  4. Aus HTML Befehl das Ergebnis in ein Datenpunkt schreiben
    5.6k
multimediablocklyjavascript
17 Beiträge 4 Kommentatoren 820 Aufrufe 4 Beobachtet
  • liv-in-skyL liv-in-sky
    @RainerSausK
    nimm das setze result oben weg
    damit bekommst du dann deinen wert auf result angewendet
    <block xmlns="https://developers.google.com/blockly/xml" type="debug" id="Scb!Qt)8`|HCX`DvQw$C" x="-837.0377807617189" y="262.00010681152366">
      <value name="TEXT">
        <shadow type="text" id=":BDGJMc@S17GI^G%@,vR">
        </shadow>
        <block type="text_getSubstring" id="iq4o[qwqQ_mj)m]oy5|~">
          <mutation at1="true" at2="true"></mutation>
          <field name="WHERE1">FROM_START</field>
          <field name="WHERE2">FROM_START</field>
          <value name="STRING">
            <block type="variables_get" id=":w?^d}~kaH.z3=?lrAxg">
              <field name="VAR" id="C{Leg;p1r5dq4z$;*6:^">dddd</field>
            </block>
          </value>
          <value name="AT1">
            <block type="math_arithmetic" id="(gp6Jj,HS%#,V@7c(dAB">
              <field name="OP">ADD</field>
              <value name="A">
                <shadow type="math_number" id="*b~*[wwwPMw^TygNZiA.">
                  <field name="NUM">1</field>
                </shadow>
                <block type="text_indexOf" id=")nXls=P*bF71,P@y@!F-">
                  <field name="END">FIRST</field>
                  <value name="VALUE">
                    <block type="variables_get" id="pP8B,ajHOue)I:kGVgRE">
                    </block>
                  </value>
                  <value name="FIND">
                    <shadow type="text" id="Cw[HZ~Z^`@FTRFWIe#Wi">
                      <field name="TEXT">&lt;sessionId&gt;</field>
                    </shadow>
                  </value>
                </block>
              </value>
              <value name="B">
                <shadow type="math_number" id="uO1*s.@[SvHUeSW;SVW_">
                  <field name="NUM">11</field>
                </shadow>
              </value>
            </block>
          </value>
          <value name="AT2">
            <block type="math_arithmetic" id="b3Ln`w^E0{,/=P,PuSGb">
              <value name="A">
                <shadow type="math_number" id=".AQX7iGUyx.M/2HQ5`ny">
                </shadow>
                <block type="text_indexOf" id="[`!5VnH4hV{S!c~0p[x2">
                    <block type="variables_get" id="7e;Xwc;#h#nxk{y=VrjH">
                    </block>
                  </value>
                  <value name="FIND">
                    <shadow type="text" id="2rOSC8j:%M#c,^J9^ONV">
                      <field name="TEXT">&lt;/sessionId&gt; </field>
                    </shadow>
                  </value>
                </block>
              </value>
              <value name="B">
                <shadow type="math_number" id="l|PFF8P`;S=F5mzRvAL=">
                </shadow>
              </value>
            </block>
          </value>
        </block>
      </value>
    </block>
    RainerSausK
    @liv-in-sky Bitte um Nachsicht...
    Wie bekomme ich denn "result" in meinen Datenpunkt? Das ist nach meinem Verständnis keine Variable?
    Wenn ich die Variable "dddd" nicht vorbelege, bekomme ich eine Fehlermeldung.
    Danke für die Rückmeldung...
    R liv-in-skyL 3 Antworten Letzte Antwort
    • R RainerSausK
      RainerSausK
      @RainerSausK Das Ergebnis müsste dochg jetzt in "dddd" stehen, oder?
      • R RainerSausK
        liv-in-skyL Offline
        liv-in-skyL Offline
        @RainerSausK
        klicke ddd an und wähle result aus
        R 1 Antwort Letzte Antwort
        • R RainerSausK
          liv-in-skyL Offline
          liv-in-skyL Offline
          @RainerSausK und mache das erste blockly module weg - setze ... auf (ganz oben)
          das brauchst du nicht nur das request blockly
            @RainerSausK
            RainerSausK
            @liv-in-sky Ich habe bei mir kein "result"?!
            • R RainerSausK
              liv-in-skyL Offline
              liv-in-skyL Offline
              @RainerSausK
              dann gehe unter Variablen und lege eine variable result an
              • R RainerSausK
                liv-in-skyL Offline
                liv-in-skyL Offline
                @RainerSausK
                ich habe 2 monitore und daher das log und das script offen und kann so beobachten
                • R RainerSausK
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @RainerSausK
                    @RainerSausK
                    RainerSausK
                    @liv-in-sky Supi... Das hat funktioniert. Es steht zwar noch mehr im Datenpunkt als benötigt,
                    aber jetzt komme ich den Rest sicherlich auch hin.
                    Vielen dank für deine Unterstützung und Geduld...
                    • R RainerSausK
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @RainerSausK
                      • R RainerSausK
                        ich habe ein Medion WLAN Radio. Um das Steuern zu können benötige ich im Steuerbefehl eine SessionID. Diese wird mit
                        http://192.168.178.91/fsapi/CREATE_SESSION?pin=1234
                        generiert.
                        Das Ergebnis im Browser sieht dann so aus.
                        <fsapiResponse>
                        <status>FS_OK</status>
                        <sessionId>1623280879</sessionId>
                        </fsapiResponse>
                        Ist es möglich die SessionID in ein Datenpunkt zu schreiben?
                        Bin für jede ausführliche Unterstützung dankbar, da Anfänger.
                        LG
                        I Offline
                        I Offline
                        ITCrowd
                        schrieb am zuletzt editiert von ITCrowd
                        @RainerSausK Lange Rede kurzer Sinn.
                        Aber genau das stand alles im ersten Post. 😂
