  4. enigma 2 error
    6.8k
enigma 2 error
enigma2 adapter
13 Beiträge 2 Kommentatoren 710 Aufrufe 2 Beobachtet
  • D denjo
    @Thomas-Braun könntest du mir das mehr erklären? steh gerade aufn schlauch
    @denjo Den Befehl in die Konsole hacken und die Ausgabe hier als Text in CodeTags posten.
    Und auch das noch:
    whoami && who -r && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    D 2 Antworten Letzte Antwort
      Und auch das noch:
      denjo
      schrieb am zuletzt editiert von denjo
      @Thomas-Braun hier
      pi@raspberrypi:~ $ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
      [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] On node 0 totalpages: 504832
      [    0.000000]   DMA zone: 2304 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 308224 pages, LIFO batch:63
      [    0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
      [    0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 502528
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:00:D0:C6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: mapped [mem 0x19400000-0x1d400000] (64MB)
      [    0.000000] Memory: 1647812K/2019328K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 109372K reserved, 262144K cma-reserved, 1232896K highmem)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 30051 entries in 59 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0
      [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
      [    0.000032] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
      [    0.000111] bcm2835: system timer (irq = 17)
      [    0.000778] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000798] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000818] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000835] Switching to timer-based delay loop, resolution 18ns
      [    0.001077] Console: colour dummy device 80x30
      [    0.001571] printk: console [tty1] enabled
      [    0.001631] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [    0.001674] pid_max: default: 32768 minimum: 301
      [    0.001998] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.002039] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.003210] Disabling memory control group subsystem
      [    0.003325] CPU: Testing write buffer coherency: ok
      [    0.003808] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.004651] Setting up static identity map for 0x200000 - 0x20003c
      [    0.004853] rcu: Hierarchical SRCU implementation.
      [    0.005484] smp: Bringing up secondary CPUs ...
      [    0.006628] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.007887] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.009090] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.009233] smp: Brought up 1 node, 4 CPUs
      [    0.009302] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [    0.009328] CPU: All CPU(s) started in HYP mode.
      [    0.009350] CPU: Virtualization extensions available.
      [    0.010134] devtmpfs: initialized
      [    0.023054] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [    0.023321] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.023368] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.031106] pinctrl core: initialized pinctrl subsystem
      [    0.032144] NET: Registered protocol family 16
      [    0.035717] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.037349] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.037383] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.037718] Serial: AMBA PL011 UART driver
      [    0.041116] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.060887] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-09-02 21:13, variant start
      [    0.070870] raspberrypi-firmware soc:firmware: Firmware hash is 4439d2aaa6c376a2d1ef4402f142e1cf4de37c43
      [    0.123604] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.128041] vgaarb: loaded
      [    0.128516] SCSI subsystem initialized
      [    0.128752] usbcore: registered new interface driver usbfs
      [    0.128850] usbcore: registered new interface driver hub
      [    0.128980] usbcore: registered new device driver usb
      [    0.130466] clocksource: Switched to clocksource arch_sys_counter
      [    0.881220] VFS: Disk quotas dquot_6.6.0
      [    0.881349] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.881537] FS-Cache: Loaded
      [    0.881732] CacheFiles: Loaded
      [    0.882533] simple-framebuffer: probe of 0.framebuffer failed with error -12
      [    0.892003] thermal_sys: Registered thermal governor 'step_wise'
      [    0.892374] NET: Registered protocol family 2
      [    0.893158] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.893209] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.893303] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.893391] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.893544] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.893592] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.893844] NET: Registered protocol family 1
      [    0.894537] RPC: Registered named UNIX socket transport module.
      [    0.894566] RPC: Registered udp transport module.
      [    0.894590] RPC: Registered tcp transport module.
      [    0.894613] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.894646] PCI: CLS 0 bytes, default 64
      [    0.896412] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
      [    0.898524] Initialise system trusted keyrings
      [    0.898763] workingset: timestamp_bits=14 max_order=19 bucket_order=5
      [    0.909369] FS-Cache: Netfs 'nfs' registered for caching
      [    0.910100] NFS: Registering the id_resolver key type
      [    0.910146] Key type id_resolver registered
      [    0.910171] Key type id_legacy registered
      [    0.910205] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.911348] Key type asymmetric registered
      [    0.911377] Asymmetric key parser 'x509' registered
      [    0.911553] bounce: pool size: 64 pages
      [    0.911623] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.911852] io scheduler mq-deadline registered
      [    0.911879] io scheduler kyber registered
      [    0.915634] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    0.915675] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      [    0.915760] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
      [    0.915843] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0000000000
      [    0.972611] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
      [    0.972957] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    0.972991] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    0.973024] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
      [    0.973099] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    0.973352] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    0.976717] PCI: bus0: Fast back to back transfers disabled
      [    0.976952] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    0.977111] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    0.977543] pci 0000:01:00.0: PME# supported from D0 D3cold
      [    0.980936] PCI: bus1: Fast back to back transfers disabled
      [    0.981008] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    0.981046] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    0.981143] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    0.981179] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    0.981487] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [    0.981731] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
      [    0.982121] pcieport 0000:00:00.0: AER: enabled with IRQ 55
      [    0.982434] pci 0000:01:00.0: enabling device (0140 -> 0142)
      [    0.989063] iproc-rng200 fe104000.rng: hwrng registered
      [    0.989405] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    0.990036] vc-sm: Videocore shared memory driver
      [    0.990639] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    1.002294] brd: module loaded
      [    1.014147] loop: module loaded
      [    1.015477] Loading iSCSI transport class v2.0-870.
      [    1.017399] libphy: Fixed MDIO Bus: probed
      [    1.017995] bcmgenet fd580000.ethernet: failed to get enet clock
      [    1.018029] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    1.018064] bcmgenet fd580000.ethernet: failed to get enet-wol clock
      [    1.018099] bcmgenet fd580000.ethernet: failed to get enet-eee clock
      [    1.018138] bcmgenet: Skipping UMAC reset
      [    1.030542] libphy: bcmgenet MII bus: probed
      [    1.110577] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.111575] usbcore: registered new interface driver r8152
      [    1.111656] usbcore: registered new interface driver lan78xx
      [    1.111739] usbcore: registered new interface driver smsc95xx
      [    1.112153] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.112200] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    1.114540] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
      [    1.115807] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
      [    1.115844] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.115876] usb usb1: Product: xHCI Host Controller
      [    1.115903] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
      [    1.115929] usb usb1: SerialNumber: 0000:01:00.0
      [    1.116516] hub 1-0:1.0: USB hub found
      [    1.116621] hub 1-0:1.0: 1 port detected
      [    1.117158] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.117198] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    1.117239] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.117692] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
      [    1.117728] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.117759] usb usb2: Product: xHCI Host Controller
      [    1.117786] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
      [    1.117813] usb usb2: SerialNumber: 0000:01:00.0
      [    1.118371] hub 2-0:1.0: USB hub found
      [    1.118465] hub 2-0:1.0: 4 ports detected
      [    1.119916] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.120199] dwc_otg: FIQ enabled
      [    1.120211] dwc_otg: NAK holdoff enabled
      [    1.120222] dwc_otg: FIQ split-transaction FSM enabled
      [    1.120236] Module dwc_common_port init
      [    1.120694] usbcore: registered new interface driver uas
      [    1.120815] usbcore: registered new interface driver usb-storage
      [    1.121027] mousedev: PS/2 mouse device common for all mice
      [    1.123054] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.125532] sdhci: Secure Digital Host Controller Interface driver
      [    1.125562] sdhci: Copyright(c) Pierre Ossman
      [    1.126134] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [    1.126662] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.130348] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.130715] hidraw: raw HID events driver (C) Jiri Kosina
      [    1.130899] usbcore: registered new interface driver usbhid
      [    1.130925] usbhid: USB HID core driver
      [    1.131917] vchiq: vchiq_init_state: slot_zero = (ptrval)
      [    1.133786] [vc_sm_connected_init]: start
      [    1.142740] [vc_sm_connected_init]: end - returning 0
      [    1.144802] Initializing XFRM netlink socket
      [    1.144852] NET: Registered protocol family 17
      [    1.144967] Key type dns_resolver registered
      [    1.145346] Registering SWP/SWPB emulation handler
      [    1.145656] registered taskstats version 1
      [    1.145687] Loading compiled-in X.509 certificates
      [    1.146192] Key type ._fscrypt registered
      [    1.146218] Key type .fscrypt registered
      [    1.156162] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.156249] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
      [    1.162232] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.163164] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.163195] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.211826] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    1.213495] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.215162] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.218133] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.219796] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.226929] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      [    1.229732] of_cfs_init
      [    1.229984] of_cfs_init: OK
      [    1.231088] Waiting for root device PARTUUID=738a4d67-02...
      [    1.267483] random: fast init done
      [    1.325691] mmc0: new ultra high speed DDR50 SDHC card at address 0001
      [    1.327607] mmcblk0: mmc0:0001 00000 29.8 GiB
      [    1.331418]  mmcblk0: p1 p2
      [    1.334140] mmc1: new high speed SDIO card at address 0001
      [    1.366491] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    1.366578] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.374838] devtmpfs: mounted
      [    1.382801] Freeing unused kernel memory: 2048K
      [    1.400767] Run /sbin/init as init process
      [    1.480562] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.663171] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    1.663215] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.663245] usb 1-1: Product: USB2.0 Hub
      [    1.665058] hub 1-1:1.0: USB hub found
      [    1.665411] hub 1-1:1.0: 4 ports detected
      [    1.831654] systemd[1]: System time before build time, advancing clock.
      [    1.931784] NET: Registered protocol family 10
      [    1.933064] Segment Routing with IPv6
      [    1.968734] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    1.969525] systemd[1]: Detected architecture arm.
      [    2.000555] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
      [    2.016943] systemd[1]: Set hostname to <raspberrypi>.
      [    2.149921] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
      [    2.149977] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    2.150020] usb 1-1.3: Product: TI CC2531 USB CDC
      [    2.150051] usb 1-1.3: Manufacturer: Texas Instruments
      [    2.150078] usb 1-1.3: SerialNumber: __0X00124B00193B116B
      [    2.250533] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
      [    2.405789] usb 1-1.4: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.32
      [    2.405835] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    2.405870] usb 1-1.4: Product: 2.4G Receiver
      [    2.405897] usb 1-1.4: Manufacturer: Compx
      [    2.416417] input: Compx 2.4G Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:25A7:FA23.0001/input/input0
      [    2.481066] hid-generic 0003:25A7:FA23.0001: input,hidraw0: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:01:00.0-1.4/input0
      [    2.490780] input: Compx 2.4G Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA23.0002/input/input1
      [    2.491136] input: Compx 2.4G Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA23.0002/input/input2
      [    2.491380] input: Compx 2.4G Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA23.0002/input/input3
      [    2.560693] input: Compx 2.4G Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA23.0002/input/input4
      [    2.561124] hid-generic 0003:25A7:FA23.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:01:00.0-1.4/input1
      [    2.705205] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.715129] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.715238] systemd[1]: Reached target Swap.
      [    2.716165] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.716514] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    2.718975] systemd[1]: Created slice User and Session Slice.
      [    2.720109] systemd[1]: Listening on udev Control Socket.
      [    2.721456] systemd[1]: Listening on Journal Socket.
      [    2.727861] systemd[1]: Mounting RPC Pipe File System...
      [    2.735153] systemd[1]: Starting Create list of required static device nodes for the current kernel...
      [    3.352748] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    3.467762] systemd-journald[117]: Received request to flush runtime journal from PID 1
      [    3.957581] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      [    3.958092] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
      [    3.958597] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      [    3.959026] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      [    3.997673] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.002983] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.005040] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.005060] [vc_sm_connected_init]: start
      [    4.024253] [vc_sm_connected_init]: installed successfully
      [    4.026311] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    4.027759] mc: Linux media interface: v0.10
      [    4.082916] videodev: Linux video capture interface: v2.00
      [    4.112343] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.154049] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.175764] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.187477] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.194100] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    4.194620] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    4.195962] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    4.197373] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    4.197491] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    4.197513] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    4.197533] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    4.197552] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    4.198003] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    4.198089] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    4.198125] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    4.206228] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    4.206268] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    4.221475] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    4.221525] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    4.427579] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
      [    4.430328] usbcore: registered new interface driver cdc_acm
      [    4.430346] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    4.439341] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    4.442481] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    4.483223] [drm] No displays found. Consider forcing hotplug if HDMI is attached
      [    4.483347] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [    4.483370] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
      [    4.483383] [drm] No driver support for vblank timestamp query.
      [    4.483400] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
      [    4.486564] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    4.558051] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    4.610764] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    4.624230] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    4.625193] usbcore: registered new interface driver brcmfmac
      [    4.652408] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
      [    4.878321] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    4.892907] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
      [    6.328093] uart-pl011 fe201000.serial: no DMA platform data
      [    6.506624] 8021q: 802.1Q VLAN Support v1.8
      [    6.525481] random: crng init done
      [    6.525497] random: 7 urandom warning(s) missed due to ratelimiting
      [    6.770685] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    6.852377] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [    7.140032] bcmgenet: Skipping UMAC reset
      [    7.142568] bcmgenet fd580000.ethernet: configuring instance for external RGMII
      [    7.142947] bcmgenet fd580000.ethernet eth0: Link is Down
      [   11.290674] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
      [   11.290720] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   13.124443] Bluetooth: Core ver 2.22
      [   13.124512] NET: Registered protocol family 31
      [   13.124522] Bluetooth: HCI device and connection manager initialized
      [   13.124543] Bluetooth: HCI socket layer initialized
      [   13.124559] Bluetooth: L2CAP socket layer initialized
      [   13.124583] Bluetooth: SCO socket layer initialized
      [   13.136735] Bluetooth: HCI UART driver ver 2.3
      [   13.136749] Bluetooth: HCI UART protocol H4 registered
      [   13.136829] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   13.137061] Bluetooth: HCI UART protocol Broadcom registered
      [   13.320521] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   13.320528] Bluetooth: BNEP filters: protocol multicast
      [   13.320540] Bluetooth: BNEP socket layer initialized
      [   33.490518] device eth0 entered promiscuous mode
      [   36.850437] FS-Cache: Netfs 'cifs' registered for caching
      [   36.869776] Key type cifs.spnego registered
      [   36.869790] Key type cifs.idmap registered
      [   36.870969] CIFS: Attempting to mount //192.168.178.1/fritz.nas/Intenso-MicroLine-01/ioBroker
      [   37.099023] CIFS VFS: Autodisabling the use of server inode numbers on \\192.168.178.1\fritz.nas.
      [   37.099031] CIFS VFS: The server doesn't seem to support them properly or the files might be on different servers (DFS).
      [   37.099037] CIFS VFS: Hardlinks will not be recognized on this mount. Consider mounting with the "noserverino" option to silence this message.
      pi@raspberrypi:~ $
      • D denjo
        @Thomas-Braun hier
        pi@raspberrypi:~ $
        @denjo Setz den Kram bitte in CodeTags, damit man das besser lesen kann.
          Und auch das noch:
          denjo
          @Thomas-Braun und hier:
          pi@raspberrypi:~ $ whoami && who -r && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          pi
                   Runlevel 5   2020-10-04 00:57
          /usr/bin/nodejs
          v12.18.3
          /usr/bin/node
          v12.18.3
          /usr/bin/npm
          6.14.6
          nodejs:
            Installiert:           12.18.3-1nodesource1
            Installationskandidat: 12.18.3-1nodesource1
            Versionstabelle:
           *** 12.18.3-1nodesource1 100
               10.22.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
               10.21.0~dfsg-1~deb10u1+rpi1 500
          pi@raspberrypi:~ $
          • D denjo
            pi
            /usr/bin/nodejs
            v12.18.3
            /usr/bin/node
            v12.18.3
            /usr/bin/npm
            6.14.6
            nodejs:
              Versionstabelle:
            pi@raspberrypi:~ $
            @denjo Soweit unauffällig.
            Ich würde allerdings das 12er-Node-Repository wieder aktivieren und den Server ohne Desktop im Runlevel 3 betreiben.
              denjo
              @Thomas-Braun versteh nicht ein wort sorry
              • D denjo
                @denjo
                Versionstabelle:
                Zeigt mir, das zwar node 12.18.3 installiert wurde, allerdings die Quelle dazu nicht (mehr) aktiv ist.
                Zum RunLevel3: Serverbetrieb ohne Desktop.
                Wird mit
                sudo raspi-config
                Menüpunkt 3 - B1 - B1 eingestellt.
                  @denjo
                  Versionstabelle:
                  Wird mit
                  sudo raspi-config
                  denjo
                  @Thomas-Braun Es gibt Menüpunkt 3-B1-B1 bis B4???
                  • D denjo
                    @denjo
                    3 -B1 -B1
                      @denjo
                      3 -B1 -B1
                      denjo
                      @Thomas-Braun
                      pi@raspberrypi:~ $ sudo raspi-config
                      rm: das Entfernen von '/etc/systemd/system/getty@tty1.service.d/autologin.conf' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                      pi@raspberrypi:~ $
