  4. Großen Datenpunkt im VIS anzeigen
vis
12 Beiträge 4 Kommentatoren 405 Aufrufe 3 Beobachtet
  • JB_SullivanJ Offline
    JB_Sullivan
    Weiß zufällig jemand wie ich einen solchen datenpunkt im VIS sinnvoll
    anzeigen lassen kann?
    {"OperationPermited":true,"BatteryWeak":false,"BatteryFailure":false,"BatteryFailureSticky":false,"MowingWindow":false,"MargingMowingCompleted":false,"UserInteraction":false,"LoopSignalValid":true,"ChargerContact":true,"ChargerActive":true,"ChargerAllowsRestart":false,"ChargerFailure":false,"ManualOperation":false,"RobotIsActive":false,"IssueDisplay":false,"HommingTriggerSchedule":false,"HommingTriggerBatteryWeak":false,"HommingTriggerUserRequest":false,"HommingTriggerRain":false,"HommingTriggerTemperature":false,"HommingTriggerMowingUnitOverload":false,"HommingTriggerRestart":false,"DayCancelled":false,"RainDetected":false,"RainAllowsMowing":true,"TemperatureMonitoringActive":true,"TemperatureAllowsMowing":true,"TemperatureAllowsHoming":true,"TemperatureAllowsCharging":true,"WheelMotorTemperatureHigh":false,"StopAfterIssue":false,"BladesService":false,"SmarthomeActive":true,"Reserved33":false,"Reserved34":false,"Reserved35":false,"Reserved36":false,"Reserved37":false,"Reserved38":false,"Reserved39":false,"Reserved40":false,"Reserved41":false,"Reserved42":false,"Reserved43":false,"Reserved44":false,"Reserved45":false,"Reserved46":false,"Reserved47":false,"Reserved48":false,"Reserved49":false,"Reserved50":false,"Reserved51":false,"Reserved52":false,"Reserved53":false,"Reserved54":false,"Reserved55":false,"Reserved56":false,"Reserved57":false,"Reserved58":false,"Reserved59":false,"Reserved60":false,"Reserved61":false,"Reserved62":false,"Reserved63":false}
    HomoranH OliverIOO 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
      @JB_Sullivan JSON Table Widget?
      Oder was meinst du?
        Oder was meinst du?
        JB_Sullivan
        @Homoran Habe ich schon probiert - aber da wird nix angezeigt. Ist im Datenpunkt auch nicht als json Objekt angegeben.
          @JB_Sullivan sagte:
          JSON ist ein String. Vielleicht enthält der Datenpunkt aber ein Objekt; dann muss er in ein JSON gewandelt werden. Was ergibt ?
            JB_Sullivan
            😨 😨 Extra ein Blockly dafür schreiben - kann man doch auch in RAW Daten nachsehen.
            Der Typ ist "string"
              @JB_Sullivan sagte:
              Das was im Datenpunkt tatsächlich vorhanden ist, stimmt leider manchmal nicht mit dem überein, was im Datenpunkt vorhanden sein soll (common.type). Deshalb benötigt man die Typabfrage per Script.
                JB_Sullivan
                schrieb am zuletzt editiert von JB_Sullivan
                wird auf jeden Fall in beiden Fällen als String angezeigt. Kann man das in json wandeln und wenn ja wie?
                  @JB_Sullivan sagte:
                  Dann ist es bereits ein JSON.
                    JB_Sullivan
                    @paul53 sagte in Großen Datenpunkt im VIS anzeigen:
                    Ich habe aber schon alle möglichen Widgets durchprobiert - eine Anzeige wie bei "richtig" als json formatierten Daten bekomme ich nirgends.
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @JB_Sullivan
                      du könntest das hier mal probieren
                      https://forum.iobroker.net/topic/31521/test-widget-json-template
                      • JSON Template2 widget hinzufügen
                      • json_oid auf deinen Datenpunkt mit dem JSON setzen
                      • als Template den folgenden Text einsetzen
                      <%- data.OperationPermited %></br>
                      <%- data.BatteryWeak %>
                      Als Template kannst du gemäß den Regeln HTML und javascript kombiniert einsetzen. die Daten des Datenpunkts werden dir über data bereitgestellt.
                      Meine Adapter und Widgets
                      Links im Profil
                      • OliverIOO OliverIO
                        @JB_Sullivan
                        JB_Sullivan
                        @OliverIO OH OH, da muss ich mich erstmal ein bisschen einarbeiten - bei überfliegen habe ich ehrlich gesagt nix verstanden :(
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @JB_Sullivan
                          am besten das beispiel, das ich dir oben aufgeschrieben hab mal probieren.
                          Wenn du alles versuchst erst zu verstehen, dann könntest du dich am Anfang überlasten.
                          Das Template-widget ist sehr mächtig, daraus kannst du dir mit Kenntnissen zu html und javascript dein eigenes beliebiges widget bauen.
                          Links im Profil
                          82.9k
