  4. Setzen von HM Systemvariablen mit JS
27 Beiträge 8 Kommentatoren 7.0k Aufrufe
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    @jensus11:
    on('geofency.0.Hans.php.Haus.entry.state', function(obj) {
        log('Neuer Geofency-Wert ' + obj.state.val);
        setState('hm-rega.0.7680.state', obj.state.val);
    Kann das sein, dass das .state da nicht hingehört?
    Also:
    on('geofency.0.Hans.php.Haus.entry', function(obj) {
    Welchen Wert benötigst Du in der CCU Variable?
    Geofency liefert nicht true oder false sondern "0" und "1".
    • J Offline
      jensus11
      ich brauche eigentlich die Werte wahr und falsch für zu Hause und unterwegs.
      wenn ich das state weglasse dann kommen Fehlermeldungen im Log.
      TypeError:	2016-02-28 12:58:15	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError:	2016-02-28 12:58:15	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      TypeError:	2016-02-28 12:58:15	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1969:80)
      TypeError:	2016-02-28 12:58:15	error	at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17)
      TypeError:	2016-02-28 12:58:15	error	at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:524:17)
      TypeError:	2016-02-28 12:58:15	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2434:28)
      TypeError:	2016-02-28 12:58:15	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2415:17)
      TypeError:	2016-02-28 12:58:15	error	at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:528:48
      TypeError:	2016-02-28 12:58:15	error	at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1190:48)
      TypeError:	2016-02-28 12:58:15	error	at Object. (script.js.Anwesenheit:3:45)
      TypeError:	2016-02-28 12:58:15	error	Cannot read property 'val' of undefined
      message	2016-02-28 12:58:15	error	geofency.0.Hans.php.Haus.entry [object Object] Cannot read property 'val' of undefined
      javascript-0	2016-02-28 12:58:15	info	script.js.Anwesenheit: Neuer Geofency-Wert 1
      geofency-0	2016-02-28 12:58:15	info	adapter geofency received webhook from device Hans.php with values: name: Haus, entry: 1
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        @jensus11:
        Jetzt reagiert Dein Script schon einmal auf die Geofency Änderung. Die Ausgabe war die Log() Zeile.
        D.h. ohne .state war richtig. Das Script reagiert nun auf Veränderungen.
        @jensus11:
        Hatte ich übersehen. Auch im hm-rega Datenpunkt ist das .state zu viel. Der Datenpunkt heisst einfach nur 7680.
        Das state ist deswegen verwirrend, da in den hm-rpc die benötigten Datenpunkten oft STATE heissen.
        Die richtige Bezeichnung findest Du immer in der linken Spalte unter Objekte, wenn Du bis zum Ende aufgeklappt hast.
        Das state, welches Du jeweils eingetragen hast ist einfach nur die Typenbeschreibung aus der Spalte Typ.
        So sollte es dann funktionieren:
            setState('hm-rega.0.7680', obj.state.val);
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
              if (obj.state.val == "1") {
              	setState('hm-rega.0.7680', true);
              } else {
              	setState('hm-rega.0.7680', false);
          Noch mit der Umwandlung der "1" in true und der "0" in false.
          • J Offline
            jensus11
            Super, jetzt funktioniert das. Leider mit eine Änderung noch.
            Das state musste ich noch entfernen.
            so ist das jetzt korrekt.
                } else {
            • ruhr70R Offline
              ruhr70R Offline
              ruhr70
              ach…
              sorry... da hatte ich den falschen Code von oben codiert und verändert ;-)
                dtp
                Hätte hierzu noch eine ergänzende Frage.
                Ich habe folgendes Skript, um damit einen ioBroker-Datenpunkt in eine HM-Systemvariable zu schreiben:
                // Vitotronic Partybetrieb
                on( 'javascript.0.Vitotronic.BetriebParty', function (obj) {
                  log(obj.newState.val);
                  setState('hm-rega.0.2883.state', obj.newState.val);
                Problem ist, dass der Datenpunkt "javascript.0.Vitotronic.BetriebParty" die Zustände "an" und "aus" besitzen kann, "hm-rega.0.2883.state" aber nur 0 und 1 akzeptiert. Nun könnte man natürlich nach obigem Beispiel eine kleine if-Abfrage zum Übersetzen der Zustände einfügen. Bei einigen Datenpunkten sind aber fünf und mehr verschiedene Werte möglich. Daher würde ich gerne auf eine Transformation verzichten und die Werte direkt in die Systemvariable schreiben.
                Mit
                  curl -s -k "http://192.168.0.20:8181/rega.exe?x=dom.GetObject(2883).State('an')"
                klappt das auch. Aber wie kann ich das nun in das obige Skript einbinden? Geht das z.B. mit exec?
                Gruß,
                Thorsten
                • paul53P Offline
                  @dtp:
                  Problem ist, dass der Datenpunkt "javascript.0.Vitotronic.BetriebParty" die Zustände "an" und "aus" besitzen kann, "hm-rega.0.2883.state" aber nur 0 und 1 akzeptiert. `
                  Dann hat die SV den falschen Typ. Sie muss vom Typ "Zeichenkette" sein !
                  Außerdem ist die ID der SV 'hm-rega.0.2883'.
                    setState('hm-rega.0.2883', obj.newState.val);  // in SV vom Typ "Zeichenkette" übertragen
                  • paul53P Offline
                    @dtp:
                    Nun könnte man natürlich nach obigem Beispiel eine kleine if-Abfrage zum Übersetzen der Zustände einfügen. Bei einigen Datenpunkten sind aber fünf und mehr verschiedene Werte möglich. `
                    Wenn SV vom Typ "Werteliste" gesetzt werden sollen, ist das auch nicht so schwierig:
                    // Zustandstexte Betriebsart
                    var ba = ['Abschaltbetrieb','Nur Warmwasser','Heizen und Warmwasser','Dauernd red. Betrieb','Dauernd Normalbetrieb'];
                    on('javascript.0.Vitotronic.Betriebsart', function (obj) {
                      setState('hm-rega.0.1234', ba.indexOf(obj.newState.val));
                      dtp
                      Danke, das hat mir schon mal sehr geholfen.
                      Gruß,
                      Thorsten
                        dtp
                        So, habe mir jetzt auf der CCU die Systemvariable als Werteliste mit den Werten
                        Abschaltbetrieb;Nur Warmwasser;Heizen und Warmwasser;Dauernd red. Betrieb;Dauernd Normalbetrieb
                        angelegt und setze deren Werte nun folgendermaßen:
                        // Vitotronic Betriebsart
                          switch (obj.newState.val) {
                            case "Abschaltbetrieb":
                              setState('hm-rega.0.1234', 0);
                            break;
                            case "Nur Warmwasser":
                              setState('hm-rega.0.1234', 1);
                            break;
                            case "Heizen und Warmwasser":
                              setState('hm-rega.0.1234', 2);
                            break;
                            case "Dauernd red. Betrieb":
                              setState('hm-rega.0.1234', 3);
                            break;
                            case "Dauernd Normalbetrieb":
                              setState('hm-rega.0.1234', 4);
                            break;
                        Damit habe ich eine Möglichkeit, die verschiedenen Zustände von "javascript.0.Vitotronic.Betriebsart" unabhängig von ihrer Reihenfolge in die Systemvariable der CCU zu schreiben.
                        Gruß,
                        Thorsten
                        • paul53P Offline
                          @dtp:
                          Damit habe ich eine Möglichkeit, die verschiedenen Zustände von "javascript.0.Vitotronic.Betriebsart" unabhängig von ihrer Reihenfolge in die Systemvariable der CCU zu schreiben. `
                          Das geht auch mit dem Array. Die Reihenfolge im Array muss der in der Werteliste (CCU) entsprechen und hat nichts mit der Wertzuordnung in vcontrold zu tun. Die Einzeltexte innerhalb des Array müssen identisch zu den Texten in der vito.xml sein, können aber von den Texten in der Werteliste abweichen.
                            dtp
                            Meinst Du mit Array die obige Variable "ba"? Da gab es nur leider ein kleines Problem. Der Datenpunkt "javascript.0.Vitotronic.Betriebsart" enthält die Strings "Abschaltbetrieb", "Nur Warmwasser" etc. Dein obiger Skriptvorschlag geht aber davon aus, dass "javascript.0.Vitotronic.Betriebsart" die Integer-Werte 0 bis 4 annimmt, die dann als Index in "setState" übergeben werden.
                            Oder habe ich da was falsch verstanden?
                            • paul53P Offline
                              @dtp:
                              Dein obiger Skriptvorschlag geht aber davon aus, dass "javascript.0.Vitotronic.Betriebsart" die Integer-Werte 0 bis 4 annimmt, die dann als Index in "setState" übergeben werden. `
                              Nein, der Vorschlag geht davon aus, dass "javascript.0.Vitotronic.Betriebsart" den jeweiligen Zustandstext ("Abschaltbetrieb", …) enthält. Würde der Datenpunkt den Wert 0 bis 4 enthalten, könnte man ihn direkt ohne Umweg über
                              in die SV schreiben. ba.indexOf(Text) ermittelt die Position des Textes im Array ba. Das Ergebnis ist ein Integer-Wert 0 bis 4.
                                dtp
                                Hallo paul53,
                                danke. Da lag wohl ein kleiner Denkfehler meinerseits vor.
                                Gruß,
                                Thorsten
