  5. [gelöst] Temparatur Umzug Fhem
    5.3k
23 Beiträge 2 Kommentatoren 2.6k Aufrufe 1 Beobachtet
    @nolimitek sagte:
    Hat jemand eine Idee
    Bau mal eine Log-Ausgabe ein:
    Lässt sich der Aktor im Tab "Objekte" schalten ?
    N Offline
    N Offline
    nolimitek
    @paul53 ja kann ich schalten
    Das kommt dabei rauß
    22.12.2020, 17:53:52.013	[info ]: javascript.0 (4229) Stop script script.js.debug
    22.12.2020, 17:53:52.024	[info ]: javascript.0 (4229) Start javascript script.js.debug
    22.12.2020, 17:53:52.031	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.temperature, timerId=undefined) => {"val":"21.1","ack":true,"ts":1608655982096,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655982096}
    22.12.2020, 17:53:52.032	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.desiredTemperature, timerId=undefined) => {"val":"13.5","ack":true,"ts":1608655945660,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655944150}
    22.12.2020, 17:53:52.032	[info ]: javascript.0 (4229) script.js.debug: Temparatur:21.1Grad13.5
    22.12.2020, 17:53:52.032	[info ]: javascript.0 (4229) script.js.debug: registered 0 subscriptions and 0 schedules
    22.12.2020, 17:54:45.610	[info ]: javascript.0 (4229) Stop script script.js.debug
    22.12.2020, 17:54:45.622	[info ]: javascript.0 (4229) Start javascript script.js.debug
    22.12.2020, 17:54:45.634	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.temperature, timerId=undefined) => {"val":"21.1","ack":true,"ts":1608655982096,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655982096}
    22.12.2020, 17:54:45.634	[info ]: javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.desiredTemperature, timerId=undefined) => {"val":"5.0","ack":false,"ts":1608656079906,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1608656079906}
    22.12.2020, 17:54:45.635	[info ]: javascript.0 (4229) script.js.debug: Temparatur:21.1Grad5.0
    22.12.2020, 17:54:45.635	[info ]: javascript.0 (4229) script.js.debug: registered 0 subscriptions and 0 schedules
    N paul53P 2 Antworten Letzte Antwort
    • N nolimitek
      N Offline
      N Offline
      nolimitek
      gerade nochmals mit dem blockly probiert
      egal ob ich das Terhmostat rauf oder runter schalte es wird immer eingeschaltet
      • N nolimitek
        @nolimitek sagte:
        Wenn der Sollwert so niedrig ist (13,5 / 5,0 °C) muss der Aktor auf wahr schalten, denn Deine Aktion ist falsch herum. Richtig:
        Ist > Soll --> falsch
        EDIT: Liefert FHEM Zahlen? Bitte mittels Modifikation der Log-Ausgabe prüfen:
        N 2 Antworten Letzte Antwort
          @nolimitek sagte:
          N Offline
          N Offline
          nolimitek
          @paul53 wenn ich
          Richtig: Ist > Soll --> falsch mache un dich den wert von zb 5 Grad auf 24 Grad erhöhe als mehr als die Ist Temparatur schaltet er auf off.
            @nolimitek sagte:
            N Offline
            N Offline
            nolimitek
            @paul53 said in Temparatur Umzug Fhem:
            @nolimitek sagte:
            18:19:38.861	info	javascript.0 (4229) Start javascript script.js.debug
            18:19:38.868	info	javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.temperature, timerId=undefined) => {"val":"21.1","ack":true,"ts":1608655982096,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608655982096}
            18:19:38.868	info	javascript.0 (4229) script.js.debug: getState(id=fhem.0.MAX_167fd8.desiredTemperature, timerId=undefined) => {"val":"6.0","ack":true,"ts":1608657576366,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1608657576366}
            18:19:38.868	info	javascript.0 (4229) script.js.debug: Temparatur:stringGradstring
            18:19:38.869	info	javascript.0 (4229) script.js.debug: registered 0 subscriptions and 0 schedules
            • N nolimitek
              @nolimitek sagte:
              @nolimitek
              Mit Strings kann es nicht funktionieren. Man muss in Zahlen wandeln:
              N 1 Antwort Letzte Antwort
                @nolimitek
                N Offline
                N Offline
                nolimitek
                @paul53 Wennst mir jetzt noch kurz schreiben könntest wo ich den Block "setze .... auf" finde.
                Seh langsam nichts mehr :-)
                • N nolimitek
                  @nolimitek sagte:
                  Unter "Variablen" müssen erst die 3 Variablen ist, soll, ein erstellt werden. Dann wird dort auch "setze auf" angeboten.
                    @nolimitek sagte:
                    N Offline
                    N Offline
                    nolimitek
                    @paul53 Besten Dank für deine Hilfe. Ich hatte das mal schon testweise gemacht da braucht ich aber die umrechnung auf zahlen nicht. Daher brachte mich das gerade fast zu wahnsinn :-)
                    Jetzt gehts auf alle Fälle
                    lg
                    Christian
                    • N nolimitek
                      lg
                      Christian
                      @nolimitek sagte:
                      Jetzt gehts
                      Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
