  4. ham.homebridge-devolo fehler
    6.8k
devolo homebridgedevolohamhomebridge-devolohomebridge accessories manager
18 Beiträge 2 Kommentatoren 961 Aufrufe 2 Beobachtet
  • B BaronT
    @Thomas-Braun Danke für die schnelle hilfe.
    Kannst du mir sagen wie ich das über die Konsole machen kann.
    Hier noch ein paar info falls du Sie benötigst:
    pi@raspberrypi:~ $ uname -m
    armv7l
    pi@raspberrypi:~ $ nodejs -v
    v14.9.0
    pi@raspberrypi:~ $ node -v
    v14.9.0
    pi@raspberrypi:~ $ npm -v
    6.14.8
    pi@raspberrypi:~ $ apt policy nodejs
    nodejs:
    Installiert: 14.9.0-1nodesource1
    Installationskandidat: 14.9.0-1nodesource1
    Versionstabelle:
    *** 14.9.0-1nodesource1 500
    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
    10.21.0~dfsg-1~deb10u1+rpi1 500
    @BaronT https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    Schau dir Teil 1.1 an.
      BaronT
      @Thomas-Braun Supi Danke. Super Anleitung.👍
      Leider habe ich immer noch die fehlermeldungen.😧
      2020-08-31 23:38:46.027 - error: ham.0 (1394) uncaught exception: Cannot read property 'length' of undefined
      2020-08-31 23:38:46.028 - error: ham.0 (1394) TypeError: Cannot read property 'length' of undefined
      at /opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/Devolo.js:363:47
      at /opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloApi.js:185:17
      at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloApi.js:69:21)
      at IncomingMessage.emit (events.js:327:22)
      at endReadableNT (_stream_readable.js:1220:12)
      at processTicksAndRejections (internal/process/task_queues.js:84:21)
      2020-08-31 23:38:46.029 - info: ham.0 (1394) cleaned everything up...
      2020-08-31 23:38:46.047 - warn: ham.0 (1394) Exception: TypeError: Cannot read property 'length' of undefined
      2020-08-31 23:38:46.054 - info: ham.0 (1394) terminating
      2020-08-31 23:38:46.055 - info: ham.0 (1394) Terminated (NO_ERROR): Without reason
      2020-08-31 23:38:46.616 - error: host.raspberrypi Caught by controller[0]: [2020-8-31 23:38:42] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-devolo' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo'.
      2020-08-31 23:38:46.618 - error: host.raspberrypi Caught by controller[1]: [2020-8-31 23:38:42] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      • B BaronT
        @BaronT Ich hatte nichts anderes erwartet.
        Da scheint irgendwas doppelt gemoppelt zu sein. Aber vom ham hab ich keine Ahnung.
        Bitte Konsolentext in CodeTags setzen.
          BaronT
          @Thomas-Braun So?
          Mfg Tobi
          2020-09-02 20:17:32.555 - info: host.raspberrypi "system.adapter.ham.0" enabled
          2020-09-02 20:17:32.593 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 4018
          2020-09-02 20:17:33.446 - debug: ham.0 (4018) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2020-09-02 20:17:33.480 - debug: ham.0 (4018) Objects client ready ... initialize now
          2020-09-02 20:17:33.484 - debug: ham.0 (4018) Objects create System PubSub Client
          2020-09-02 20:17:33.485 - debug: ham.0 (4018) Objects create User PubSub Client
          2020-09-02 20:17:33.486 - debug: ham.0 (4018) Objects client initialize lua scripts
          2020-09-02 20:17:33.500 - debug: ham.0 (4018) Objects connected to redis: 127.0.0.1:9001
          2020-09-02 20:17:33.507 - debug: ham.0 (4018) objectDB connected
          2020-09-02 20:17:33.509 - debug: ham.0 (4018) Redis States: Use Redis connection: 127.0.0.1:9000
          2020-09-02 20:17:33.516 - debug: ham.0 (4018) States create User PubSub Client
          2020-09-02 20:17:33.519 - debug: ham.0 (4018) States create System PubSub Client
          2020-09-02 20:17:33.529 - debug: ham.0 (4018) States connected to redis: 127.0.0.1:9000
          2020-09-02 20:17:33.530 - debug: ham.0 (4018) statesDB connected
          2020-09-02 20:17:33.667 - info: ham.0 (4018) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.3, js-controller: 3.1.6
          2020-09-02 20:17:33.695 - info: ham.0 (4018) Install/Update the following Libraries: homebridge-devolo
          2020-09-02 20:17:33.696 - info: ham.0 (4018) Install/Update homebridge-devolo
          2020-09-02 20:17:33.697 - info: ham.0 (4018) All Libraries installed/updated
          2020-09-02 20:17:35.145 - debug: ham.0 (4018) [2020-9-2 20:17:35] Loaded plugin: homebridge-devolo
          2020-09-02 20:17:35.147 - debug: ham.0 (4018) [2020-9-2 20:17:35] Registering platform 'homebridge-devolo.Devolo'
          2020-09-02 20:17:35.148 - debug: ham.0 (4018) [2020-9-2 20:17:35] ---
          2020-09-02 20:17:35.156 - debug: ham.0 (4018) [2020-9-2 20:17:35] Loading 1 platforms...
          2020-09-02 20:17:35.158 - debug: ham.0 (4018) [2020-9-2 20:17:35] [Devolo] Initializing Devolo platform...
          2020-09-02 20:17:35.163 - debug: ham.0 (4018) [2020-9-2 20:17:35] [Devolo] HBDevoloPlatform > Searching for Devolo Central Unit.
          2020-09-02 20:17:35.177 - debug: ham.0 (4018) [2020-9-2 20:17:35] Loading 0 accessories...
          2020-09-02 20:17:35.253 - debug: ham.0 (4018) Trying to connect to socket.
          2020-09-02 20:17:35.679 - debug: ham.0 (4018) Websocket open
          2020-09-02 20:17:35.687 - debug: ham.0 (4018) [2020-9-2 20:17:35] [Devolo] HBDevoloPlatform > Central Unit found.
          2020-09-02 20:17:36.760 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
          > Model: %s
          > ProductID: %s
          > ProductTypeID: %s
          > Sensors: %s
          2020-09-02 20:17:36.761 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
          > Model: %s
          > ProductID: %s
          > ProductTypeID: %s
          > Sensors: %s
          2020-09-02 20:17:36.763 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
          > Model: %s
          > ProductID: %s
          > ProductTypeID: %s
          > Sensors: %s
          2020-09-02 20:17:36.764 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
          > Model: %s
          > ProductID: %s
          > ProductTypeID: %s
          > Sensors: %s
          2020-09-02 20:17:36.765 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
          > Model: %s
          > ProductID: %s
          > ProductTypeID: %s
          > Sensors: %s
          2020-09-02 20:17:36.766 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
          > Model: %s
          > ProductID: %s
          > ProductTypeID: %s
          > Sensors: %s
          2020-09-02 20:17:37.342 - error: ham.0 (4018) uncaught exception: Cannot read property 'length' of undefined
          2020-09-02 20:17:37.343 - error: ham.0 (4018) TypeError: Cannot read property 'length' of undefined
          2020-09-02 20:17:37.344 - info: ham.0 (4018) cleaned everything up...
          2020-09-02 20:17:37.351 - warn: ham.0 (4018) Exception: TypeError: Cannot read property 'length' of undefined
          2020-09-02 20:17:37.357 - info: ham.0 (4018) terminating
          2020-09-02 20:17:37.358 - info: ham.0 (4018) Terminated (NO_ERROR): Without reason
          2020-09-02 20:17:37.931 - error: host.raspberrypi Caught by controller[0]: [2020-9-2 20:17:34] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-devolo' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo'.
          2020-09-02 20:17:37.932 - error: host.raspberrypi Caught by controller[1]: [2020-9-2 20:17:34] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
          2020-09-02 20:17:37.932 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
          2020-09-02 20:17:37.933 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
          • B BaronT
            @Thomas-Braun So?
            Mfg Tobi
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            BaronT
            2020-09-02 23:13:50.185 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 25036
            2020-09-02 23:13:51.088 - debug: ham.0 (25036) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-09-02 23:13:51.127 - debug: ham.0 (25036) Objects client ready ... initialize now
            2020-09-02 23:13:51.131 - debug: ham.0 (25036) Objects create System PubSub Client
            2020-09-02 23:13:51.132 - debug: ham.0 (25036) Objects create User PubSub Client
            2020-09-02 23:13:51.133 - debug: ham.0 (25036) Objects client initialize lua scripts
            2020-09-02 23:13:51.147 - debug: ham.0 (25036) Objects connected to redis: 127.0.0.1:9001
            2020-09-02 23:13:51.153 - debug: ham.0 (25036) objectDB connected
            2020-09-02 23:13:51.156 - debug: ham.0 (25036) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-09-02 23:13:51.163 - debug: ham.0 (25036) States create User PubSub Client
            2020-09-02 23:13:51.166 - debug: ham.0 (25036) States create System PubSub Client
            2020-09-02 23:13:51.188 - debug: ham.0 (25036) States connected to redis: 127.0.0.1:9000
            2020-09-02 23:13:51.189 - debug: ham.0 (25036) statesDB connected
            2020-09-02 23:13:51.419 - info: ham.0 (25036) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.3, js-controller: 3.1.6
            2020-09-02 23:13:51.448 - info: ham.0 (25036) Install/Update the following Libraries: homebridge-plugin-wrapper
            2020-09-02 23:13:51.449 - info: ham.0 (25036) Install/Update homebridge-plugin-wrapper
            2020-09-02 23:13:51.450 - info: ham.0 (25036) All Libraries installed/updated
            2020-09-02 23:13:52.860 - debug: ham.0 (25036) [2020-9-2 23:13:52] Loaded plugin: homebridge-devolo
            2020-09-02 23:13:52.863 - debug: ham.0 (25036) [2020-9-2 23:13:52] Registering platform 'homebridge-devolo.Devolo'
            2020-09-02 23:13:52.864 - debug: ham.0 (25036) [2020-9-2 23:13:52] ---
            2020-09-02 23:13:52.872 - debug: ham.0 (25036) [2020-9-2 23:13:52] Loading 1 platforms...
            2020-09-02 23:13:52.873 - debug: ham.0 (25036) [2020-9-2 23:13:52] [Devolo] Initializing Devolo platform...
            2020-09-02 23:13:52.879 - debug: ham.0 (25036) [2020-9-2 23:13:52] [Devolo] HBDevoloPlatform > Searching for Devolo Central Unit.
            2020-09-02 23:13:52.893 - debug: ham.0 (25036) [2020-9-2 23:13:52] Loading 0 accessories...
            2020-09-02 23:13:52.971 - debug: ham.0 (25036) Trying to connect to socket.
            2020-09-02 23:13:53.038 - debug: ham.0 (25036) Websocket open
            2020-09-02 23:13:53.042 - debug: ham.0 (25036) [2020-9-2 23:13:53] [Devolo] HBDevoloPlatform > Central Unit found.
            2020-09-02 23:13:54.096 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 23:13:54.097 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 23:13:54.098 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 23:13:54.099 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 23:13:54.100 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 23:13:54.101 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 23:13:54.690 - error: ham.0 (25036) uncaught exception: Cannot read property 'length' of undefined
            2020-09-02 23:13:54.692 - error: ham.0 (25036) TypeError: Cannot read property 'length' of undefined
            at /usr/lib/node_modules/homebridge-devolo/node_modules/node-devolo/dist/Devolo.js:363:47
            at /usr/lib/node_modules/homebridge-devolo/node_modules/node-devolo/dist/DevoloApi.js:185:17
            at IncomingMessage. (/usr/lib/node_modules/homebridge-devolo/node_modules/node-devolo/dist/DevoloApi.js:69:21)
            2020-09-02 23:13:54.693 - info: ham.0 (25036) cleaned everything up...
            2020-09-02 23:13:54.714 - warn: ham.0 (25036) Exception: TypeError: Cannot read property 'length' of undefined
            2020-09-02 23:13:54.726 - info: ham.0 (25036) terminating
            2020-09-02 23:13:54.729 - info: ham.0 (25036) Terminated (NO_ERROR): Without reason
            2020-09-02 23:13:55.276 - error: host.raspberrypi Caught by controller[0]: [2020-9-2 23:13:52] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
            2020-09-02 23:13:55.277 - error: host.raspberrypi Caught by controller[1]: [2020-9-2 23:13:52] Plugin /usr/lib/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
            2020-09-02 23:13:55.278 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
            2020-09-02 23:13:55.279 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
            2020-09-02 23:13:58.241 - info: host.raspberrypi "system.adapter.ham.0" disabled
            • B BaronT
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              @BaronT Da ist was doppelt.
              /usr/lib/node_modules sollte (so) nicht existieren. Mal als root angemeldet und dann iobroker installiert?
                BaronT
                schrieb am zuletzt editiert von BaronT
                @Thomas-Braun Das möchte ich nicht ausschließen.
                Kann ich das einfach über die Konsole löschen oder muss ich den iobroker neu installieren?
                • B BaronT
                  @BaronT Da wäre ich äußerst vorsichtig. Ich würde da vielleicht erstmal nur den Verzeichnisnamen nur umbenennen. Z.B. in node_modules_test oder so. Das kannst du dann leichter wieder korrigieren.
                    BaronT
                    @Thomas-Braun Okay dann probiere ich es morgen mal aus.
                    • B BaronT
                      @BaronT Da liegt Zeuch von node bzw. npm drin, aber eigentlich keine Module direkt vom iobroker.
                      • B BaronT
                        @BaronT sagte in ham.homebridge-devolo fehler:
                        Das ist halt auch so ein Grund warum man sich nicht als root direkt anmeldet.
                          BaronT
                          @Thomas-Braun Das habe ich mittlerweile auch verstanden, dass man damit viel schaden anrichten kann.😕
                          Aber bei manchen Installationen muss man dies doch machen oder nicht?
                          Wie z.B. bei Node da ging es ohne root meine ich nicht.
                          Aber zurück zum Thema: 😊
                          Ich habe den Ordner unbenannt danach ging npm nicht mehr. Habe alles wieder zurück benannt und habe die Plugins im Ornder gelöscht.
                          Danach bekamm ich im Debug eine fehlermeldung das "homebridge-plugin" nicht im package.json unter keyword steht, habe dort "Homebride-plugin" eingegeben. Dannach hatte ich diese fehlermeldung weg.
                          Jetzt wird mir das im Debug angezeigtt wo ich nicht verstehe, was er mir sagen möchte:
                          2020-09-03 20:14:40.196 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 11044
                          2020-09-03 20:14:41.098 - debug: ham.0 (11044) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-09-03 20:14:41.129 - debug: ham.0 (11044) Objects client ready ... initialize now
                          2020-09-03 20:14:41.132 - debug: ham.0 (11044) Objects create System PubSub Client
                          2020-09-03 20:14:41.134 - debug: ham.0 (11044) Objects create User PubSub Client
                          2020-09-03 20:14:41.135 - debug: ham.0 (11044) Objects client initialize lua scripts
                          2020-09-03 20:14:41.151 - debug: ham.0 (11044) Objects connected to redis: 127.0.0.1:9001
                          2020-09-03 20:14:41.158 - debug: ham.0 (11044) objectDB connected
                          2020-09-03 20:14:41.160 - debug: ham.0 (11044) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-09-03 20:14:41.167 - debug: ham.0 (11044) States create User PubSub Client
                          2020-09-03 20:14:41.170 - debug: ham.0 (11044) States create System PubSub Client
                          2020-09-03 20:14:41.180 - debug: ham.0 (11044) States connected to redis: 127.0.0.1:9000
                          2020-09-03 20:14:41.181 - debug: ham.0 (11044) statesDB connected
                          2020-09-03 20:14:41.493 - info: ham.0 (11044) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.3, js-controller: 3.1.6
                          2020-09-03 20:14:41.522 - info: ham.0 (11044) Install/Update the following Libraries: homebridge-devolo
                          2020-09-03 20:14:41.523 - info: ham.0 (11044) Install/Update homebridge-devolo
                          2020-09-03 20:14:41.524 - info: ham.0 (11044) All Libraries installed/updated
                          2020-09-03 20:14:42.965 - debug: ham.0 (11044) [2020-9-3 20:14:42] Loaded plugin: homebridge-devolo
                          2020-09-03 20:14:42.968 - debug: ham.0 (11044) [2020-9-3 20:14:42] Registering platform 'homebridge-devolo.Devolo'
                          2020-09-03 20:14:42.969 - debug: ham.0 (11044) [2020-9-3 20:14:42] ---
                          2020-09-03 20:14:42.985 - debug: ham.0 (11044) [2020-9-3 20:14:42] Loading 1 platforms...
                          2020-09-03 20:14:42.986 - debug: ham.0 (11044) [2020-9-3 20:14:42] [Devolo] Initializing Devolo platform...
                          2020-09-03 20:14:42.992 - debug: ham.0 (11044) [2020-9-3 20:14:42] [Devolo] HBDevoloPlatform > Searching for Devolo Central Unit.
                          2020-09-03 20:14:43.006 - debug: ham.0 (11044) [2020-9-3 20:14:43] Loading 0 accessories...
                          2020-09-03 20:14:43.464 - debug: ham.0 (11044) Trying to connect to socket.
                          2020-09-03 20:14:43.529 - debug: ham.0 (11044) Websocket open
                          2020-09-03 20:14:43.533 - debug: ham.0 (11044) [2020-9-3 20:14:43] [Devolo] HBDevoloPlatform > Central Unit found.
                          2020-09-03 20:14:44.593 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                          > Model: %s
                          > ProductID: %s
                          > ProductTypeID: %s
                          > Sensors: %s
                          2020-09-03 20:14:44.594 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                          > Model: %s
                          > ProductID: %s
                          > ProductTypeID: %s
                          > Sensors: %s
                          > Model: %s
                          > ProductID: %s
                          > ProductTypeID: %s
                          > Sensors: %s
                          2020-09-03 20:14:44.595 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                          > Model: %s
                          > ProductID: %s
                          > ProductTypeID: %s
                          > Sensors: %s
                          > Model: %s
                          > ProductID: %s
                          > ProductTypeID: %s
                          > Sensors: %s
                          2020-09-03 20:14:44.596 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                          > Model: %s
                          > ProductID: %s
                          > ProductTypeID: %s
                          > Sensors: %s
                          2020-09-03 20:14:45.182 - error: ham.0 (11044) uncaught exception: Cannot read property 'length' of undefined
                          2020-09-03 20:14:45.185 - error: ham.0 (11044) TypeError: Cannot read property 'length' of undefined
                          2020-09-03 20:14:45.187 - info: ham.0 (11044) cleaned everything up...
                          2020-09-03 20:14:45.203 - warn: ham.0 (11044) Exception: TypeError: Cannot read property 'length' of undefined
                          2020-09-03 20:14:45.644 - info: ham.0 (11044) terminating
                          2020-09-03 20:14:45.645 - info: ham.0 (11044) Terminated (NO_ERROR): Without reason
                          2020-09-03 20:14:46.180 - error: host.raspberrypi Caught by controller[0]: [2020-9-3 20:14:42] ====================
                          2020-09-03 20:14:46.180 - error: host.raspberrypi Caught by controller[1]: [2020-9-3 20:14:42] ERROR LOADING PLUGIN homebridge-plugin-wrapper:
                          2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: [2020-9-3 20:14:42] Error: Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper does not contain the 'homebridge' package in 'engines'.
                          2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: at Plugin.load (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js:49:11)
                          2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: at Server. (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:153:14)
                          2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: at Array.forEach ()
                          2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:145:22)
                          2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
                          2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:221:19)
                          2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:111:23)
                          2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.ham/main.js:276:39
                          2020-09-03 20:14:46.183 - error: host.raspberrypi Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.ham/main.js:177:27
                          2020-09-03 20:14:46.183 - error: host.raspberrypi Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4008:33
                          2020-09-03 20:14:46.183 - error: host.raspberrypi Caught by controller[3]: [2020-9-3 20:14:42] ====================
                          2020-09-03 20:14:46.184 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
                          2020-09-03 20:14:46.184 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
                          • B BaronT
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            Aber bei manchen Installationen muss man dies doch machen oder nicht? Wie z.B. bei Node da ging es ohne root meine ich nicht.
                            Doch, auch die Installation via apt geht ohne root. sudo davor und gut ist. Unter Debian meldet man sich nie als root an. Der ist ja auch eigentlich gesperrt, aus Gründen.
                            Nach dem Umbenennen hättest du einfach nodeJS nochmal auf das System bügeln können. Aber so scheint es auch zu funktionieren, die Doublette ist wohl weg.
                              BaronT
                              @Thomas-Braun said in ham.homebridge-devolo fehler:
                              Achso also nur sudo davor. Ich packe den root nicht mehr an.
                              Jap die ist weg. Kannst du denn erkennen was jetzt nicht richtig läuft?
                              (Anders gefragt ist mein Problem ggf. weg wenn ich alles nochmal neu installiere, also den kompletten Raspberry)
                              Mfg Tobi
                              • B BaronT
                                Mfg Tobi
                                @BaronT Von ham habe ich wie gesagt keine Ahnung.
