -
@thomas-braun said in Reparatur einer defekten Grundinstallation:
Ergebnis:
which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r && sudo apt update /usr/bin/nodejs v12.20.1 /usr/bin/node v12.20.1 /usr/bin/npm 6.14.10 nodejs: Installed: 12.20.1-1nodesource1 Candidate: 12.20.1-1nodesource1 Version table: *** 12.20.1-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.23.1~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages run-level 5 2021-01-18 15:35 Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 https://deb.nodesource.com/node_12.x buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. -
Ergebnis:
which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r && sudo apt update /usr/bin/nodejs v12.20.1 /usr/bin/node v12.20.1 /usr/bin/npm 6.14.10 nodejs: Installed: 12.20.1-1nodesource1 Candidate: 12.20.1-1nodesource1 Version table: *** 12.20.1-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.23.1~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages run-level 5 2021-01-18 15:35 Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 https://deb.nodesource.com/node_12.x buster InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date.@mb78
Ja, das passt jetzt. Wenn du ganz 'mutig' bist stellst du den Server auf den richtigen RunLevel (3) ein. Dann wird der komplette Grafik-Stack nicht unnötigerweise mitgeladen. Das setzt allerdings vorraus, dass da kein Display z. B. für eine Visualisierung dran hängt, der Server also 'headless' läuft.
Zugang per ssh/puTTY ist ja jetzt bekannt. -
bin ich nicht.
soll ich jetzt mal zigbee neu starten? der steht jetzt nämlich auf komlett rot@mb78
Hängt denn da überhaupt ein Display dran?Jedenfalls kannst du dich jetzt um zigbee kümmern.
Vielleicht den angeknabberten Thread mit @Asgothian wieder aufleben lassen. -
Weiß ich nicht.
? Du wirst doch wissen, ob an dem Pi ein Monitor/TV oder sowas hängt.
@mb78
Dann würde ich die Kiste auf RunLevel3 umstellen.
Spart ein paar Körner auf den kleinen Dingern.
Jetzt funkt die Kiste eine graphische Oberfläche ins Schwarze. -
@mb78 Dann bitte im entsprechenden Thread posten.
Die reparatur-einer-defekten-grundinstallation ist erledigt.
