  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ModBus
Драйвер ModBus
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
174 Beiträge 25 Kommentatoren 70.3k Aufrufe 2 Beobachtet
    MSapogov
    @Bluefox:
    @MSapogov:
    Что-то покраснел modbus при выборе TCP и master.
    host-Bee-IoT	2016-10-18 21:07:39.679	info	Restart adapter system.adapter.modbus.0 because enabled
    host-Bee-IoT	2016-10-18 21:07:39.679	error	instance system.adapter.modbus.0 terminated with code 0 (OK)
    modbus-0	2016-10-18 21:07:39.671	info	terminating
    RangeError:	2016-10-18 21:07:39.651	error	at Socket.Readable.push (_stream_readable.js:111:10)
    RangeError:	2016-10-18 21:07:39.651	error	at readableAddChunk (_stream_readable.js:153:18)
    RangeError:	2016-10-18 21:07:39.651	error	at Socket.emit (events.js:169:7)
    RangeError:	2016-10-18 21:07:39.651	error	at emitOne (events.js:77:13)
    RangeError:	2016-10-18 21:07:39.651	error	at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-tcp-client.js:129:22)
    RangeError:	2016-10-18 21:07:39.651	error	at Object.emit (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit-event-bus/src/stampit-event-bus.js:20:38)
    RangeError:	2016-10-18 21:07:39.651	error	at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-client-core.js:135:17)
    RangeError:	2016-10-18 21:07:39.651	error	at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-client-core.js:91:33)
    RangeError:	2016-10-18 21:07:39.651	error	at Buffer.readUInt8 (buffer.js:718:5)
    RangeError:	2016-10-18 21:07:39.651	error	at checkOffset (buffer.js:680:11)
    RangeError:	2016-10-18 21:07:39.651	error	index out of range
    uncaught	2016-10-18 21:07:39.651	error	exception: index out of range
    modbus-0	2016-10-18 21:07:39.620	info	Connected to slave 192.168.11.205
    modbus-0	2016-10-18 21:07:39.565	warn	Serial is not available
    modbus-0	2016-10-18 21:07:39.561	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
    host-Bee-IoT	2016-10-18 21:07:39.136	info	instance system.adapter.modbus.0 started with pid 23265
    host-Bee-IoT	2016-10-18 21:07:26.437	info	Restart adapter system.adapter.modbus.0 because enabled
    host-Bee-IoT	2016-10-18 21:07:26.437	error	instance system.adapter.modbus.0 terminated with code 0 (OK)
    uncaught	2016-10-18 21:07:26.423	error	exception: index out of range
    modbus-0	2016-10-18 21:07:26.403	info	Connected to slave 192.168.11.205
    modbus-0	2016-10-18 21:07:26.353	warn	Serial is not available
    А настройки? Адреса? Тип адресов? `
    IP адрес партнера: 192.168.11.205
    Порт: 502
    ID устройства: 5
    Тип: Master
    В шлюзе ничего не менялось.
    • BluefoxB Offline
      BluefoxB Offline
      @MSapogov:
      Порт: 502
      ID устройства: 5
      Тип: Master
      В шлюзе ничего не менялось. `
      Какой адрес и какой тип регистра. Какой максимальный и какой минимальный адреса для данного типа регистра?
        MSapogov
        @Bluefox:
        @MSapogov:
        Порт: 502
        ID устройства: 5
        Тип: Master
        В шлюзе ничего не менялось. Какой адрес и какой тип регистра. Какой максимальный и какой минимальный адреса для данного типа регистра?
        ??? Только Holding (40001-40009)
        Опрос 200 мс.
        • BluefoxB Offline
          BluefoxB Offline
          @MSapogov:
          @Bluefox:
          @MSapogov:
          Порт: 502
          ID устройства: 5
          Тип: Master
          Опрос 200 мс. `
          Я надеюсь с Aliases?
          А лучше скрин настроек и страницы с регистрами
            MSapogov
            @Bluefox:
            @MSapogov:
            @Bluefox:
            Какой адрес и какой тип регистра. Какой максимальный и какой минимальный адреса для данного типа регистра? `
            Опрос 200 мс. `
            А лучше скрин настроек и страницы с регистрами `
            Да с ними.
            Может я в настройках что не учел…
              MSapogov
              @dito85:
              @MSapogov:
              Правильно ли я понял, что в этой связке я не подключу еще устройства на шину RS-485.
              Даже создав новый драйвер modbus.1 и указав в нем то-же IP 192.168.11.205, только изменив ID устройства например на 10, у меня уже неполучается считать данный с 10-го устройства.
              Выходит что для каждого устройства нужен свой Modbus TCP to Modbus RTU шлюз.
              А если в качестве мастера будет Modbus TCP to Modbus RTU шлюз, то как в этом случае настраивать драйвер? `
              Вы, видимо, не совсем разобрались в настройках и принципах работы самого шлюза. Шлюз, как бы, состоит из двух устройств:
              1. ModBus RTU master -который опрашивает и управляет устройствами на линии 485 (я подключал 6 устройств). Причем опрос устройств на стороне RTU происходит независимо от запросов со стороны TCP(скорость опроса, сами запросы настраиваются в шлюзе) . Ответы от каждого устройства записываются в определенный участок памяти.
              2. ModBus TCP slave - устройство, которое и должно отвечать вашему IOB, это устройство видит ту же область памяти что и ModBus RTU. Поэтому в IOB достаточно одного экземпляра драйвера ModBus TCP. Просто обращайтесь к определенному участку памяти где лежат данные от нужного устройства.
              P.S. На стороне TCP данный шлюз, так же поддерживает GET запросы, которыми можно управлять и опрашивать устройства на стороне RTU. `
              У меня пока 2 устройства RTU c ID 5 и ID 10 у обоих только Holding 40001-40009. Опрос 2 раза секунду.
              Подскажите, как правильно настроить ESP , что-бы можно было использовать 1 экземпляр драйвера на IOB.
              И как тогда в IOB правильно прописать 2 устройства 5 и 10.
                dito85
                @MSapogov:
                И как тогда в IOB правильно прописать 2 устройства 5 и 10. `
                Чтобы подсказать, нужно знать какие используются девайсы, какие у них настройки связи (скорость, четность, и т.д.).
                Сразу скажу, что если эти два девайса сделаны на основе Arduino и используется стандартная библиотека ModBus slave, то в настройках ESP ставьте очень большое время ожидания ответа, потому как стандартная библиотека работает очень медленно и не соответствует стандарту в 3,5 символа.
                Так же правильно настройте транзакторы. Подробное описание настройки ESP есть на соответствующем форуме.
                  dito85
                  Не стал дожидаться посылки из Китая. Сделал опрос по ModBus TCP из IOB (опрашивается программный ModBus Slave).
                  Первое на что обратил внимание, это смещение адресов в Coils и discreteinputs. Например в slave взвожу coil с адресом 3, а в IOB взводится coil с адресом 1
                  • BluefoxB Offline
                    BluefoxB Offline
                    @dito85:
                    Первое на что обратил внимание, это смещение адресов в Coils и discreteinputs. Например в slave взвожу coil с адресом 3, а в IOB взводится coil с адресом 1 `
                    В modbus есть два типа адресации. Прямые адреса от 0 до 65536 плюс тип регИстра или так называемые Aliases: например Coils от 1 до 1000
                    Потом есть устройства, где адреса перевернуты при Aliases, а где нет.
                    Вопрос: Aliases или нет.
                    • BluefoxB Offline
                      BluefoxB Offline
                      ` > У меня пока 2 устройства RTU c ID 5 и ID 10 у обоих только Holding 40001-40009. Опрос 2 раза секунду.
                      Для каждого Slave надо свою инстанцию заводить в iob. Как настраивать esp я не знаю, но вижу, что это rtu over tcp, а это пока не поддерживается.
                      Можешь сделать запись wireshark? Я проверил твои настройки с симулятором, работает.
                        MSapogov
                        @Bluefox:
                        Можешь сделать запись wireshark? Я проверил твои настройки с симулятором, работает. `
                        Я понял, что Modbus TCP для меня пока не по силам. Решил испытать себя в Modbus RTU.
                        Выбрал в настройке драйвера Serial. А вот порт не ввести не выбрать на дает (нажимаю на треугольничке, а ничего не вылазиет).
                        Лог установки на ESXi (Ubuntu 14.04 LTS). Драйвер есть, в настройках нет выбора COM порта.
                        $ ./iobroker url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus --debug
                        install https://github.com/ioBroker/ioBroker.modbus/tarball/master
                        npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --prefix "/opt/iobroker" (System call)
                        serialport@2.1.2 install /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport
                        node-pre-gyp install --fallback-to-build
                        ! module.js:327
                        throw err;
                        ! Error: Cannot find module 'nopt' at Function.Module._resolveFilename (module.js:325:15)
                        at Function.Module._load (module.js:276:25)
                        at Module.require (module.js:353:17)
                        at require (internal/module.js:12:17)
                        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/node_modules/node-pre-gyp/lib/node-pre-gyp.js:14:12)
                        at Module._compile (module.js:409:26)
                        at Object.Module._extensions..js (module.js:416:10)
                        at Module.load (module.js:343:32)
                        at Function.Module._load (module.js:300:12)
                        ! at Module.require (module.js:353:17)
                        npm
                        WARN
                        optional dep failed, continuing
                        serialport@2.1.2
                        serialport@4.0.3 install /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
                        ! [serialport] Success: "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node" is installed via remote
                        iobroker.modbus@0.4.0 opt/iobroker/node_modules/iobroker.modbus├── stampit-log@0.3.0
                        ├── stampit-state-machine@0.2.1
                        ├── stampit-event-bus@0.1.1
                        ├── put@0.0.6
                        ├── stampit@2.1.2 (supermixer@1.0.3, lodash@3.10.1)
                        └── jsmodbus@1.2.4 (q@1.0.1, crc@3.4.0, serialport@4.0.3)
                        ! got /opt/iobroker/node_modules/iobroker.modbus/admin
                        upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                        upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript
                        upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
                        upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
                        upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
                        upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
                        upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
                        upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
                        upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
                        upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html
                        upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png
                        process exited with code 0</anonymous>
                        Переходник на виртуалке lsusb
                        Bus 002 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
                        Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
                        Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
                        Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                        Порты на виртуалке ls -l /dev/ttyS* /dev/ttyUSB*
                        crw-rw---- 1 root dialout   4, 64 окт 19 13:29 /dev/ttyS0
                        crw-rw---- 1 root dialout   4, 65 окт 19 13:29 /dev/ttyS1
                        crw-rw---- 1 root dialout   4, 74 окт 19 13:29 /dev/ttyS10
                        crw-rw---- 1 root dialout   4, 75 окт 19 13:29 /dev/ttyS11
                        crw-rw---- 1 root dialout   4, 76 окт 19 13:29 /dev/ttyS12
                        crw-rw---- 1 root dialout   4, 77 окт 19 13:29 /dev/ttyS13
                        crw-rw---- 1 root dialout   4, 78 окт 19 13:29 /dev/ttyS14
                        crw-rw---- 1 root dialout   4, 79 окт 19 13:29 /dev/ttyS15
                        crw-rw---- 1 root dialout   4, 80 окт 19 13:29 /dev/ttyS16
                        crw-rw---- 1 root dialout   4, 81 окт 19 13:29 /dev/ttyS17
                        crw-rw---- 1 root dialout   4, 82 окт 19 13:29 /dev/ttyS18
                        crw-rw---- 1 root dialout   4, 83 окт 19 13:29 /dev/ttyS19
                        crw-rw---- 1 root dialout   4, 66 окт 19 13:29 /dev/ttyS2
                        crw-rw---- 1 root dialout   4, 84 окт 19 13:29 /dev/ttyS20
                        crw-rw---- 1 root dialout   4, 85 окт 19 13:29 /dev/ttyS21
                        crw-rw---- 1 root dialout   4, 86 окт 19 13:29 /dev/ttyS22
                        crw-rw---- 1 root dialout   4, 87 окт 19 13:29 /dev/ttyS23
                        crw-rw---- 1 root dialout   4, 88 окт 19 13:29 /dev/ttyS24
                        crw-rw---- 1 root dialout   4, 89 окт 19 13:29 /dev/ttyS25
                        crw-rw---- 1 root dialout   4, 90 окт 19 13:29 /dev/ttyS26
                        crw-rw---- 1 root dialout   4, 91 окт 19 13:29 /dev/ttyS27
                        crw-rw---- 1 root dialout   4, 92 окт 19 13:29 /dev/ttyS28
                        crw-rw---- 1 root dialout   4, 93 окт 19 13:29 /dev/ttyS29
                        crw-rw---- 1 root dialout   4, 67 окт 19 13:29 /dev/ttyS3
                        crw-rw---- 1 root dialout   4, 94 окт 19 13:29 /dev/ttyS30
                        crw-rw---- 1 root dialout   4, 95 окт 19 13:29 /dev/ttyS31
                        crw-rw---- 1 root dialout   4, 68 окт 19 13:29 /dev/ttyS4
                        crw-rw---- 1 root dialout   4, 69 окт 19 13:29 /dev/ttyS5
                        crw-rw---- 1 root dialout   4, 70 окт 19 13:29 /dev/ttyS6
                        crw-rw---- 1 root dialout   4, 71 окт 19 13:29 /dev/ttyS7
                        crw-rw---- 1 root dialout   4, 72 окт 19 13:29 /dev/ttyS8
                        crw-rw---- 1 root dialout   4, 73 окт 19 13:29 /dev/ttyS9
                        crw-rw---- 1 root dialout 188,  0 окт 19 13:29 /dev/ttyUSB0
                        Что-то не везет мне. А так хочется насосы и датчики в теплице по modbus включить… но до весны еще далеко... разберусь.
                        • BluefoxB Offline
                          BluefoxB Offline
                          А драйвер запущен? В логе есть что нибудь при уровне Debug?
                            dito85
                            @Bluefox:
                            @dito85:
                            Вопрос: Aliases или нет. `
                            Посмотрел запросы, которые шлет IOB при опросе Coils и discreteinputs. Независимо от количества и адресов переменных. Запрос всегда выглядит одинаково - 10 регистров с нулевого адреса.
                            • BluefoxB Offline
                              BluefoxB Offline
                              @dito85:
                              @Bluefox:
                              @dito85:
                              Посмотрел запросы, которые шлет IOB при опросе Coils и discreteinputs. Независимо от количества и адресов переменных. Запрос всегда выглядит одинаково - 10 регистров с нулевого адреса. `
                              В wireshark видны только прямые адреса. И iob перекодирует Aliases в прямые адреса при запросе.
                                MSapogov
                                @Bluefox:
                                А драйвер запущен? В логе есть что нибудь при уровне Debug? `
                                Уж не помню где дебаг включается в новой админке…
                                modbus-0 2016-10-19 14:27:50.315 info terminating
                                RangeError: 2016-10-19 14:27:50.302 error at Socket.Readable.push (_stream_readable.js:111:10)
                                RangeError: 2016-10-19 14:27:50.302 error at readableAddChunk (_stream_readable.js:153:18)
                                RangeError: 2016-10-19 14:27:50.302 error at Socket.emit (events.js:169:7)
                                RangeError: 2016-10-19 14:27:50.302 error at emitOne (events.js:77:13)
                                RangeError: 2016-10-19 14:27:50.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-tcp-client.js:129:22)
                                RangeError: 2016-10-19 14:27:50.302 error at Object.emit (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit-event-bus/src/stampit-event-bus.js:20:38)
                                RangeError: 2016-10-19 14:27:50.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-client-core.js:135:17)
                                RangeError: 2016-10-19 14:27:50.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-client-core.js:91:33)
                                RangeError: 2016-10-19 14:27:50.302 error at Buffer.readUInt8 (buffer.js:718:5)
                                RangeError: 2016-10-19 14:27:50.302 error at checkOffset (buffer.js:680:11)
                                RangeError: 2016-10-19 14:27:50.302 error index out of range
                                uncaught 2016-10-19 14:27:50.301 error exception: index out of range
                                modbus-0 2016-10-19 14:27:50.292 info Connected to slave 192.168.11.205
                                modbus-0 2016-10-19 14:27:50.239 warn Serial is not available
                                modbus-0 2016-10-19 14:27:50.235 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
                                host-Bee-IoT 2016-10-19 14:27:49.803 info instance system.adapter.modbus.0 started with pid 4679
                                host-Bee-IoT 2016-10-19 14:27:47.318 info instance system.adapter.modbus.0 terminated with code 0 (OK)
                                modbus-0 2016-10-19 14:27:47.307 info terminating
                                host-Bee-IoT 2016-10-19 14:27:47.298 info stopInstance system.adapter.modbus.0 killing pid 4668
                                host-Bee-IoT 2016-10-19 14:27:47.298 info object change system.adapter.modbus.0
                                modbus-0 2016-10-19 14:27:39.556 warn Module serialport is not available
                                modbus-0 2016-10-19 14:27:12.621 info Connected to slave 192.168.11.205
                                modbus-0 2016-10-19 14:27:12.571 warn Serial is not available
                                modbus-0 2016-10-19 14:27:12.567 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.modbus
                                host-Bee-IoT 2016-10-19 14:27:12.129 info instance system.adapter.modbus.0 started with pid 4668
                                host-Bee-IoT 2016-10-19 14:27:12.126 info object change system.adapter.modbus.0
                                host-Bee-IoT 2016-10-19 14:27:09.269 info object change system.adapter.modbus.0
                                host-Bee-IoT 2016-10-19 14:26:36.974 info object change system.adapter.modbus.0
                                host-Bee-IoT 2016-10-19 14:16:51.782 info Do not restart adapter system.adapter.modbus.0 because disabled or deleted
                                host-Bee-IoT 2016-10-19 14:16:51.782 error instance system.adapter.modbus.0 terminated with code 3 (Adapter disabled or invalid config)
                                host-Bee-IoT 2016-10-19 14:16:38.916 info object change system.adapter.modbus.0
                                host-Bee-IoT 2016-10-19 14:16:21.327 info Restart adapter system.adapter.modbus.0 because enabled
                                host-Bee-IoT 2016-10-19 14:16:21.327 error instance system.adapter.modbus.0 terminated with code 0 (OK)
                                Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:773:21
                                Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.modbus/main.js:1150:13
                                Error: 2016-10-19 14:16:21.302 error at clear (/opt/iobroker/node_modules/iobroker.modbus/main.js:1147:22)
                                Error: 2016-10-19 14:16:21.302 error at Object.main.start (/opt/iobroker/node_modules/iobroker.modbus/main.js:1631:53)
                                Error: 2016-10-19 14:16:21.302 error at Object.Factory [as complete] (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:177:48)
                                Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/createForEach.js:15:9
                                Error: 2016-10-19 14:16:21.302 error at arrayEach (/opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/node_modules/lodash/internal/arrayEach.js:15:9)
                                Error: 2016-10-19 14:16:21.302 error at /opt/iobroker/node_modules/iobroker.modbus/node_modules/stampit/dist/stampit.js:185:31
                                Error: 2016-10-19 14:16:21.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:119:9)
                                Error: 2016-10-19 14:16:21.302 error at Object. (/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/src/modbus-serial-client.js:19:23)
                                Error: 2016-10-19 14:16:21.302 error No portname.
                                uncaught 2016-10-19 14:16:21.301 error exception: No portname.
                                modbus-0 2016-10-19 14:16:21.234 warn Serial is not available
                                Если удаляю драйвер, а затем его ставлю вновь, то список с COM портами раскрывается (на выбор "Выбирите порт" и "Not available")
                                Если сохранить изменения и снова зайти в настройки, то выбора уже никакого нет.
                                А поддерживаются только ttyS* порты, или ttyUSB* тоже?
                                  dito85
                                  @Bluefox:
                                  Для каждого Slave надо свою инстанцию заводить в iob. Как настраивать esp я не знаю, но вижу, что это rtu over tcp, а это пока не поддерживается. `
                                  Нет в ESP не rtu over tcp, там именно ModBus TCP. Драйвер ModBusTCP в IOB опрашивает ESP без проблем
                                  • H Offline
                                    Haus
                                    @MSapogov:
                                    @Bluefox:
                                    А драйвер запущен? В логе есть что нибудь при уровне Debug? Уж не помню где дебаг включается в новой админке…
                                    Настройки драйверов_режим эксперта_уровень_debug
                                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                    admin: 3.6.0
                                    javascript: 4.1.10
                                    web: 2.4.1 vis: 1.1.10
                                    cloud: 2.6.2
                                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                                    Adapter: MegaD-2561, Mega-ES…
                                      dito85
                                      @Bluefox:
                                      @dito85:
                                      @Bluefox:
                                      В wireshark видны только прямые адреса. И iob перекодирует Aliases в прямые адреса при запросе. `
                                      Попробую объяснить… например, в IOB, я задаю опрашивать три подряд Holding регистра начиная с адреса X (не важно aliases или нет), в запросе от IOB я вижу, что стартовый адрес X и длина запрашиваемых регистров равна трем. Если же я запрашиваю, например, три Coils регистра, то в запросе от IOB я всегда вижу, что стартовый адрес 00 и длина запрашиваемых регистров равна 10. Всегда!!! Даже если я добавлю 15 переменных в Coils, запрос всегда одинаковый.
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        @MSapogov:
                                        @Bluefox:
                                        А поддерживаются только ttyS* порты, или ttyUSB* тоже? `
                                        Я уже вижу
                                        А build-essential поставлены?
                                        cd /opt/iobroker
                                        sudo apt-get install build-essential
                                        iobroker stop modbus
                                        npm install iobroker.modbus
                                        iobroker start modbus
                                          MSapogov
                                          #66
                                          @Bluefox:
                                          @MSapogov:
                                          @Bluefox:
                                          Я уже вижу
                                          А build-essential поставлены? `
                                          А как-же без нее
                                          build-essential is already the newest version (12.1ubuntu2).
                                          При дебаге есть не обльшие отличия…
                                          modbus-0	2016-10-19 15:06:44.372	debug	statesDB connected
                                          modbus-0	2016-10-19 15:06:44.366	debug	objectDB connected
                                          host-Bee-IoT	2016-10-19 15:06:44.036	info	instance system.adapter.modbus.0 started with pid 5312
                                          host-Bee-IoT	2016-10-19 15:06:44.032	info	object change system.adapter.modbus.0
                                          host-Bee-IoT	2016-10-19 15:06:36.076	info	Restart adapter system.adapter.modbus.0 because enabled
                                          host-Bee-IoT	2016-10-19 15:06:36.076	error	instance system.adapter.modbus.0 terminated with code 0 (OK)
                                          modbus-0	2016-10-19 15:06:36.067	info	terminating
                                          inMem	2016-10-19 15:06:36.062	debug	message modbus.0.* modbus.0.info.connection val=false, ack=true, ts=1476864396059, q=0, from=system.adapter.modbus.0, lc=1476864395998
                                          В npm install iobroker.modbus - старый!!!
                                          Ставлю с гита.
