Sleeptimer mit Countdown
würde dir ja gerne helfen, zumal es bei mir direkt funktionierte.
Aber ohne zu wissen was genau nicht funktioniert ist das schwer.
Was genau funktioniert denn nicht? gibt es Einträge im Log?
Eventuell helfen auch Screenshots weiter?
Hier meine Widgets… Sie unterscheiden sich aber fast gar nicht von deinen!
[{"tpl":"tplHqCircle","data":{"visibility-cond":">","visibility-val":"0","oid":"javascript.0.Countdown.Sleeptimer.countdown_seconds","min":"0","max":"javascript.0.Countdown.Sleeptimer.countdown_seconds","step":"1","displayPrevious":true,"readOnly":true,"unit":" s","visibility-oid":"","name":"Countdown","caption":"bis zur Aktivierung","hideNumber":false,"color":"#ffffff","thickness":"0.15","cursor":"","bgcolor":"#f00f36","linecap":true,"anticlockwise":false,"oid-working":"javascript.0.Countdown.Sleeptimer.countdown_seconds","oid-signal":"","angleArc":"360","angleOffset":"0","comment":"","digits":"0","is_comma":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"450px","top":"170px","width":"200px","height":"200px","z-index":"80","text-align":"center","color":"#e7f5f9","font-family":"","font-style":"","font-weight":"","font-size":"","background-color":"rgba(0,140,200,1)","border-radius":"490px"},"widgetSet":"hqwidgets"},{"tpl":"tplValueStringRaw","data":{"oid":"javascript.0.Countdown.Sleeptimer.countdown","visibility-cond":"==","visibility-val":1,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"650px","top":"210px","z-index":"20","color":"white","width":"137px","height":"32px"},"widgetSet":"basic"},{"tpl":"tplJquiButtonState","data":{"oid":"javascript.0.Countdown.Sleeptimer.trigger30min","visibility-cond":"==","visibility-val":1,"buttontext":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"true"},"style":{"left":"670px","top":"270px"},"widgetSet":"jqui"},{"tpl":"tplJquiButtonState","data":{"oid":"javascript.0.Countdown.Sleeptimer.trigger60min","visibility-cond":"==","visibility-val":1,"buttontext":"60","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value":"true"},"style":{"left":"670px","top":"310px"},"widgetSet":"jqui"}]Das Java-Skript habe ich unter folgendem Pfad abgelegt: /global/sleeptimer/. Im Skript selbst habe ich gar nichts geändert. -
eines ganz schnell vorweg…
Scripte die unter "global" liegen werden an alle anderen scripte angehängt. Es dort abzulegen ist sicher "suboptimal"
sieht das bei dir unter Objekte –> Javascript.0 (außer den bose-Punkten) genauso aus?
und das script ist auch gestartet?
@htrecksler: Danke für Deine Mühe! Ich habe das Skript jetzt von GLOBAL nach COMMON gepackt. Alles andere, was du geschrieben hast, habe ich kontrolliert. Was mir nur aufgefallen ist, dass mir der Unterordner "1" im Ordner "Countdown" fehlt. Bei mir ist da lediglich der Ordner "Sleeptimer" aufgeführt.
LEIDER läuft der Countdown immer noch nicht :-(
LEIDER läuft der Countdown immer noch nicht :-( `
Hallo Pix,
super Arbeit.
Dieser Unterordner wurde bei mir auch nicht angelegt. Versuche ich nacher mal per Hand. Unter Vis läuft soweit der Counter.
Würde evt. die Möglichkeit bestehen einen 3 ten Button wo eine individuelle Zeit möglich ist einzufügen?
mfg
Armin
@a-flow:@htrecksler: Danke für Deine Mühe! Ich habe das Skript jetzt von GLOBAL nach COMMON gepackt. Alles andere, was du geschrieben hast, habe ich kontrolliert. Was mir nur aufgefallen ist, dass mir der Unterordner "1" im Ordner "Countdown" fehlt. Bei mir ist da lediglich der Ordner "Sleeptimer" aufgeführt.
Der Unterordner 1 im Ordner Countdown ist ein anderer Countdown als der Sleeptimer. Den brauchst du nicht.Was läuft denn nicht?
Startet der Countdown nicht? Null er nicht? Zählt er nicht runter? Keine Aktion nach Ablauf?
Würde evt. die Möglichkeit bestehen einen 3 ten Button wo eine individuelle Zeit möglich ist einzufügen? `
Kannst du das umformulieren? In JavaScript hast du (fast) alle Möglichkeiten. Was ist eine individuelle Zeit? Fragst du, ob das jemand programmieren kann? :D :) ;)Gruß
Pix
nach einer kleinen Pause habe ich mich jetzt nochmal versucht das Skript zum Laufen zu bekommen. Leider klappt es immer noch nicht.
Nachstehend habe ich mal beschrieben, wie ich die Funktion in meine View eingebaut habe. Vielleicht habe ich irgendwas falsch gemacht oder einfach etwas vergessen.
Kopieren des Skripts
Das Skript von Pix habe ich einfach aus dem Forum in mein ioBroker unter Skripte kopiert (siehe Screenshots). Selbstverständlich habe ich das Skript auch gestartet.
Screenshot:
http://www.a-flow.de/bilder/timer_01.jpg" />~~Importieren des WidgetsDas Widget-Code habe ich aus dem Forum kopiert und damit das Widget in Vis importiert. Anschließend habe ich, soweit ich es überblickt habe, sämtliche Pfadangaben im Widget zu Skript-Variablen angepasst (siehe Screenshot). Hier nochmal ausführlich, welche Pfadangaben ich geändert habe:
- *Button 30: Objekt-ID: javascript.0.Countdown.Sleeptimer.trigger30min
*Button 60: Objekt-ID: javascript.0.Countdown.Sleeptimer.trigger60min *Kreisdiagramm: Objekt-ID: javascript.0.Countdown.Sleeptimer.countdown_seconds *Kreisdiagramm: In Arbeit Zustand ID: javascript.0.Countdown.Sleeptimer.countdown_seconds *Kreisdiagramm: Wert Max.: {javascript.0.Countdown.Sleeptimer.countdown_seconds}Screenshot:
http://www.a-flow.de/bilder/timer_02.jpg" />~~Wenn ich die View starte und dann auf einen der Buttons drücke, passiert nichts. Soweit ich es überblicke, wird auch nirgends eine Art Fehlerlog gespeichert.Ich würde mich sehr freuen, wenn mir jemand hilft das Teil zum Laufen zu bekommen!
Viele Grüße
Andi~~~~
Hallo Andi,
ist ein wenig schwieriger, nach zwei Monaten aus dem Thema wieder da hinein zukommen.
Hast du dieses Skript genutzt? http://forum.iobroker.net/viewtopic.php … 436#p31882
Bei Armin geht es, wie er schreibt~~@Arminhh:~~
Hallo Pix,
super Arbeit.
mfg
Armin `
Kommen irgendwann die Log-Zeilen<size size="85">Countdown abgelaufen
X min Sleeptimer gestartet/gestoppt</size> ?
Ändern sich die Objekte nach dem Start einem Tastendruck auf 30 oder 60?
Pix
Ja, ich habe genau das Skript aus deinem Post genommen.
Soweit ich es erkennen kann, kommen keine Logs. Wo genau sollen die Logs kommen? In ioBroker/Logs oder in ioBroker/Skripte/Logs?
Vielleicht fehlt etwas Grundlegendes… ich habe bisher noch nicht mit Skripten gearbeitet und das ist das einzige Skript, was bei mir läuft.
Okay, dann testen wir erstmal deine Installation.
Deaktiviere das Skript und erstelle ein Weiteres im Ordner "common"
Inhalt:
log('Hallo Welt!'); ````Wenn du dieses Skript gespeichert und aktiviert hast, sollte natürlich im Log "Hallo Welt" stehen. Logs, welche das aktuell im Editor gezeigte Skript betreffen,w erden darunter dargestellt. Alle Logs aller Skript im Reiter Admin/Logs oder in der Logdatei auf dem Server. Gruß Pix -
@Stephan61: Javaskript unter Instanzen ist gestartet gewesen.
@Pix: Das mit dem Log schein zu funktionieren. Es erscheint folgendes im Log:
javascript-0 2016-10-18 11:51:21.323 info script.js.common.Skript1: registered 0 subscriptions and 0 schedules javascript-0 2016-10-18 11:51:21.322 info script.js.common.Skript1: Hallo Welt! javascript-0 2016-10-18 11:51:21.317 info Start javascript script.js.common.Skript1 -
die Visualisierung gefällt mir (Widget) und würde sie gerne bei mir einbinden, inkl. des Skripts.
Nur müsste das Skript ein wenig angepasst werden.
<u>Funktionsweise</u>: Wenn Variable Alarmanlage=true, dann zeige das Widget mit dem Countdown und starte den Timer und werde unsichtbar, wenn Timer bei 0s.
Kann mir jemand dabei helfen?
Danke und Gruß Balu
Hallo balu,
es reicht, wenn der Countdown angezeigt wird, wenn die Restzeit/Timer größer als 0s ist.
Du schreibst in den Einstellungen des Widgets unter Sichtbarkeit OID den Datenpunkt des TImers (in Sekunden) und als Bedingung > 0
Ob die Alarmanlage dabei ein oder aus ist, spielt doch eigentlich keine Rolle.
Pix
Hallo Pix,
erstmal danke. Das mit dem Widget habe ich verstanden.
Wie muss ich das Skript anpassen, dass der Timer los läuft, wenn eine bestimmte Variable=true ist?
Gruß Balu
Edit: hab es jetzt angepasst, funktioniert sogar.
Wer evtl. das gleiche "Problem" hat, hier das Skript.
hm-rega.0.xxxxx startet den Timer (in meinem Fall wenn alle Personen abwesend sind)
hm-rega.0.yyyyy schaltet dann den Alarm scharf
` > createState('countdown', 20);
function count() {
setTimeout(function () {
var timer = getState('countdown').val || 20;
if (timer > 1) {
setState("hm-rega.0.xxxxx", false);
setState('countdown', timer - 1);
count();
} else {
setState('countdown', 0);
setState("hm-rega.0.yyyyy", true);
}, 1000);
on("hm-rega.0.xxxxx", function (obj) {
if (obj.newState.val === true || obj.newState.val === 'true' || obj.newState.val == 1) {
setState('countdown', 20);
setState("hm-rega.0.yyyyy", false);
count();
Super, wie einem hier geholfen wird. Daumen hoch
Danke und Gruß
Balu
