  4. 2021 geht ja gut los - Iobroker hängt!
    6.7k
iobroker hängt
16 Beiträge 3 Kommentatoren 635 Aufrufe 2 Beobachtet
  • B brokeling
    Ich komm noch nicht drauf.
    hier mal ein Auszug aus den logs, da ist wohl was schief gelaufen mit einem falsch deklarierten Wert - boolean...
    Es scheint als hätten sich die Fehler aufgestaut und müssten abgearbeitet werden.
    javascript.0	2021-01-01 18:12:47.880	warn	(17318) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5352:41
    javascript.0	2021-01-01 18:12:47.880	warn	(17318) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:472:25)
    javascript.0	2021-01-01 18:12:47.880	warn	(17318) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1055:38)
    javascript.0	2021-01-01 18:12:47.880	warn	(17318) at Object.<anonymous> (script.js.common.Bewegungsmelder.Alle_BM_Status.BM_Garage_Latenz:6:5)
    javascript.0	2021-01-01 18:12:47.880	warn	(17318) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
    javascript.0	2021-01-01 18:12:47.879	warn	(17318) You are assigning a number to the state "alias.0.Bewegungsmelder._BM_Garage.MAINTAIN" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This wa
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at processImmediate (internal/timers.js:461:21)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:236:41)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5346:46)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at Array.forEach (<anonymous>)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5352:41
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:472:25)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1055:38)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at Object.<anonymous> (script.js.common.Bewegungsmelder.Alle_BM_Status.BM_Garage_Latenz:6:5)
    javascript.0	2021-01-01 18:12:47.878	warn	(17318) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
    javascript.0	2021-01-01 18:12:47.877	warn	(17318) You are assigning a number to the state "alias.0.Bewegungsmelder._BM_Garage.MAINTAIN" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This wa
    javascript.0	2021-01-01 18:12:47.877	warn	(17318) at processImmediate (internal/timers.js:461:21)
    javascript.0	2021-01-01 18:12:47.876	warn	(17318) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:236:41)
    javascript.0	2021-01-01 18:12:47.876	warn	(17318) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5346:46)
    javascript.0	2021-01-01 18:12:47.876	warn	(17318) at Array.forEach (<anonymous>)
    javascript.0	2021-01-01 18:12:47.876	warn	(17318) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5352:41
    javascript.0	2021-01-01 18:12:47.876	warn	(17318) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:472:25)
    @brokeling
    iobroker restart
      @brokeling
      iobroker restart
      brokeling
      @Thomas-Braun
      Er mag noch nicht.
      Die falsche Zuweisung ist in Alias drin. Vielleicht auch das stoppen?
      B Thomas BraunT 2 Antworten Letzte Antwort
      • B brokeling
        @Thomas-Braun
        Er mag noch nicht.
        brokeling
        Und ich sehe gerade - Javascript läuft wohl immer noch!
        Kann das sein, dass es nach restart wieder automatisch startet?
        • B brokeling
          @Thomas-Braun
          Er mag noch nicht.
          @brokeling
          Dann stop mal beide Adapter.
          • B brokeling
            @brokeling sagte:
            Ja, alle aktivierten Instanzen starten wieder. Du hast anscheinend eine Endlosschleife programmiert.
            @brokeling sagte:
            Den js-controller ?
              @brokeling sagte:
              @brokeling sagte:
              Den js-controller ?
              brokeling
              schrieb am zuletzt editiert von brokeling
              Habe jetzt einen restart iobroker gemacht, dann sofort javascript gestoppt, so hat der Adapter gar nicht soviel Gelegenheit gehabt, Fehler zu produzieren.
              Jetzt bin ich reingekommen!
              Wie ich "Alias" stoppe wusste ich nicht.
              Jetzt muss ich auf Fehlersuche.
              • B brokeling
                @brokeling sagte:
                Stoppe das Script "common.Bewegungsmelder.Alle_BM_Status.BM_Garage_Latenz" und suche darin den Fehler.
                  @brokeling sagte:
                  brokeling
                  Ich weiß jetzt den Fehler.
                  In diesem von dir genannten Skript wird dem Alias vorgegebenen Typ "maintain" ein number-Wert zugewiesen.
                  Definiert ist maintain aber als boolean. Daher kann er wohl den Wert nicht zuweisen, versucht es aber immer wieder.
                  Ich habe den Alias maintain von boolean in number geändert. Jetzt müsste es passen, es läuft wieder!!! :)
                  Mit den Aliasen kenne ich noch nicht so recht aus, unter maintain hab ich bei z.B. bei Bewegungsmeldern die Latenzzeit eingestellt, die ich möglichst kurz will. Die Aqaras BM haben in der Grundeinstellung 90s - mit einem Hardware-Mod gehen auch 6s. Von Zeit zu Zeit stellen die sich gerne wieder auf 90s (Grund unbekannt). Das javaskript erkennt dies und stellt sofort wieder auf 6s.
                  Und diesen Latenz-Wert (BM Objekt) hinterlege ich unter maintain, habe aber wohl vergessen, dass ich noch boolean umstellen muss.
                  Ich weiß nicht ob mein Vorgehen so korrekt ist, und ich "maintain" dafür verwenden kann. Aber nach der Umstellung geht es jetzt, wie auch bei meinen anderen BM!
                  • B brokeling
                    @brokeling
                    Das ist "nur" eine Warnung. Der Wert wird trotzdem geschrieben.
                    Damit wird keine Endlosschleife erzeugt, die anscheinend Deinen ioBroker lahm gelegt hat. Du wirst wohl weiter suchen müssen.
                      @brokeling
                      brokeling
                      aber mit dieser Änderung
                      Objekt "maintain" Datentyp boolean -> number besteht das Problem nicht mehr.
                      Das ist das einzige, was ich verändert habe, und dann den javascript adapter wieder laufen lassen. Und jetzt geht es.
                        @brokeling
                        brokeling
                        @Thomas-Braun,
                        @paul53 ,
                        auf alle Fälle herzlichen Dank an euch dass mein System jetzt wieder läuft!!!!!!!!
