  5. Brauche Hilfe um ein json abzurufen und auszuwerten
    6.4k
53 Beiträge 3 Kommentatoren 5.4k Aufrufe 2 Beobachtet
  • F fastfoot
    @Homoran wenn du die URL im Browser eingibst dann siehst du die JSON Daten? Kannst du mal ein komplettes JSON posten?
    @fastfoot sagte in Brauche Hilfe um ein json abzurufen und auszuwerten:
    Ja!
    Da habe ich es ja her
    Das war eins ;-)
    Ich hole dir gerne noch ein aktuelles
    EDIT:
    { "now" : 1603545549.7,
      "messages" : 1678929,
      "aircraft" : [
        {"hex":"3c4d8f","flight":"ABR1540 ","alt_baro":34075,"ias":263,"mach":0.764,"mag_heading":54.8,"baro_rate":64,"geom_rate":32,"version":0,"nac_p":0,"sil":0,"sil_type":"unknown","mlat":[],"tisb":[],"messages":29,"seen":3.5,"rssi":-23.2},
        {"hex":"3e3f1f","alt_baro":11075,"version":0,"nac_p":8,"sil":2,"sil_type":"unknown","mlat":[],"tisb":[],"messages":8,"seen":2.4,"rssi":-22.9},
        {"hex":"3c56f3","flight":"EWG53N  ","alt_baro":18725,"alt_geom":19150,"gs":354.9,"ias":288,"tas":376,"mach":0.612,"track":221.7,"track_rate":0.06,"roll":-0.4,"mag_heading":223.1,"baro_rate":2048,"geom_rate":2016,"squawk":"4132","emergency":"none","category":"A3","nav_qnh":1012.8,"nav_altitude_mcp":24000,"lat":51.072507,"lon":6.167068,"nic":8,"rc":186,"seen_pos":38.8,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":148,"seen":3.8,"rssi":-23.1},
        {"hex":"484160","flight":"KLM1631 ","alt_baro":41000,"alt_geom":41125,"gs":443.6,"ias":226,"tas":436,"mach":0.768,"track":159.7,"track_rate":-0.03,"roll":-0.4,"mag_heading":163.7,"baro_rate":64,"geom_rate":0,"squawk":"1000","category":"A0","nav_qnh":1013.2,"nav_altitude_mcp":41008,"lat":50.771453,"lon":6.746521,"nic":7,"rc":371,"seen_pos":3.4,"version":0,"nac_p":7,"nac_v":0,"sil":2,"sil_type":"unknown","mlat":[],"tisb":[],"messages":2832,"seen":2.6,"rssi":-20.3},
        {"hex":"3ddc04","mlat":[],"tisb":[],"messages":52,"seen":101.5,"rssi":-19.9},
        {"hex":"440395","flight":"EJU93MQ ","alt_baro":38000,"alt_geom":38425,"gs":414.3,"ias":242,"tas":432,"mach":0.764,"track":241.8,"track_rate":-0.03,"roll":0.4,"mag_heading":245.6,"baro_rate":0,"geom_rate":-32,"squawk":"1136","emergency":"none","category":"A3","nav_qnh":1013.6,"nav_altitude_mcp":38016,"lat":50.905655,"lon":7.165090,"nic":8,"rc":186,"seen_pos":1.2,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":653,"seen":0.5,"rssi":-20.2},
        {"hex":"4070e2","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":219,"seen":64.5,"rssi":-23.4},
        {"hex":"48548d","flight":"KLM73C  ","alt_baro":23600,"alt_geom":37350,"gs":451.2,"ias":233,"tas":414,"mach":0.724,"track":149.1,"track_rate":0.00,"roll":0.2,"mag_heading":149.9,"baro_rate":0,"geom_rate":-32,"squawk":"3177","emergency":"none","category":"A3","nav_qnh":1013.6,"nav_altitude_mcp":37024,"nav_altitude_fms":37008,"nav_modes":["autopilot","althold","tcas"],"lat":50.463464,"lon":7.402261,"nic":8,"rc":186,"seen_pos":45.5,"version":2,"nic_baro":1,"nac_p":10,"nac_v":2,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":3056,"seen":3.8,"rssi":-24.7},
        {"hex":"aa9300","flight":"UAL2777 ","alt_baro":29825,"alt_geom":30275,"gs":475.0,"ias":321,"tas":488,"mach":0.828,"track":317.6,"roll":0.2,"mag_heading":314.3,"baro_rate":1408,"geom_rate":1376,"squawk":"0635","emergency":"none","category":"A5","nav_qnh":1012.8,"nav_altitude_mcp":34016,"nav_heading":314.3,"lat":50.999313,"lon":6.929255,"nic":8,"rc":186,"seen_pos":43.6,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":2082,"seen":1.5,"rssi":-22.9},
        {"hex":"40697c","version":0,"sil_type":"unknown","mlat":[],"tisb":[],"messages":123,"seen":184.6,"rssi":-21.9},
        {"hex":"3c0ca5","category":"A3","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":514,"seen":90.3,"rssi":-23.4},
        {"hex":"3d11d6","mlat":[],"tisb":[],"messages":1345,"seen":165.9,"rssi":-23.0},
        {"hex":"3ded08","mlat":[],"tisb":[],"messages":2819,"seen":171.5,"rssi":-22.5}
      ich habe mir ein neues Spielzeug angeschafft.
      piAware01.png - piAware
      Seit Jahren wollte ich das schon umsetzen und komme jetzt endlich dazu.
      Wir wohnen relativ nahe am Flughafen Köln-Bonn und besonders nachts wenn die überladenen Frachtmaschinen von FedEx, UPS u.a. gegen 03:00 gefühlt die Antenne unseres Hauses streifen wollte ich gerne die Daten der Maschinen (insbesondere Flug, Aircraft-Typ, und ganz wichtig die Höhe) auswerten, da wir gerade außerhalb der Fördergrenze für Schallschutzmaßnahmen liegen, weil hier die Flugzeuge angeblich immer >1700m hoch sein sollen.
      Jetzt habe ich gestern das System zum laufen bekommen und kann über `http://<IP-des-Raspi>/dump1090-fa/data/aircraft.json die Daten abrufen.
        "messages" : 43742,
        "aircraft" : [
          {"hex":"407834","alt_baro":39025,"alt_geom":39275,"gs":481.2,"ias":238,"mach":0.772,"track":104.4,"mag_heading":107.6,"baro_rate":64,"geom_rate":32,"version":0,"nac_p":8,"nac_v":1,"sil":2,"sil_type":"unknown","mlat":[],"tisb":[],"messages":6,"seen":0.5,"rssi":-23.7},
          {"hex":"3c56e6","flight":"EWG9NA  ","alt_baro":5025,"alt_geom":5150,"gs":210.8,"ias":213,"tas":224,"mach":0.352,"track":265.1,"track_rate":-0.22,"roll":-2.3,"mag_heading":263.3,"baro_rate":3008,"geom_rate":2976,"squawk":"5022","emergency":"none","category":"A3","nav_qnh":1011.2,"nav_altitude_mcp":7008,"lat":50.841002,"lon":7.026062,"nic":8,"rc":186,"seen_pos":0.5,"version":2,"nic_baro":1,"nac_p":9,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":864,"seen":0.1,"rssi":-8.6},
          {"hex":"4855d1","flight":"KLM71B  ","alt_baro":37000,"alt_geom":37200,"gs":431.4,"ias":236,"tas":424,"mach":0.736,"track":133.9,"track_rate":0.00,"roll":-0.4,"mag_heading":142.6,"baro_rate":64,"geom_rate":32,"squawk":"0173","nav_qnh":1013.6,"nav_altitude_mcp":37024,"nav_altitude_fms":37008,"nav_modes":["autopilot","althold","tcas"],"lat":51.026420,"lon":7.245483,"nic":8,"rc":186,"seen_pos":0.5,"version":2,"nic_baro":1,"nac_p":9,"nac_v":2,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":235,"seen":0.0,"rssi":-19.3},
          {"hex":"06a0f6","flight":"QTR8009 ","alt_baro":28450,"alt_geom":28350,"gs":449.0,"ias":283,"tas":426,"mach":0.720,"track":104.8,"track_rate":0.00,"roll":-0.2,"mag_heading":110.4,"baro_rate":1536,"geom_rate":1632,"squawk":"0144","emergency":"none","category":"A5","nav_qnh":1013.6,"nav_altitude_mcp":35008,"nav_heading":110.4,"lat":50.319385,"lon":7.311847,"nic":8,"rc":186,"seen_pos":2.7,"version":2,"nic_baro":1,"nac_p":9,"nac_v":2,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":336,"seen":2.5,"rssi":-22.6},
          {"hex":"a762cc","flight":"UPS223  ","alt_baro":12350,"alt_geom":12500,"gs":338.6,"ias":258,"tas":310,"mach":0.488,"track":62.0,"track_rate":0.06,"roll":1.2,"mag_heading":60.5,"baro_rate":-448,"geom_rate":-480,"squawk":"2021","emergency":"none","category":"A5","nav_qnh":1013.6,"nav_altitude_mcp":8000,"nav_heading":59.8,"nav_modes":["tcas"],"lat":50.865646,"lon":6.797122,"nic":8,"rc":186,"seen_pos":0.3,"version":2,"nic_baro":1,"nac_p":10,"nac_v":1,"sil":3,"sil_type":"perhour","gva":2,"sda":2,"mlat":[],"tisb":[],"messages":668,"seen":0.1,"rssi":-16.6},
          {"hex":"3d1363","mlat":[],"tisb":[],"messages":193,"seen":139.5,"rssi":-22.9},
          {"hex":"3c4dc6","mlat":[],"tisb":[],"messages":1357,"seen":42.1,"rssi":-24.6}
      da würde ich mir dann die gemäß der lat und long am dichtesten fliegenden Maschinen unterhalb einer gewissen Höhe loggen.
      Leider scheitere ich mal wieder direkt am Anfang.
      Wie komme ich an das json?
      Ich bin mir ziemlich sicher, dass ich das schon mal irgendwo geschafft hatte, komme aber ums Verr*** nicht mehr drauf :-(
      Die weiteren Schritte würde ich gerne selber versuchen.
      Spätestens beim iterieren durch das Array werde ich wahrscheinlich wieder hängen bleiben.
      Ich denke, dass ich das json gerne in einer Variable speichern würde um mit dieser weiter zu arbeiten ???
      @Homoran Ansatz, um das Array in einer Variablen zu erzeugen. Die Bezeichnung der Variablen result ist vorgegeben.
        @paul53 sagte in Brauche Hilfe um ein json abzurufen und auszuwerten:
        Super heißen Dank!
        Da war ich schon fast.
        kannst du mir bitte noch erklären wie und wohin die "mit Ergebnissen" hinfließen und wie man da wieder ran kommt.
        Das war nämlich mein Denk-Knoten.
          Super heißen Dank!
          @Homoran sagte:
          Die Ergebnisse werden an die Callback-Funktion (das Maul) in den Variablen error, response und result übergeben. Das JSON wird in result übergeben.
            @Homoran sagte:
            und das muss man wissen :-(
            die so bezeichneten Variablen liegen nicht irgendwo als pulldown vor?
            Dann habe ich es schon richtig geahnt, nur verzweifelt den passende Block gesucht
            Das Result ist
            [{'hex':'89644e','flight':'UAE184 ','alt_baro':34975,'alt_geom':35475,'gs':517.7,'ias':281,'tas':474,'mach':0.824,'track':99.9,'roll':0,'mag_heading':95.6,'baro_rate':576,'geom_rate':512,'squawk':'0112','category':'A5','nav_qnh':1012.8,'nav_altitude_mcp':35008,'lat':50.293259,'lon':6.842459,'nic':8,'rc':186,'seen_pos':2.6,'version':0,'nic_baro':1,'nac_p':8,'nac_v':1,'sil':2,'sil_type':'unknown','mlat':[],'tisb':[],'messages':148,'seen':2.6,'rssi':-22.8},{'hex':'3d1bb0','mlat':[],'tisb':[],'messages':131,'seen':133,'rssi':-22.2},{'hex':'407510','flight':'WUK1329 ','alt_baro':35025,'alt_geom':35475,'gs':489.5,'ias':265,'tas':446,'mach':0.78,'track':121.1,'track_rate':0.06,'roll':1.2,'mag_heading':117.4,'baro_rate':-128,'geom_rate':-128,'squawk':'2273','emergency':'none','category':'A3','nav_qnh':1012.8,'nav_altitude_mcp':35008,'lat':50.667409,'lon':7.959669,'nic':7,'rc':371,'seen_pos':22.6,'version':2,'nic_baro':1,'nac_p':8,'nac_v':1,'sil':3,'sil_type':'perhour','gva':1,'sda':3,'mlat':[],'tisb':[],'messages':2810,'seen':20.8,'rssi':-22.3},{'hex':'3c4583','flight':'BOX462 ','alt_baro':28000,'alt_geom':28425,'gs':486.4,'ias':335,'tas':500,'mach':0.844,'track':317.9,'roll':0,'mag_heading':314.8,'baro_rate':64,'geom_rate':32,'squawk':'0637','emergency':'none','category':'A5','nav_qnh':1012.8,'nav_altitude_mcp':28000,'nav_heading':315,'lat':50.970016,'lon':6.930814,'nic':8,'rc':186,'seen_pos':7.6,'version':2,'nic_baro':1,'nac_p':9,'nac_v':1,'sil':3,'sil_type':'perhour','gva':2,'sda':2,'mlat':[],'tisb':[],'messages':2000,'seen':1.8,'rssi':-21.1},{'hex':'3c5ee4','category':'A3','version':1,'sil_type':'unknown','mlat':[],'tisb':[],'messages':377,'seen':292.2,'rssi':-22.4},{'hex':'484cb6','alt_baro':39000,'alt_geom':39250,'gs':449.9,'ias':228,'tas':418,'mach':0.74,'track':145.8,'track_rate':0,'roll':0.4,'mag_heading':147.3,'baro_rate':32,'geom_rate':0,'squawk':'0157','category':'A0','lat':50.253296,'lon':7.449526,'nic':8,'rc':186,'seen_pos':52.7,'version':0,'nac_p':8,'nac_v':0,'sil':2,'sil_type':'unknown','mlat':[],'tisb':[],'messages':6980,'seen':31.9,'rssi':-24.2},{'hex':'471f5a','category':'A3','version':2,'sil_type':'perhour','mlat':[],'tisb':[],'messages':664,'seen':248.9,'rssi':-23},{'hex':'484acc','category':'A3','version':2,'sil_type':'perhour','mlat':[],'tisb':[],'messages':4599,'seen':170.9,'rssi':-24.4}]
            und den muss ich jetzt splitten -
            Danke erst einmal
            F 1 Antwort Letzte Antwort
              Das Result ist
              Danke erst einmal
              F Online
              F Online
              fastfoot
              schrieb am zuletzt editiert von fastfoot
              @Homoran sagte in Brauche Hilfe um ein json abzurufen und auszuwerten:
              da empfehle ich jsonata, geiles Tool und gibt es auch im Blockly :-) hier mal ein paar Daten
              Jsonata Ausdruck:
              aircraft[flight.$contains(/./)].{
                  "flight":flight,
                  "lat":lat,
                  "lon":lon,
                  "alt_baro":alt_baro
              Blockly
              Gefilterte Daten
              [{'flight':'ABR1540 ','alt_baro':34075},{'flight':'EWG53N ','lat':51.072507,'lon':6.167068,'alt_baro':18725},{'flight':'KLM1631 ','lat':50.771453,'lon':6.746521,'alt_baro':41000},{'flight':'EJU93MQ ','lat':50.905655,'lon':7.16509,'alt_baro':38000},{'flight':'KLM73C ','lat':50.463464,'lon':7.402261,'alt_baro':23600},{'flight':'UAL2777 ','lat':50.999313,'lon':6.929255,'alt_baro':29825}]
              Spielen mit den Ausdrücken auf https://try.jsonata.org/
              • F fastfoot
                Jsonata Ausdruck:
                    "flight":flight,
                    "lat":lat,
                    "lon":lon,
                    "alt_baro":alt_baro
                Blockly
                Gefilterte Daten
                janz langsam mit den alten Pferden ;-)
                ich will das ganze ja auch verstehen.
                Bin ja schon ganz stolz, dass ich das json(-Array) iteriert bekommen habe.
                Habe dann mal zur Übung die Flugnummer genommen
                Da ich aber nicht von allen Flugzeugen immer alle Daten reinbekomme muss ich jetzt die undefined abfangen.
                Das Ganze ist für mich auch eine Übung mich immer tiefer in js einzuarbeiten
                Optimierungen, wie @paul53 sie bis in den Exzess treibt kommen erst vieeeeeel später
                F paul53P 2 Antworten Letzte Antwort
                  F Online
                  F Online
                  fastfoot
                  Du kannst ja auch über die gefilterten Daten iterieren, letztendlich ist das Ergebnis auch 'nur' ein JSON. Arbeit haste da noch genug, ist aber einfacher, gerade als Anfänger
                  • F fastfoot
                    das stimmt.
                    Wollte jetzt Höhe, lat und long auskesen.
                    Dann kommt noch Pythagoras in der Ebene zu meinem Wohnort und vor dem Pythagoras im dreidimensionalen Raum (Entfernung Flugzeug zum Haus) graut mir auch schon.
                    Dann wollte ich das Ergebnis jeweils in ein weiteres Json abspeichern, wenn der Flieger am dichtesten bei mir ist und diese Liste dann in vis darstellen.
                    Das ist für mich ein Jahresprogramm ;-)
                    Aber ich bilde mir ein, man lernt am besten wenn man weiß was man will und ein Ziel hat
                    EDIT:
                    Habe mir dein Blockly jetzt doch näher angesehen, war einfach zu neugierig.
                    Mit dem JSONata kann man das UrsprungsJSON also filtern und dann nur noch mit den Datensätzen, die für mich relevant wären weiterarbeiten?
                      @Homoran sagte:
                        @Homoran sagte:
                        @paul53 ich habe wieder zu komliziert (nämlich umgekehrt) gedacht und mit Falls nicht undefined versucht
                          das stimmt.
                          EDIT:
                          F Online
                          F Online
                          fastfoot
                          Genau, habe den Ausdruck extra formatiert, einfach die Daten, welche du brauchst anhängen und dann hast du nur die Daten welche du brauchst, lan, lon und Höhe sind ja schon drin.. Den Rest machst du wie von Paul gezeigt
                            @fastfoot
                            DANKE!
                            das muss ich jetzt erst einmal verdauen
                              @fastfoot
                              DANKE!
                              F Online
                              F Online
                              fastfoot
                              vor einer Woche konnte ich jsonata gerade mal buchstabieren, jetzt gehts schon recht flott :-) Genau so wird es dir auch gehen mit deinem Projekt. Viel Erfolg.
                              PS: Die Daten die du ziehst sind kostenpflichtig?
                              • F fastfoot
                                Nö, ich fange sie mit einem DVB-T Receiver an einem RasPi selber ab
                                • F fastfoot
                                  Jsonata Ausdruck:
                                      "flight":flight,
                                      "lat":lat,
                                      "lon":lon,
                                      "alt_baro":alt_baro
                                  Blockly
                                  Gefilterte Daten
                                  Habe ich jetzt ein wenig gemacht.
                                  Das erträumte Ergebnis war ernüchternd ;-)
                                  Habe dann sogar das Unmögliche getan und die Doku gelesen. Aber auch dort keinen korrekten Hinweis auf meinen Wunsch erhalten:
                                  kann man in dem expression bereits z.B. (Wohnort - x) < lat > (Wohnort +x) filtern?
                                  Habe dazu nichts gefunden, resp. bekam nur ERROR
                                    F Online
                                    F Online
                                    fastfoot
                                    Du kannst im Filter(alles zwischen den eckigen Klammern) folgendes eingeben
                                    aircraft[lat >50 and lat < 52].{
                                        "flight":flight,
                                        "lat":lat,
                                        "lon":lon,
                                        "alt_baro":alt_baro
                                    probiere das mal mit fixen Werten zuerst, später kannst du ja Variablen einfügen. Hier habe ich den Filter für die Flugnummer entfernt, weil ich denke dass lat und lon eh nur da sind wenn eine Flugnummer existiert. denke daran dass du einen Punkt statt Komma in der Angabe benutzt, also zB lat > 50.0400776
                                    • F fastfoot
                                          "flight":flight,
                                          "lat":lat,
                                          "lon":lon,
                                          "alt_baro":alt_baro
                                      @fastfoot werde ich testen - danke!
                                      genau das hatte ich vor, zumal ich nicht weiß wie ich an die Geokoordinaten aus der Systemsteuerung komme
                                      nicht mal dann.
                                      Wenn der Empfang schlecht ist heisst es:
                                      Total Aircraft: 7
                                      With Positions: 4
                                      Die 7 haben ihr Kennzeichen aber nicht alle eine aktuelle Position.
                                      Die Daten werden jede Sekunde aktualisiert
                                        nicht mal dann.
                                        Total Aircraft: 7
                                        With Positions: 4
                                        F Online
                                        F Online
                                        fastfoot
                                        @Homoran solange du noch entwickelst, würde ich die Aktualisierungsrate nicht so niedrig setzen, damit du nicht durcheinander kommst. der letzte Filter bringt nur Daten wenn Positionsdaten da sind, könntest auch noch die Höhe einbeziehen. Ich würde mir ein JSON in eine Variable schreiben und mit diesen Daten hantieren bis das Ergebnis stimmt, dann erst würde ich live Daten auf mein Programm loslassen
                                          @fastfoot
                                          Habe jetzt dem JSONata noch die maximale Höhe mitgegeben da laufe ich in das nächste für mich nicht nachvollziehbare Problem:
                                          es kommt wieder undefined :-(
                                          17:07:00.047	info	javascript.0 (13728) script.js.Fliegenklatsche: undefined
                                          17:07:15.012	info	javascript.0 (13728) script.js.Fliegenklatsche: undefined
                                          das json ist im Moment leer
                                          Außerdem erscheint immer mal wieder ein parser Error (IMHO vom debug), den ich auch nicht verstehe
