  3. Cloud Dienste
  4. Allgemein Google Home mit Iobroker (gelöst)
    6.5k
google homeiot
33 Beiträge 3 Kommentatoren 3.6k Aufrufe 3 Beobachtet
    @Marco-Willi Systematisch vorgehen und das System 'von unten' abklopfen.
    Was läuft da als Grundsystem?
    Alles aktuell?
    Dann welche Node-Version läuft?
    Ist die richtig im System drin?
    Welche Version von ioBroker inkl. der Adapter läuft?
    Marco WilliM Offline
    Marco Willi
    @Thomas-Braun
    Raspi 4 4GB version
    Node.js
    v12.19.0
    NPM
    6.14.8
    IoT Assistants
    more_vert
    Verfügbare Version: 1.5.3
    Installierte Version: 1.5.3
    Hier der Log
    host.raspberrypi 2020-11-11 20:33:30.774 info instance system.adapter.iot.0 started with pid 17337
    host.raspberrypi 2020-11-11 20:33:00.740 info Restart adapter system.adapter.iot.0 because enabled
    host.raspberrypi 2020-11-11 20:33:00.740 error instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi 2020-11-11 20:33:00.739 error Caught by controller[0]: at processImmediate (internal/timers.js:461:21)
    host.raspberrypi 2020-11-11 20:33:00.739 error Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2588:45)
    host.raspberrypi 2020-11-11 20:33:00.739 error Caught by controller[0]: at GoogleHome.getStates (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2580:13)
    host.raspberrypi 2020-11-11 20:33:00.739 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2613:29
    host.raspberrypi 2020-11-11 20:33:00.738 error Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi 2020-11-11 20:33:00.738 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2620:52
    host.raspberrypi 2020-11-11 20:33:00.737 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2624:67
    host.raspberrypi 2020-11-11 20:33:00.737 error Caught by controller[0]: at eval (eval at <anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2623:58), <anonymous>:1:1)
    host.raspberrypi 2020-11-11 20:33:00.735 error Caught by controller[0]: ReferenceError: Test is not defined
    iot.0 2020-11-11 20:33:00.524 info (16762) Connection lost
    iot.0 2020-11-11 20:33:00.524 info (16762) Connection changed: disconnect
    iot.0 2020-11-11 20:33:00.490 info (16762) Terminated (NO_ERROR): Without reason
    iot.0 2020-11-11 20:33:00.488 info (16762) terminating
    iot.0 2020-11-11 20:33:00.472 error at processImmediate (internal/timers.js:461:21)
    iot.0 2020-11-11 20:33:00.472 error at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2588:45)
    iot.0 2020-11-11 20:33:00.472 error at GoogleHome.getStates (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2580:13)
    iot.0 2020-11-11 20:33:00.472 error at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2613:29
    iot.0 2020-11-11 20:33:00.472 error at Array.forEach (<anonymous>)
    iot.0 2020-11-11 20:33:00.472 error at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2620:52
    iot.0 2020-11-11 20:33:00.472 error at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2624:67
    iot.0 2020-11-11 20:33:00.472 error at eval (eval at <anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2623:58), <anonymous>:1:1)
    iot.0 2020-11-11 20:33:00.472 error (16762) ReferenceError: Test is not defined
    iot.0 2020-11-11 20:33:00.472 error (16762) uncaught exception: Test is not defined
    iot.0 2020-11-11 20:32:41.506 info (16762) Connection changed: connect
    iot.0 2020-11-11 20:32:41.459 warn (16762) [GHOME] Invalid URL Pro key. Status auto-update is disabled you can set states but receive states only manually: {"error":"Email not found or URL key not found"}
    iot.0 2020-11-11 20:32:41.457 error (16762) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: {"error":"Email not
    iot.0 2020-11-11 20:32:40.930 info (16762) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    iot.0 2020-11-11 20:32:40.893 info (16762) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.iot, node: v12.19.0, js-controller: 3.1.6
    host.raspberrypi 2020-11-11 20:32:38.809 info instance system.adapter.iot.0 started with pid 16762
    host.raspberrypi 2020-11-11 20:32:08.792 info Restart adapter system.adapter.iot.0 because enabled
    host.raspberrypi 2020-11-11 20:32:08.792 error instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi 2020-11-11 20:32:08.792 error Caught by controller[0]: at processImmediate (internal/timers.js:461:21)
    host.raspberrypi 2020-11-11 20:32:08.791 error Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2588:45)
    host.raspberrypi 2020-11-11 20:32:08.791 error Caught by controller[0]: at GoogleHome.getStates (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2580:13)
    host.raspberrypi 2020-11-11 20:32:08.791 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2613:29
    host.raspberrypi 2020-11-11 20:32:08.791 error Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi 2020-11-11 20:32:08.791 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2620:52
    host.raspberrypi 2020-11-11 20:32:08.790 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2624:67
    host.raspberrypi 2020-11-11 20:32:08.790 error Caught by controller[0]: at eval (eval at <anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2623:58), <anonymous>:1:1)
    host.raspberrypi 2020-11-11 20:32:08.789 error Caught by controller[0]: ReferenceError: Test is not defined
    Sobald ich eine Aktion mit Google durchführe geht der Adapter auf rot und es kommen alle diese fehlermeldungen.
    Marco WilliM Thomas BraunT 2 Antworten Letzte Antwort
    • Marco WilliM Marco Willi
      @Thomas-Braun
      Raspi 4 4GB version
      Node.js
      v12.19.0
      NPM
      6.14.8
      IoT Assistants
      more_vert
      Hier der Log
      Marco Willi
      Die Lampe ist jetzt mal bei google drin, konnte das also von iobroker übernehmen. Sobald ein Sprachbefehl gegeben wird kackt alles ab. Das gleiche wenn ich die Lampe in der GH App anklicke. Adapter wird sofort rot und es hagelt von Hostfehlern, iot Fehler, Probleme mit URL etc.
      Marco WilliM 1 Antwort Letzte Antwort
        @Thomas-Braun
        Raspi 4 4GB version
        Node.js
        v12.19.0
        NPM
        6.14.8
        IoT Assistants
        more_vert
        Hier der Log
        @Marco-Willi Texte auch in CodeTags packen, damit man das lesen kann.
        Marco WilliM 2 Antworten Letzte Antwort
          Marco Willi
          @Thomas-Braun na toll, bin doch anfänger. Wie meinste das?
            Marco Willi
            Log.txt
              Marco Willi
              @Thomas-Braun besser so?
                @Marco-Willi
                Nee. Entsprechenden Text markieren und dann das Icon </> anklicken.
                  @Marco-Willi
                  Marco Willi
                  2020-11-11 20:45:43.328 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
                  2020-11-11 20:45:44.851 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
                  2020-11-11 20:45:46.220 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
                  2020-11-11 20:45:51.888 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
                  2020-11-11 20:45:52.490 - info: web.0 (1997) ==>Connected system.user.admin from ::ffff:192.168.1.154
                  2020-11-11 20:45:58.741 - info: web.0 (1997) <==Disconnect system.user.admin from ::ffff:192.168.1.154 vis.0
                  2020-11-11 20:46:38.826 - info: host.raspberrypi "system.adapter.iot.0" enabled
                  2020-11-11 20:46:38.864 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 25632
                  2020-11-11 20:46:40.925 - info: iot.0 (25632) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.iot, node: v12.19.0, js-controller: 3.1.6
                  2020-11-11 20:46:40.965 - info: iot.0 (25632) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                  2020-11-11 20:46:41.560 - info: iot.0 (25632) Connection changed: connect
                  2020-11-11 20:46:41.629 - error: iot.0 (25632) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: {"error":"Email not found or URL key not found"}
                  2020-11-11 20:46:41.630 - warn: iot.0 (25632) [GHOME] Invalid URL Pro key. Status auto-update is disabled you can set states but receive states only manually: {"error":"Email not found or URL key not found"}
                  2020-11-11 20:46:47.353 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2020-11-11 20:46:47.354 - error: iot.0 (25632) unhandled promise rejection: Test is not defined
                  2020-11-11 20:46:47.359 - error: iot.0 (25632) ReferenceError: Test is not defined
                  at eval (eval at (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2920:62), :1:1)
                  at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2921:63
                  at Array.forEach ()
                  at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2917:43
                  at Array.forEach ()
                  at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2825:61
                  at Array.forEach ()
                  at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2802:37
                  at Array.forEach ()
                  at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2799:35
                  2020-11-11 20:46:47.375 - info: iot.0 (25632) terminating
                  2020-11-11 20:46:47.377 - info: iot.0 (25632) Terminated (NO_ERROR): Without reason
                  2020-11-11 20:46:47.407 - info: iot.0 (25632) Connection changed: disconnect
                  2020-11-11 20:46:47.408 - info: iot.0 (25632) Connection lost
                  2020-11-11 20:46:47.927 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  2020-11-11 20:46:47.928 - error: host.raspberrypi Caught by controller[1]: ReferenceError: Test is not defined
                  2020-11-11 20:46:47.929 - error: host.raspberrypi Caught by controller[1]: at eval (eval at (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2920:62), :1:1)
                  2020-11-11 20:46:47.929 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2921:63
                  2020-11-11 20:46:47.930 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
                  2020-11-11 20:46:47.930 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2917:43
                  2020-11-11 20:46:47.931 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
                  2020-11-11 20:46:47.931 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2825:61
                  2020-11-11 20:46:47.932 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2802:37
                  2020-11-11 20:46:47.932 - error: host.raspberrypi Caught by controller[1]: at Array.forEach ()
                  2020-11-11 20:46:47.933 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:2799:35
                  2020-11-11 20:46:47.933 - info: host.raspberrypi instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                    @Marco-Willi
                      @Marco-Willi
                      Marco Willi
                      @Thomas-Braun jap, das habe ich schon ein paar mal gelesen und an den Kopf bekommen. Trotz Mailadressenwechsel und Neuregistrierung immer die gleiche Meldung. Was muss ich tun?
                      Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                        @Marco-Willi
                        Hab kein iot pro, daher musste ich da auch noch nie was machen.
                          @Marco-Willi
                          Marco Willi
                          @Thomas-Braun soll ich es mal mit free versuchen? Meinste das könnte klappen? Ich will auch keine Lizenz für meine 2 Anfragen am Tag kaufen.
                            Marco Willi
                            also mit free account bleibt der adapter auf gelb
                              Meister MopperM Online
                              Meister Mopper
                              @Marco-Willi sagte in Allgemein Google Home mit Iobroker:
                              Da steht ja, dass Du die certs löschen sollst. Hast Du das getan, mal auf den Mülleimer (s. Bild) geklickt?
                              Proxmox und HA ...
                                Marco Willi
                                @Meister-Mopper neiiin hab ich noch nicht. Fürs erste setzt ich das Projekt mal einer Pause aus. Nächste Woche nochmal.
                                Müsste ich dann was neues anfordern?
                                  Meister Mopper
                                  @Marco-Willi Kostet ja nichts!
                                  Proxmox und HA ...
                                    Marco Willi
                                    @meister-mopper
                                    Hi Leute. Habe es jetzt in der zwischenzeit hinbekommen. Lag eher bei einem Verständnisproblem denke ich.
                                    Alles nochmals auf. Sämtliche Verknüpfungen aufgehoben.
                                    Alles neu registiert und wieder verknüpft. Ging nachher relativ flott.
                                    Dann beim Broker die Sensoren die ich abfragen wollte reingeknallt und als Thermostat gekennzeichnet.
                                    „Hey Google aktualisiere Geräte“ dann war iobroker auch mit von der Party und ich konnte die Geräte einem Raum zuordnen. Jetzt klappt es auch mit abfragen der Temps.
