  4. Hm-rpc 1.2.0
Hm-rpc 1.2.0
63 Beiträge 12 Kommentatoren 10.5k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Ich habe 1.3.0 auf dem git gemacht.
    Kann jemand prüfen? Da habe ich das Problem mit bin-rpc gelöst.
    • BluefoxB Offline
      BluefoxB Offline
      @pix:
      habe ja auf ein Backup vor dem Update zurückgespielt (hm-rpc 1.1.3). Leider seitdem trotzdem Fehler:
      2016-06-21 22:06:57.129  - [31merror[39m: hm-rpc.0 Error: XML-RPC fault: ping: unknown method name
      2016-06-21 22:08:27.130  - [31merror[39m: hm-rpc.0 Error: XML-RPC fault: ping: unknown method name
      `2016-06-21 21:36:20.053  - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.hm-rpc.0 started with pid 3024
      2016-06-21 21:36:20.585  - [32minfo[39m: hm-rpc.0 starting. Version 1.1.3 in /Users/pix/Documents/iobroker/node_modules/iobroker.hm-rpc
      2016-06-21 21:36:20.780  - [32minfo[39m: hm-rpc.0 binrpc server is trying to listen on 192.168.178.38:3000
      2016-06-21 21:36:20.781  - [32minfo[39m: hm-rpc.0 binrpc -> 192.168.178.33:2001 init ["xmlrpc_bin://192.168.178.38:3000","hm-rpc.0"]
      2016-06-21 21:36:20.794  - [32minfo[39m: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
      2016-06-21 21:36:20.832  - [32minfo[39m: hm-rpc.0 binrpc -> 371 devices
      2016-06-21 21:36:23.877  - [31merror[39m: uncaught exception: Cannot read property '2' of undefined
      2016-06-21 21:36:23.879  - [31merror[39m: TypeError: Cannot read property '2' of undefined
          at handleCall (/Users/pix/Documents/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:74:48)
          at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
          at emitOne (events.js:77:13)
          at Socket.emit (events.js:169:7)
          at readableAddChunk (_stream_readable.js:146:16)
          at Socket.Readable.push (_stream_readable.js:110:10)
          at TCP.onread (net.js:523:20)
      2016-06-21 21:36:23.880  - [32minfo[39m: hm-rpc.0 binrpc -> 192.168.178.33:2001 init ["xmlrpc_bin://192.168.178.38:3000",""]
      2016-06-21 21:36:23.951  - [32minfo[39m: hm-rpc.0 terminating[/code]</anonymous>`
      Pix
      Edit: Nach Neustart CCU1 hetzt keine Verbindung mehr über HM-RPC.0 (ccu1)
      Da kommen unerwartete Daten vom CCU.
      Kannst du _~~[i]~~/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js[/i]_ ändern (ab Zeile 70):
      von
      `~~[code]~~	    // reorder WORKING datapoint
                  for (var i = 0; i < request.params[0].length; i++) {
                      if (request.params[0][i].params[2] === 'WORKING') {
                          request.params[0][0] = request.params[0].splice(i, 1, request.params[0][0])[0];
      auf
                      if (request.params[0][i].params && request.params[0][i].params[2] === 'WORKING') {
                  }` [/i][/i][/code][/i][/code]
      • nieIPN Offline
        nieIPN Offline
        nieIP
        Hallo
        ich versuche es. Bisher bin ich noch mit der Installation beschäftigt :(
        1.3.0 bin-rpc funktioniert bei mir.
        Daten werden von der CCU empfangen.
        Danke für die Reparatur
         hm-rpc-0	2016-06-23 22:58:51.987	info	Connected
        hm-rpc-0	2016-06-23 22:58:50.118	info	binrpc -> 680 devices
        hm-rpc-0	2016-06-23 22:58:49.942	info	binrpc <- listDevices ["hm-rpc.0"]
        hm-rpc-0	2016-06-23 22:58:49.924	info	binrpc <- system.listMethods ["hm-rpc.0"]
        hm-rpc-0	2016-06-23 22:58:49.890	info	Connected. Send init...
        hm-rpc-0	2016-06-23 22:58:49.685	info	1 Init binrc...
        hm-rpc-0	2016-06-23 22:58:49.681	info	binrpc client is trying to connect to 192.168.1.55:2001 with ["xmlrpc_bin://192.168.1.161:2001","hm-rpc.0"]
        hm-rpc-0	2016-06-23 22:58:49.679	info	binrpc server is trying to listen on 192.168.1.161:2001
        hm-rpc-0	2016-06-23 22:58:48.547	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
        host-raspi-3	2016-06-23 22:58:47.286	info	instance system.adapter.hm-rpc.0 started with pid 31917
        host-raspi-3	2016-06-23 22:58:44.852	info	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
        hm-rpc-0	2016-06-23 22:58:44.822	info	terminating
        • HomoranH Offline
          HomoranH Offline
          Habe wie immer direkt in der produktiven Umgebung upgedatet.
          Keine Fehlermeldung im Log.
          Umgeschaltet auf BIN
          hm-rpc-1	2016-06-23 22:57:28.427	warn	No image for "HM-RC-2-PBU-FM" found.
          hm-rpc-1	2016-06-23 22:57:28.427	warn	No image for "HM-PB-2-FM" found.
          hm-rpc-1	2016-06-23 22:57:28.426	warn	No image for "HM-PB-2-FM" found.
          hm-rpc-1	2016-06-23 22:57:28.416	warn	No image for "ZEL STG RM FDK" found.
          hm-rpc-1	2016-06-23 22:57:28.415	warn	No image for "ZEL STG RM FDK" found.
          hm-rpc-1	2016-06-23 22:57:28.414	warn	No image for "ZEL STG RM FDK" found.
          hm-rpc-1	2016-06-23 22:57:28.408	info	binrpc <- newDevices 382
          hm-rpc-1	2016-06-23 22:57:25.365	info	Connected
          hm-rpc-1	2016-06-23 22:57:25.185	info	binrpc -> 0 devices
          hm-rpc-1	2016-06-23 22:57:25.132	info	binrpc <- listDevices ["hm-rpc.1"]
          hm-rpc-1	2016-06-23 22:57:25.117	info	binrpc <- system.listMethods ["hm-rpc.1"]
          hm-rpc-1	2016-06-23 22:57:25.093	info	Connected. Send init...
          hm-rpc-1	2016-06-23 22:57:24.886	info	1 Init binrc...
          hm-rpc-1	2016-06-23 22:57:24.882	info	binrpc client is trying to connect to 192.168.138.52:2001 with ["xmlrpc_bin://192.168.138.44:2001","hm-rpc.1"]
          hm-rpc-1	2016-06-23 22:57:24.879	info	binrpc server is trying to listen on 192.168.138.44:2001
          hm-rpc-1	2016-06-23 22:57:24.205	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
          host-Test-Pi3	2016-06-23 22:57:22.896	info	instance system.adapter.hm-rpc.1 started with pid 31010
          Sieht gut aus, (trotz lxccu :D )
          Mal überwachen, ob die Daten auch aktualisiert werden
          • BluefoxB Offline
            BluefoxB Offline
            Wer hat die Bilder für: ZEL STG RM FDK, HM-PB-2-FM und HM-RC-2-PBU-FM?
            angelnu?
            • HomoranH Offline
              HomoranH Offline
              Der Zel ist ein tfk nur von Roto
              • N Offline
                N Offline
                nobody
                Hallo Bluefox,
                ich hab die Version 1.3.0 installiert und mit mehreren Aktoren ausprobiert.
                Mit einfachen Schaltaktoren klappt die Übertragung in beide Richtungen.
                Problem ist auch hier der Jalousie-Aktor. Damit klappt es bei mir leider noch nicht.
                Wenn ich den Wert für level in VIS ändere, wird dieser korrekt übertragen.
                Wenn ich die Jalousie von Hand oder in der Homematic ändere, kam jedoch nur eine Änderung auf 0 (komplett zu) durch. Alle anderen Änderungen werden nicht übertragen.
                Markus
                • N Offline
                  N Offline
                  nobody
                  Ich hab jetzt auch den Grund gefunden, warum die Level-Werte falsch sind:
                  Es fehlt die Sonderlogik für Unit=100% in der neuen Version.
                  Statt 45% oder 100% wird nun als Level 0.45 % oder 1 % eingetragen.
                  • P Offline
                    pix
                    @Bluefox:
                    Kannst du /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js ändern (ab Zeile 70):
                    von
                     `// reorder WORKING datapoint
                    auf
                    Erledigt. HM-RPC und HM-REGA vorher angehalten. Warte Änderungen ab.
                    Danke,
                    Pix
                    ~~[color]~~
                    EDIT:[/color]
                    XML Verbindung brachte weiterhin Fehler:
                    `~~[code]~~2016-06-24 11:57:19.970  - [31merror[39m: hm-rpc.0 Error: XML-RPC fault: ping: unknown method name[/code]`
                    Umstellung auf BIN-RPC funktionierte danach tadellos. Keine Fehler ausser dem obligatorischen
                    `~~[code]~~2016-06-24 11:58:40.865  - [33mwarn[39m: hm-rpc.1 No image for "HM-TC-IT-WM-W-EU" found.[/code]`
                     :lol:
                    Somit sind auch Fehler beim Auslesen der Stromzähler und beim Schreiben der LED16-Anzeige wieder korrigiert.
                    Danke![/code][/code][/i][/i][/code][/i]
                    • BluefoxB Offline
                      BluefoxB Offline
                      @nobody:
                      filename="levelbug.png" index="0">~~ `
                      Kannst du das Objekt hier Posten?
                      • N Offline
                        N Offline
                        nobody
                        Was benötigst du genau?
                        Hier erstmal ein Export eines Jalousieaktors von der Admin-Seite:
                        ! {"hm-rpc.0.MEQ0735184.1":{"_id":"hm-rpc.0.MEQ0735184.1","type":"channel","common":{"name":"HM-LC-Bl1PBU-FMMEQ0735184:1","role":"blind","icon":"/icons/PushButton-2ch-wm_thumb.png"},"native":{"ADDRESS":"MEQ0735184:1","AES_ACTIVE":0,"DIRECTION":2,"FLAGS":1,"INDEX":1,"LINK_SOURCE_ROLES":"","LINK_TARGET_ROLES":"SWITCHWEATHER_CS","PARAMSETS":["LINK","MASTER","VALUES"],"PARENT":"MEQ0735184","PARENT_TYPE":"HM-LC-Bl1PBU-FM","TYPE":"BLIND","VERSION":8}},"hm-rpc.0.MEQ0735184.0":{"_id":"hm-rpc.0.MEQ0735184.0","type":"channel","common":{"name":"RolloWohnzOst1:0","icon":"/icons/PushButton-2ch-wm_thumb.png"},"native":{"ADDRESS":"MEQ0735184:0","AES_ACTIVE":0,"DIRECTION":0,"FLAGS":3,"INDEX":0,"LINK_SOURCE_ROLES":"","LINK_TARGET_ROLES":"","PARAMSETS":["MASTER","VALUES"],"PARENT":"MEQ0735184","PARENT_TYPE":"HM-LC-Bl1PBU-FM","TYPE":"MAINTENANCE","VERSION":8}},"hm-rpc.0.MEQ0735184":{"_id":"hm-rpc.0.MEQ0735184","type":"device","common":{"name":"RolloWohnzOst1","role":"blind","icon":"/icons/PushButton-2ch-wm_thumb.png"},"native":{"ADDRESS":"MEQ0735184","AVAILABLE_FIRMWARE":"2.8","CHILDREN":["MEQ0735184:0","MEQ0735184:1"],"FIRMWARE":"2.8","FLAGS":1,"INTERFACE":"LEQ0418982","PARAMSETS":["MASTER"],"PARENT":"","RF_ADDRESS":4093332,"ROAMING":0,"RX_MODE":1,"TYPE":"HM-LC-Bl1PBU-FM","UPDATABLE":1,"VERSION":8}},"hm-rpc.0.MEQ0735184.0.AES_KEY":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":127,"role":"value","name":"RolloWohnzOst1:0.AES_KEY"},"native":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":8,"TYPE":"INTEGER","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.AES_KEY"},"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator","name":"RolloWohnzOst1:0.CONFIG_PENDING"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING"},"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"name":"RolloWohnzOst1:0.DEVICE_IN_BOOTLOADER"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER"},"hm-rpc.0.MEQ0735184.0.DUTYCYCLE":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"value","name":"RolloWohnzOst1:0.DUTYCYCLE"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"DUTYCYCLE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.DUTYCYCLE"},"hm-rpc.0.MEQ0735184.0.RSSI_DEVICE":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-2147483648,"max":2147483647,"role":"value","name":"RolloWohnzOst1:0.RSSI_DEVICE"},"native":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.RSSI_DEVICE"},"hm-rpc.0.MEQ0735184.0.RSSI_PEER":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-2147483648,"max":2147483647,"role":"value.rssi","name":"RolloWohnzOst1:0.RSSI_PEER"},"native":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.RSSI_PEER"},"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"indicator.unreach","name":"RolloWohnzOst1:0.STICKY_UNREACH"},"native":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH"},"hm-rpc.0.MEQ0735184.0.UNREACH":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"RolloWohnzOst1:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.UNREACH"},"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"name":"RolloWohnzOst1:0.UPDATE_PENDING"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING"},"hm-rpc.0.MEQ0735184.1.DIRECTION":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":3,"states":{"0":"NONE","1":"UP","2":"DOWN","3":"UNDEFINED"},"role":"indicator.direction","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.DIRECTION"},"native":{"DEFAULT":0,"FLAGS":3,"ID":"DIRECTION","MAX":3,"MIN":0,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"ENUM","UNIT":"","VALUE_LIST":["NONE","UP","DOWN","UNDEFINED"]},"_id":"hm-rpc.0.MEQ0735184.1.DIRECTION"},"hm-rpc.0.MEQ0735184.1.INHIBIT":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"state.inhibit","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.INHIBIT"},"native":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.INHIBIT"},"hm-rpc.0.MEQ0735184.1.INSTALL_TEST":{"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"indicator","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.INSTALL_TEST"},"native":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.INSTALL_TEST"},"hm-rpc.0.MEQ0735184.1.LEVEL":{"type":"state","common":{"def":0,"type":"number","read":true,"write":true,"min":0,"max":100,"unit":"%","role":"level.blind","workingID":"WORKING","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.LEVEL"},"native":{"CONTROL":"BLIND.LEVEL","DEFAULT":0,"FLAGS":1,"ID":"LEVEL","MAX":1,"MIN":0,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"100%"},"_id":"hm-rpc.0.MEQ0735184.1.LEVEL"},"hm-rpc.0.MEQ0735184.1.STOP":{"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"action.stop","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.STOP"},"native":{"CONTROL":"BLIND.STOP","DEFAULT":false,"FLAGS":1,"ID":"STOP","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.STOP"},"hm-rpc.0.MEQ0735184.1.WORKING":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.working","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.WORKING"},"native":{"DEFAULT":false,"FLAGS":3,"ID":"WORKING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.WORKING"},"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.CONFIG_PENDING","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.CONFIG_PENDING","TypeName":"ALARM","DP":"12759"},"_id":"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING_ALARM"},"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.DEVICE_IN_BOOTLOADER","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.DEVICE_IN_BOOTLOADER","TypeName":"ALARM","DP":"12763"},"_id":"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER_ALARM"},"hm-rpc.0.MEQ0735184.0.DUTYCYCLE_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.DUTYCYCLE","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.DUTYCYCLE","TypeName":"ALARM","DP":"12767"},"_id":"hm-rpc.0.MEQ0735184.0.DUTYCYCLE_ALARM"},"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.STICKY_UNREACH","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.STICKY_UNREACH","TypeName":"ALARM","DP":"12773"},"_id":"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH_ALARM"},"hm-rpc.0.MEQ0735184.0.UNREACH_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.UNREACH","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.UNREACH","TypeName":"ALARM","DP":"12777"},"_id":"hm-rpc.0.MEQ0735184.0.UNREACH_ALARM"},"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.UPDATE_PENDING","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.UPDATE_PENDING","TypeName":"ALARM","DP":"12781"},"_id":"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING_ALARM"}}
                        • N Offline
                          N Offline
                          nobody
                          Ich hab mal noch ein wenig nachgeforscht. Das Problem ist der folgende Code-Abschnitt:
                              event: function (err, params) {
                                  adapter.log.debug(adapter.config.type + 'rpc <- event ' + JSON.stringify(params));
                                  var val;
                                  var channel = params[1].replace(':', '.');
                                  var name = params[0] + '.' + channel + '.' + params[2];
                                  if (dpTypes[name] && dpTypes[name].UNIT === '100%') {
                                      val = (params[3] * 100);
                                  } else {
                                      val = params[3];
                          Es wird versucht, mit dem Namen in dpTypes den Eintrag zu finden. Problem ist nur, dass kein Eintrag gefunden wird.
                          Hier der relevante Ausschnitt für einen der Aktoren:
                          ! name: raspberrypi.hm-rpc.0.LEQ1438264.1.LEVEL New value:1
                          ! dpTypes: {"hm-rpc.0.LEQ1438264.0.AES_KEY":{"UNIT":"","TYPE":"INTEGER"},"hm-rpc.0.LEQ1438264.0.CONFIG_PENDING":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.DEVICE_IN_BOOTLOADER":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.DUTYCYCLE":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.RSSI_DEVICE":{"UNIT":"","TYPE":"INTEGER"},"hm-rpc.0.LEQ1438264.0.RSSI_PEER":{"UNIT":"","TYPE":"INTEGER"},"hm-rpc.0.LEQ1438264.0.STICKY_UNREACH":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.UNREACH":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.UPDATE_PENDING":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.1.DIRECTION":{"UNIT":"","TYPE":"ENUM"},"hm-rpc.0.LEQ1438264.1.INHIBIT":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.1.INSTALL_TEST":{"UNIT":"","TYPE":"ACTION"},"hm-rpc.0.LEQ1438264.1.LEVEL":{"UNIT":"100%","TYPE":"FLOAT"},"hm-rpc.0.LEQ1438264.1.STOP":{"UNIT":"","TYPE":"ACTION"},"hm-rpc.0.LEQ1438264.1.WORKING":{"UNIT":"","TYPE":"BOOL"}}
                          Update:
                          Der Name, mit dem gesucht wird, enthält den Host-Namen der Instanz raspberrypi.hm-rpc.0.LEQ1438264.1.LEVEL,
                          Im Array sind die Werte aber nur ohne Host-Namen drin: hm-rpc.0.LEQ1438264.1.LEVEL
                          mfg
                          Markus
                          • N Offline
                            N Offline
                            nobody
                            Hallo bluefox,
                            ich hab jetzt die hm-rpc.js so abgeändert, dass in den Methoden für das Setzen und Übertagen der Werte beim Zugriff auf dpTypes der Hostname ergänzt wird. Jetzt funktioniert bei mir die Übertagung wieder in beide Richtungen.
                            Keine Ahnung, ob die Änderung so in deinem Interesse ist, aber vielleicht hilft die Datei ja bei der Fehlerbereinigung.
                            Markus
                            632_hm-rpc.js
                            • BluefoxB Offline
                              BluefoxB Offline
                              Ich habe da was geändert, was ich nicht ändern sollte. Jetzt gibt es neue Version.
                              • BluefoxB Offline
                                BluefoxB Offline
                                Geht jetzt ?
                                • N Offline
                                  N Offline
                                  nobody
                                  Hallo bluefox,
                                  Ja geht jetzt wieder.
                                  Vielen Dank.
                                  Gesendet von meinem GT-N8000 mit Tapatalk
                                    Brati
                                    Hmm, Update installiert und Reboot gemacht. Die Jalousien haben danach Level "null". Nach der ersten Betätigung egal ob Iobroker oder am Gerät stimmt es.
                                    Grüße Brati
                                    Gesendet via Tapatalk.
                                    • HomoranH Offline
                                      HomoranH Offline
                                      Ist so! :D
                                      Dazu gibt's schon mehrere Postings.
                                        Brati
                                        Ok, kann ich mit leben.
