  5. Blockly Zähler reset spinnt
    5.5k
22 Beiträge 2 Kommentatoren 2.1k Aufrufe 1 Beobachtet
  • AphofisA Aphofis
    Sorry so schnell war ich nun nicht!
      <block type="on" id="Kql_jD{YI^5mrLu1Hv;{" x="-1812" y="-787">
        <field name="OID">Aqua_Control.0.Triton.Lösung_1.Verbrauch.Triton_Lösung_1_Füllstand</field>
        <statement name="STATEMENT">
          <block type="controls_if" id="DaR,)=s,A|^ULPy2%[FM">
            <value name="IF0">
              <block type="logic_compare" id="!KF(P?x#H^c,1~Sodh}H">
                <field name="OP">LTE</field>
                <value name="A">
                  <block type="convert_tonumber" id="{LZSoa`$c~#Y-a77;77.">
                    <value name="VALUE">
                      <block type="get_value" id="+zp$KC,B6*YG)Yw?o}bn">
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="boYhq.a(y,y#[Jscz!o^">
                    <field name="NUM">100</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="schedule" id="!Q:B-2DfSDOqG1?!iq$^">
                <field name="SCHEDULE">0 18 * * *</field>
                  <block type="control" id="OrdL/cPS%7MR_)L6m^`#">
                    <field name="OID">alexa2.0.Echo-Devices.G090LV0371040175.Commands.speak</field>
                      <block type="text_join" id="ig:Yh+)?@/Za8yd6F(8g">
                        <mutation items="1"></mutation>
                        <value name="ADD0">
                          <block type="text" id=")Q39z2#sCyy~Zl(BGtwJ">
                            <field name="TEXT">Triton Lösung 1,, hat 100 Milliliter erreicht,, Die Lösung muss nachgefüllt werden</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="telegram" id="EOKFW$rxUI+r?bsg{PKg">
                        <field name="INSTANCE">.0</field>
                        <field name="LOG"></field>
                        <value name="MESSAGE">
                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="}fYL_L*}V:~I89QakQf[">
                          </shadow>
                          <block type="text_join" id="-(YNO(+?uMLqgop(2Q31">
                            <value name="ADD0">
                              <block type="text" id="%uh`JSHE6EYIJO?,nyt!">
                                <field name="TEXT">Triton Lösung 1 hat 100 Milliliter erreicht</field>
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="text_newline" id="]OtqJ!Tr7m@Or_!{KCp4">
                                <field name="Type">\n</field>
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="Y61B)zXh|99rd,d_#AMa">
                                <field name="TEXT">Die Lösung muss nachgefüllt werden</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    @Aphofis
    Das ist nicht auf meinem Mist gewachsen: Trigger im Trigger !!
    Mache es so:
    AphofisA 2 Antworten Letzte Antwort
      @Aphofis
      Mache es so:
      AphofisA Offline
      AphofisA Offline
      Aphofis
      Vielen Dank!!!
      Dann werde ich das mal bis morgen laufen lassen und gucken was daraus wird.
      Ich dachte die Steuerung haben wir zusammen gemacht. Naja nicht ganz so schlimm!
        @Aphofis
        Mache es so:
        AphofisA Offline
        AphofisA Offline
        Aphofis
        @paul53 ^So nun muss ich leider paar Tage warten, hatte gerade resettet also den Kanister neu befüllt aber eine andere Lösung müsste in den nächsten Tagen eine Meldung ausgeben.
        Ist es möglich ab der ersten Meldung das Datum mit im text zu senden damit ich weiß wie viele Tage ich drüber bin wenn ich es durch die arbeit abends nicht mehr schaffe ?! Da ja jeden abend dann ab 100 ml jeder Lösung eine Meldung ausgegeben wird nur soll dann das Datum ab den ersten 100 ml mit rein! geht sowas ?
        • AphofisA Aphofis
          @Aphofis sagte:
          AphofisA 1 Antwort Letzte Antwort
            @Aphofis sagte:
            AphofisA Offline
            AphofisA Offline
            Aphofis
            und das nimmt dann immer das Datum von dem ersten Tag wo 100 ml erreicht sind!?
            • AphofisA Aphofis
              @Aphofis sagte:
              Ja, wenn das Script nicht zwischendurch neu gestartet wird. Das Telegramm wird nur am ersten Tag mit dem Datum gesendet, die Speak-Ausgabe erfolgt täglich bis nachgefüllt wird. Oder soll das Telegramm täglich gesendet werden mit dem Datum vom ersten Tag ? Dann so:
                @Aphofis sagte:
                AphofisA Offline
                AphofisA Offline
                Aphofis
                schrieb am zuletzt editiert von Aphofis
                @paul53 ja soll mit dem Datum vom ersten Tag gesendet werden.
                Damit ich weiß wann die 100 ml erreicht sind. da 100 ml ca 10 Tage noch reichen wieß ich dann wann es kritisch wird!
                Nein das Script wird nihct neu gestartet, nur Der Raspberry sprich iobroker starten nachts um 5 jede nacht neu. Ich habe auch noch nicht herausgefunden was dafür verantwortlich ist.
                Trotzdem schon mal Vielen Dank!!!
                • AphofisA Offline
                  AphofisA Offline
                  Aphofis
                  ist es möglich die Datums Angabe auch hier zu integrieren???
                    <variables>
                      <variable id="K.oz,4#UMgx/|!4vK/!}">Start Datum</variable>
                    </variables>
                    <block type="schedule" id="[H5qz$AU(jK-g*ohRGew" x="37" y="588">
                        <block type="variables_set" id="t:07|=Y]Z5[Y{dE)b=Wr">
                          <field name="VAR" id="K.oz,4#UMgx/|!4vK/!}">Start Datum</field>
                            <block type="lists_split" id="p|s;MB5#-TA#_9w0Cc6A">
                              <mutation mode="SPLIT"></mutation>
                              <field name="MODE">SPLIT</field>
                              <value name="INPUT">
                                <block type="get_value" id="`[ncv(,}hRD8H=@Gbbal">
                                  <field name="OID">Aqua_Control.0.System.Reaktoren_Datum</field>
                                </block>
                              </value>
                              <value name="DELIM">
                                <shadow type="text" id=":E?qi1Qh:_V-7F:wfz)N">
                                  <field name="TEXT">.</field>
                                </shadow>
                              </value>
                            </block>
                          </value>
                          <next>
                            <block type="variables_set" id="D_?.J%U)+DwN;%w?,H+D">
                                <block type="text_join" id="bKmk8!W6Qfif--ETUyf;">
                                  <mutation items="5"></mutation>
                                  <value name="ADD0">
                                    <block type="lists_getIndex" id="EW9`4zy[fngnWwTTrz[f">
                                      <mutation statement="false" at="true"></mutation>
                                      <field name="MODE">GET</field>
                                      <field name="WHERE">FROM_START</field>
                                        <block type="variables_get" id="8%36kyqEKIkba3QjoXFu">
                                        </block>
                                      </value>
                                      <value name="AT">
                                        <block type="math_number" id="G!UqN.${lfbX?9?fC(]7">
                                          <field name="NUM">3</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    <block type="text" id="175Fww}yzf/:Li=:7EFZ">
                                      <field name="TEXT">-</field>
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    <block type="lists_getIndex" id="7=%sMFe1TfVXiENyv])X">
                                        <block type="variables_get" id="B%zI(=|@mQ$E!;xWQ53/">
                                        </block>
                                      </value>
                                      <value name="AT">
                                        <block type="math_number" id="L?@Yy0.FrC|HpAD,19.:">
                                          <field name="NUM">2</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="ADD3">
                                    <block type="text" id=";eW0_/sun%t5@K5bJ2Nf">
                                    </block>
                                  </value>
                                  <value name="ADD4">
                                    <block type="lists_getIndex" id="(khUT%*jN`U6hCz;|u?/">
                                        <block type="variables_get" id="y-r;mKOl[yuUNAI9S%cx">
                                        </block>
                                      </value>
                                      <value name="AT">
                                        <block type="math_number" id="^CoREjH=BLQx+w[+VBvn">
                                          <field name="NUM">1</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                <block type="variables_set" id="l$Ya))eB-9)DbmW`$8f]">
                                    <block type="convert_from_date" id=";sg/oP`v/X{GBst#`iwE">
                                      <field name="OPTION">object</field>
                                        <block type="variables_get" id="|G[Nx#SHgEXX9z@KaO)I">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="controls_if" id="(`^{GKOFHmiu=!*~V}3C">
                                      <value name="IF0">
                                        <block type="logic_compare" id="ICTqO:*ALjLX2g@Mo`U~">
                                          <field name="OP">GTE</field>
                                          <value name="A">
                                            <block type="time_get" id="v9.z:sj3U1CgjlI[pOff">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="math_arithmetic" id=":/*YP!I6tE30OrDM_{$Y">
                                              <field name="OP">ADD</field>
                                              <value name="A">
                                                <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="iaLFl0tm+gwBmIB;^Fa@">
                                                </shadow>
                                                <block type="variables_get" id="@v*2#Igz]tqz4ae~_$Ni">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=";@a8$1DnJrvd5G`#eIrh">
                                                </shadow>
                                                <block type="math_arithmetic" id="vf6KSTN}bXy.4ntVdSfI">
                                                  <field name="OP">MULTIPLY</field>
                                                  <value name="A">
                                                    <shadow type="math_number" id="xw[OCp^B6+7i^ggq232o">
                                                      <field name="NUM">720</field>
                                                    </shadow>
                                                  </value>
                                                  <value name="B">
                                                    <shadow type="math_number" id="JF?T)=jlgQTMcXF7V0hP">
                                                      <field name="NUM">3600000</field>
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="telegram" id="?2YC.60?J)M%@bPzt_qe">
                                            <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Ae-*h@qEA(|^L^IU-o-J">
                                            </shadow>
                                            <block type="text_join" id="p/`G_kh+j|GClHdd8-(,">
                                              <value name="ADD0">
                                                <block type="text" id="JZGB0zZ;([-oQZBUb]rL">
                                                  <field name="TEXT">Reaktoren Absorber Wechsel steht an</field>
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                <block type="text_newline" id="6__.:CFUXypx8vvV~C9,">
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                <block type="text" id="0T$YX467PDa]rSz$=7z!">
                                                  <field name="TEXT">Reaktoren müßen neu bestückt werden</field>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="control" id="{)KwDaVN%@R)p;1oue!R">
                                                <block type="text_join" id="DFgL?D_|.Lx#djY;*0^z">
                                                  <value name="ADD0">
                                                    <block type="text" id="!ADXURU^temtR1(UjD5w">
                                                      <field name="TEXT">Reaktoren Absorber Wechsel steht an, Du musst,, Deine Reaktoren neu bestücken</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="control" id="bztvKmxJ_0x-M8s`LVt@">
                                                  <field name="OID">Aqua_Control.0.VIS.Meldungen.Info</field>
                                                    <block type="text_join" id="yLx@~$=p(^7;}8A4;}|7">
                                                      <value name="ADD0">
                                                        <block type="text" id="AYR_#o]I(3]hgGWD])^=">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                        <block type="text_newline" id="iAz.I4F*nHr_Qa_dmB;]">
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                        <block type="text" id="3k/#fXZzf#S^/MlM;`S1">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </xml>
                  • AphofisA Aphofis
                      <variables>
                      </variables>
                                  </block>
                                </value>
                                  </shadow>
                                </value>
                              </block>
                            </value>
                            <next>
                                    <value name="ADD0">
                                          </block>
                                        </value>
                                        <value name="AT">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                          </block>
                                        </value>
                                        <value name="AT">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      </block>
                                    </value>
                                    <value name="ADD4">
                                          </block>
                                        </value>
                                        <value name="AT">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                        <value name="IF0">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                                <value name="A">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </shadow>
                                                    <value name="A">
                                                      </shadow>
                                                    </value>
                                                    <value name="B">
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                              </shadow>
                                                <value name="ADD0">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                    <value name="ADD0">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                        <value name="ADD0">
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </xml>
                    @Aphofis sagte:
                    Ja, auf die gleiche Weise wie hier.
                      @Aphofis sagte:
                      AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      also so:
                        <variables>
                          <variable id="=hdidY4}B|L;6..|G=D_">erster Tag</variable>
                          <variable id="+G_CFrCr9TLsYxNuK2Kc">Datum</variable>
                        </variables>
                                    </block>
                                  </value>
                                    </shadow>
                                  </value>
                                </block>
                              </value>
                              <next>
                                      <value name="ADD0">
                                            </block>
                                          </value>
                                          <value name="AT">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                        </block>
                                      </value>
                                      <value name="ADD2">
                                            </block>
                                          </value>
                                          <value name="AT">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="ADD3">
                                        </block>
                                      </value>
                                      <value name="ADD4">
                                            </block>
                                          </value>
                                          <value name="AT">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                      <value name="A">
                                                        </shadow>
                                                      </value>
                                                      <value name="B">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="controls_if" id="/(OQbd.ZC`Lhn`/r[n!m">
                                                      <value name="IF0">
                                                        <block type="logic_negate" id="e@rn3Zf(2;@lSZnOl)Of">
                                                          <value name="BOOL">
                                                            <block type="variables_get" id="uJ$K~j9pi1foBShY?CES">
                                                              <field name="VAR" id="=hdidY4}B|L;6..|G=D_">erster Tag</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="variables_set" id="Y#29kGTW*rsQRU42Evyc">
                                                          <field name="VAR" id="+G_CFrCr9TLsYxNuK2Kc">Datum</field>
                                                            <block type="time_get" id="jM1q.*:.:O~0rlB,Y#MJ">
                                                              <field name="OPTION">DD.MM.</field>
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="variables_set" id="1=ZTTn@Uog~Xssww(7Us">
        <block type="logic_boolean" id="V`lxG5fb#+%5T4lp9hYE">
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                            </shadow>
                                                              <mutation items="6"></mutation>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        <block type="text" id="_%u7ANuZ^]KYvO4dkQ`s">
        <field name="TEXT">Wechsel steht seid dem: </field>
        </block>
                                                              </value>
                                                              <value name="ADD3">
        <block type="variables_get" id="lU/G,/@iO?~s]rvkYJ^V">
        </block>
                                                              </value>
                                                              <value name="ADD4">
        <block type="text" id="3doJLLAR1#4K[AebE[.O">
        <field name="TEXT"> an</field>
        </block>
                                                              </value>
                                                              <value name="ADD5">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <statement name="ELSE">
                                            <block type="variables_set" id="Nm/JI$blRQ#]EgIsmMl7">
                                                <block type="logic_boolean" id="NqGA;/7*k%!AtTj|6w@w">
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </xml>
                      • AphofisA Aphofis
                        also so:
                          <variables>
                          </variables>
                                      </block>
                                    </value>
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                        <value name="ADD0">
                                              </block>
                                            </value>
                                            <value name="AT">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                              </block>
                                            </value>
                                            <value name="AT">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="ADD3">
                                          </block>
                                        </value>
                                        <value name="ADD4">
                                              </block>
                                            </value>
                                            <value name="AT">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                            <value name="IF0">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                    <value name="A">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </shadow>
                                                        <value name="A">
                                                          </shadow>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                    <value name="ADD0">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                        <value name="ADD0">
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                        <value name="IF0">
                                                            <value name="BOOL">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                              </block>
                                                            </value>
                                                            <next>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                        <next>
                                                              </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </xml>
                        @Aphofis sagte:
                        also so:
                        Ja.
                          @Aphofis sagte:
                          also so:
                          Ja.
                          AphofisA Offline
                          AphofisA Offline
                          Aphofis
                          @paul53 OK dann versuche ich das so!
                          Vielen Dank
                            @Aphofis sagte:
                            also so:
                            Ja.
                            AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            Also Telegram gibt das Datum korrekt aus! nur Alexa sagt das Datum nicht, woran kann das liegen?
                            • AphofisA Aphofis
                              @Aphofis sagte:
                              Ich sehe nicht, dass das Datum an Alexa übergeben wird. Wenn die Alexa-Ausgabe so erweitert wird, muss Alexa aufgerufen werden, nachdem das Datum in die Variable datum geschrieben wurde.
                                @Aphofis sagte:
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                @paul53 ups Sorry
                                  <variables>
                                  </variables>
                                              </block>
                                            </value>
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                                <value name="ADD0">
                                                      </block>
                                                    </value>
                                                    <value name="AT">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                      </block>
                                                    </value>
                                                    <value name="AT">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="ADD3">
                                                  </block>
                                                </value>
                                                <value name="ADD4">
                                                      </block>
                                                    </value>
                                                    <value name="AT">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                    <value name="IF0">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </shadow>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
        <value name="A">
        </shadow>
        </value>
        <value name="B">
        </shadow>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                            <value name="ADD0">
        <field name="TEXT">Reaktoren Absorber Wechsel steht seid dem,,</field>
                                                              </block>
                                                            </value>
                                                            <value name="ADD1">
                                                              <block type="variables_get" id="J=0tV1{ud=lca,7DB6+L">
                                                              </block>
                                                            </value>
                                                            <value name="ADD2">
                                                              <block type="text" id="FS#QNqjv.,hMV2kf*YZU">
        <field name="TEXT"> an,, Du musst,, Deine Reaktoren neu bestücken</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
        <value name="ADD0">
        <field name="TEXT">Reaktoren Absorber Wechsel steht seid dem </field>
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        <block type="variables_get" id="moO?0hiF?607[@F#[Zuk">
        </block>
        </value>
        <value name="ADD3">
        <block type="text" id="Z4/g17s5*8l[qDMtw~G7">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        </shadow>
        <value name="ADD0">
        <field name="TEXT">Reaktoren Absorber Wechsel steht seid dem</field>
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        <block type="text_newline" id="FExw[XZ@~t^r(mcZUQ]}">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </xml>
                                • AphofisA Aphofis
                                  @paul53 ups Sorry
                                    <variables>
                                    </variables>
                                                </block>
                                              </value>
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                  <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="AT">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                        </block>
                                                      </value>
                                                      <value name="AT">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                    </block>
                                                  </value>
                                                  <value name="ADD4">
                                                        </block>
                                                      </value>
                                                      <value name="AT">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                      <value name="IF0">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <next>
        <value name="IF0">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        <value name="ADD4">
        </block>
        </value>
        <value name="ADD5">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </xml>
                                  @Aphofis sagte:
                                  ups Sorry
                                  Wie schon geschrieben: Erst die Variable Datum setzen, dann ausgeben (steuere).
                                    @Aphofis sagte:
                                    ups Sorry
                                    AphofisA Offline
                                    AphofisA Offline
                                    Aphofis
                                    Ich teste das heute Abend mal!
                                      @Aphofis sagte:
                                      ups Sorry
                                      AphofisA Offline
                                      AphofisA Offline
                                      Aphofis
                                      funktioniert schon mal so weit nur alexa sagt seid dem 18 komma 0 6 kann alexa kein normales datum ansagen !?
