  4. Internetinhalte auf Wandtablet ohne Inetzugang darstellen?
    6.8k
visandroid app vis
58 Beiträge 7 Kommentatoren 7.0k Aufrufe 6 Beobachtet
    @liv-in-sky irgendwas mache ich noch falsch.
    es steht jetzt bei deinem und bei pauls script etwas im Datenpunkt.
    Habe jetzt mit image, HTML und iFrame versucht, das Bild kommt nicht
    Das dumme ist: irgendwann hatte es mal was angezeigt
    liv-in-skyL Offline
    liv-in-skyL Offline
    html -widget mit diesem inhalt
      <img src="{javascript.0.cam.image}">
    [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"30000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"  <img src=\"{javascript.0.cam.image}\">\n"},"style":{"left":"958px","top":"422px","z-index":"190","width":"279px","height":"190px","transform":"scale(1.5)"},"widgetSet":"basic"}]
    • liv-in-skyL liv-in-sky
      @liv-in-sky
      @harrym
      passt beides - man darf es nur nicht genau anders herum machen :-(
      Danke - jetzt muss ich es aufs produktive System ziehen und nachsehen, ob es unten an den Tablets ohne Internet auch zu sehen ist
      • harrymH harrym
        @Homoran basic image und binding auf den datenpunkt ;)
        liv-in-skyL Offline
        liv-in-skyL Offline
        @harrym
        dein image widget ist besser - bei dem html widget wird bei mir die größe verändert - keine ahnung warum
          @harrym
          @liv-in-sky sagte in Internetinhalte auf Wandtablet ohne Inetzugang darstellen?:
          Wahrscheinlich deswegen hatte Paul die Größe mit angegeben!
          Im produktiven System läuft es jetzt auch, aber...
          Nach dem Start blitzt das Bild nur kurz auf, dann kommt das icon für defektes Bild.
          Ab der nächsten Abfrage des Bildes (Änderung des States) bleibt das Bild stehen.
          Das ist natürlich extrem ärgerlich wenn im Wohnzimmer das große 22" Tablet im Sleep ist, angetippt wird und dann ist da nix.
          Beim Refresh alle 5 Minuten ist das nicht gut.
          Habe dort das image mit Binding drin.
            Ich muss leider dieses Thema noch mal aufmachen.
            Läuft bisher wie gewünscht!
            aber die Wünsche ändern sich ;-)
            Ich wollte jetzt statt des bisherigen Standbildes den Radarfilm einbinden und habe den URL gegen https://www.dwd.de/DWD/wetter/radar/radfilm_nrw_akt.gif getauscht.
            das hat auch wunderbar geklappt.
            Dann wollte ich ein Bild-im Bild erzeugen. Das Standbild groß und den Film klein in einer Ecke.
            ich wollte mir dazu die Datenstruktur unter Objekte ansehen und bekam den Pfad nicht geöffnet, die Seite fror ein sobald ich ...Wetter.Regen öffnen wollte - reproduzierbar.
            Habe dann im Skript wieder das Standbild laden lassen. damit klappt auch wieder das Öffnen des Verzeichnisses.
            Hat irgendjemand eine Idee woran das liegen kann?
            gif vs. jpg???
              gif vs. jpg???
              liv-in-skyL Offline
              liv-in-skyL Offline
              @Homoran
              verstehe eigentlich nicht, was das problem ist - was ist Wetter.Regen
              hier zwei gifs, die mit script verwandelt werden und angezeigt
                @Homoran
                der Pfad in meinen Objekten zu dem Bild (0_userdata.0.Wetter.Regen.NRW)
                und bei dem Versuch das Verzeichnis Regen zu öffnen friert der admin ein, wenn sich in dem DP das gif befindet
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @Homoran seltsamer fehler -
                  habe ein ähnliches problem - wenn ich den states kopieren will oder den bleistift zum betrachten wähle, braucht da ewig - habe mal den code rauskopiert - ist 7MB groß - vielleicht ist das ein problem
                  werd ich wohl wieder löschen - oder die auflösung muss runter
                  SVallantS 1 Antwort Letzte Antwort
                    SVallantS Offline
                    SVallantS Offline
                    SVallant
                    ich bin mir nicht sicher, ob das noch relevant ist, aber es gibt dafür https://github.com/ioBroker/ioBroker.phantomjs
                    • SVallantS SVallant
                      @SVallant sagte in Internetinhalte auf Wandtablet ohne Inetzugang darstellen?:
                      Danke für den Hinweis.
                      im Moment läuft es ja, aber ich werde es mal im Auge behalten für weitere ähnliche Projekte
