<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Großen Datenpunkt im VIS anzeigen]]></title><description><![CDATA[<p dir="auto">Weiß zufällig jemand wie ich einen solchen datenpunkt im VIS sinnvoll<br />
anzeigen lassen kann?</p>
<pre><code>{"OperationPermited":true,"BatteryWeak":false,"BatteryFailure":false,"BatteryFailureSticky":false,"MowingWindow":false,"MargingMowingCompleted":false,"UserInteraction":false,"LoopSignalValid":true,"ChargerContact":true,"ChargerActive":true,"ChargerAllowsRestart":false,"ChargerFailure":false,"ManualOperation":false,"RobotIsActive":false,"IssueDisplay":false,"HommingTriggerSchedule":false,"HommingTriggerBatteryWeak":false,"HommingTriggerUserRequest":false,"HommingTriggerRain":false,"HommingTriggerTemperature":false,"HommingTriggerMowingUnitOverload":false,"HommingTriggerRestart":false,"DayCancelled":false,"RainDetected":false,"RainAllowsMowing":true,"TemperatureMonitoringActive":true,"TemperatureAllowsMowing":true,"TemperatureAllowsHoming":true,"TemperatureAllowsCharging":true,"WheelMotorTemperatureHigh":false,"StopAfterIssue":false,"BladesService":false,"SmarthomeActive":true,"Reserved33":false,"Reserved34":false,"Reserved35":false,"Reserved36":false,"Reserved37":false,"Reserved38":false,"Reserved39":false,"Reserved40":false,"Reserved41":false,"Reserved42":false,"Reserved43":false,"Reserved44":false,"Reserved45":false,"Reserved46":false,"Reserved47":false,"Reserved48":false,"Reserved49":false,"Reserved50":false,"Reserved51":false,"Reserved52":false,"Reserved53":false,"Reserved54":false,"Reserved55":false,"Reserved56":false,"Reserved57":false,"Reserved58":false,"Reserved59":false,"Reserved60":false,"Reserved61":false,"Reserved62":false,"Reserved63":false}
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/35561/großen-datenpunkt-im-vis-anzeigen</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 21:54:29 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/35561.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jul 2020 11:59:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 13:39:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jb_sullivan" aria-label="Profile: JB_Sullivan">@<bdi>JB_Sullivan</bdi></a><br />
am besten das beispiel, das ich dir oben aufgeschrieben hab mal probieren.</p>
<p dir="auto">Wenn du alles versuchst erst zu verstehen, dann könntest du dich am Anfang überlasten.<br />
Das Template-widget ist sehr mächtig, daraus kannst du dir mit Kenntnissen zu html und javascript dein eigenes beliebiges widget bauen.</p>
]]></description><link>https://forum.iobroker.net/post/468150</link><guid isPermaLink="true">https://forum.iobroker.net/post/468150</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Thu, 30 Jul 2020 13:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 13:30:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a>  OH OH, da muss ich mich erstmal ein bisschen einarbeiten - bei überfliegen habe ich ehrlich gesagt nix verstanden :(</p>
]]></description><link>https://forum.iobroker.net/post/468146</link><guid isPermaLink="true">https://forum.iobroker.net/post/468146</guid><dc:creator><![CDATA[JB_Sullivan]]></dc:creator><pubDate>Thu, 30 Jul 2020 13:30:54 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 13:23:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jb_sullivan" aria-label="Profile: JB_Sullivan">@<bdi>JB_Sullivan</bdi></a><br />
du könntest das hier mal probieren<br />
<a href="https://forum.iobroker.net/topic/31521/test-widget-json-template">https://forum.iobroker.net/topic/31521/test-widget-json-template</a></p>
<ul>
<li>JSON Template2 widget hinzufügen</li>
<li>json_oid auf deinen Datenpunkt mit dem JSON setzen</li>
<li>als Template den folgenden Text einsetzen</li>
</ul>
<pre><code>&lt;%- data.OperationPermited %&gt;&lt;/br&gt;
&lt;%- data.BatteryWeak %&gt;
</code></pre>
<p dir="auto">Als Template kannst du gemäß den Regeln HTML und javascript kombiniert einsetzen. die Daten des Datenpunkts werden dir über data bereitgestellt.</p>
]]></description><link>https://forum.iobroker.net/post/468138</link><guid isPermaLink="true">https://forum.iobroker.net/post/468138</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Thu, 30 Jul 2020 13:23:08 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 13:10:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul53" aria-label="Profile: paul53">@<bdi>paul53</bdi></a> sagte in <a href="/post/468119">Großen Datenpunkt im VIS anzeigen</a>:</p>
<blockquote>
<p dir="auto">Dann ist es bereits ein JSON.</p>
</blockquote>
<p dir="auto">Ich habe aber schon alle möglichen Widgets durchprobiert - eine Anzeige wie bei "richtig" als json formatierten Daten bekomme ich nirgends.</p>
]]></description><link>https://forum.iobroker.net/post/468136</link><guid isPermaLink="true">https://forum.iobroker.net/post/468136</guid><dc:creator><![CDATA[JB_Sullivan]]></dc:creator><pubDate>Thu, 30 Jul 2020 13:10:44 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:47:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jb_sullivan" aria-label="Profile: JB_Sullivan">@<bdi>JB_Sullivan</bdi></a> sagte:</p>
<blockquote>
<p dir="auto">wird auf jeden Fall in beiden Fällen als String angezeigt.</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/468119</link><guid isPermaLink="true">https://forum.iobroker.net/post/468119</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:47:45 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:38:25 GMT]]></title><description><![CDATA[<p dir="auto">wird auf jeden Fall in beiden Fällen als String angezeigt. Kann man das in json wandeln und wenn ja wie?</p>
]]></description><link>https://forum.iobroker.net/post/468107</link><guid isPermaLink="true">https://forum.iobroker.net/post/468107</guid><dc:creator><![CDATA[JB_Sullivan]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:38:25 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:34:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jb_sullivan" aria-label="Profile: JB_Sullivan">@<bdi>JB_Sullivan</bdi></a> sagte:</p>
<blockquote>
<p dir="auto">kann man doch auch in RAW Daten nachsehen.</p>
</blockquote>
<p dir="auto">Das was im Datenpunkt tatsächlich vorhanden ist, stimmt leider manchmal nicht mit dem überein, was im Datenpunkt vorhanden sein soll (<em>common.type</em>). Deshalb benötigt man die Typabfrage per Script.</p>
]]></description><link>https://forum.iobroker.net/post/468101</link><guid isPermaLink="true">https://forum.iobroker.net/post/468101</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:34:14 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:17:21 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f628.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--fearful" style="height:23px;width:auto;vertical-align:middle" title=":fearful:" alt="😨" /> <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f628.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--fearful" style="height:23px;width:auto;vertical-align:middle" title=":fearful:" alt="😨" />  Extra ein Blockly dafür schreiben - kann man doch auch in RAW Daten nachsehen.</p>
<p dir="auto">Der Typ ist "string"</p>
]]></description><link>https://forum.iobroker.net/post/468093</link><guid isPermaLink="true">https://forum.iobroker.net/post/468093</guid><dc:creator><![CDATA[JB_Sullivan]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:17:21 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:08:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jb_sullivan" aria-label="Profile: JB_Sullivan">@<bdi>JB_Sullivan</bdi></a> sagte:</p>
<blockquote>
<p dir="auto">nicht als json Objekt angegeben.</p>
</blockquote>
<p dir="auto">JSON ist ein String. Vielleicht enthält der Datenpunkt aber ein Objekt; dann muss er in ein JSON gewandelt werden. Was ergibt ?</p>
<p dir="auto"><img src="/assets/uploads/files/1596110907363-blockly_temp.jpg" alt="Blockly_temp.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/468088</link><guid isPermaLink="true">https://forum.iobroker.net/post/468088</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:02:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a> Habe ich schon probiert -  aber da wird nix angezeigt. Ist im Datenpunkt auch nicht als json Objekt angegeben.</p>
]]></description><link>https://forum.iobroker.net/post/468084</link><guid isPermaLink="true">https://forum.iobroker.net/post/468084</guid><dc:creator><![CDATA[JB_Sullivan]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:02:57 GMT</pubDate></item><item><title><![CDATA[Reply to Großen Datenpunkt im VIS anzeigen on Thu, 30 Jul 2020 12:01:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jb_sullivan" aria-label="Profile: JB_Sullivan">@<bdi>JB_Sullivan</bdi></a> JSON Table Widget?</p>
<p dir="auto">Oder was meinst du?</p>
]]></description><link>https://forum.iobroker.net/post/468079</link><guid isPermaLink="true">https://forum.iobroker.net/post/468079</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Thu, 30 Jul 2020 12:01:09 GMT</pubDate></item></channel></rss>
