  4. Restore schlägt fehl
    6.7k
restore backup
178 Beiträge 5 Kommentatoren 18.9k Aufrufe 2 Beobachtet
  • L LJSven
    @Thomas-Braun sagte in Restore schlägt fehl:
    @LJSven Die Kiste läuft ja noch in runlevel 5.
    Wolltest du das nicht auf RL3 umstellen?
    Was muss ich da machen? Sorry Leute, ich bin kein Profi!
    Jan1
    @LJSven
    Wurde oben schon mal genannt ;)
    • L LJSven
      sudo systemctl get-default
      sudo systemctl list-units --type=target
      sudo systemctl set-default multi-user.target
      Wenn beim letzten Befehl was mit Multiuser steht, dann reboot. Dann sollte da immer noch Multiuser kommen.
      L 1 Antwort Letzte Antwort
        LJSven
        pi@tinkerboardmaster:~$ sudo systemctl get-default
        [sudo] Passwort für pi:
        graphical.target
        pi@tinkerboardmaster:~$ sudo systemctl list-units --type=target
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        basic.target          loaded active active Basic System
        bluetooth.target      loaded active active Bluetooth
        cryptsetup.target     loaded active active Encrypted Volumes
        getty.target          loaded active active Login Prompts
        graphical.target      loaded active active Graphical Interface
        local-fs-pre.target   loaded active active Local File Systems (Pre)
        local-fs.target       loaded active active Local File Systems
        multi-user.target     loaded active active Multi-User System
        network-online.target loaded active active Network is Online
        network.target        loaded active active Network
        nfs-client.target     loaded active active NFS client services
        paths.target          loaded active active Paths
        remote-fs-pre.target  loaded active active Remote File Systems (Pre)
        remote-fs.target      loaded active active Remote File Systems
        rpcbind.target        loaded active active RPC Port Mapper
        slices.target         loaded active active Slices
        sockets.target        loaded active active Sockets
        sound.target          loaded active active Sound Card
        swap.target           loaded active active Swap
        sysinit.target        loaded active active System Initialization
        time-sync.target      loaded active active System Time Synchronized
        timers.target         loaded active active Timers
        22 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        pi@tinkerboardmaster:~$ sudo systemctl set-default multi-user.target
        Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
        multi-user.target
        • L LJSven
          graphical.target
          multi-user.target
          @LJSven Okay, jetzt sollte das System immer nur bis zur Kommandozeile booten. Probier mal aus
            LJSven
            Svens-MacBook-Pro:~ Sven$ ssh pi@192.168.178.15
            pi@192.168.178.15's password:
             _____ _       _             _                         _
            |_   _(_)_ __ | | _____ _ __| |__   ___   __ _ _ __ __| |
              | | | | '_ \| |/ / _ \ '__| '_ \ / _ \ / _` | '__/ _` |
              | | | | | | |   <  __/ |  | |_) | (_) | (_| | | | (_| |
              |_| |_|_| |_|_|\_\___|_|  |_.__/ \___/ \__,_|_|  \__,_|
            Welcome to Debian Stretch with Armbian Linux 4.19.69-rockchip
            System load:   3.07 0.86 0.29  	Up time:       1 min
            Memory usage:  34 % of 2002MB 	IP:            192.168.178.15
            CPU temp:      71°C
            Usage of /:    34% of 30G
            Last login: Tue Dec 15 09:38:08 2020 from 192.168.178.201
            pi@tinkerboardmaster:~$ htop
            pi@tinkerboardmaster:~$ who -r
                     Runlevel 3   2020-12-15 09:40
            Thomas BraunT J 2 Antworten Letzte Antwort
            • L LJSven
               _____ _       _             _                         _
              CPU temp:      71°C
              @LJSven Gut, jetzt bist du schon mal den ganzen Overhead vom Desktop/X server los.
                LJSven
                Okay - ein Backup lässt sich aber nach wie vor nicht durchführen :-(
                Log Backitup Restore:
                [DEBUG] [iobroker] Start ioBroker Restore ...
                [DEBUG] [iobroker] iobroker controller daemon is not running
                [DEBUG] [iobroker] host.tinkerboardmaster OK.
                [DEBUG] [iobroker] <--- Last few GCs --->
                [DEBUG] [iobroker] [11236:0x235ebc8] 37457 ms: Mark-sweep 502.3 (503.8) -> 502.3 (503.8) MB, 231.9 / 0.0 ms (average mu = 0.148, current mu = 0.000) last resort GC in old space requested
                [DEBUG] [iobroker] [11236:0x235ebc8] 37753 ms: Mark-sweep 502.3 (503.8) -> 502.3 (503.8) MB, 295.9 / 0.0 ms (average mu = 0.087, current mu = 0.000) last resort GC in old space requested
                [DEBUG] [iobroker] <--- JS stacktrace --->
                [DEBUG] [iobroker] ==== JS stack trace =========================================
                [DEBUG] [iobroker] Security context: 0x5decea21
                [DEBUG] [iobroker] 0: builtin exit frame: parse(this=0x5dec65a9 ,0x4ec0b9d1 ,0x5dec65a9 )
                [DEBUG] [iobroker] 1: restoreAfterStop [0x5280ca19] [/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:627] [bytecode=0x544f7b15 offset=168](this=0x257def6d ,0x33bc03c1 ,0x257df67d
                [ERROR] [iobroker] FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
                [DEBUG] [iobroker] ioBroker Restore completed successfully
                [EXIT] null **** Restore was canceled!! ****
                The log can be closed ...
                • L LJSven
                   _____ _       _             _                         _
                  CPU temp:      71°C
                  Jan1
                  @LJSven
                  Hast den IOBroker Ordner gelöscht und wird das nun mit dem Adapter restored?
                  • L LJSven
                    @LJSven
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      @LJSven
                      LJSven
                      schrieb am zuletzt editiert von LJSven
                      pi@tinkerboardmaster:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      v12.20.0
                      /usr/bin/node
                      v12.20.0
                      /usr/bin/npm
                      6.14.8
                      nodejs:
                        Installiert:           12.20.0-1nodesource1
                        Installationskandidat: 12.20.0-1nodesource1
                        Versionstabelle:
                       *** 12.20.0-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                           8.11.1~dfsg-2~bpo9+1 100
                              100 http://httpredir.debian.org/debian stretch-backports/main armhf Packages
                           4.8.2~dfsg-1 500
                              500 http://httpredir.debian.org/debian stretch/main armhf Packages
                      • J Jan1
                        @LJSven
                        LJSven
                        @Jan1 sagte in Restore schlägt fehl:
                        @LJSven
                        Nein, daß habe ich noch nicht gemacht.
                        • L LJSven
                          @LJSven
                          @LJSven
                          free -h
                          Kann aber auch sein, dass das backup korrupt ist.
                          L 2 Antworten Letzte Antwort
                            @LJSven
                            free -h
                            LJSven
                            free -h
                            pi@tinkerboardmaster:~$ free -h
                            Mem:           2,0G        1,2G        304M        2,8M        449M        890M
                            Swap:          1,0G        768K        1,0G
                              @LJSven
                              free -h
                              LJSven
                              @LJSven
                              free -h
                              Wenn ich das backup von vorgestern nehme, kommt folgende Meldung
                              [DEBUG] [iobroker] tart of marking 381 ms) (average mu = 0.336, current mu = 0.103) allocation f[14934:0x2cc5bc8] 19107 ms: Mark-sweep 505.1 (506.2) -> 505.1 (507.5) MB, 272.8 / 0.0 ms (+ 77.4 ms in 18 steps since start of marking, biggest step 8.3 ms, walltime since start of marking 373 ms) (average mu = 0.230, current mu = 0.083) allocation fa[14934:0x2cc5bc8] 19522 ms: Mark-sweep 506.5 (507.5) -> 506.7 (508.2) MB, 391.7 / 0.0 ms (average mu = 0.147, current mu = 0.057) allocation failure scavenge might not succeed
                              [DEBUG] [iobroker] Cannot get stack trace in GC.
                              [ERROR] [iobroker] FATAL ERROR: MarkCompactCollector: semi-space copy, fallback in old gen Allocation failed - JavaScript heap out of memory
                              • L LJSven
                                @UncleSam Das ist ein Tinkerboard / das System läuft eigentlich seit einem Jahr. Gestern habe ich ein System Update gemacht. Vermutlich nimmt sich da einer Resourcen. Wie kann ich vorgehen? Selbst wenn der Tinkerboard neu gestartet wurde, lässt sich das Update nicht installieren. Der Iobroker läuft, aber nach dem Neustart fehlen Werte in Datenpunkten. Deshalb wollte ich ein Backup einspielen. Oder gibt es eine andere Möglichkeit die Werte wieder zu bekommen. Habe das Problem gelegentlich, wenn nicht ordentlich neu gestartet wird.
                                @LJSven sagte in Restore schlägt fehl:
                                Das hat doch 2GB RAM!?
                                Meine Tinkerboards laufen mit Armbian ohne jegliche Probleme
                                • L LJSven
                                  @LJSven
                                  free -h
                                  Jan1
                                  @LJSven
                                  Was geht denn eigentlich nicht, außer die etwas schräge Methode ein Backup zu restoren?
                                  Kann man vielleicht auch so flicken, bevor der IOBroker Ordner gelöscht wird und keiner weiß ob Deine Backups überhaupt funktionieren.
                                    LJSven
                                    @Homoran sagte in Restore schlägt fehl:
                                    Meins auch - bis ich gestern ein system Update gemacht habe.
                                    J Thomas BraunT 2 Antworten Letzte Antwort
                                    • L LJSven
                                      Jan1
                                      @LJSven
                                      Dann poste doch mal die Probleme und Logfiles dazu .
                                      • J Jan1
                                        @LJSven
                                        LJSven
                                        @LJSven
                                        Es fehlen die Werte in verschiedenen Datenpunkten. Bisher konnte ich es immer fixen, in dem ich ein Backup eingespielt habe.
                                        J HomoranH 2 Antworten Letzte Antwort
                                        • L LJSven
                                          @LJSven
                                          Jan1
                                          @LJSven
                                          Was wurde upgedatet und sind das Werte die von Deinem Slave kommen?
