  4. JavaScript
  5. Fenster Script: Liste der offenen Fenster
    6.3k
56 Beiträge 11 Kommentatoren 8.5k Aufrufe 11 Beobachtet
    dos1973
    dein Vorschlag klappt nicht, bzw.das Script funktioniert dann nicht, bzw. bringt Fehler.
    	2020-03-28 23:35:18.465	info	(22746) Stop script script.js.1_Überwachung_Wohnung.Fenster_Licht_Status
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1055:17)
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1464:17)
    javascript.0	2020-03-28 23:34:32.025	error	(22746) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1411:37)
    javascript.0	2020-03-28 23:34:32.024	error	(22746) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1188:28)
    javascript.0	2020-03-28 23:34:32.024	error	(22746) at Object.createScript (vm.js:277:10)
    javascript.0	2020-03-28 23:34:32.024	error	(22746) at new Script (vm.js:83:7)
    javascript.0	2020-03-28 23:34:32.024	error	(22746) SyntaxError: missing ) after argument list
    javascript.0	2020-03-28 23:34:32.024	error	(22746) ^
    javascript.0	2020-03-28 23:34:32.024	error	(22746) listlights.forEach((a) => { lights_onText += a + '\n';}
    javascript.0	2020-03-28 23:34:32.024	error	at script.js.1_Überwachung_Wohnung.Fenster_Licht_Status:50
    javascript.0	2020-03-28 23:34:32.024	error	(22746) script.js.1_Überwachung_Wohnung.Fenster_Licht_Status compile failed:
    der Zeilenumbruch wird nicht angenommen, ich habe schon einen DP im VIS um das zu prüfen.
    • D dos1973
      T Nicht stören
      T Nicht stören
      ticaki
      @dos1973
      jup in meinem Vorschlag hab ich wieder ); vergessen, passiert mir häufiger.
      listlights.forEach((a) => { lights_onText += a + '\n';});
      Aber VIS ist nicht Datenpunkt: schreib mal von hand
      1<br>2<br>3
      oder
      1<br/>2<br/>3
      oder
      1\n2\n3
      oder
      1\r\n2\r\n3
      in den Datenpunkt. Eines davon wird gehen.
      Spenden
        dos1973
        ich bekomme immer mehr das Gefühl dass ich in einem DP gar kein Zeilenumbruch haben kann??
        auch wenn ich das manuell Eingebe gehts nicht?
        ALSO im VIS wird einfach Fließtext ausgegeben, der in dem DP aufgenommen ist
        • D dos1973
          dos1973
          ich habs gefunden - mein Fehler "natürlich"
           if(listlights.length) lights_onText = 'Lampen ein: ' + listlights.join((',<br>'));
          aber in VIS hatte ich einen Basic-String genommen, damit gehts natürlich nicht.
          Jetzt mit einem HTML Widget gehts.
          • D dos1973
            J-Lind
            @dos1973 said in Fenster Script: Liste der offenen Fenster:
            Hi Dos1973
            wie trägst du den datenpunkt in dem HTML widget ein?
            Gruss Juergen
            • O Offline
              O Offline
              Oak
              Guten Abend,
              Ich würde die Aufzählung auch gerne Verwenden.
              Irgendwie werden mir in dem String nur die Homematic ID ausgegeben.
              Im Iobroker selber habe Ich den Namen bereits geändert. Bleibt aber das gleiche.
              Kann Ich das Script an Irgendeiner stelle abändern, sodass Ich den Namen und nicht die ID ausgegeben bekomme?
              • O Oak
                Guten Abend,
                @Oak sagte:
                Welches Script ?
                • v522533V v522533
                  ich bräuchte mal ein wenig Hilfe: Ich habe folgendes Script von smarthome-tricks.de benutzt, um mir meine offenen Fenster anzuzeigen. Leider zeigt es nur die Anzahl an, ich brauche aber eine Auflistung, welche Fenster offen sind. Kann mir jemand kurz behilflich sein, da mein Javascriptwissen leider nicht sehr gut ist.
                  function countOpenWindowsDoors()
                  var openWindows = 0;
                  var openDoors = 0;
                  // Fenster
                  var windows = getObject("enum.functions.windowstatus").common.members;
                  for(let i = 0; i < windows.length; i++) {
                  var Status = getState(windows[i]).val;
                  if ( Status ) { openWindows = openWindows + 1; }
                  // Türen
                  var doors = getObject("enum.functions.doorstatus").common.members;
                  for(let i = 0; i < doors.length; i++) { var Status = getState(doors[i]).val; if ( Status ) { openDoors = openDoors + 1; } } var openWindowsText = "Kein Fenster geöffnet"; var openDoorText = "Keine Tür geöffnet"; if ( openWindows > 0 ) {
                  openWindowsText = openWindows + " Fenster geöffnet";
                  if ( openDoors > 0 ) {
                  openDoorText = openDoors + " Türe(n) geöffnet";
                  setState('Datenpunkte.0.StatusWindowOpenText', openWindowsText );
                  setState('Datenpunkte.0.StatusDoorOpenText', openDoorText );
                  setState('Datenpunkte.0.StatusWindowOpen', openWindows, true );
                  setState('Datenpunkte.0.StatusDoorOpen', openDoors, true );
                  function registerSubscription()
                  $('state(functions=windowstatus)').on(function(obj) {
                  countOpenWindowsDoors();
                  $('state(functions=doorstatus)').on(function(obj) {
                  registerSubscription();
                  Danke schonmal.
                  O Offline
                  O Offline
                  Oak
                  schrieb am zuletzt editiert von Oak
                  @v522533 said in Fenster Script: Liste der offenen Fenster:
                  Ich habe das hier genutzt.
                  Passiert aber bei jeden Script hier im Thema.
        function countOpenWindowsDoors()        {        var openWindows = 0;        var openDoors = 0;        // Fenster        var windows = getObject("enum.functions.windowstatus").common.members;        for(let i = 0; i < windows.length; i++) {        var Status = getState(windows[i]).val;        if ( Status ) { openWindows = openWindows + 1; }        }        // Türen        var doors = getObject("enum.functions.doorstatus").common.members;        for(let i = 0; i < doors.length; i++) { var Status = getState(doors[i]).val; if ( Status ) { openDoors = openDoors + 1; } } var openWindowsText = "Kein Fenster geöffnet"; var openDoorText = "Keine Tür geöffnet"; if ( openWindows > 0 ) {        openWindowsText = openWindows + " Fenster geöffnet";        }        if ( openDoors > 0 ) {        openDoorText = openDoors + " Türe(n) geöffnet";        }        setState('Datenpunkte.0.StatusWindowOpenText', openWindowsText );        setState('Datenpunkte.0.StatusDoorOpenText', openDoorText );        setState('Datenpunkte.0.StatusWindowOpen', openWindows, true );        setState('Datenpunkte.0.StatusDoorOpen', openDoors, true );        }        function registerSubscription()        {        $('state(functions=windowstatus)').on(function(obj) {        countOpenWindowsDoors();        });        $('state(functions=doorstatus)').on(function(obj) {        countOpenWindowsDoors();        });        }        registerSubscription();        countOpenWindowsDoors();
                  • O Oak
                    @Oak sagte:
                    Das Script zählt nur offen Fenster und Türen.
                    O 1 Antwort Letzte Antwort
                      @Oak sagte:
                      O Offline
                      O Offline
                      Oak
                      Sry, Ich habe mal fix zum PC gewechselt!
                      Vom Handy klappt das nicht so gut.
                      Das Script ist folgendes
                          var openDoors = 0;
                          var listWindows = [];
                          var listDoors = [];
                          // Fenster
                          var windows = getObject("enum.functions.fensterstatus").common.members;
                              if ( Status ) {
                                  openWindows++;
                                  let id = windows[i].substring(0, windows[i].lastIndexOf('.')); // Device ID
                                   listWindows.push(getObject(id).common.name); // Device Name
                          // Türen
                          var doors = getObject("enum.functions.turstatus").common.members;
                              if ( Status ) {
                                  openDoors++;
                                   listDoors.push(getObject(id).common.name); // Device Name
                          var openDoorsText = "Keine Tür geöffnet";
                          if(listWindows.length) openWindowsText = '' + listWindows.join(', ');
                          if(listDoors.length) openDoorsText = 'Offene Türen: ' + listDoors.join(', ');
                          setState('0_userdata.0.FensteroffenText', openWindowsText, true);
                          setState('0_userdata.0.turoffenText', openDoorsText, true);
                          setState('0_userdata.0.FensteroffenAnzahl', openWindows, true );
                          setState('0_userdata.0.turoffenAnzahl', openDoors, true );
                      $('state(functions=fensterstatus)').on(function(obj) {
                      $('state(functions=turstatus)').on(function(obj) {
                      Und das schreibt er mir halt!
                      Nur hätte Ich halt den Namen (in dem Fall Kellertür) dort stehen.
                      • O Oak
                            var openDoors = 0;
                            var listDoors = [];
                            // Fenster
                                if ( Status ) {
                                    openWindows++;
                            // Türen
                                if ( Status ) {
                                    openDoors++;
                        @Oak sagte:
                        Welches Objekt hat den Namen "Kellertür"? Das Device oder der Datenpunkt?
                        Für den Devicename füge eine Zeile ein (an 2 Stellen):
                                    let id = windows[i].substring(0, windows[i].lastIndexOf('.')); // Channel ID
                                    id = id.substring(0, id.lastIndexOf('.')); // Device ID
                          @Oak sagte:
                          O Offline
                          O Offline
                          Oak
                          Sauber das Funktioniert!
                          Vielen Dank für deine Unsterstützung paul53.
                          N 1 Antwort Letzte Antwort
                          • O Oak
                            N Offline
                            N Offline
                            Nobody28
                            Guten Morgen in die Runde. Ich habe versucht, alles aus diesem Thread auch umzusetzen... aber es will nicht klappen.
                            Hier mal die Log Ausgabe (sind alles Magnetkontakte über den MiHome Adapter, nur als Info):
                            20.2.2021, 07:22:42.392	[info ]: javascript.0 (6691) Start javascript script.js.common.Aufzählungen.Fenster
                            20.2.2021, 07:22:42.433	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.433	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.435	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.435	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.436	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.436	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.438	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.438	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.441	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.442	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.443	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.443	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.445	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.445	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.447	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.447	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.449	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.449	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.450	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.451	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.452	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.453	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.454	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.454	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.457	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.457	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.458	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.459	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.460	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.460	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.462	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.462	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.463	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.463	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.464	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.465	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.467	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.467	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.472	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:11:22)
                            20.2.2021, 07:22:42.473	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.474	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.474	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.476	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.476	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.478	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.478	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.479	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.479	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.480	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.481	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.482	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.482	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.483	[warn ]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:24:22)
                            20.2.2021, 07:22:42.483	[warn ]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            20.2.2021, 07:22:42.485	[error]: javascript.0 (6691) script.js.common.Aufzählungen.Fenster: script.js.common.Aufzählungen.Fenster:29
                            20.2.2021, 07:22:42.486	[error]: javascript.0 (6691)     at countOpenWindowsDoors (script.js.common.Aufzählungen.Fenster:29:41)
                            20.2.2021, 07:22:42.486	[error]: javascript.0 (6691)     at script.js.common.Aufzählungen.Fenster:54:1
                            Hier das Script bisher:
                                var openDoors = 0;
                                var listDoors = [];
                                // Fenster
                                var windows = getObject("enum.functions.fenster").common.members;
                                    if ( Status ) {
                                        openWindows++;
                                // Türen
                                var doors = getObject("enum.functions.tür").common.members;
                                    if ( Status ) {
                                        openDoors++;
                                if (listWindows.length) openWindowsText = 'Offene Fenster: ' + listWindows.join(', ');
                                if (listDoors.length) openDoorsText = 'Offene Türen: ' + listDoors.join(', ');
                                setState('0_userdata.0.Zähler.FensteroffenText', openWindowsText, true);
                                setState('0_userdata.0.Zähler.TuroffenText', openDoorsText, true);
                                setState('0_userdata.0.Zähler.FensteroffenAnzahl', openWindows, true );
                                setState('0_userdata.0.Zähler.TueroffenAnzahl', openDoors, true );
                            $('state(functions=fenster)').on(function(obj) {
                            $('state(functions=tür)').on(function(obj) {
                            Hier soll er reinschreiben:
                            und:
                            Evtl. sieht jemand meinen Fehler.
                            Danke schon einmal.
                            Liebe Grüße und allen ein schönes Wochenende.
                            • N Nobody28
                                  var openDoors = 0;
                                  var listDoors = [];
                                  // Fenster
                                      if ( Status ) {
                                          openWindows++;
                                  // Türen
                                      if ( Status ) {
                                          openDoors++;
                              und:
                              Danke schon einmal.
                              @nobody28 sagte: Hier das Script bisher:
                              Dieses Script funktioniert nur unter folgenden Voraussetzungen:
                              • Den Enums "enum.functions.fenster" und "enum.functions.tür" sind Datenpunkte zugeordnet
                              • 2 Ordner-Ebenen über den Datenpunkten existieren Objekte (device), deren Namen ausgegeben werden soll
                                N Offline
                                N Offline
                                Nobody28
                                Sorry Paul,
                                ich kann Dir leider nicht ganz Folgen.
                                Das sind die Sensoren, und einen exemplarisch aufgeklappt:
                                Was ist da die besagt 2. Ebene bitte?
                                Danke schon mal für die Hilfe.
                                Liebe Grüße
                                • N Nobody28
                                  Sorry Paul,
                                  Liebe Grüße
                                  @nobody28 sagte: Was ist da die besagt 2. Ebene bitte?
                                  Die gibt es bei Dir nicht als Objekt (Ordner "devices").
                                  Du hast die Gewerke den Kanälen zugeordnet, damit sind die Kanäle in common.members und nicht die Datenpunkte.
                                  Verwende besser die Lösung mit $selector.each().
                                  const idsFenster = $('mihome.0.*.state(functions=fenster)');
                                  const idsTueren = $('mihome.0.*.state(functions=tür)');
                                      var openDoors = 0;
                                      var listDoors = [];
                                      // Fenster
                                      idsFenster.each(function(id, i) {
                                          if(getState(id).val) {
                                              openWindows++;
                                              id = id.substring(0, id.lastIndexOf('.')); // Channel ID
                                              listWindows.push(getObject(id).common.name); // Channel Name
                                      // Türen
                                      idsTueren.each(function(id, i) {
                                              openDoors++;
                                              listDoors.push(getObject(id).common.name); // Channel Name
                                      log(openWindowsText);
                                  idsFenster.on(function(obj) {
                                  idsTueren.on(function(obj) {
                                        var openDoors = 0;
                                        var listDoors = [];
                                        // Fenster
                                                openWindows++;
                                        // Türen
                                                openDoors++;
                                    N Offline
                                    N Offline
                                    Nobody28
                                    Vielen Dank, das funktioniert auf Anhieb. :)
                                    Nur mir ist leider der Unterschied zwischen Kanal und Datenpunkt nicht ganz klar.
                                    Kannst du das mit einem einfachen Beispiel wohl erklären?
                                    Vielen Dank.
                                    Liebe Grüße
                                    • N Nobody28
                                      Vielen Dank.
                                      Liebe Grüße
                                      @nobody28 sagte: Unterschied zwischen Kanal und Datenpunkt
                                      Ein Datenpunkt ist ein Objekt vom Typ "state" und hat Zustände/Werte (rechts in Deinem Bild). Ein Kanal ist ein Objekt vom Typ "channel" und hat keine Zustände.
