  4. [Vorstellung] Meine dritte VIS
    6.6k
visvis projekte
640 Beiträge 83 Kommentatoren 244.3k Aufrufe 117 Beobachtet
  • K Kuddel
    @marhal das ist aktuell mein Skript
    // Liest die ioBroker Adapter aus und legt verschiedenen State's an.
    on({id:"system.adapter.admin.0.uptime",change:'any'}, function (obj) {
       createState('Adapter.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Adapter', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
       createState('Adapter.AdapterNummer', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
       //var counterAlt = getState("javascript.0.Adapter.Anzahl").val;
       var counter =0;
       var on = 0
       var manuell=0
       var cacheSelector = $('[id=system.adapter.*.alive]');
       cacheSelector.each(function(id, i) {
           var devicename = getObject(id).common.name;
       	//Instanzen ausklammern
       	instanz0 = devicename.indexOf('daswetter');
       	instanz1 = devicename.indexOf('dwd');
           instanz2 = devicename.indexOf('ical');
       	instanz3 = devicename.indexOf('feiertage');
           instanz4 = devicename.indexOf('kodi.0');
       	instanz5 = devicename.indexOf('snmp.1');
           instanz6 = devicename.indexOf('vis.0');
           instanz7 = devicename.indexOf('yamaha.0');
       	if(instanz0 !=0 && instanz1 != 0 && instanz2 !=0 && instanz3 != 0 && instanz4 != 0 && instanz5 !=0 && instanz6 !=0 && instanz7 !=0){
       		var devicenameName=devicename;
       		var instanzname=getObject(id).common.name;
       		var test = devicenameName;
       		var devicename_array = devicenameName.split(' ');
       		devicenameName = devicename_array[0];
       		counter = counter+1;
       		var strStatePath = "system.adapter." + devicenameName + ".alive";
       		if (isState(strStatePath, true)) {
       			var uptime = getState("system.adapter." + devicenameName + ".uptime").val;
       			var tage = Math.floor(uptime / (24*3600));
       			var stunden = Math.floor((uptime % (24*3600))/3600);
       			var minuten = Math.floor((uptime % (3600))/60);
       			//var sekunden = Math.floor(uptime % 60);
       			if (stunden < 10) {stunden = "0"+stunden};
                   if (minuten < 10) {minuten = "0"+minuten};
       			if (tage == 1) {uptime = tage.toString()+" Tag, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";};
       			if (tage != 1) {uptime = tage.toString()+" Tage, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";}
       			//var total = getState("system.adapter." + devicenameName + ".memHeapTotal").val;
       			//var used = getState("system.adapter." + devicenameName + ".memHeapUsed").val;
       			//var rss = getState("system.adapter." + devicenameName + ".memRss").val;
       			var connect = getState("system.adapter." + devicenameName + ".alive").val;
       			if(connect == false){var con = 0;}
       			else {
       				var con = 1;
       				var strStatePath = devicenameName + ".info.connection";
       					var connectS = getState(devicenameName + ".info.connection").val;
       					if (connectS == false) {
       						con = 2;
       			if(con==1) {on = on + 1}
       		devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
       		createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
       		setStateDelayed(devicename, devicenameName, 800);
       		var contentstring = devicenameName;
       		var suchstring = /(ical)/g;
       		var suchergebnis = suchstring.test( contentstring );
       		if (suchergebnis != true) {
       			var devicename_array = devicenameName.split('.');
       		if (devicenameName == "daswetter") {
       			var bild = "/" + devicenameName + ".admin/" + devicenameName + "com.png";
       		} else if (suchergebnis != false) {
       			var icalName = devicename_array[0];
       			var bild = "/" + icalName + ".admin/" + icalName + ".png";
       		} else {
       			var bild = "/" + devicenameName + ".admin/" + devicenameName + ".png";
       		//Alexa2
       		if (devicenameName == 'alexa2') {var bild = "/" + devicenameName + ".admin/" + "alexa.png";}
       		//FritzDECT
       		if (devicenameName == 'fritzdect') {var bild = "/" + devicenameName + ".admin/" + "fritzdect_logo.png";}
       		//FullyBrowser
       		if (devicenameName == 'fullybrowser') {var bild = "/" + devicenameName + ".admin/" + "fully.png";}
       		//HM-Rega
       		//if (devicenameName == 'hm-rega') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
       		if (devicenameName == 'hm-rega') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
       		//HomeMatic
       		//if (instanzname == 'hm-rpc.0 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
       		if (instanzname == 'hm-rpc.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
       		//HomeMatic-IP
       		//if (instanzname == 'hm-rpc.1 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
       		if (instanzname == 'hm-rpc.1 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic_ip.jpg";}
       		//UPNP
       		if (devicenameName == 'upnp') {var bild = "/" + devicenameName + ".admin/" + "upnp-discovery.png";}
               //Pushover.1
       		if (instanzname == 'pushover.1 alive') {var bild = "/mihome-vacuum.admin/mihome-vacuum.png";}
               //Pushover.2
       		if (instanzname == 'pushover.2 alive') {var bild = "/daswetter.admin/daswettercom.png";}
       		//AdapterName anpassen
               //DasWetter
       		if (instanzname == 'daswetter.0 alive') {devicenameName='DasWetter'; manuell=1}
       		//DWD
       		if (instanzname == 'dwd.0 alive') {devicenameName='DWD'; manuell=1}
       		//HM-REGA
       		if (instanzname == 'hm-rega.0 alive') {devicenameName='HM-Rega'; manuell=1}
       		//HM-RPC.0
       		if (instanzname == 'hm-rpc.0 alive') {devicenameName='HomeMatic'; manuell=1}
       		//HM-RPC.1
       		if (instanzname == 'hm-rpc.1 alive') {devicenameName='HM-IP'; manuell=1}
       		//MiHome-Vacuum
       		if (instanzname == 'mihome-vacuum.0 alive') {devicenameName='Nono'; manuell=1}
       		//Pushover
       		if (instanzname == 'pushover.0 alive') {devicenameName='Pushover.0'; manuell=1}
       		if (instanzname == 'pushover.1 alive') {devicenameName='Pushover.1'; manuell=1}
       		if (instanzname == 'pushover.2 alive') {devicenameName='Pushover.2'; manuell=1}
       		//Simple-API
       		if (instanzname == 'simple-api.0 alive') {devicenameName='Simple-API'; manuell=1}
       		//SNMP.0
       		if (instanzname == 'snmp.0 alive') {devicenameName='SNMP.0'; manuell=1}
       		//SNMP.1
       		if (instanzname == 'snmp.1 alive') {devicenameName='SNMP.1'; manuell=1}
               //Spotify
               if (instanzname == 'spotify-premium.0 alive') {devicenameName='Spotify'; manuell=1}
               //TR-064.0
       		if (instanzname == 'tr-064.0 alive') {devicenameName='TR-064.0'; manuell=1}
       		//TR-064.1
       		if (instanzname == 'tr-064.1 alive') {devicenameName='TR-064.1'; manuell=1}
               //XPEnology
               if (instanzname == 'synology.1 alive') {devicenameName='XPEnology'; manuell=1}
       		//Instanz-Namen setzen
       		if(manuell!=1) {devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();}
               //devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();
       		devicename="Adapter.Adapter"+counter.toString()+".NameInstanz";
       		createState(devicename, 'empty', { name: 'Name des Geräts', desc: '', type: 'string', role: '',read: true, write: true });
       		//Bild Pfad setzen
       		devicename="Adapter.Adapter"+counter.toString()+".Bild";
       		createState(devicename, 'empty', { name: 'Speicherort Bild', desc: '', type: 'string', role: '',read: true, write: true });
       		setStateDelayed(devicename, bild, 800);
       		//Uptime setzen
       		devicename="Adapter.Adapter"+counter.toString()+".Uptime";
       		createState(devicename, 'empty', { name: 'Uptime', desc: '', type: 'string', role: '',read: true, write: true });
       		setStateDelayed(devicename, uptime, 800);
       		//MemUsed setzen
       		//devicename="Adapter.Adapter"+counter.toString()+".MemUsed";
       		//createState(devicename, 0, { name: 'Link MemUsed', desc: '', type: 'number', role: '',read: true, write: true });
       		//setStateDelayed(devicename, used, 800);
       		//MemToal setzen
       		//devicename="Adapter.Adapter"+counter.toString()+".MemTotal";
       		//createState(devicename, 0, { name: 'Link MemTotal', desc: '', type: 'number', role: '',read: true, write: true });
       		//setStateDelayed(devicename, total, 800);
       		//MemRSS setzen
       		//devicename="Adapter.Adapter"+counter.toString()+".MemRSS";
       		//createState(devicename, 0, { name: 'Link MemRSS', desc: '', type: 'number', role: '',read: true, write: true });
       		//setStateDelayed(devicename, rss, 800);
       		//Connected setzen
       		devicename="Adapter.Adapter"+counter.toString()+".Connected";
       		createState(devicename, 0, { name: 'Status Adapter', desc: '', type: 'number', role: '',read: true, write: true });
       		setStateDelayed(devicename, con, 800);
               //Wert zurücksetzen
               var manuell=0
       //Adaptet Icon Übersicht
       visstatus="javascript.0.VIS-Status.alle_adapter_gestartet";
       if(on == counter){setState(visstatus, true);}
       if(on == counter -1){setState(visstatus, true);}
       if(on < counter -1){setState(visstatus, false);}
       setStateDelayed('Adapter.Anzahl', counter, 800);
       function isState(strStatePath, strict) {
           let mSelector;
           if (strict) {
               mSelector = $('state[id=' + strStatePath + '$]');
           } else {
               mSelector = $('state[id=' + strStatePath + ']');
           if (mSelector.length > 0) {
               return true;
           } else {
               return false;
    on({id:"javascript.0.Adapter.AdapterNummer", change: 'any'}, function (dpobj) {
       if (getState("javascript.0.Adapter.AdapterNummer").val != 0) {
           const instanz = "javascript." + instance;
           var adapterNummer = getState(instanz + ".Adapter.AdapterNummer").val;
           var adapter = getState(instanz + ".Adapter.Adapter" + adapterNummer + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
           var idAdapter = "system.adapter." + adapter;
           var obj = getObject(idAdapter);
           if (dpobj.state.val == false) {
               obj.common.enabled = true;  // Adapter einschalten
           } else if (dpobj.state.val == true) {
               obj.common.enabled = false;  // Adapter ausschalten
           setObject(idAdapter, obj);
           setStateDelayed('javascript.0.Adapter.AdapterNummer', 0, 800);
    Bevor wir jetzt groß rumprobieren, nimm einfach mal diese Version
    KHK
    #418
    @Kuddel
    Habe dein eingestellte Script mal probiert, aber irgenwie werden nicht alle Daten gelesen...oder ist der Eintrag "object.object" richtig?
    • K KHK
      @Kuddel
      Kuddel
      #419
      @KHK ne da läuft was nicht richtig. Uptime und Connected werde nicht korrekt ausgelesen.
      Sieht das bei allen Adaptenr so aus?
      • K Kuddel
        KHK
        #420
        @Kuddel
        ja, deswegen war ich mir nicht ganz sicher...
        • K KHK
          @Kuddel
          Kuddel
          #421
          @KHK wie sehen deine Einstellungen von der Javascript Instanz aus ?
          K 2 Antworten Letzte Antwort
          • K Kuddel
            KHK
            #422
            @Kuddel Der Haken unter "Erlaube das Kommando "sendtohost" war nicht gesetzt. Habe das angepasst, aber keine Änderung.
            • K Kuddel
              KHK
              #423
              @Kuddel
              Habe im Log dies entdeckt:
              Wo könnte ich dies finden?
              • K KHK
                @Kuddel
                Kuddel
                #424
                @KHK die Warnung sagt nur aus, dass der Wert, der in die DPs geschrieben werden soll, den falschen Typ hat. Bei Uptime wird ein String erwartet und bei Connected eine Nummer
                • K Kuddel
                  KHK
                  schrieb am zuletzt editiert von KHK
                  #425
                  @Kuddel Ok, d.h. muss jetzt der DP jeweils an die zu erwartenden Wert angepasst werden? Wenn ja, wo kann ich das machen?
                  sri - meine Javascript /ioBroker Kenntnisse sind noch in den Anfängen...
                  • C Offline
                    Chris0680
                    schrieb am zuletzt editiert von Chris0680
                    #426
                    @Kuddel
                    Hallo Kuddel,
                    zuallererst einmal, danke für deine tolle Arbeit. Leider funktioniert bei mir die Steuerung der Heizung nicht. Umschaltbetrieb AUTO und MANU funktioniert nicht, Datenpunkt AUTO gewählt. Was für Heizkörperthermostate verwendest du? Ich verwende Homematic-Classic Thermostate.
                    Ich bitte um Hilfe, LG Chris
                    • K KHK
                      Kuddel
                      #427
                      @KHK wenn das Skript alle Werte korrekt auslesen kann, dann werden die auch korrekt in die Datenpunkte geschrieben.
                      Am besten nochmal das Skript stoppen, alle DPs löschen und dann das Skript neu starten
                      K C 2 Antworten Letzte Antwort
                      • C Chris0680
                        @Kuddel
                        Hallo Kuddel,
                        Kuddel
                        #428
                        @Chris0680 ich verwende auch die normalen Homematic Thermostate.
                        Ich habe immer den manuellen Betrieb ausgewählt und habe deswegen vllt. keine Probleme festgestellt.
                        Was genau funktioniert denn nicht ?
                        C 1 Antwort Letzte Antwort
                        • K Kuddel
                          KHK
                          #429
                          @Kuddel said in [Vorstellung] Meine dritte VIS:
                          Nee, leider nicht 😧 - nach der Löschung und den Neustart - endete es mit dem gleichem Ergebnis ....
                          • K Kuddel
                            Chris0680
                            #430
                            @Kuddel die Umschaltung von AUTO in den MAN Modus bzw. auch umgekehrt. Weiters fehlen mir die ICONS des Boost und Ein/Aus Schalter.
                            • K KHK
                              Kuddel
                              #431
                              @KHK dann bin ich jetzt leider auch überfragt, da ich das Skript nicht selber erstellt habe. Sorry
                              V 1 Antwort Letzte Antwort
                              • C Chris0680
                                Kuddel
                                schrieb am zuletzt editiert von Kuddel
                                #432
                                @Chris0680 habe mal eben das Umschalten ausprobiert.
                                Das ist tatsächlich ein Fehler drin.
                                Wenn man den Manu-Modus wieder aktivieren will, muss man direkt die Temperatur im DP setzen:
                                hm-rpc.0.LEQ123456ABCD.MANU_MODE
                                Danke für den Hinweis, werde ich mal direkt bei mir anpassten.
                                Die Icons werden bei dir nicht angezeigt, da in den Signalbildern eine Abhändigkeit zum Thermostat drin ist
                                • K Kuddel
                                  V Offline
                                  V Offline
                                  volx3eet
                                  #433
                                  @Kuddel Ich hab mich damit auch schon mal 5min beschäftigt - wie sieht deine Anpassung aus und wo machst du die?
                                  • V volx3eet
                                    Kuddel
                                    #434
                                    @volx3eet
                                    Beispielhaft meine korrigierten Widgets für meinen Heizkörper im Büro
                                    [{"tpl":"tplShapes","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","svgType":"square","strokeColor":"","fill":"#212121","strokeWidth":"5","scaleWidth":"1","scaleHeight":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"rotate":"45","name":"!_Hintergrund"},"style":{"left":"0px","top":"0px","background":"#212121","background-color":"#212121","z-index":"0","width":"380px","height":"250px","border-radius":"","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","font-family":"Arial, Helvetica, sans-serif"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Heizung","name":"!_Überschrift"},"style":{"left":"0px","top":"0px","height":"30px","width":"380px","z-index":"10","color":"white","text-align":"center","text-shadow":"","font-family":"Arial, Helvetica, sans-serif","font-style":"","font-variant":"","font-weight":"bolder","font-size":"20px","line-height":"30px","background":"grey"},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"oid":"hm-rpc.0.LEQ0850926.4.ACTUAL_TEMPERATURE","is_comma":"true","factor":"1","html_append_singular":" ºC","html_append_plural":" ºC","is_tdp":"false","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"1","name":"Aktuelle_Temp","g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"30px","top":"55px","width":"160px","height":"25px","color":"white","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"normal","font-size":"20px","z-index":"20","border-width":"1px","border-style":"none","border-color":"white","border-radius":"0px"},"widgetSet":"basic"},{"tpl":"tplValueString","data":{"oid":"hm-rpc.0.LEQ0850926.4.BOOST_STATE","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"3","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Boost_Zeit","html_append":" Min","visibility-oid":"hm-rpc.0.LEQ0850926.4.CONTROL_MODE"},"style":{"left":"190px","top":"225px","width":"70px","height":"15px","color":"red","text-align":"center","font-style":"normal","font-size":"medium","font-variant":"normal","font-weight":"bolder"},"widgetSet":"basic"},{"tpl":"tplHqButton","data":{"oid":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE","min":"4.5","max":"18","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":"4.5","signals-icon-0":"/icons-mfd-png/control_standby.png","signals-icon-size-0":"80","signals-blink-0":false,"signals-horz-0":"-30","signals-vert-0":"-30","signals-hide-edit-0":false,"signals-cond-1":"!=","signals-val-1":"4.5","signals-icon-1":"/icons-mfd-png/control_standby.png","signals-icon-size-1":"80","signals-blink-1":false,"signals-horz-1":"-30","signals-vert-1":"-30","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"pushButton":false,"usejQueryStyle":false,"g_visibility":false,"styleActive":"hq-button-no-background","name":"Modus_An_Aus","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","gestures-swipeLeft-limit":"-1","gestures-rotateLeft-limit":"2","styleNormal":"hq-button-no-background","testActive":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Side brush lifetime reset","descriptionLeftDisabled":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-oid-0":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE","signals-oid-1":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE","g_center":true,"iconName":"","btIconWidth":"56","offsetAuto":"true","leftOffset":"15","topOffset":"55"},"style":{"left":"275px","top":"165px","width":"50px","height":"50px","border-width":"3px","border-style":"solid","border-color":"{wert:hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE; wert!=\"4.5\" ? \"#212121\" : \"red\"}","border-radius":"10px","z-index":"20","text-align":"center","font-size":"small","box-shadow":"","background":"#303030","background-color":"#303030"},"widgetSet":"hqwidgets"},{"tpl":"tplIconState","data":{"oid":"hm-rpc.0.LEQ0850926.4.AUTO_MODE","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/time_automatic.svg","value":"true","name":"Modus_Auto"},"style":{"left":"50px","top":"165px","width":"50px","height":"50px","background":"#303030","background-color":"#303030","color":"","border-radius":"10px","border-width":"3px","box-shadow":"","z-index":"20","border-color":"{wert:hm-rpc.0.LEQ0850926.4.CONTRO_MODE; wert==\"0\" ? \"#41f316\" : \"#212121\"}","border-style":"solid"},"widgetSet":"jqui"},{"tpl":"tplIconState","data":{"oid":"hm-rpc.0.LEQ0850926.4.BOOST_MODE","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/icons-mfd-png/text_max.png","signals-icon-size-0":"70","signals-blink-0":true,"signals-horz-0":"-20","signals-vert-0":"-15","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"false","signals-icon-1":"/icons-mfd-png/text_max.png","signals-icon-size-1":"70","signals-blink-1":false,"signals-horz-1":"-20","signals-vert-1":"-15","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"","value":"true","text":"","name":"Modus_Boost","invert_icon":false,"signals-oid-0":"hm-rpc.0.LEQ0850926.4.BOOST_MODE","signals-oid-1":"hm-rpc.0.LEQ0850926.4.BOOST_MODE"},"style":{"left":"200px","top":"165px","width":"50px","height":"50px","background":"#303030","background-color":"#303030","color":"","border-radius":"10px","border-width":"3px","box-shadow":"","z-index":"30","line-height":"48px","border-style":"solid","border-color":"{wert:hm-rpc.0.LEQ0850926.4.BOOST_MODE; wert==\"true\" ? \"#41f316\" : \"#212121\"}"},"widgetSet":"jqui"},{"tpl":"tplIconState","data":{"oid":"hm-rpc.0.LEQ0850926.4.MANU_MODE","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/time_manual_mode.svg","value":"18","name":"Modus_Manuell"},"style":{"left":"125px","top":"165px","width":"50px","height":"50px","background":"#303030","background-color":"#303030","color":"","border-radius":"10px","border-width":"3px","box-shadow":"","z-index":"20","border-style":"solid","border-color":"{wert:hm-rpc.0.LEQ0850926.4.CONTROL_MODE; wert==\"1\" ? \"#41f316\" : \"#212121\"}"},"widgetSet":"jqui"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/temp_temperature.svg","name":"Temp_Icon"},"style":{"left":"50px","top":"45px","width":"40px","height":"40px","z-index":"100"},"widgetSet":"basic"},{"tpl":"tplIconInc","data":{"oid":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE","visibility-cond":"==","visibility-val":1,"repeat_delay":"800","repeat_interval":"800","src":"/icons-mfd-svg/control_plus.svg","step":"+0.5","minmax":"25","text":"","gestures-offsetX":0,"gestures-offsetY":"-1","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Temp_Plus"},"style":{"left":"240px","top":"90px","background":"#303030","width":"50px","height":"50px","z-index":"50","font-family":"RobotoCondensed-Light","background-color":"#303030","font-weight":"normal","border-width":"0px","border-radius":"10px","box-shadow":"","color":""},"widgetSet":"jqui"},{"tpl":"tplValueFloat","data":{"oid":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE","is_comma":"true","factor":"1","html_append_singular":" ºC","html_append_plural":" ºC","digits":"1","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"name":"Temp_Set","g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"0px","top":"90px","width":"380px","height":"50px","color":"white","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"bold","font-size":"22px","z-index":"20","box-shadow":"","line-height":"50px"},"widgetSet":"basic"},{"tpl":"tplIconInc","data":{"oid":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE","visibility-cond":"==","visibility-val":1,"repeat_delay":"800","repeat_interval":"800","src":"/icons-mfd-svg/control_minus.svg","step":"-0.5","minmax":"4.5","text":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-is-moment":false,"lc-zindex":0,"name":"Tep_Minus"},"style":{"left":"80px","top":"90px","background":"#303030","width":"50px","height":"50px","z-index":"25","font-family":"RobotoCondensed-Light","background-color":"#303030","font-weight":"normal","border-width":"0px","box-shadow":"","color":"","border-radius":"10px"},"widgetSet":"jqui"},{"tpl":"tplValueFloat","data":{"oid":"hm-rpc.0.LEQ0850926.4.VALVE_STATE","visibility-cond":"!=","visibility-val":"4.5","is_comma":true,"factor":"1","html_append_singular":" %","html_append_plural":" %","is_tdp":"false","gestures-offsetX":0,"gestures-offsetY":0,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS_v3/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"1","name":"Öffnung","visibility-oid":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE"},"style":{"left":"180px","top":"55px","width":"190px","height":"25px","color":"white","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-style":"normal","font-variant":"normal","font-weight":"normal","font-size":"20px","z-index":"20","border-width":"","border-style":"none","border-color":"","border-radius":""},"widgetSet":"basic"},{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"!=","visibility-val":"4.5","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/edit_settings.svg","name":"Öffnung_Icon","visibility-oid":"hm-rpc.0.LEQ0850926.4.SET_TEMPERATURE"},"style":{"left":"205px","top":"45px","width":"40px","height":"40px","z-index":"100"},"widgetSet":"basic"}]
                                    Edit: einfach in einen Editor kopieren und mit suchen und erstzen meine HM ID durch deine austauschen und dann alles importieren
                                    • K Kuddel
                                      @volx3eet
                                      V Offline
                                      V Offline
                                      volx3eet
                                      #435
                                      @Kuddel Danke dir!
                                      • K Kuddel
                                        Chris0680
                                        #436
                                        @Kuddel Umschaltung funktioniert jetzt, herzlichen Dank, aber leider nicht mit dem Wert welcher zuvor im AUTO-Modus war, ist aber auch egal. Ein anderes Problem ist, dass die Selektion des Modus nicht angezeigt wird, grüner Rahmen.
                                        LG
                                        • C Chris0680
                                          LG
                                          Kuddel
                                          #437
                                          @Chris0680 die Übernahme der Temperatur werde ich morgen noch einmal testen.
                                          Vllt. geht da was mit Binding.
                                          Bzgl. des grünen Rahmens schau dir mal die Einstellungen der Rahmenfarbe an. Vllt. ist da ein Fehler drin ?
                                          Evtl. noch meine HM ID ?
                                          EDIT: Hm das mitnehmen der einfestellten Temp von manu zu auto bzw. auto zu manu geht nur, wenn der Heizkörper aktiv ist. Sobald der Heizkörper aus ist, wird die eingestellte temp auf 4.5 Grad gesetzt
