  4. Seit update keine Zustandsänderungen der z.B. Fensterkontakte
18 Beiträge 3 Kommentatoren 2.1k Aufrufe
    audioconcept
    Hallo
    ich habe seit dem updaten der Adapter im Adminmodul keine veränderung der Schaltzustände im VIS.
    Im Log steht das:
    host-raspberrypi	2016-06-30 16:59:13.904	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host-raspberrypi	2016-06-30 16:59:13.902	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    hm-rpc-0	2016-06-30 16:59:13.869	info	terminating
    hm-rpc-0	2016-06-30 16:59:13.839	info	Disconnected
    hm-rpc-0	2016-06-30 16:59:13.798	info	binrpc -> 192.168.2.102:2001 init ["xmlrpc_bin://192.168.2.138:2001",""]
    TypeError:	2016-06-30 16:59:13.791	error	at TCP.onread (net.js:531:20)
    TypeError:	2016-06-30 16:59:13.791	error	at Socket.Readable.push (_stream_readable.js:111:10)
    TypeError:	2016-06-30 16:59:13.791	error	at readableAddChunk (_stream_readable.js:153:18)
    TypeError:	2016-06-30 16:59:13.791	error	at Socket.emit (events.js:169:7)
    TypeError:	2016-06-30 16:59:13.791	error	at emitOne (events.js:77:13)
    TypeError:	2016-06-30 16:59:13.791	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
    TypeError:	2016-06-30 16:59:13.791	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
    TypeError:	2016-06-30 16:59:13.791	error	Cannot read property '2' of undefined
    uncaught	2016-06-30 16:59:13.767	error	exception: Cannot read property '2' of undefined
    hm-rpc-0	2016-06-30 16:58:49.221	info	Connected
    hm-rpc-0	2016-06-30 16:58:47.630	info	binrpc -> 143 devices
    hm-rpc-0	2016-06-30 16:58:47.592	info	binrpc <- listDevices ["hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:58:47.323	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:58:47.318	info	binrpc server is trying to listen on 192.168.2.138:2001
    hm-rpc-0	2016-06-30 16:58:46.784	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
    host-raspberrypi	2016-06-30 16:58:44.102	info	instance system.adapter.hm-rpc.0 started with pid 2241
    host-raspberrypi	2016-06-30 16:58:14.073	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host-raspberrypi	2016-06-30 16:58:14.072	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    uncaught	2016-06-30 16:58:13.964	error	exception: Cannot read property '2' of undefined
    hm-rpc-0	2016-06-30 16:57:52.079	info	Connected
    hm-rpc-0	2016-06-30 16:57:50.423	info	binrpc -> 143 devices
    hm-rpc-0	2016-06-30 16:57:50.387	info	binrpc <- listDevices ["hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:57:49.119	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:57:49.113	info	binrpc server is trying to listen on 192.168.2.138:2001
    hm-rpc-0	2016-06-30 16:57:48.508	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
    host-raspberrypi	2016-06-30 16:57:45.803	info	instance system.adapter.hm-rpc.0 started with pid 2219
    host-raspberrypi	2016-06-30 16:57:15.771	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host-raspberrypi	2016-06-30 16:57:15.769	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    uncaught	2016-06-30 16:57:15.647	error	exception: Cannot read property '2' of undefined
    hm-rpc-0	2016-06-30 16:55:22.354	info	Connected
    hm-rpc-0	2016-06-30 16:55:20.755	info	binrpc -> 143 devices
    hm-rpc-0	2016-06-30 16:55:20.715	info	binrpc <- listDevices ["hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:55:20.446	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:55:20.440	info	binrpc server is trying to listen on 192.168.2.138:2001
    hm-rpc-0	2016-06-30 16:55:19.910	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
    host-raspberrypi	2016-06-30 16:55:17.409	info	instance system.adapter.hm-rpc.0 started with pid 2036
    host-raspberrypi	2016-06-30 16:54:47.386	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host-raspberrypi	2016-06-30 16:54:47.384	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    hm-rpc-0	2016-06-30 16:54:47.350	info	terminating
    hm-rpc-0	2016-06-30 16:54:47.319	info	Disconnected
    hm-rpc-0	2016-06-30 16:54:47.298	info	binrpc -> 192.168.2.102:2001 init ["xmlrpc_bin://192.168.2.138:2001",""]
    TypeError:	2016-06-30 16:54:47.293	error	at TCP.onread (net.js:531:20)
    TypeError:	2016-06-30 16:54:47.293	error	at Socket.Readable.push (_stream_readable.js:111:10)
    TypeError:	2016-06-30 16:54:47.293	error	at readableAddChunk (_stream_readable.js:153:18)
    TypeError:	2016-06-30 16:54:47.293	error	at Socket.emit (events.js:169:7)
    TypeError:	2016-06-30 16:54:47.293	error	at emitOne (events.js:77:13)
    TypeError:	2016-06-30 16:54:47.293	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
    TypeError:	2016-06-30 16:54:47.293	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
    TypeError:	2016-06-30 16:54:47.293	error	Cannot read property '2' of undefined
    uncaught	2016-06-30 16:54:47.277	error	exception: Cannot read property '2' of undefined
    hm-rpc-0	2016-06-30 16:52:23.893	info	Connected
    hm-rpc-0	2016-06-30 16:52:22.298	info	binrpc -> 143 devices
    hm-rpc-0	2016-06-30 16:52:22.263	info	binrpc <- listDevices ["hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:52:21.993	info	binrpc client is trying to connect to 192.168.2.102:2001 with ["xmlrpc_bin://192.168.2.138:2001","hm-rpc.0"]
    hm-rpc-0	2016-06-30 16:52:21.988	info	binrpc server is trying to listen on 192.168.2.138:2001
    hm-rpc-0	2016-06-30 16:52:21.442	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
    host-raspberrypi	2016-06-30 16:52:19.004	info	instance system.adapter.hm-rpc.0 started with pid 1973
    host-raspberrypi	2016-06-30 16:51:48.980	info	Restart adapter system.adapter.hm-rpc.0 because enabled
    host-raspberrypi	2016-06-30 16:51:48.979	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    Gruß aus Dortmund
    Michael
    <size size="85">Ausstattung: PI 4 , Rasbian , IOBroker , Admin 1.2.3, VIS 0.10.2, Host 0.90 [wird immer auf dem neuesten Stand geha…</size>
      Was hast du denn upgedated?
      Sind ALLE Adapter und auch der js-controller auf dem neuesten Stand?
        audioconcept
        Hi ja habe alle Adapter im Adminmodul aktualisiert.
        Gesendet von meinem STV100-4 mit Tapatalk
        Gruß aus Dortmund
        Michael
          audioconcept
          der js controller muss ich den anders auf dem neuesten Stand bringen?
          Komischerweise wird die Temperatur und Uhrzeit richtig angezeigt.Nur der Zustandbder Fenster und Türen nicht.
          Gruß aus Dortmund
          Michael
          • htreckslerH Offline
            htreckslerH Offline
            htrecksler
            Forum Testing
            guckst du hier
            http://www.iobroker.net/?page_id=3074&lang=de
            Gruss Hermann
              audioconcept
              Hi ist denn der Fehler hm-rpc oder node_modules?
              Soll ich das so ausführen?
              cd /opt/iobroker
              npm install iobroker.hm-rpc –production
              iobroker upload hm-rpc
              ./iobroker restart
              Gruß aus Dortmund
              Michael
                audioconcept
                Könnte ihr mir bitte noch mal weiterhelfen?
                Gruß aus Dortmund
                Michael
                  Wie ist denn jetzt der aktuelle Status?
                  Meine letzte Frage war:
                  @Homoran:
                  Sind ALLE Adapter und auch der js-controller auf dem neuesten Stand? `
                  Leider bekam ich nur die folgende Antwort:
                  @audioconcept:
                  ja … habe alle Adapter im Adminmodul aktualisiert. `
                  Da kann ich mir jetzt etwas bei aussuchen, oder?
                  Dann kommt:
                  @audioconcept:
                  der js controller muss ich den anders auf dem neuesten Stand bringen? `
                  und weiter Informationen, die ich nicht der aktuellen Lage zuordnen konnte.
                  Könnten aber ursächlich sein.
                  Also nochmal:
                  Was ist jetzt der Status?
                  • Fehlermeldungen im Log??
                    audioconcept
                    Hallo Rainer
                    Ich hatte Jessie neu installiert auf dem Pi. Habe es nach der Anleitung auf der IOBROKER Seite gemacht. Danach habe ich letzte Sicherungsdatei eingespielt.
                    Auf der Admin-Adapterseite habe ich alle Aktualisierungen ausgeführt.
                    ist der js-controller dann nicht automatisch auf den neuesten Stand?
                    Muss ich es dann so installieren?:
                    ` > cd /opt/iobroker
                    iobroker stop
                    npm install iobroker.js-controller –production
                    iobroker start `
                    Die Logmeldung ist noch die im ersten Beitrag.
                    Gruß aus Dortmund
                    Michael
                      @audioconcept:
                      ist der js-controller dann nicht automatisch auf den neuesten Stand? `
                      Nein, das update dazu findest du unter dem Reiter "Hosts"
                      @audioconcept:
                      cd /opt/iobroker
                      iobroker stop
                      npm install iobroker.js-controller --production
                      iobroker start
                      ja!
                        audioconcept
                        Hi Rainer
                        sorry ja unter Host ist der js controller auch auf dem neuesten Stand 0.9.0. Hatte ich auch alles gemacht.
                        Was kann ich noch machen?
                        Gruß aus Dortmund
                        Michael
                          Bitte folgendes alles auf der konsole ausführen und Fehlermeldungen sofort posten (cut and paste in code-tags)
                          zuerst einmal überprüfen, ob alles auf dem neuesten Stand ist.
                          cd /opt/iobroker
                          iobroker update
                          Sollte da hinter einem Adapter "updateable" stehen bitte diesen updaten, aber erst:
                          Da es ja immer sein kann, dass eine Datei beim Download korrupt ist, und damit diese auch wieder neu heruntergeladen wird, mache bitte als erstes:
                          cd /opt/iobroker
                          npm cache clean
                          Dann ggf. noch zu aktualisierende Adapter aktualisieren.
                          Da der Fehler anscheinend etwas mit dem hm-rpc zu tun hat würde ich jetzt erst einmal den neu installieren.
                          cd /opt/iobroker
                          iobroker stop
                          npm install iobroker.hm-rpc --production
                          iobroker start
                          Und dann mal sehen, ob es jetzt wieder läuft.
                            audioconcept
                            ok Danke versuche ich morgen sofort.
                            Gruß aus Dortmund
                            Michael
                              audioconcept
                              Hi hab alles jetzt so gemacht.
                              Geht aber noch immer nicht.
                              Im log steht immer noch:
                              Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                              raspberrypi	2016-07-04 20:27:47.231	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                              raspberrypi	2016-07-04 20:27:47.230	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc.0	2016-07-04 20:27:47.133	info	hm-rpc.0 Disconnected
                              hm-rpc.0	2016-07-04 20:27:46.932	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              hm-rpc.0	2016-07-04 20:27:46.932	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                              hm-rpc.0	2016-07-04 20:27:46.930	error	uncaught exception: Cannot read property '2' of undefined
                              hm-rpc.0	2016-07-04 20:26:04.552	info	hm-rpc.0 Connected
                              hm-rpc.0	2016-07-04 20:26:03.236	info	hm-rpc.0 binrpc -> 143 devices
                              hm-rpc.0	2016-07-04 20:26:02.859	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:26:02.596	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:26:02.593	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                              hm-rpc.0	2016-07-04 20:26:02.182	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              raspberrypi	2016-07-04 20:25:59.522	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 2009
                              raspberrypi	2016-07-04 20:25:29.511	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                              raspberrypi	2016-07-04 20:25:29.510	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc.0	2016-07-04 20:24:44.565	info	hm-rpc.0 Connected
                              hm-rpc.0	2016-07-04 20:24:43.252	info	hm-rpc.0 binrpc -> 143 devices
                              hm-rpc.0	2016-07-04 20:24:42.843	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:24:42.582	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:24:42.579	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                              hm-rpc.0	2016-07-04 20:24:42.172	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              raspberrypi	2016-07-04 20:24:39.539	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 1838
                              raspberrypi	2016-07-04 20:24:09.519	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                              raspberrypi	2016-07-04 20:24:09.517	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc.0	2016-07-04 20:24:09.458	info	hm-rpc.0 Disconnected
                              hm-rpc.0	2016-07-04 20:24:09.457	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              hm-rpc.0	2016-07-04 20:24:09.457	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                              hm-rpc.0	2016-07-04 20:24:09.453	error	uncaught exception: Cannot read property '2' of undefined
                              hm-rpc.0	2016-07-04 20:24:09.221	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              hm-rpc.0	2016-07-04 20:24:09.220	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                              hm-rpc.0	2016-07-04 20:24:09.219	error	uncaught exception: Cannot read property '2' of undefined
                              hm-rpc.0	2016-07-04 20:24:08.978	info	hm-rpc.0 Connected
                              hm-rpc.0	2016-07-04 20:24:07.646	info	hm-rpc.0 binrpc -> 143 devices
                              hm-rpc.0	2016-07-04 20:24:07.240	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:24:06.968	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:24:06.965	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                              hm-rpc.0	2016-07-04 20:24:06.567	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              raspberrypi	2016-07-04 20:24:05.831	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 1748
                              raspberrypi	2016-07-04 20:23:33.657	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                              raspberrypi	2016-07-04 20:23:33.656	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc.0	2016-07-04 20:23:33.575	info	hm-rpc.0 Disconnected
                              hm-rpc.0	2016-07-04 20:23:33.575	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              hm-rpc.0	2016-07-04 20:23:33.575	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                              hm-rpc.0	2016-07-04 20:23:33.574	error	uncaught exception: Cannot read property '2' of undefined
                              hm-rpc.0	2016-07-04 20:23:33.405	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              hm-rpc.0	2016-07-04 20:23:33.404	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                              hm-rpc.0	2016-07-04 20:23:33.402	error	uncaught exception: Cannot read property '2' of undefined
                              hm-rpc.0	2016-07-04 20:23:33.311	info	hm-rpc.0 Connected
                              hm-rpc.0	2016-07-04 20:23:31.925	info	hm-rpc.0 binrpc -> 143 devices
                              hm-rpc.0	2016-07-04 20:23:31.542	info	hm-rpc.0 binrpc <- listDevices ['hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:23:31.278	info	hm-rpc.0 binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                              hm-rpc.0	2016-07-04 20:23:31.275	info	hm-rpc.0 binrpc server is trying to listen on 192.168.2.138:2001
                              hm-rpc.0	2016-07-04 20:23:30.856	info	hm-rpc.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              raspberrypi	2016-07-04 20:23:28.984	info	host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 1739
                              raspberrypi	2016-07-04 20:22:57.953	info	host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                              raspberrypi	2016-07-04 20:22:57.952	error	host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc.0	2016-07-04 20:22:57.874	info	hm-rpc.0 Disconnected
                              hm-rpc.0	2016-07-04 20:22:57.682	info	hm-rpc.0 binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              hm-rpc.0	2016-07-04 20:22:57.681	error	TypeError: Cannot read property '2' of undefined at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48) at Socket.(/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                              hm-rpc.0	2016-07-04 20:22:57.678	error	uncaught exception: Cannot read property '2' of undefined
                              hm-rpc-0	2016-07-04 20:21:55.938	info	Connected
                              hm-rpc-0	2016-07-04 20:21:54.359	info	binrpc -> 143 devices
                              hm-rpc-0	2016-07-04 20:21:54.320	info	binrpc <- listDevices ['hm-rpc.0']
                              hm-rpc-0	2016-07-04 20:21:54.038	info	binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                              hm-rpc-0	2016-07-04 20:21:54.031	info	binrpc server is trying to listen on 192.168.2.138:2001
                              hm-rpc-0	2016-07-04 20:21:53.458	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              host-raspberrypi	2016-07-04 20:21:50.909	info	instance system.adapter.hm-rpc.0 started with pid 1651
                              host-raspberrypi	2016-07-04 20:21:20.887	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                              host-raspberrypi	2016-07-04 20:21:20.886	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc-0	2016-07-04 20:21:20.842	info	terminating
                              hm-rpc-0	2016-07-04 20:21:20.801	info	Disconnected
                              hm-rpc-0	2016-07-04 20:21:20.685	info	binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              TypeError:	2016-07-04 20:21:20.680	error	at TCP.onread (net.js:531:20)
                              TypeError:	2016-07-04 20:21:20.680	error	at Socket.Readable.push (_stream_readable.js:111:10)
                              TypeError:	2016-07-04 20:21:20.680	error	at readableAddChunk (_stream_readable.js:153:18)
                              TypeError:	2016-07-04 20:21:20.680	error	at Socket.emit (events.js:169:7)
                              TypeError:	2016-07-04 20:21:20.680	error	at emitOne (events.js:77:13)
                              TypeError:	2016-07-04 20:21:20.680	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
                              TypeError:	2016-07-04 20:21:20.680	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
                              TypeError:	2016-07-04 20:21:20.680	error	Cannot read property '2' of undefined
                              uncaught	2016-07-04 20:21:20.664	error	exception: Cannot read property '2' of undefined
                              hm-rpc-0	2016-07-04 20:20:46.258	info	Connected
                              hm-rpc-0	2016-07-04 20:20:44.616	info	binrpc -> 143 devices
                              hm-rpc-0	2016-07-04 20:20:44.576	info	binrpc <- listDevices ['hm-rpc.0']
                              hm-rpc-0	2016-07-04 20:20:44.299	info	binrpc client is trying to connect to 192.168.2.102:2001 with ['xmlrpc_bin://192.168.2.138:2001','hm-rpc.0']
                              hm-rpc-0	2016-07-04 20:20:44.293	info	binrpc server is trying to listen on 192.168.2.138:2001
                              hm-rpc-0	2016-07-04 20:20:43.752	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              host-raspberrypi	2016-07-04 20:20:41.198	info	instance system.adapter.hm-rpc.0 started with pid 1630
                              host-raspberrypi	2016-07-04 20:20:11.176	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                              host-raspberrypi	2016-07-04 20:20:11.175	error	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              hm-rpc-0	2016-07-04 20:20:11.139	info	terminating
                              hm-rpc-0	2016-07-04 20:20:11.095	info	Disconnected
                              hm-rpc-0	2016-07-04 20:20:11.075	info	binrpc -> 192.168.2.102:2001 init ['xmlrpc_bin://192.168.2.138:2001','']
                              TypeError:	2016-07-04 20:20:11.068	error	at TCP.onread (net.js:531:20)
                              TypeError:	2016-07-04 20:20:11.068	error	at Socket.Readable.push (_stream_readable.js:111:10)
                              TypeError:	2016-07-04 20:20:11.068	error	at readableAddChunk (_stream_readable.js:153:18)
                              TypeError:	2016-07-04 20:20:11.068	error	at Socket.emit (events.js:169:7)
                              TypeError:	2016-07-04 20:20:11.068	error	at emitOne (events.js:77:13)
                              TypeError:	2016-07-04 20:20:11.068	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
                              TypeError:	2016-07-04 20:20:11.068	error	at handleCall (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:72:48)
                              TypeError:	2016-07-04 20:20:11.068	error	Cannot read property '2' of undefined
                              uncaught	2016-07-04 20:20:11.047	error	exception: Cannot read property '2' of undefined
                              Gruß aus Dortmund
                              Michael
                                Stimmen die Konfigurationen von hm-rpc und hm-rega noch?
                                Irgendetwas scheint der hm-rpc einzulesen, mit dem er aber nicht klar kommt.
                                  audioconcept
                                  Hallo sollte eigentlich stimmen.
                                  filename="IMG_20160630_1708479.jpg" index="0">~~ filename="IMG_20160630_1708199.jpg" index="1">~~ filename="IMG_20160630_1708171.jpg" index="2">~~
                                  Gruß aus Dortmund
                                  Michael
                                    audioconcept
                                    Es waren keine Updates mehr offen (nur zwei Wetterupdates).
                                    Hast du noch eine Idee?
                                    Gruß aus Dortmund
                                    Michael
                                      audioconcept
                                      HI
                                      aus irgend einen Grund war im RPC Adapter BIN-RPC anstatt XML-RPC eingestellt. Jetzt geht es wieder.
                                      Danke euch.
                                      Gruß aus Dortmund
                                      Michael
                                      82.8k
