    6.6k
  • D DarkDevil
    @Zefau Ich habe heute morgen den die Visalisierung bei mir am Desktop laufen lassen, ohne das der Fehler genauso wie auf dem Tablet entstand. Folgende Fehlermeldungen habe ich im log:
    Vielleicht verhält sich das Tablet bzw. Fully Browser etwas sensibler als der Firefox
    Im Chrome habe ich es nun auch wie auf dem Tab:
    App # Welcome to jarvis 1.1.0-beta.87
    Connection.js:57 Connecting to http://192.168.123.100:8082 ..
    Connection.js:61 Connected to http://192.168.123.100:8082.
    Log.js:55 App # GET_SETTINGS: Cannot read property 'val' of null
    value @ Log.js:55
    (anonymous) @ App.js:153
    Promise.then (async)
    (anonymous) @ App.js:141
    (anonymous) @ App.js:139
    value @ App.js:120
    is @ react-dom.production.min.js:212
    hu @ react-dom.production.min.js:255
    t.unstable_runWithPriority @ scheduler.production.min.js:19
    Br @ react-dom.production.min.js:122
    fu @ react-dom.production.min.js:248
    Qs @ react-dom.production.min.js:239
    qs @ react-dom.production.min.js:230
    Au @ react-dom.production.min.js:281
    (anonymous) @ react-dom.production.min.js:284
    tu @ react-dom.production.min.js:240
    Bu @ react-dom.production.min.js:284
    t.render @ react-dom.production.min.js:290
    (anonymous) @ index.js:8
    a @ index.html:1
    (anonymous) @ main.30a76171.chunk.js:1
    a @ index.html:1
    t @ index.html:1
    r @ index.html:1
    Log.js:55 App # GET_LAYOUT: Cannot read property 'val' of null
    value @ Log.js:55
    (anonymous) @ App.js:203
    (anonymous) @ App.js:180
    (anonymous) @ App.js:178
    value @ App.js:120
    a @ index.html:1
    a @ index.html:1
    t @ index.html:1
    r @ index.html:1
    Log.js:55 App # GET_DEVICES: Cannot read property 'val' of null
    value @ Log.js:55
    (anonymous) @ App.js:243
    (anonymous) @ App.js:230
    (anonymous) @ App.js:228
    value @ App.js:120
    a @ index.html:1
    a @ index.html:1
    t @ index.html:1
    r @ index.html:1
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    #1635
    @DarkDevil sagte in jarvis - just another remarkable vis:
    Dort steht Cannot read property 'val' of null. Das bedeutet, dass er unter jarvis.0.settings nichts findet. Laut Screenshot findet er auch nichts unter jarvis.0.devices und jarvis.0.layout.
    Sind die Datenpunkte korrekt angelegt und befüllt?
    • R raama90
      @WW1983 Super, danke. Ich war einfach nur blind :D
      @all: Ich bekomme es einfach nicht hin das Jarvis im Fully Browser auf einem FireTab 10 aktuell bleibt. Habe schon an den Energieeinstellungen gespielt, ohne Erfolg bisher. Nach ein paar Minuten aktualisert sich die Visualisierung einfach nicht mehr. Ein Refresh der Seite hilft da für ein paar weitere Minuten, aber das ist ja auch nicht Sinn und Zweck. Am PC klappt das einwandfrei. Hat noch wer eine Idee?
      ZefauZ Offline
      ZefauZ Offline
      Zefau
      #1636
      @raama90 sagte in jarvis - just another remarkable vis:
      Ist bekannt, siehe https://github.com/Zefau/ioBroker.jarvis/issues/295
      • M MarkusMac
        @Zefau Zwei Sachen habe ich gerade beim Testen der neuen Beta.88 bemerkt:
        • Nach einiger Zeit erscheint "Connect ran into timeout" am unteren Rand - die Seite an sich scheint sich aber ohne Probleme weiterhin zu aktualisieren.
        • nach einem Klick auf den blauen Schraubenschlüssel (siehe Screenshot) passiert nichts. Hier: Bildschirmfoto 2020-11-09 um 13.57.44.png
          In der Konsole erscheint dann folgendes:
        Kann leider nicht sagen, ob diese beiden Bugs mit der .88 erstmals aufgetreten sind oder auch schon früher da waren.
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        #1637
        @MarkusMac sagte in jarvis - just another remarkable vis:
        Danke für den Hinweis. Dies mit der nächsten beta behoben.
        • M MCU
          @Zefau Bei der Adapterliste wäre es auch sinnvoll den Verwahrungsort (stable / latest) mit anzugeben:
          bzw. Aktualisierungen im stable und im latest
          stable : 1 / latest : 20
          Neuer Punkt:
          Popup-Version beim Calendar-Widget zeigt gar nichts!?
          Falsche Nutzung?
          Nächster Punkt:
          false Wert wird nicht gesetzt:
          Wenn ich auf aus schalte ist der Status leer:
          Weiterer Punkt:
          Im Gerät sind Unterpunkte definiert:
          Diese werden haben nicht mit dem Namen angezeigt:
          Dort sollte Türauf, Türzu, detectionState stehen?
          Lösung zu diesem Punkt: zusätzlich die Bezeichnung in das label zum Gerät und Unterpunkt schreiben! ( @FuXXz2 )
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          #1638
          @MCU sagte in jarvis - just another remarkable vis:
          Falsche Nutzung?
          Popup erscheint, wenn in der Kalender-Vorschau (die aktiviert sein muss) ein Tag angeklickt wird.
          Ist bekannt, siehe https://github.com/Zefau/ioBroker.jarvis/issues/237
          Ist mit der nächsten beta behoben.
          • M MCU
            Neuer Punkt:
            Falsche Nutzung?
            Nächster Punkt:
            Weiterer Punkt:
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            #1639
            Ich kann die Anzeige stable / latest aufnehmen, aber nicht, welche Updaten aus welchem Repository kommen. Die Daten kommen aus dem admin Adapter und die Information aus welchem Repo die Updates kommen erscheint dort nicht.
            • M MarkusMac
              @Zefau
              Planst du zufällig eine Integration und ein Widget von Alexa-Geräten? Ich fände es sehr praktisch, wenn ich mir zum Beispiel die aktiven Timer anzeigen lassen könnte, idealerweise auch mit einem Button zum Beenden. Eventuell wären auch Alarme und Reminder sinnvoll. Geb kurz Bescheid, dann kann ich auch gerne ein Issue einstellen.
              Falls das erstmal nicht geplant ist, würde ich mir das wahrscheinlich irgendwie in einer einfachen Version selber zusammenbasteln und mit einem HTML- oder iframe-Widget darstellen. Aber ein eigenes Widget dafür wäre schon schick, analog zum Kalender-Widget. Ich denke, sowas wäre auch für andere hier interessant?
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #1640
              Ja, ist geplant. Habe dazu nun auch ein Feature Request angelegt (https://github.com/Zefau/ioBroker.jarvis/issues/331). Kommt aber nicht in naher Zukunft.
              • M MCU
                @Zefau Klick auf Fläche mit Icon
                löst nur aus beim Klicken auf die Schrift Popup aus! Beim Klicken auf das Symbol bzw. Icon wird kein Popup geöffnet.
                ZefauZ Offline
                ZefauZ Offline
                Zefau
                #1641
                Klick auf Icon sollte gehen. Die Schaltfläche sollte beim rüberfahren farblich hervorgehoben sein. Ist dies bei dir der Fall? Ist das Icon in dieser farblichen Hervorhebung nicht drin? Mach mal bitte einen Screenshot.
                • ZefauZ Zefau
                  M Online
                  M Online
                  MCU
                  #1642
                  @Zefau Hervorhebung ist zu erkennen. Icon ist da auch drin, trotzdem keinen Effekt!
                  Auch in der anderen Variante:
                  Auf Icon Klick kein Effekt!
                  Hier nochmal als Video: 2020-11-09 20-05-27.flv
                  • ZefauZ Zefau
                    @hssteuerung sagte in jarvis - just another remarkable vis:
                    Also nur im fully klappt es nicht. erstelle ich eine Instanz und rufe jarvis aus chrome auf, ist alles normal nur fully läd eine andere Version
                    Was genau ist denn das Problem? Bei mir funktioniert es mit der aktuellen beta v1.1.0-beta.88 auf fully.
                    hssteuerungH Offline
                    hssteuerung
                    schrieb am zuletzt editiert von hssteuerung
                    #1643
                    @Zefau said in jarvis - just another remarkable vis:
                    Abend @Zefau,
                    Also ich habe das Problem schon seit Anfang an. Ich lade mir jarvis runter. OHNE eine Instanz zu installieren, kann ich jarvis öffnen ubd konfigurieren. Diese Version wir mir immer im fully angezeigt.
                    Erstelle ich eine Instanz, wird auf dem Chrome, ob Handy oder Desktop, mir die jarvis Version von der Instanz angezeigt.
                    Im fully Browser wird mir aber immer die Version ohne Instanz angezeigt. Egal ob ich Cache löschen.
                    Hoffe du versteht jetzt mein Problem mit dem fully
                    • hssteuerungH hssteuerung
                      Abend @Zefau,
                      ZefauZ Offline
                      ZefauZ Offline
                      Zefau
                      #1644
                      @hssteuerung daran kann ich nichts ändern. Das ist ein struktureller Fehler von ioBroker.
                      Welchen js-controller und admin hast du bei dir im Einsatz?
                      hssteuerungH 1 Antwort Letzte Antwort
                      • ZefauZ Zefau
                        hssteuerung
                        #1645
                        Admin ist bei 4.1.10
                        ZefauZ 2 Antworten Letzte Antwort
                          ZefauZ Offline
                          ZefauZ Offline
                          Zefau
                          #1646
                          @hssteuerung Admin hab ich auch auf v4.1.10. Und js-controller ? Auch v3.1.6 ?
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            #1647
                            @hssteuerung Welche Dateien hast du denn im jarvis-Ordern unter iobroker-data ?
                            • ZefauZ Zefau
                              M Online
                              M Online
                              MCU
                              #1648
                              @Zefau Den Effekt ohne Instanz hatte ich auch: mit Admin v4.0.10
                              Siehe oben: https://forum.iobroker.net/topic/30668/jarvis-just-another-remarkable-vis/1576
                              • M MCU
                                ZefauZ Offline
                                ZefauZ Offline
                                Zefau
                                #1649
                                @MCU Welche Dateien hast du denn im jarvis-Ordern unter iobroker-data ?
                                hssteuerungH M 2 Antworten Letzte Antwort
                                • ZefauZ Zefau
                                  hssteuerung
                                  #1650
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    #1651
                                    @hssteuerung ... unter files und dann jarvis!
                                    • ZefauZ Zefau
                                      hssteuerung
                                      #1652
                                      • ZefauZ Zefau
                                        M Online
                                        M Online
                                        MCU
                                        #1653
                                        @Zefau
                                        Jarvis:
                                        jarvis.admin
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #1654
                                          @hssteuerung @MCU danke euch. Sieht gut aus, sofern eine Instanz angelegt ist. Wenn keine Instanz angelegt ist, muss der Ordner leer sein (bis auf die json Dateien -> das sind die Backups).
                                          Bei jedem Update ändert sich die precache-manifest Datei (also die ID, die da im Dateinamen ist, ist dann immer anders).
                                          Bitte schaut nochmal in den static Ordner. Wie sieht der aus? Auch dort sollten die Dateien nicht doppelt sein (mit unterschiedlichen IDs). Auch diese ändern sich mit jedem Release.
                                          M hssteuerungH 2 Antworten Letzte Antwort
