- ioBroker Community Home
- Deutsch
- Skripten / Logik
- Blockly
- [gelöst] Kodi: Enduhrzeit berechnen
@paul53 ah danke das minus hatte ich falsch. ich werde testen.
ja die DPs haben den gleichen Namen
EDIT: Funktioniert, Vielen Dank
hier das Endergenis als Blockly-Export
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="Gv49fQ40~+/ya6#JMvO}">time_total</variable> <variable id="8?J4Jmf7%_-wS9!yell|">time</variable> <variable id="z6@)Eo%V776?qOlzgeJq">sekunden_total</variable> <variable id="c70ch.|4qGYP3!UEvS8x">sekunden</variable> <variable id="7gbI~lkqQ~M|C;mJ+cDq">i</variable> <variable id="fB}3.DkAG[Zns[jkc^B)">diff</variable> </variables> <block type="on_ext" id="UyS4Ckq]DK=u(E|IV5|a" x="-37" y="-412"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="y%CApDq%H-@(J:5?MAiU"> <field name="oid">kodi.0.state</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="U|}v1P+7Z((QVxnb;L(Z"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id="_WknMe|%WU5qtbA=6L4y"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="ne2kI/B~3Ag$)Up_!s92"> <field name="ATTR">val</field> <field name="OID">kodi.0.state</field> </block> </value> <value name="B"> <block type="text" id="^t@S/LR+s?0fdO/$$5Fr"> <field name="TEXT">stop</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="D63tdWNK3cfIk,(8*g[7"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> <value name="VALUE"> <block type="lists_split" id="#Bs8uF;CIVzH*#~zWC[Z"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="O,$imajljBUn8`qd51tT"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time_total</field> </block> </value> <value name="DELIM"> <shadow type="text" id="i][20zd:a%Z5WuNJbjiW"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="}rdCX^x;8$i%04ZJcd2o"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> <value name="VALUE"> <block type="lists_split" id="/Tn?XMzhD[7o!]%7bN|`"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="DHiTi[yB@_!HVVYFZQ#{"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time</field> </block> </value> <value name="DELIM"> <shadow type="text" id="9r`t]#N.!+f5CYhltB$5"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="N+qpos_aO8E|Dv1]If3E"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="VALUE"> <block type="math_number" id="e+Zv|}##KEg-jWW.VhR^"> <field name="NUM">0</field> </block> </value> <next> <block type="variables_set" id="CI6cuB*r3V3air$w}Th*"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="VALUE"> <block type="math_number" id=")aK/~m.cZKr^5i+?jiyR"> <field name="NUM">0</field> </block> </value> <next> <block type="controls_for" id="05XR;DD2{J#JGlH#k1Pp"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="Z0e;xMGN}wF~qup4h:!n"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number" id="5v*f*V{Pbzjd%cm[w9}|"> <field name="NUM">10</field> </shadow> <block type="lists_length" id=";l8nh!gomPd#o,AWU(x~"> <value name="VALUE"> <block type="variables_get" id="Fie%v/GluA(0/Uv2LjvW"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="Na-(x3y(g|Ic]PwD}Bc6"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="#RfBewH#M+$qHo,i[pW]"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="DELTA"> <shadow type="math_number" id="c)!+NvI${{Hqg6ODoKwG"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="DO0C_qkin^w7Zg`13^Ax" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id=":u]~YX#Px.)8XVC^+4OC"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="UthyNeMI|9X*q)Zg.`%k"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id=")MuNoA~pKeC)=?cD[FLN"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number" id="EZi-Gj-IR~d^|{BPNXC|"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="ugyZ{PW4wVs9l6@OZ9s1"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="qaDS=5JKYmJ..f7O8[rN"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="^49ie8|ms}QAX2RjO=B("> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="#;ZqpYS`M@3`7V=OE{#H"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number" id="Hc[Z7Ru]=Ptfd}zfJPK)"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="jsfEtcf|%mTFET*+J97e"> <value name="VALUE"> <block type="lists_getIndex" id="{,3_@Jd`[eLJtDn9%zQ."> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="t-j[3g5C#p5(I;hJu6`{"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> <value name="AT"> <block type="variables_get" id="#k^6{@JW.j_lLZz-!au["> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_for" id="*i`Bgncmb]fI%^@Yqe+d"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="T:rLT72NA!Ldh.=kc(#!"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="/bH4Y.WEZHIFo-V02N1!"> <value name="VALUE"> <block type="variables_get" id="0CwKH!7j{{B.14[u{-pc"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="S?1g$6pH5gYVMz44YY[!"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="^$zYDn-;*4Y1zrxPf`|r"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="~T0g:DWVaNElI(yal`W!" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="1k[z/FsR547Q9QvY8WT%"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="#dXtj]g-7}K4y(W0N?_1"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="b-Q:1*!1y!-0ROIQ}2mg"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id=";Yi(1HBUE0);GL[iBTB="> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="b8dUH`nESfT3H]?K#I!?"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="Gz7jq)g)/PC(]P*_n@hr"> <value name="VALUE"> <block type="lists_getIndex" id="7M0K,#1MX$pd$@jGnpXu"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="5jm{qI-%F/VhD?1%BdF4"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> <value name="AT"> <block type="variables_get" id="}m`fxeU`x/9js9M#}FPY"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="variables_set" id=")?r?W1sUUKIHU@q^jKu2"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> <value name="VALUE"> <block type="math_arithmetic" id="9xBzQF]l!H5ehz:-`(nh" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="^}W9TM?z6jjL}N_j,Mx^"> <field name="NUM">1000</field> </shadow> </value> <value name="B"> <shadow type="math_number" id="5SNb|`kFhqCJGU|p/@JB"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="CaGXbf_m9_?=FT}9C8ic" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="-czVq.1JE(QbLjRK7NMa"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="+vZTtD$s`!^[Woo)#Rk^"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number" id=";7BwHg}pRu600~Q4*No]"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="e[e9GA[x@o4N9f0,%5.^"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> </block> </value> <next> <block type="control" id="ZHfzdb6%v,`[zO_!f:6d"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="convert_from_date" id="423)BA7-JL#+K^YrxtY!"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">hh:mm</field> <value name="VALUE"> <block type="math_arithmetic" id="M~;ci|@Wq$,ydkp6uLd1"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="?TYndgc}q5yB$k0|Tp?@"> <field name="NUM">1</field> </shadow> <block type="time_get" id="OGG8/S@3l23!N9-LzSR{"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">object</field> </block> </value> <value name="B"> <shadow type="math_number" id="s-,[jty8kUa~cG{-qS1Z"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="v)f?IW~A1oRX9GvWUZMp"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> </block> </value> </block> </value> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="control" id="VSZMp_fJpd1OzYCY=~xN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="b8vzkml]yd@f[0(Q`e(2"> <field name="TEXT"></field> </block> </value> </block> </statement> </block> </statement> </block> </xml> -
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="Gv49fQ40~+/ya6#JMvO}">time_total</variable> <variable id="8?J4Jmf7%_-wS9!yell|">time</variable> <variable id="z6@)Eo%V776?qOlzgeJq">sekunden_total</variable> <variable id="c70ch.|4qGYP3!UEvS8x">sekunden</variable> <variable id="7gbI~lkqQ~M|C;mJ+cDq">i</variable> <variable id="fB}3.DkAG[Zns[jkc^B)">diff</variable> </variables> <block type="on_ext" id="UyS4Ckq]DK=u(E|IV5|a" x="-37" y="-412"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="y%CApDq%H-@(J:5?MAiU"> <field name="oid">kodi.0.state</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="U|}v1P+7Z((QVxnb;L(Z"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id="_WknMe|%WU5qtbA=6L4y"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="ne2kI/B~3Ag$)Up_!s92"> <field name="ATTR">val</field> <field name="OID">kodi.0.state</field> </block> </value> <value name="B"> <block type="text" id="^t@S/LR+s?0fdO/$$5Fr"> <field name="TEXT">stop</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="D63tdWNK3cfIk,(8*g[7"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> <value name="VALUE"> <block type="lists_split" id="#Bs8uF;CIVzH*#~zWC[Z"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="O,$imajljBUn8`qd51tT"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time_total</field> </block> </value> <value name="DELIM"> <shadow type="text" id="i][20zd:a%Z5WuNJbjiW"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="}rdCX^x;8$i%04ZJcd2o"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> <value name="VALUE"> <block type="lists_split" id="/Tn?XMzhD[7o!]%7bN|`"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="DHiTi[yB@_!HVVYFZQ#{"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time</field> </block> </value> <value name="DELIM"> <shadow type="text" id="9r`t]#N.!+f5CYhltB$5"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="N+qpos_aO8E|Dv1]If3E"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="VALUE"> <block type="math_number" id="e+Zv|}##KEg-jWW.VhR^"> <field name="NUM">0</field> </block> </value> <next> <block type="variables_set" id="CI6cuB*r3V3air$w}Th*"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="VALUE"> <block type="math_number" id=")aK/~m.cZKr^5i+?jiyR"> <field name="NUM">0</field> </block> </value> <next> <block type="controls_for" id="05XR;DD2{J#JGlH#k1Pp"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="Z0e;xMGN}wF~qup4h:!n"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number" id="5v*f*V{Pbzjd%cm[w9}|"> <field name="NUM">10</field> </shadow> <block type="lists_length" id=";l8nh!gomPd#o,AWU(x~"> <value name="VALUE"> <block type="variables_get" id="Fie%v/GluA(0/Uv2LjvW"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="Na-(x3y(g|Ic]PwD}Bc6"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="#RfBewH#M+$qHo,i[pW]"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="DELTA"> <shadow type="math_number" id="c)!+NvI${{Hqg6ODoKwG"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="DO0C_qkin^w7Zg`13^Ax" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id=":u]~YX#Px.)8XVC^+4OC"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="UthyNeMI|9X*q)Zg.`%k"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id=")MuNoA~pKeC)=?cD[FLN"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number" id="EZi-Gj-IR~d^|{BPNXC|"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="ugyZ{PW4wVs9l6@OZ9s1"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="qaDS=5JKYmJ..f7O8[rN"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="^49ie8|ms}QAX2RjO=B("> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="#;ZqpYS`M@3`7V=OE{#H"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number" id="Hc[Z7Ru]=Ptfd}zfJPK)"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="jsfEtcf|%mTFET*+J97e"> <value name="VALUE"> <block type="lists_getIndex" id="{,3_@Jd`[eLJtDn9%zQ."> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="t-j[3g5C#p5(I;hJu6`{"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> <value name="AT"> <block type="variables_get" id="#k^6{@JW.j_lLZz-!au["> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_for" id="*i`Bgncmb]fI%^@Yqe+d"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="T:rLT72NA!Ldh.=kc(#!"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="/bH4Y.WEZHIFo-V02N1!"> <value name="VALUE"> <block type="variables_get" id="0CwKH!7j{{B.14[u{-pc"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="S?1g$6pH5gYVMz44YY[!"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="^$zYDn-;*4Y1zrxPf`|r"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="~T0g:DWVaNElI(yal`W!" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="1k[z/FsR547Q9QvY8WT%"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="#dXtj]g-7}K4y(W0N?_1"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="b-Q:1*!1y!-0ROIQ}2mg"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id=";Yi(1HBUE0);GL[iBTB="> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="b8dUH`nESfT3H]?K#I!?"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="Gz7jq)g)/PC(]P*_n@hr"> <value name="VALUE"> <block type="lists_getIndex" id="7M0K,#1MX$pd$@jGnpXu"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="5jm{qI-%F/VhD?1%BdF4"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> <value name="AT"> <block type="variables_get" id="}m`fxeU`x/9js9M#}FPY"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="variables_set" id=")?r?W1sUUKIHU@q^jKu2"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> <value name="VALUE"> <block type="math_arithmetic" id="9xBzQF]l!H5ehz:-`(nh" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="^}W9TM?z6jjL}N_j,Mx^"> <field name="NUM">1000</field> </shadow> </value> <value name="B"> <shadow type="math_number" id="5SNb|`kFhqCJGU|p/@JB"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="CaGXbf_m9_?=FT}9C8ic" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="-czVq.1JE(QbLjRK7NMa"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="+vZTtD$s`!^[Woo)#Rk^"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number" id=";7BwHg}pRu600~Q4*No]"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="e[e9GA[x@o4N9f0,%5.^"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> </block> </value> <next> <block type="control" id="ZHfzdb6%v,`[zO_!f:6d"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="convert_from_date" id="423)BA7-JL#+K^YrxtY!"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">hh:mm</field> <value name="VALUE"> <block type="math_arithmetic" id="M~;ci|@Wq$,ydkp6uLd1"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="?TYndgc}q5yB$k0|Tp?@"> <field name="NUM">1</field> </shadow> <block type="time_get" id="OGG8/S@3l23!N9-LzSR{"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">object</field> </block> </value> <value name="B"> <shadow type="math_number" id="s-,[jty8kUa~cG{-qS1Z"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="v)f?IW~A1oRX9GvWUZMp"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> </block> </value> </block> </value> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="control" id="VSZMp_fJpd1OzYCY=~xN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="b8vzkml]yd@f[0(Q`e(2"> <field name="TEXT"></field> </block> </value> </block> </statement> </block> </statement> </block> </xml>Danke Dir für das Bereitstellen des fertigen Blockeis
ich habe bei mir den DPkodi.0.seekergänzt
das hat den Vorteil dass ich vorspulen kann und die Enduhrzeit aktualisiert sich aus gleich.Was mir etwas Kopfzerbrechen macht ist die Häufigkeit der Aktualisierung da der DP "Seek" aufgrund der 3 "Komma Nachstellen" sehr viele Aktualisierungen erfährt, das geht sozusagen im Sekunden Takt.
wie schätzt du das ein, kann ich das ignorieren oder sollte so etwas vermieden werden. -
wie schätzt du das ein, kann ich das ignorieren oder sollte so etwas vermieden werden.@dos1973 sagte:
Mit Sekundentakt sollte eine moderne Hardware zurecht kommen.
Produktiv: Asus PN 42 / N100 / 8 GB / 500 GB; Proxmox mit 2 VM (iob / openCCU) -
am liebsten wäre es mir, wenn eine Zeit Aktualisierung bei ganzen Zahlen des "Seek" erfolg. Aktuell zeigt der DP den Wert "27.0689" in % aber ich wüsste nicht wie und wo ich das anpasse/ anheften müsste.
Ich stelle mich schwer mit Blockly :-( -
Ich stelle mich schwer mit Blockly :-(@dos1973 wird glaube nicht funktionieren.
wenn man seek als Trigger nimmt, löst das Skript bei jeder noch so kleinen Änderung vom seek wert aus.
man könnte evtl. versuchen mit einmal falls Block zu prüfen ob es ein *.0 wert ist und nur dann die Berechnung ausführen
@Kuddel sagte:
Die Prüfung wird nur selten erfolgreich sein. Besser runden und auf Änderung zum vorherigen gerundeten Wert prüfen.
@Kuddel
Ich habe den Ansatz Verfolgt bei Änderung von Seek ein Timeout zu setzen (2-5sekunden) und dann zu aktualisieren.
aber hat bisher nicht gefruchtetE
@dos1973 macht auch keinen sinn. das skript startet ja trotzdem bei jeder änderung. die berechnung folgt dann nur ein paar sekunden später
@Kuddel
Soll ja auch, ich will ja die ende Uhrzeit haben.Oder haben wir ein Missverständnis ?
Es ist nicht im Sekundenbereich,
Eher im ms Sekunden Bereich wo das Script dann immer ausgeführt wird. Ich denke dass kann dann schon zu Engpässen führen@dos1973 das finde ich auch.
also den trigger selber mit kodi.0.state und kodi.0.seek wird man nicht verbessern können.
somit startet das skirpt quasi permanent.
Entweder prüft man jetzt auf den % Wert, sodass die weitere Berechnung nicht ausgeführt wird.
Oder man baut das Skript komplett um:
Trigger = kodi.0.state
wenn state = play -> alle 1000ms Schleife, die die Berechnung durchführt.
wenn state = stop -> beende Schleife
Eher im ms Sekunden Bereich wo das Script dann immer ausgeführt wird. Ich denke dass kann dann schon zu Engpässen führen@dos1973 habe mein Skript nochmal umgebaut.
Als Trigger nehme ich nach wie vor kodi.0.state.
Wenn state = play oder pause -> Skript läuft in einer Schleife, alle 30 Sekunden
Somit wird auch während einer Pause sowie wenn man Spult die Endzeit korrekt berechnet.
Export:
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable type="interval" id="Pause">Pause</variable> <variable id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</variable> <variable id="Gv49fQ40~+/ya6#JMvO}">time_total</variable> <variable id="8?J4Jmf7%_-wS9!yell|">time</variable> <variable id="z6@)Eo%V776?qOlzgeJq">sekunden_total</variable> <variable id="c70ch.|4qGYP3!UEvS8x">sekunden</variable> <variable id="7gbI~lkqQ~M|C;mJ+cDq">i</variable> <variable id="fB}3.DkAG[Zns[jkc^B)">diff</variable> </variables> <block type="on_ext" id="q-.)uV_$xX9EqI#0)1V{" x="-37" y="-270"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="3Y]sGqJzX97#Y#bnc%2B"> <field name="oid">kodi.0.state</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="#KCO]0`h|hPacKdL)=A2"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="Fk*MZyx-?jaWVfOUD74{" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_operation" id="7^bj8pwH}Zu%AB)noQ?@" inline="false"> <field name="OP">OR</field> <value name="A"> <block type="logic_compare" id="f;Y93jeAj5hLE=HpAXci"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="+oIYTrzhXShgXD?-dx?!"> <field name="ATTR">val</field> <field name="OID">kodi.0.state</field> </block> </value> <value name="B"> <block type="text" id="L7`/vLtiabj}GQ5_)n?I"> <field name="TEXT">play</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="q@QCe9klq^hq~N~GDy45"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id=".a9WA=7@YR;|n8VLbG6V"> <field name="ATTR">val</field> <field name="OID">kodi.0.state</field> </block> </value> <value name="B"> <block type="text" id=".JZ%Qo2ld8Wni+Ay9fQu"> <field name="TEXT">pause</field> </block> </value> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="S;@tsc#Y9J{l-nz(8#%L"> <field name="OP">NEQ</field> <value name="A"> <block type="variables_get" id="_lYj.M;X6{:Ig+t1H-OG"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> </block> </value> <value name="B"> <block type="logic_boolean" id=":eRp?twu(kMNOV|nraj#"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_setinterval" id="uGdM,D)hhj,Ipm210S*$"> <field name="NAME">Pause</field> <field name="INTERVAL">30000</field> <field name="UNIT">ms</field> <statement name="STATEMENT"> <block type="variables_set" id="0o{kX1g9TrRziofKKE`n"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> <value name="VALUE"> <block type="logic_boolean" id="57_A}S_9aHo-D7/*Q-bz"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="fTK`7dy@}I9{xOUk:fdm"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> <value name="VALUE"> <block type="lists_split" id="fSNHlFM[e|2s~?~WLoA]"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="%}I/[z=}v|bA_s+cN3T+"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time_total</field> </block> </value> <value name="DELIM"> <shadow type="text" id="bO/MuTT:URPjI@SOF^wu"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="3L:9B.c/-jdK~YPS;}kk"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> <value name="VALUE"> <block type="lists_split" id="m0vWY?4A}Fy?zECIMa-g"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="cmBA^z.eb9hODfdHQbW8"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time</field> </block> </value> <value name="DELIM"> <shadow type="text" id=";o/sw@k#dD0mWkC4+b)M"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id=";/]R)Ct0Dfu6i-d@fN1="> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="VALUE"> <block type="math_number" id="!A%IT%#arX*{$UY8=Kva"> <field name="NUM">0</field> </block> </value> <next> <block type="variables_set" id="%LYJ{05i.|T3]O%OZlti"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="VALUE"> <block type="math_number" id="-:ZTaSM~NWM#h9LoWuBz"> <field name="NUM">0</field> </block> </value> <next> <block type="controls_for" id="2R-$*vTVI{p#n(T8RV.d"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="yo3lqjuQw}eovRb+XXQ?"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="030ssz#WyY6qdm{Y]+%7"> <value name="VALUE"> <block type="variables_get" id="LtjmBy}A-?%QRfowFhZH"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="W4)e3sbN-C[AtksvJyb0"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="gZ[fn:P}L%w5Hu*/k[w]"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="_nrssb{}I|MM@7r=B2*[" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="?QRRgY%9F+.UW^4Wl#AO"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="`nZhdJ)1xBsAmv:WOH{$"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="%5v;FD87a~}IdxMU?0vb"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="~kv8]AFICio,y}2%8r:A"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="By?4fEM=/cIUg=PVf-%."> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="Xjk8qkB+rf0:[Z@JKl{4"> <value name="VALUE"> <block type="lists_getIndex" id="=M7:!eN*k,;Op`ncPBu)"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="4n4]sPE}}yOyCqIR6sK$"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> <value name="AT"> <block type="variables_get" id="5KN91f+6[?BIQQU^P+T/"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_for" id="/[|3}k{qYeK4wFiN6#lx"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="1FErI$q)qi=X^N_:%Js?"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="yJ$~7a^l4Gd#j:0c3$xr"> <value name="VALUE"> <block type="variables_get" id="Lh*:^j)}o|0jC8rH:.-+"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="T3rAediff*:%E88l7+4%"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="Bsy0,}!M#a)Xi$$B[t]z"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="ecXevA40kHBJjiNry:#^" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="K#Ey7v.v;+lcl{1f@5]H"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="a~E=mS#u_.VcC[jX^/;*"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="p}_MS2!F;,r~o9#j=$`e"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="Wr7+iV$a;ynQ,P%0v/|h"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="7DDk.nAP2`-o[3:5T/`V"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="95Wkc=Wn9wjOL/~emwC:"> <value name="VALUE"> <block type="lists_getIndex" id="):n}4;0GiBs#gE+_-.uf"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="WCs.rt_18?skHj|HC;)H"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> <value name="AT"> <block type="variables_get" id="dA]HyO~W)iY5ROXqc$PI"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="variables_set" id="x8t?3^{cNVFaKtPFnFq9"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> <value name="VALUE"> <block type="math_arithmetic" id="2+`tDY!LQG^9AZO8#!ZQ" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="(_=}+a~Ov.r2s~-^a_*5"> <field name="NUM">1000</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="D.`(%|9dOcm*(umN9bT@" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="u7f(0GaP.#L;(fYVBLIF"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="]@3~@l|_;uO[L%2ioP,k"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> </block> </value> <next> <block type="control" id="E.QKHpVBex}})iCx|o|3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text_join" id="r1UQi]J^lm7$v9OOADL%"> <mutation items="2"></mutation> <value name="ADD0"> <block type="convert_from_date" id="TgQBU@2m$Aam**8naRqf"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">hh:mm</field> <value name="VALUE"> <block type="math_arithmetic" id="vFX,u4337mHL^[94MZjL"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="time_get" id="WGy*s;07oKI/J`GDI-x3"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">object</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="%/#p`[h/wlvqSaXg{l2J"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="text" id="+v9neh|_70u#CP~sT+@%"> <field name="TEXT"> Uhr</field> </block> </value> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="timeouts_clearinterval" id="Jb@;uzYL;m`:c=QqzD4L"> <field name="NAME">Pause</field> <next> <block type="variables_set" id="iv;KGC[hF6MD=bcKz-}~"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> <value name="VALUE"> <block type="logic_boolean" id="V0z@IGk2vj.t5+#2j3f;"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="VSZMp_fJpd1OzYCY=~xN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="b8vzkml]yd@f[0(Q`e(2"> <field name="TEXT"></field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </xml> -
Eher im ms Sekunden Bereich wo das Script dann immer ausgeführt wird. Ich denke dass kann dann schon zu Engpässen führen@dos1973 habe die Restzeit auch noch eingebaut:
Das Skript läuft jetzt sekündlich, so lange kodi.0.state nicht gleich stop
<block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="q-.)uV_$xX9EqI#0)1V{" x="-37" y="-270"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="3Y]sGqJzX97#Y#bnc%2B"> <field name="oid">kodi.0.state</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="#KCO]0`h|hPacKdL)=A2"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="Fk*MZyx-?jaWVfOUD74{" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="f;Y93jeAj5hLE=HpAXci"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="+oIYTrzhXShgXD?-dx?!"> <field name="ATTR">val</field> <field name="OID">kodi.0.state</field> </block> </value> <value name="B"> <block type="text" id="L7`/vLtiabj}GQ5_)n?I"> <field name="TEXT">stop</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="S;@tsc#Y9J{l-nz(8#%L"> <field name="OP">NEQ</field> <value name="A"> <block type="variables_get" id="_lYj.M;X6{:Ig+t1H-OG"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> </block> </value> <value name="B"> <block type="logic_boolean" id=":eRp?twu(kMNOV|nraj#"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_setinterval" id="uGdM,D)hhj,Ipm210S*$"> <field name="NAME">calc</field> <field name="INTERVAL">1000</field> <field name="UNIT">ms</field> <statement name="STATEMENT"> <block type="variables_set" id="0o{kX1g9TrRziofKKE`n"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> <value name="VALUE"> <block type="logic_boolean" id="57_A}S_9aHo-D7/*Q-bz"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="fTK`7dy@}I9{xOUk:fdm"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> <value name="VALUE"> <block type="lists_split" id="fSNHlFM[e|2s~?~WLoA]"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="%}I/[z=}v|bA_s+cN3T+"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time_total</field> </block> </value> <value name="DELIM"> <shadow type="text" id="bO/MuTT:URPjI@SOF^wu"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="3L:9B.c/-jdK~YPS;}kk"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> <value name="VALUE"> <block type="lists_split" id="m0vWY?4A}Fy?zECIMa-g"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="cmBA^z.eb9hODfdHQbW8"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time</field> </block> </value> <value name="DELIM"> <shadow type="text" id=";o/sw@k#dD0mWkC4+b)M"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id=";/]R)Ct0Dfu6i-d@fN1="> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="VALUE"> <block type="math_number" id="!A%IT%#arX*{$UY8=Kva"> <field name="NUM">0</field> </block> </value> <next> <block type="variables_set" id="%LYJ{05i.|T3]O%OZlti"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="VALUE"> <block type="math_number" id="-:ZTaSM~NWM#h9LoWuBz"> <field name="NUM">0</field> </block> </value> <next> <block type="controls_for" id="2R-$*vTVI{p#n(T8RV.d"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="yo3lqjuQw}eovRb+XXQ?"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="030ssz#WyY6qdm{Y]+%7"> <value name="VALUE"> <block type="variables_get" id="LtjmBy}A-?%QRfowFhZH"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="W4)e3sbN-C[AtksvJyb0"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="gZ[fn:P}L%w5Hu*/k[w]"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="_nrssb{}I|MM@7r=B2*[" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="?QRRgY%9F+.UW^4Wl#AO"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="`nZhdJ)1xBsAmv:WOH{$"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="%5v;FD87a~}IdxMU?0vb"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="~kv8]AFICio,y}2%8r:A"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="By?4fEM=/cIUg=PVf-%."> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="Xjk8qkB+rf0:[Z@JKl{4"> <value name="VALUE"> <block type="lists_getIndex" id="=M7:!eN*k,;Op`ncPBu)"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="4n4]sPE}}yOyCqIR6sK$"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> <value name="AT"> <block type="variables_get" id="5KN91f+6[?BIQQU^P+T/"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_for" id="/[|3}k{qYeK4wFiN6#lx"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="1FErI$q)qi=X^N_:%Js?"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="yJ$~7a^l4Gd#j:0c3$xr"> <value name="VALUE"> <block type="variables_get" id="Lh*:^j)}o|0jC8rH:.-+"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="T3rAediff*:%E88l7+4%"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="Bsy0,}!M#a)Xi$$B[t]z"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="ecXevA40kHBJjiNry:#^" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="K#Ey7v.v;+lcl{1f@5]H"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="a~E=mS#u_.VcC[jX^/;*"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="p}_MS2!F;,r~o9#j=$`e"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="Wr7+iV$a;ynQ,P%0v/|h"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="7DDk.nAP2`-o[3:5T/`V"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="95Wkc=Wn9wjOL/~emwC:"> <value name="VALUE"> <block type="lists_getIndex" id="):n}4;0GiBs#gE+_-.uf"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="WCs.rt_18?skHj|HC;)H"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> <value name="AT"> <block type="variables_get" id="dA]HyO~W)iY5ROXqc$PI"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="variables_set" id="x8t?3^{cNVFaKtPFnFq9"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> <value name="VALUE"> <block type="math_arithmetic" id="2+`tDY!LQG^9AZO8#!ZQ" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="(_=}+a~Ov.r2s~-^a_*5"> <field name="NUM">1000</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="D.`(%|9dOcm*(umN9bT@" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="u7f(0GaP.#L;(fYVBLIF"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="]@3~@l|_;uO[L%2ioP,k"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> </block> </value> <next> <block type="control" id="E.QKHpVBex}})iCx|o|3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text_join" id="r1UQi]J^lm7$v9OOADL%"> <mutation items="2"></mutation> <value name="ADD0"> <block type="convert_from_date" id="TgQBU@2m$Aam**8naRqf"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">hh:mm</field> <value name="VALUE"> <block type="math_arithmetic" id="vFX,u4337mHL^[94MZjL"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="time_get" id="WGy*s;07oKI/J`GDI-x3"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">object</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="%/#p`[h/wlvqSaXg{l2J"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="text" id="+v9neh|_70u#CP~sT+@%"> <field name="TEXT"> Uhr</field> </block> </value> </block> </value> <next> <block type="variables_set" id="nhKmUFQhs[6|q%}ff0,i"> <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field> <value name="VALUE"> <block type="math_round" id="x}`o/-C2Wlv:@=^_3G[a"> <field name="OP">ROUNDDOWN</field> <value name="NUM"> <shadow type="math_number" id="Rguwmsm{fn2;p`R/F+a:"> <field name="NUM">3.1</field> </shadow> <block type="math_arithmetic" id="+onb0BIs?/9$Yw3z|L~1" inline="false"> <field name="OP">DIVIDE</field> <value name="A"> <shadow type="math_number" id="1ayYAO}MFY09NC(V(*GM"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="s!0#t?dmhC6%l^`PxZe}" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="#7%I3W~1uE-TD~wta#+4"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="SgkpuEuN:JsZXnT2uiEq"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="qn{!2^XJ4`(v,M5e*2D("> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> <value name="B"> <shadow type="math_number" id="^L@[tikpu/4]}P`vZMd!"> <field name="NUM">60</field> </shadow> </value> </block> </value> </block> </value> <next> <block type="variables_set" id="Ig)k@jiA9xaKTc]*wBI1"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> <value name="VALUE"> <block type="math_arithmetic" id="7;16331LR(~*?2+JX6w(" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="CIIcN4{7e~{BnyvZ*~^6"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id=";3*On@WOxyMp^0y1_Z(Y" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="b%.CyBM,CrX$vS8~1tsR"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="G)4-/!z*)m%l/V.ry4?R"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> <value name="B"> <shadow type="math_number" id=".+85]3KB6[(gBZ%[,7Y~"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="zmhqTi9sN}dQKx97##xL" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="lis_nxPR2u]H-3F[$b~S"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="Bt;RhM}rb7h:@KbT}11W"> <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field> </block> </value> <value name="B"> <shadow type="math_number" id="LKQ#wr7Q=}y?2oYqM^Z("> <field name="NUM">60</field> </shadow> </value> </block> </value> </block> </value> <next> <block type="controls_if" id="NQRm#kW6C~H}~,#%L^7%"> <value name="IF0"> <block type="logic_compare" id="LB3RPmG+6NgIm[`*dHW*"> <field name="OP">LT</field> <value name="A"> <block type="variables_get" id="x8kn5l:/}[T/I1{38:!m"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> </block> </value> <value name="B"> <block type="math_number" id="4MfeA;EPvu1_2Q5)5*18"> <field name="NUM">10</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="S4e+8dy%x$|x`kw^Y1eG"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> <value name="VALUE"> <block type="text_join" id="m8@abxaQFWUShO4Yh?^e"> <mutation items="2"></mutation> <value name="ADD0"> <block type="text" id="CGW`SmYv*y^!z[QWs^o["> <field name="TEXT">0</field> </block> </value> <value name="ADD1"> <block type="variables_get" id="jhU!RpxkLcDqpJhV*2c2"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> </block> </value> </block> </value> </block> </statement> <next> <block type="control" id="Ea:z~+62@$PdX^kjvAcF"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_restzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text_join" id="Ha28o];Hw|$Cmy5!r;{L"> <mutation items="4"></mutation> <value name="ADD0"> <block type="variables_get" id="7OYB3%b#mpP$M/XIeJ%S"> <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field> </block> </value> <value name="ADD1"> <block type="text" id="qD7(2)-oK%;2Rz.5k,:`"> <field name="TEXT">:</field> </block> </value> <value name="ADD2"> <block type="variables_get" id="zNo@n~vAZH2|)3f|_NT}"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> </block> </value> <value name="ADD3"> <block type="text" id="gMw;QinOi/kC}T?H,Gbn"> <field name="TEXT"> Min.</field> </block> </value> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="timeouts_clearinterval" id="Jb@;uzYL;m`:c=QqzD4L"> <field name="NAME">calc</field> <next> <block type="variables_set" id="iv;KGC[hF6MD=bcKz-}~"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> <value name="VALUE"> <block type="logic_boolean" id="V0z@IGk2vj.t5+#2j3f;"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="VSZMp_fJpd1OzYCY=~xN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="b8vzkml]yd@f[0(Q`e(2"> <field name="TEXT"></field> </block> </value> <next> <block type="control" id="AIf3cY6ex%9}xpyKmOtB"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_restzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="nX.)Ffq{`}-Hsq,#!6^6"> <field name="TEXT"></field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> -
<block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="q-.)uV_$xX9EqI#0)1V{" x="-37" y="-270"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="3Y]sGqJzX97#Y#bnc%2B"> <field name="oid">kodi.0.state</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="#KCO]0`h|hPacKdL)=A2"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="Fk*MZyx-?jaWVfOUD74{" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="f;Y93jeAj5hLE=HpAXci"> <field name="OP">NEQ</field> <value name="A"> <block type="get_value" id="+oIYTrzhXShgXD?-dx?!"> <field name="ATTR">val</field> <field name="OID">kodi.0.state</field> </block> </value> <value name="B"> <block type="text" id="L7`/vLtiabj}GQ5_)n?I"> <field name="TEXT">stop</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="S;@tsc#Y9J{l-nz(8#%L"> <field name="OP">NEQ</field> <value name="A"> <block type="variables_get" id="_lYj.M;X6{:Ig+t1H-OG"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> </block> </value> <value name="B"> <block type="logic_boolean" id=":eRp?twu(kMNOV|nraj#"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_setinterval" id="uGdM,D)hhj,Ipm210S*$"> <field name="NAME">calc</field> <field name="INTERVAL">1000</field> <field name="UNIT">ms</field> <statement name="STATEMENT"> <block type="variables_set" id="0o{kX1g9TrRziofKKE`n"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> <value name="VALUE"> <block type="logic_boolean" id="57_A}S_9aHo-D7/*Q-bz"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="fTK`7dy@}I9{xOUk:fdm"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> <value name="VALUE"> <block type="lists_split" id="fSNHlFM[e|2s~?~WLoA]"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="%}I/[z=}v|bA_s+cN3T+"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time_total</field> </block> </value> <value name="DELIM"> <shadow type="text" id="bO/MuTT:URPjI@SOF^wu"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id="3L:9B.c/-jdK~YPS;}kk"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> <value name="VALUE"> <block type="lists_split" id="m0vWY?4A}Fy?zECIMa-g"> <mutation mode="SPLIT"></mutation> <field name="MODE">SPLIT</field> <value name="INPUT"> <block type="get_value" id="cmBA^z.eb9hODfdHQbW8"> <field name="ATTR">val</field> <field name="OID">kodi.0.info.playing_time</field> </block> </value> <value name="DELIM"> <shadow type="text" id=";o/sw@k#dD0mWkC4+b)M"> <field name="TEXT">:</field> </shadow> </value> </block> </value> <next> <block type="variables_set" id=";/]R)Ct0Dfu6i-d@fN1="> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="VALUE"> <block type="math_number" id="!A%IT%#arX*{$UY8=Kva"> <field name="NUM">0</field> </block> </value> <next> <block type="variables_set" id="%LYJ{05i.|T3]O%OZlti"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="VALUE"> <block type="math_number" id="-:ZTaSM~NWM#h9LoWuBz"> <field name="NUM">0</field> </block> </value> <next> <block type="controls_for" id="2R-$*vTVI{p#n(T8RV.d"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="yo3lqjuQw}eovRb+XXQ?"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="030ssz#WyY6qdm{Y]+%7"> <value name="VALUE"> <block type="variables_get" id="LtjmBy}A-?%QRfowFhZH"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="W4)e3sbN-C[AtksvJyb0"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="gZ[fn:P}L%w5Hu*/k[w]"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="_nrssb{}I|MM@7r=B2*[" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="?QRRgY%9F+.UW^4Wl#AO"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="`nZhdJ)1xBsAmv:WOH{$"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="%5v;FD87a~}IdxMU?0vb"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="~kv8]AFICio,y}2%8r:A"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="By?4fEM=/cIUg=PVf-%."> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="Xjk8qkB+rf0:[Z@JKl{4"> <value name="VALUE"> <block type="lists_getIndex" id="=M7:!eN*k,;Op`ncPBu)"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="4n4]sPE}}yOyCqIR6sK$"> <field name="VAR" id="Gv49fQ40~+/ya6#JMvO}">time_total</field> </block> </value> <value name="AT"> <block type="variables_get" id="5KN91f+6[?BIQQU^P+T/"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="controls_for" id="/[|3}k{qYeK4wFiN6#lx"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> <value name="FROM"> <shadow type="math_number" id="1FErI$q)qi=X^N_:%Js?"> <field name="NUM">1</field> </shadow> </value> <value name="TO"> <shadow type="math_number"> <field name="NUM">10</field> </shadow> <block type="lists_length" id="yJ$~7a^l4Gd#j:0c3$xr"> <value name="VALUE"> <block type="variables_get" id="Lh*:^j)}o|0jC8rH:.-+"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> </block> </value> <value name="BY"> <shadow type="math_number" id="T3rAediff*:%E88l7+4%"> <field name="NUM">1</field> </shadow> </value> <statement name="DO"> <block type="math_change" id="Bsy0,}!M#a)Xi$$B[t]z"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> <value name="DELTA"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="ecXevA40kHBJjiNry:#^" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="K#Ey7v.v;+lcl{1f@5]H"> <field name="OP">POWER</field> <value name="A"> <shadow type="math_number" id="a~E=mS#u_.VcC[jX^/;*"> <field name="NUM">60</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="p}_MS2!F;,r~o9#j=$`e"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="Wr7+iV$a;ynQ,P%0v/|h"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> <value name="B"> <shadow type="math_number" id="7DDk.nAP2`-o[3:5T/`V"> <field name="NUM">1</field> </shadow> </value> </block> </value> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="convert_tonumber" id="95Wkc=Wn9wjOL/~emwC:"> <value name="VALUE"> <block type="lists_getIndex" id="):n}4;0GiBs#gE+_-.uf"> <mutation statement="false" at="true"></mutation> <field name="MODE">GET</field> <field name="WHERE">FROM_END</field> <value name="VALUE"> <block type="variables_get" id="WCs.rt_18?skHj|HC;)H"> <field name="VAR" id="8?J4Jmf7%_-wS9!yell|">time</field> </block> </value> <value name="AT"> <block type="variables_get" id="dA]HyO~W)iY5ROXqc$PI"> <field name="VAR" id="7gbI~lkqQ~M|C;mJ+cDq">i</field> </block> </value> </block> </value> </block> </value> </block> </value> </block> </statement> <next> <block type="variables_set" id="x8t?3^{cNVFaKtPFnFq9"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> <value name="VALUE"> <block type="math_arithmetic" id="2+`tDY!LQG^9AZO8#!ZQ" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="(_=}+a~Ov.r2s~-^a_*5"> <field name="NUM">1000</field> </shadow> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="D.`(%|9dOcm*(umN9bT@" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="u7f(0GaP.#L;(fYVBLIF"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="]@3~@l|_;uO[L%2ioP,k"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> </block> </value> <next> <block type="control" id="E.QKHpVBex}})iCx|o|3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text_join" id="r1UQi]J^lm7$v9OOADL%"> <mutation items="2"></mutation> <value name="ADD0"> <block type="convert_from_date" id="TgQBU@2m$Aam**8naRqf"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">hh:mm</field> <value name="VALUE"> <block type="math_arithmetic" id="vFX,u4337mHL^[94MZjL"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="time_get" id="WGy*s;07oKI/J`GDI-x3"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">object</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="%/#p`[h/wlvqSaXg{l2J"> <field name="VAR" id="fB}3.DkAG[Zns[jkc^B)">diff</field> </block> </value> </block> </value> </block> </value> <value name="ADD1"> <block type="text" id="+v9neh|_70u#CP~sT+@%"> <field name="TEXT"> Uhr</field> </block> </value> </block> </value> <next> <block type="variables_set" id="nhKmUFQhs[6|q%}ff0,i"> <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field> <value name="VALUE"> <block type="math_round" id="x}`o/-C2Wlv:@=^_3G[a"> <field name="OP">ROUNDDOWN</field> <value name="NUM"> <shadow type="math_number" id="Rguwmsm{fn2;p`R/F+a:"> <field name="NUM">3.1</field> </shadow> <block type="math_arithmetic" id="+onb0BIs?/9$Yw3z|L~1" inline="false"> <field name="OP">DIVIDE</field> <value name="A"> <shadow type="math_number" id="1ayYAO}MFY09NC(V(*GM"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="s!0#t?dmhC6%l^`PxZe}" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="#7%I3W~1uE-TD~wta#+4"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="SgkpuEuN:JsZXnT2uiEq"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="qn{!2^XJ4`(v,M5e*2D("> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> <value name="B"> <shadow type="math_number" id="^L@[tikpu/4]}P`vZMd!"> <field name="NUM">60</field> </shadow> </value> </block> </value> </block> </value> <next> <block type="variables_set" id="Ig)k@jiA9xaKTc]*wBI1"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> <value name="VALUE"> <block type="math_arithmetic" id="7;16331LR(~*?2+JX6w(" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="CIIcN4{7e~{BnyvZ*~^6"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id=";3*On@WOxyMp^0y1_Z(Y" inline="false"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="b%.CyBM,CrX$vS8~1tsR"> <field name="VAR" id="z6@)Eo%V776?qOlzgeJq">sekunden_total</field> </block> </value> <value name="B"> <shadow type="math_number"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="G)4-/!z*)m%l/V.ry4?R"> <field name="VAR" id="c70ch.|4qGYP3!UEvS8x">sekunden</field> </block> </value> </block> </value> <value name="B"> <shadow type="math_number" id=".+85]3KB6[(gBZ%[,7Y~"> <field name="NUM">1</field> </shadow> <block type="math_arithmetic" id="zmhqTi9sN}dQKx97##xL" inline="false"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="lis_nxPR2u]H-3F[$b~S"> <field name="NUM">1</field> </shadow> <block type="variables_get" id="Bt;RhM}rb7h:@KbT}11W"> <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field> </block> </value> <value name="B"> <shadow type="math_number" id="LKQ#wr7Q=}y?2oYqM^Z("> <field name="NUM">60</field> </shadow> </value> </block> </value> </block> </value> <next> <block type="controls_if" id="NQRm#kW6C~H}~,#%L^7%"> <value name="IF0"> <block type="logic_compare" id="LB3RPmG+6NgIm[`*dHW*"> <field name="OP">LT</field> <value name="A"> <block type="variables_get" id="x8kn5l:/}[T/I1{38:!m"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> </block> </value> <value name="B"> <block type="math_number" id="4MfeA;EPvu1_2Q5)5*18"> <field name="NUM">10</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="S4e+8dy%x$|x`kw^Y1eG"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> <value name="VALUE"> <block type="text_join" id="m8@abxaQFWUShO4Yh?^e"> <mutation items="2"></mutation> <value name="ADD0"> <block type="text" id="CGW`SmYv*y^!z[QWs^o["> <field name="TEXT">0</field> </block> </value> <value name="ADD1"> <block type="variables_get" id="jhU!RpxkLcDqpJhV*2c2"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> </block> </value> </block> </value> </block> </statement> <next> <block type="control" id="Ea:z~+62@$PdX^kjvAcF"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_restzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text_join" id="Ha28o];Hw|$Cmy5!r;{L"> <mutation items="4"></mutation> <value name="ADD0"> <block type="variables_get" id="7OYB3%b#mpP$M/XIeJ%S"> <field name="VAR" id="HgJGj)ghP0%IGPO(|r4V">rest_min</field> </block> </value> <value name="ADD1"> <block type="text" id="qD7(2)-oK%;2Rz.5k,:`"> <field name="TEXT">:</field> </block> </value> <value name="ADD2"> <block type="variables_get" id="zNo@n~vAZH2|)3f|_NT}"> <field name="VAR" id="2aa2oIH5eFR9DL.}%Aq-">rest_sek</field> </block> </value> <value name="ADD3"> <block type="text" id="gMw;QinOi/kC}T?H,Gbn"> <field name="TEXT"> Min.</field> </block> </value> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="timeouts_clearinterval" id="Jb@;uzYL;m`:c=QqzD4L"> <field name="NAME">calc</field> <next> <block type="variables_set" id="iv;KGC[hF6MD=bcKz-}~"> <field name="VAR" id="-d4vHniCbHM?ag:={@Pk">skript_aktiv</field> <value name="VALUE"> <block type="logic_boolean" id="V0z@IGk2vj.t5+#2j3f;"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="VSZMp_fJpd1OzYCY=~xN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_endzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="b8vzkml]yd@f[0(Q`e(2"> <field name="TEXT"></field> </block> </value> <next> <block type="control" id="AIf3cY6ex%9}xpyKmOtB"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.sonstige.kodi_restzeit</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="nX.)Ffq{`}-Hsq,#!6^6"> <field name="TEXT"></field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block>@Kuddel
Wow, ich bin begeistert.
Beide Werte sind vorhanden. ich habe bei mir den wert auf 5 Sekunden angepasst.
aber was ist den "calc"rein optisch gesehen bei Restzeit 76:22, würde ich folgende Formatierung "01:16:22" ansprechender finden.
Klasse Ding. Vielen Dank für deine Mühe!
@Kuddel
@dos1973 calc ist die Schleife. kannst du ignorieren. habe das Skript schon wieder umgebaut.
nehme jetzt die Spielzeit als trigger.
baue seine Vorschlag mit der Formatierung morgen noch ein
@dos1973 sagte:
@paul53 kann man die Umrechnung der Restzeit evtl. besser bauen?
Ich habe das aktuell so umgesetzt:
Würde auch irgendwie mit Konvertierung gehen ?
Irgendwie so ?
@Kuddel sagte:
Ja, man muss die Zeitzone berücksichtigen.
@Kuddel sagte:
@paul53 ah okay.
habe zu dem Problem mal ein extra Threaad eröffnet:
https://forum.iobroker.net/topic/38326/sekunden-in-std-min-sek-formatieren/2
Auf die Zeitzonen wurde da auch schon hingewiesen.
Weiter bin ich aber dadurch auch nicht ^^
