  4. Test Adapter nanoleaf-lightpanels v1.3.x GitHub/latest
canvaslight panelsnanoleafshapes
143 Beiträge 15 Kommentatoren 27.2k Aufrufe 16 Beobachtet
  • O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    @daniel_2k sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
    Du wirst im Log nix davon sehen
    Richtig:
    nanoleaf-lightpanels.0	2020-07-05 21:35:01.762	info	(4103) Reconnected to "192.168.0.105:16021
    nanoleaf-lightpanels.0	2020-07-05 21:35:01.761	debug	(4103) Connect timer stopped!
    nanoleaf-lightpanels.0	2020-07-05 21:34:01.753	debug	(4103) Connect timer started with 60000 ms
    nanoleaf-lightpanels.0	2020-07-05 21:34:01.751	debug	(4103) SSE connection closed!
    nanoleaf-lightpanels.0	2020-07-05 21:34:01.750	debug	(4103) Command queue cleared!
    nanoleaf-lightpanels.0	2020-07-05 21:34:01.749	debug	(4103) Polling timer stopped!
    nanoleaf-lightpanels.0	2020-07-05 21:34:01.748	warn	(4103) Connection to '192.168.0.105:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.762	debug	(4103) SSE subscription started, listening...
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.648	debug	(4103) nanoleaf Device "Canvas" (NL29) detected!
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.646	info	(4103) Connected to "192.168.0.105:16021
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.645	debug	(4103) Connect timer stopped!
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.612	info	(4103) Connecting to "192.168.0.105:16021"...
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.611	debug	(4103) SSDP events initialized!
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.609	info	(4103) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
    nanoleaf-lightpanels.0	2020-07-05 21:32:46.581	info	(4103) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.16.3, js-controller: 3.1.6
    Könntest du mal die Geräte-Suche ausprobieren?
    Es wurden keine Geräte gefunden! Versuche die manuelle Eingabe der IP-Adresse oder Hostname.
    • O oFbEQnpoLKKl6mbY5e13
      Richtig:
      daniel_2k
      @oFbEQnpoLKKl6mbY5e13
      So. Ich habe jetzt mal eine Entwickler-Version bereitgestellt, die diverse Anpassungen hat. Wenn du die mal testen könntest, wäre das gut.
      Bitte aus dem GitBranch hier installieren: https://github.com/daniel-2k/ioBroker.nanoleaf-lightpanels/tarball/dev_1.0.1
      Ich habe jetzt das fehlende Handling der SSDP notify Nachrichten für die Canvas ergänzt, so dass die warnings mit den connection losses weg sein sollte.
      Des Weiteren habe ich die Geräte-Suche angepasst. Ich vermute, dass die Canvas auf den ST der Lightpanels schlicht nicht reagiert haben. Leider steht dazu nix in der Doku, ob da auch unterschieden wird.
      Deshalb bitte mal die Geräte-Suche testen und schauen, ob die SSDP notify Messages jetzt verarbeitet werden und die Warning weg ist.
      Daneben habe ich in der Version mal das Logging etwas aufgeweicht. Im Debug werden jetzt alle SSDP-Nachrichten ausgegeben, die der Adapter empfängt (ohne Filter auf Notification Type). Da könnte jetzt durchaus einiges geloggt werden. So wäre interessant (falls es immer noch nicht funktioniert), ob im Log überhaupt SSDP Nachrichten zu sehen sind, und wenn ja, was da für ein ST bzw. NT für die Geräte drin steht.
      • O Abwesend
        O Abwesend
        Sieht gut aus:
        2020-07-06 16:01:38.441 - info: nanoleaf-lightpanels.0 (4374) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.16.3, js-controller: 3.1.6
        2020-07-06 16:01:38.471 - info: nanoleaf-lightpanels.0 (4374) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
        2020-07-06 16:01:38.474 - debug: nanoleaf-lightpanels.0 (4374) SSDP events initialized!
        2020-07-06 16:01:38.475 - info: nanoleaf-lightpanels.0 (4374) Connecting to "192.168.0.105:16021"...
        2020-07-06 16:01:38.514 - debug: nanoleaf-lightpanels.0 (4374) Connect timer stopped!
        2020-07-06 16:01:38.515 - info: nanoleaf-lightpanels.0 (4374) Connected to "192.168.0.105:16021
        2020-07-06 16:01:38.516 - warn: nanoleaf-lightpanels.0 (4374) nanoleaf device "NL29" unknown! Using Canvas device as fallback. Please report this to the developer!
        2020-07-06 16:01:38.518 - debug: nanoleaf-lightpanels.0 (4374) nanoleaf Device "Canvas" (NL29) detected!
        2020-07-06 16:01:38.636 - debug: nanoleaf-lightpanels.0 (4374) SSE subscription started, listening...
        2020-07-06 16:02:27.231 - debug: nanoleaf-lightpanels.0 (4374) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","location":"http://192.168.0.105:16021","usn":"uuid:XXX","nts":"ssdp:alive","nt":"nanoleaf:nl29"}
        2020-07-06 16:02:27.231 - debug: nanoleaf-lightpanels.0 (4374) ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","location":"http://192.168.0.105:16021","usn":"uuid:XXX","nts":"ssdp:alive","nt":"nanoleaf:nl29"}
        2020-07-06 16:02:27.232 - debug: nanoleaf-lightpanels.0 (4374) nanoleaf uuid:XXX from device '192.168.0.105' set!
        Suche auch:
        2020-07-06 16:04:14.689 - debug: nanoleaf-lightpanels.0 (4374) Incoming adapter message: searchDevice
        2020-07-06 16:04:14.802 - debug: nanoleaf-lightpanels.0 (4374) TEST: SSDP M-Search found device with USN: uuid:XXX and location: http://192.168.0.105:16021
        2020-07-06 16:04:14.802 - debug: nanoleaf-lightpanels.0 (4374) SSDP M-Search found device with USN: uuid:XXX and OpenAPI location: http://192.168.0.105:16021
        2020-07-06 16:04:14.803 - debug: nanoleaf-lightpanels.0 (4374) TEST: SSDP M-Search found device with USN: uuid:XXX and location: http://192.168.0.106:16021
        2020-07-06 16:04:14.805 - debug: nanoleaf-lightpanels.0 (4374) SSDP M-Search found device with USN: uuid:XXX and OpenAPI location: http://192.168.0.106:16021
        2020-07-06 16:04:19.692 - debug: nanoleaf-lightpanels.0 (4374) MSEARCH: 2 devices found!
        2 Gerät(e) wurde(n) gefunden und konnen in der Liste oben ausgewählt werden
        Welche Liste? 🤔
          Sieht gut aus:
          Suche auch:
          Welche Liste? 🤔
          daniel_2k
          @oFbEQnpoLKKl6mbY5e13 sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
          Welche Liste?
          Wenn die Suche abgeschlossen ist, ist ja das Feld für Host/IP ja leer. Wenn du mit der Maus über das Feld fährst, sollte rechts ein Klapppfeil zu sehen sein. Dann kannst du die Liste ausklappen und da sollten dann alle gefundenen Geräte (IP) drin stehen.
          • O Abwesend
            O Abwesend
            Da erscheint kein Pfeil.
            Aber wenn ich Doppelklicke, erhalte ich die zwei IP-Adressen.
              daniel_2k
              Naja, dass Verhalten dieser Datalist hängt auch etwas vom verwendeten Browser ab. Standardmäßig, wenn man die Adapter-Einstellungen öffnet, ist das ja nur ein stinknormales Inputfeld. Nachdem man die Suche angestoßen hat und was gefunden wurde, ist das eine Datalist. In Chrome sehe ich dann, wenn ich mit der Maus drüberhalte, einen Pfeil. Oder man klickt einfach in das Feld, dann geht die Liste auf.
              Bei Firefox, Edge etc. könnte sein, das da kein Pfeil zu sehen ist. Aber die Liste sollte durch reinklicken auf jeden Fall aufgehen. Habs mit Edge, IE, Firefox und Chrome getestet.
                daniel_2k
                Habe jetzt die Fixes in Version 1.0.2 gegossen und auf den GitHub Master sowie ins npm published.
                Sollte ab morgen im latest verfügbar sein. Bitte noch mal prüfen, jetzt sollte alles sauber laufen.
                • O Abwesend
                  O Abwesend
                  Okayyyyy.
                  (Mindestens 8 Zeichen... 😒 )
                  • O Abwesend
                    O Abwesend
                    2020-07-07 08:23:58.795 - info: nanoleaf-lightpanels.0 (4987) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.16.3, js-controller: 3.1.6
                    2020-07-07 08:23:58.821 - info: nanoleaf-lightpanels.0 (4987) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
                    2020-07-07 08:23:58.824 - debug: nanoleaf-lightpanels.0 (4987) SSDP events initialized!
                    2020-07-07 08:23:58.826 - info: nanoleaf-lightpanels.0 (4987) Connecting to "192.168.0.105:16021"...
                    2020-07-07 08:23:58.870 - debug: nanoleaf-lightpanels.0 (4987) Connect timer stopped!
                    2020-07-07 08:23:58.871 - info: nanoleaf-lightpanels.0 (4987) Connected to "192.168.0.105:16021"
                    2020-07-07 08:23:58.873 - debug: nanoleaf-lightpanels.0 (4987) nanoleaf Device "Canvas" (NL29) detected!
                    2020-07-07 08:23:59.445 - debug: nanoleaf-lightpanels.0 (4987) SSE subscription started, listening...
                    2020-07-07 08:24:41.897 - debug: nanoleaf-lightpanels.0 (4987) ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","location":"http://192.168.0.105:16021","usn":"uuid:XXX","nts":"ssdp:alive","nt":"nanoleaf:nl29"}
                    2020-07-07 08:24:41.899 - debug: nanoleaf-lightpanels.0 (4987) nanoleaf uuid:XXX from device '192.168.0.105' set!
                    • sentinelS Offline
                      sentinelS Offline
                      sentinel
                      Hallo Daniel.
                      Habe heute Morgen das 1.0.2 update eingespielt und es lief alles gut. Jetzt musste ich gerade den server rebooten und der Adapter reconnected sich danach wieder alle zwei Minuten wie vorher 🙃
                      Das Panel habe ich heute losgeschickt 😉
                      • sentinelS sentinel
                        Hallo Daniel.
                        daniel_2k
                        @sentinel
                        Naja, wenn es erst funktioniert hat und dann nicht mehr, dann kann es eigentlich nur ein Firewall/Netzwerkproblem sein. Sprich, es kommen gar keine SSDP Multicasts in dem Adapter respektive ioBroker Host an. Du wolltest ja ohnehin einiges abdrehen. Vielleicht zu viel abgedreht :-) ?
                        Jedenfalls im Debug siehst du ja die ssdp:alive Nachrichten. In deinem Log ist davon ja nix zu sehen, also kommt nix an.
                          stefande
                          @daniel_2k
                          Ich hab hier ein paar Canvas die auch Probleme machen.
                          Der ioBroker läuft unter Debian Buster in einer VirtualBox.
                          Die Suche funktioniert aber das SSE nicht.
                          2020-07-07 18:21:20.253 - info: host.iobroker-deb "system.adapter.nanoleaf-lightpanels.0" enabled
                          2020-07-07 18:21:20.276 - info: host.iobroker-deb instance system.adapter.nanoleaf-lightpanels.0 started with pid 20074
                          2020-07-07 18:21:20.822 - debug: nanoleaf-lightpanels.0 (20074) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-07-07 18:21:20.857 - debug: nanoleaf-lightpanels.0 (20074) Objects client ready ... initialize now
                          2020-07-07 18:21:20.860 - debug: nanoleaf-lightpanels.0 (20074) Objects create System PubSub Client
                          2020-07-07 18:21:20.861 - debug: nanoleaf-lightpanels.0 (20074) Objects create User PubSub Client
                          2020-07-07 18:21:20.869 - debug: nanoleaf-lightpanels.0 (20074) Objects client initialize lua scripts
                          2020-07-07 18:21:20.882 - debug: nanoleaf-lightpanels.0 (20074) Objects connected to redis: 127.0.0.1:9001
                          2020-07-07 18:21:20.887 - debug: nanoleaf-lightpanels.0 (20074) objectDB connected
                          2020-07-07 18:21:20.889 - debug: nanoleaf-lightpanels.0 (20074) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-07-07 18:21:20.895 - debug: nanoleaf-lightpanels.0 (20074) States create User PubSub Client
                          2020-07-07 18:21:20.897 - debug: nanoleaf-lightpanels.0 (20074) States create System PubSub Client
                          2020-07-07 18:21:20.906 - debug: nanoleaf-lightpanels.0 (20074) States connected to redis: 127.0.0.1:9000
                          2020-07-07 18:21:20.907 - debug: nanoleaf-lightpanels.0 (20074) statesDB connected
                          2020-07-07 18:21:21.587 - info: nanoleaf-lightpanels.0 (20074) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.18.2, js-controller: 3.1.6
                          2020-07-07 18:21:21.617 - info: javascript.0 (1759) script.js.Adapter_Überwachung: Adapter_Überwachung OK
                          2020-07-07 18:21:21.601 - info: nanoleaf-lightpanels.0 (20074) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
                          2020-07-07 18:21:21.603 - debug: nanoleaf-lightpanels.0 (20074) SSDP events initialized!
                          2020-07-07 18:21:21.604 - info: nanoleaf-lightpanels.0 (20074) Connecting to "192.168.0.151:16021"...
                          2020-07-07 18:21:21.658 - debug: nanoleaf-lightpanels.0 (20074) Connect timer stopped!
                          2020-07-07 18:21:21.659 - info: nanoleaf-lightpanels.0 (20074) Connected to "192.168.0.151:16021"
                          2020-07-07 18:21:21.668 - debug: nanoleaf-lightpanels.0 (20074) nanoleaf Device "Canvas" (NL29) detected!
                          2020-07-07 18:21:21.777 - debug: nanoleaf-lightpanels.0 (20074) SSE subscription started, listening...
                          2020-07-07 18:21:21.785 - debug: nanoleaf-lightpanels.0 (20074) Update from OpenAPI: value for state "Canvas.state" changed >>>> set new value: false
                          2020-07-07 18:21:21.797 - debug: nanoleaf-lightpanels.0 (20074) State change status: id: nanoleaf-lightpanels.0.Canvas.state: {"val":false,"ack":true,"ts":1594138881790,"q":0,"from":"system.adapter.nanoleaf-lightpanels.0","user":"system.user.admin","lc":1594138811247}
                          2020-07-07 18:21:24.247 - debug: nanoleaf-lightpanels.0 (20074) system.adapter.admin.0: logging true
                          2020-07-07 18:22:05.531 - info: host.iobroker-deb instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                          2020-07-07 18:22:36.769 - warn: nanoleaf-lightpanels.0 (20074) Connection to '192.168.0.151:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
                          2020-07-07 18:22:36.770 - debug: nanoleaf-lightpanels.0 (20074) Polling timer stopped!
                          2020-07-07 18:22:36.770 - debug: nanoleaf-lightpanels.0 (20074) Command queue cleared!
                          2020-07-07 18:22:36.771 - debug: nanoleaf-lightpanels.0 (20074) SSE connection closed!
                          2020-07-07 18:22:36.772 - debug: nanoleaf-lightpanels.0 (20074) Connect timer started with 60000 ms
                          • S stefande
                            @daniel_2k
                            daniel_2k
                            @stefande
                            Das SSE läuft schon, das hat mit dem "Keep alive" auch erstmal nix zu tun. Das ist ja nur eine ausgehende HTTP-Verbindung zu den nanoleafs.
                            Die Suche nutzt auch SSDP Nachrichten. Allerdings antworten die nanoleaf-Geräte auf einen MSEARCH-Request ja direkt dem Absender. Bei den SSDP:alive Notifications, die genutzt werden, um zu erkennen, ob das Gerät noch lebt, sind das allerdings Multicasts die von den nanoleafs gesendet werden. Die scheinen deinen ioBroker/Adapter nicht zu erreichen. Im Log sind die jedenfalls nicht zu sehen. Da ich die Auswertung der Nachrichten (bezüglich Notification Type in der 1.0.2 gefixt habe, dürfte das nicht die Ursache sein).
                            Kannst du prüfen, ob dein Debian dort firewalltechnisch diese blockiert?
                            • sentinelS Offline
                              sentinelS Offline
                              sentinel
                              @daniel_2k
                              Hab den Fehler bei mir gefunden. IGMP war nicht eingerichtet. Jetzt funzen die alive Signale wieder. Hatte meinen UniFi APs auch ein Update verpasst. Zu viele Updates zugleich sind nicht gut für eine anschließend notwendige Fehlersuche :)
                              • D daniel_2k
                                @stefande
                                stefande
                                @daniel_2k
                                Ich bin jetzt nicht wirklich der Debian Spezialist, aber so wie ich das sehe sollte die Firewall nix machen.
                                iobroker-deb:~# iptables -L
                                Chain INPUT (policy ACCEPT)
                                target     prot opt source               destination
                                Chain FORWARD (policy ACCEPT)
                                Chain OUTPUT (policy ACCEPT)
                                • S stefande
                                  @daniel_2k
                                  daniel_2k
                                  schrieb am zuletzt editiert von daniel_2k
                                  @stefande sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
                                  @daniel_2k
                                  Da hast du recht. Da wird gar nix gefiltert. Alles geht rein.
                                  OK. Die Geräte-Suche geht, sagst du. D.h. du findest dein nanoleaf-Gerät und kannst es in der Liste auswählen?
                                  Installiere mal die Test-Version hier von GitHub:
                                  https://github.com/daniel-2k/ioBroker.nanoleaf-lightpanels/tarball/test
                                  und stelle das Log-Level mal auf Debug. Dann werden alle SSDP Messages, die empfangen werden, geloggt. So sehen wir erstmal, ob überhaupt was ankommt und wenn ja, was genau.
                                  S 2 Antworten Letzte Antwort
                                  • D daniel_2k
                                    @daniel_2k
                                    stefande
                                    @daniel_2k
                                    Bitte schön:
                                    2020-07-07 20:02:17.288 - debug: nanoleaf-lightpanels.0 (9522) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2020-07-07 20:02:17.328 - debug: nanoleaf-lightpanels.0 (9522) Objects client ready ... initialize now
                                    2020-07-07 20:02:17.330 - debug: nanoleaf-lightpanels.0 (9522) Objects create System PubSub Client
                                    2020-07-07 20:02:17.331 - debug: nanoleaf-lightpanels.0 (9522) Objects create User PubSub Client
                                    2020-07-07 20:02:17.332 - debug: nanoleaf-lightpanels.0 (9522) Objects client initialize lua scripts
                                    2020-07-07 20:02:17.357 - debug: nanoleaf-lightpanels.0 (9522) Objects connected to redis: 127.0.0.1:9001
                                    2020-07-07 20:02:17.361 - debug: nanoleaf-lightpanels.0 (9522) objectDB connected
                                    2020-07-07 20:02:17.363 - debug: nanoleaf-lightpanels.0 (9522) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2020-07-07 20:02:17.370 - debug: nanoleaf-lightpanels.0 (9522) States create User PubSub Client
                                    2020-07-07 20:02:17.372 - debug: nanoleaf-lightpanels.0 (9522) States create System PubSub Client
                                    2020-07-07 20:02:17.383 - debug: nanoleaf-lightpanels.0 (9522) States connected to redis: 127.0.0.1:9000
                                    2020-07-07 20:02:17.383 - debug: nanoleaf-lightpanels.0 (9522) statesDB connected
                                    2020-07-07 20:02:18.161 - info: nanoleaf-lightpanels.0 (9522) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.18.2, js-controller: 3.1.6
                                    2020-07-07 20:02:18.184 - info: nanoleaf-lightpanels.0 (9522) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
                                    2020-07-07 20:02:18.185 - debug: nanoleaf-lightpanels.0 (9522) SSDP events initialized!
                                    2020-07-07 20:02:18.186 - info: nanoleaf-lightpanels.0 (9522) Connecting to "192.168.0.151:16021"...
                                    2020-07-07 20:02:18.199 - info: javascript.0 (1759) script.js.Adapter_Überwachung: Adapter_Überwachung OK
                                    2020-07-07 20:02:18.226 - debug: nanoleaf-lightpanels.0 (9522) Connect timer stopped!
                                    2020-07-07 20:02:18.228 - info: nanoleaf-lightpanels.0 (9522) Connected to "192.168.0.151:16021"
                                    2020-07-07 20:02:18.230 - debug: nanoleaf-lightpanels.0 (9522) nanoleaf Device "Canvas" (NL29) detected!
                                    2020-07-07 20:02:18.279 - debug: nanoleaf-lightpanels.0 (9522) SSE subscription started, listening...
                                    2020-07-07 20:02:25.933 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:02:25.934 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:02:25.934 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:02:30.648 - debug: nanoleaf-lightpanels.0 (9522) system.adapter.admin.0: logging true
                                    2020-07-07 20:02:35.930 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:02:35.930 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:02:35.931 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:02:45.932 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:02:45.933 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:02:45.933 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:02:49.383 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:02:49.389 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                    2020-07-07 20:02:49.390 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                    2020-07-07 20:02:49.391 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                    2020-07-07 20:02:49.392 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                    2020-07-07 20:02:49.392 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                    2020-07-07 20:02:55.938 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:02:55.940 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:02:55.942 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:03:05.936 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:05.937 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:03:05.937 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:03:10.034 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:10.036 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1","nts":"ssdp:alive","nt":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1"}
                                    2020-07-07 20:03:10.038 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:schemas-upnp-org:device:MediaServer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaServer:1"}
                                    2020-07-07 20:03:10.046 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:schemas-upnp-org:service:ContentDirectory:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ContentDirectory:1"}
                                    2020-07-07 20:03:10.049 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                    2020-07-07 20:03:10.053 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","nts":"ssdp:alive","nt":"urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1"}
                                    2020-07-07 20:03:10.057 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:avm.de:service:AVM_ServerStatus:1","nts":"ssdp:alive","nt":"urn:avm.de:service:AVM_ServerStatus:1"}
                                    2020-07-07 20:03:11.034 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:11.036 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1","nts":"ssdp:alive","nt":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1"}
                                    2020-07-07 20:03:11.040 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-upnp-org:device:fritzbox:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:fritzbox:1"}
                                    2020-07-07 20:03:11.050 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-any-com:service:fritzbox:1","nts":"ssdp:alive","nt":"urn:schemas-any-com:service:fritzbox:1"}
                                    2020-07-07 20:03:15.944 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:15.945 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:03:15.947 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:03:22.033 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:22.034 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1","nts":"ssdp:alive","nt":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1"}
                                    2020-07-07 20:03:22.035 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-upnp-org:device:avmnexus:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:avmnexus:1"}
                                    2020-07-07 20:03:22.042 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-any-com:service:avmnexus:1","nts":"ssdp:alive","nt":"urn:schemas-any-com:service:avmnexus:1"}
                                    2020-07-07 20:03:25.944 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:25.945 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:03:25.945 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:03:26.499 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:26.501 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","nts":"ssdp:alive","nt":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:26.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:27.500 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:27.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","nts":"ssdp:alive","nt":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:27.505 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:device:MediaServer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:27.506 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ContentDirectory:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ContentDirectory:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:27.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:27.509 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","nts":"ssdp:alive","nt":"urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:03:33.251 - warn: nanoleaf-lightpanels.0 (9522) Connection to '192.168.0.151:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
                                    2020-07-07 20:03:33.252 - debug: nanoleaf-lightpanels.0 (9522) Polling timer stopped!
                                    2020-07-07 20:03:33.253 - debug: nanoleaf-lightpanels.0 (9522) Command queue cleared!
                                    2020-07-07 20:03:33.254 - debug: nanoleaf-lightpanels.0 (9522) SSE connection closed!
                                    2020-07-07 20:03:33.255 - debug: nanoleaf-lightpanels.0 (9522) Connect timer started with 60000 ms
                                    2020-07-07 20:03:35.950 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:35.952 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:03:35.953 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:03:45.737 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                    2020-07-07 20:03:45.738 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","nts":"ssdp:alive","nt":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                    2020-07-07 20:03:45.738 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                    2020-07-07 20:03:45.950 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:45.950 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:03:45.951 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:03:49.454 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:49.455 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                    2020-07-07 20:03:49.456 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                    2020-07-07 20:03:49.457 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                    2020-07-07 20:03:49.457 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                    2020-07-07 20:03:49.458 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                    2020-07-07 20:03:55.956 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:03:55.957 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:03:55.958 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:04:01.405 - info: daswetter.0 (9895) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.18.2, js-controller: 3.1.6
                                    2020-07-07 20:04:05.956 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:05.957 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:04:05.958 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:04:10.733 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                    2020-07-07 20:04:10.736 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","nts":"ssdp:alive","nt":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                    2020-07-07 20:04:10.742 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                    2020-07-07 20:04:15.959 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:15.960 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:04:15.961 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:04:25.959 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:25.959 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:04:25.960 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:04:33.268 - debug: nanoleaf-lightpanels.0 (9522) Connect timer stopped!
                                    2020-07-07 20:04:33.269 - info: nanoleaf-lightpanels.0 (9522) Reconnected to "192.168.0.151:16021"
                                    2020-07-07 20:04:33.270 - debug: nanoleaf-lightpanels.0 (9522) nanoleaf Device "Canvas" (NL29) detected!
                                    2020-07-07 20:04:33.343 - debug: nanoleaf-lightpanels.0 (9522) SSE subscription started, listening...
                                    2020-07-07 20:04:35.967 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:35.968 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:04:35.969 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:04:45.969 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:45.971 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:04:45.972 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:04:49.524 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:49.525 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                    2020-07-07 20:04:49.526 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                    2020-07-07 20:04:49.528 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                    2020-07-07 20:04:49.529 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                    2020-07-07 20:04:49.529 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                    2020-07-07 20:04:50.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:50.505 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","nts":"ssdp:alive","nt":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:50.507 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:51.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:51.505 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","nts":"ssdp:alive","nt":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:51.506 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:device:MediaServer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:51.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ContentDirectory:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ContentDirectory:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:51.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:51.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","nts":"ssdp:alive","nt":"urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                    2020-07-07 20:04:55.973 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:04:55.975 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:04:55.976 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:05.974 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:05.974 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:05:05.975 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:15.978 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:15.980 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:05:15.981 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:25.985 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:25.986 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:05:25.988 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:35.990 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:35.990 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:05:35.991 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:45.993 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:45.994 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:05:45.994 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:48.326 - warn: nanoleaf-lightpanels.0 (9522) Connection to '192.168.0.151:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
                                    2020-07-07 20:05:48.327 - debug: nanoleaf-lightpanels.0 (9522) Polling timer stopped!
                                    2020-07-07 20:05:48.327 - debug: nanoleaf-lightpanels.0 (9522) Command queue cleared!
                                    2020-07-07 20:05:48.328 - debug: nanoleaf-lightpanels.0 (9522) SSE connection closed!
                                    2020-07-07 20:05:48.328 - debug: nanoleaf-lightpanels.0 (9522) Connect timer started with 60000 ms
                                    2020-07-07 20:05:49.597 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:49.599 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                    2020-07-07 20:05:49.600 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                    2020-07-07 20:05:49.601 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                    2020-07-07 20:05:49.602 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                    2020-07-07 20:05:49.604 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                    2020-07-07 20:05:55.997 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                    2020-07-07 20:05:55.997 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                    2020-07-07 20:05:55.998 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                    2020-07-07 20:05:58.692 - info: host.iobroker-deb "system.adapter.nanoleaf-lightpanels.0" disabled
                                    2020-07-07 20:05:58.697 - info: host.iobroker-deb stopInstance system.adapter.nanoleaf-lightpanels.0 (force=false, process=true)
                                    2020-07-07 20:05:58.703 - info: nanoleaf-lightpanels.0 (9522) Got terminate signal TERMINATE_YOURSELF
                                    2020-07-07 20:05:58.698 - info: host.iobroker-deb stopInstance system.adapter.nanoleaf-lightpanels.0 send kill signal
                                    • S stefande
                                      @daniel_2k
                                      Bitte schön:
                                      daniel_2k
                                      @stefande
                                      Also wie du siehst kommen SSDP Multicasts grundsätzlich mal im Adapter an. Deine anderen Netzwerkgeräte sieht man.
                                      Aber es sind keine von den nanoleafs dabei. Deine Canvas senden offenbar schlicht keine ssdp:alive Nachrichten.
                                      Welche Firmware hast du im Einsatz?
                                      Im Moment kann ich mir das auch nicht erklären, warum die nichts senden.
                                      Kannst du die Canvas mal neustarten (Strom weg und wieder einschalten)?
                                      • D daniel_2k
                                        @daniel_2k
                                        stefande
                                        @daniel_2k sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
                                        Ach ja... Die Suche geht und das Nanoleaf lässt sich auswählen. Ein Pfeil ist allerdings bei mir auch nicht zu sehen. Aber das ist wohl nebensächlich.
                                        In der Zeit wo der Adapter grün ist kann ich steuern, und bekomme auch Rückmeldungen.
                                        Verliert er die Connection wird der Adapter gelb.
                                        • S stefande
                                          daniel_2k
                                          @stefande
                                          Das mit dem Pfeil ist Browserspezifisch. Starte mal deine Canvas neu und schaue mal, ob dann was kommt. Kann nur am Gerät liegen, da andere SSDP Notifications ja ankommen.
