  5. Blockly Hilfe benötigt Zeit/Astro Kombi
    5.5k
14 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • K Kodo_sh
    @buggybeast
    hi, danke für die Info.
    Die Lampen sollen morgens zur bestimmten Zeit bis zum Sonnenaufgang an sein.
    Dann abends wieder vom Sonnenuntergang bis 23:30
    Alex
    @Kodo_sh sagte:
    Dann benötigt man 4 Zeit-Trigger.
      <variables>
        <variable id="V?nEV]cj4WnZ?x!]ubau">ein</variable>
      </variables>
      <block type="procedures_callnoreturn" id="W1mvr^P_XH3@^fN_xC$8" x="38" y="38">
        <mutation name="licht">
          <arg name="ein"></arg>
        </mutation>
        <value name="ARG0">
          <block type="logic_operation" id="f77K;[=@s2qJX)HV^FhC" inline="false">
            <field name="OP">OR</field>
            <value name="A">
              <block type="time_compare_ex" id="8Fk.#KWH.+mJ`MWH{U(~">
                <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                <field name="USE_ACTUAL_TIME">TRUE</field>
                <field name="OPTION">between</field>
                <value name="START_TIME">
                  <shadow type="text" id="I_K({wVTN~H|QKl-k2*,">
                    <field name="TEXT">05:20</field>
                  </shadow>
                </value>
                <value name="END_TIME">
                  <shadow type="text" id="u@[F9*=qaqWR%vy*_@/.">
                    <field name="TEXT">18:00</field>
                  </shadow>
                  <block type="time_astro" id="2/aexGAcTJBhuIINM`N!">
                    <field name="TYPE">sunrise</field>
                    <field name="OFFSET">0</field>
                  </block>
                </value>
              </block>
            </value>
            <value name="B">
              <block type="time_compare_ex" id="g[P4iG$4(M4b^.D4ti[B">
                  <shadow type="text" id="9DHH`}]SM)bn%R+C|-9|">
                    <field name="TEXT"></field>
                  </shadow>
                  <block type="time_astro" id="}0gO}-R5Z(+J/i}G6PG`">
                    <field name="TYPE">sunset</field>
                  </block>
                </value>
                  <shadow type="text" id="R=wM%b6A`T^dr$(2?+]o">
                    <field name="TEXT">23:30</field>
                  </shadow>
                </value>
              </block>
            </value>
          </block>
        </value>
        <next>
          <block type="schedule" id="StP1-qG7w)Xf1r(W0g9)">
            <field name="SCHEDULE">20 5 * * *</field>
            <statement name="STATEMENT">
              <block type="procedures_callnoreturn" id="8VM[]N/`rt)8_x3w?kUE" inline="true">
                </mutation>
                <value name="ARG0">
                  <block type="logic_boolean" id="[XnLWRk]lXu68e6|{WE5">
                  </block>
                </value>
              </block>
            </statement>
            <next>
              <block type="astro" id="+p=6QfG16!:1FA}UF;/e">
                  <block type="procedures_callnoreturn" id="?GN.PNC$WX|NWlx#yE.T" inline="true">
                    </mutation>
                    <value name="ARG0">
                      <block type="logic_boolean" id="m6^K%pgQGopWYF?DSQ+f">
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block type="astro" id="ra-E7lJRID5{|v}uyTu[">
                      <block type="procedures_callnoreturn" id="?CUg0OZc+rg]!=p]p/T@" inline="true">
                        </mutation>
                        <value name="ARG0">
                          <block type="logic_boolean" id="#)1wN:B!I]ij^du`RuOd">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                      <block type="schedule" id="($).L-y$4sh+D3+/Ba]+">
                        <field name="SCHEDULE">30 23 * * *</field>
                          <block type="procedures_callnoreturn" id=")1Nx*(.=NO:GWJKayNaz" inline="true">
                            </mutation>
                            <value name="ARG0">
                              <block type="logic_boolean" id="r:Bpb5Apy2$lx*)+G{KJ">
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="procedures_defnoreturn" id="vxtwARV1Ztr*B`w}#3mN" x="513" y="163">
        <mutation>
          <arg name="ein" varid="V?nEV]cj4WnZ?x!]ubau"></arg>
        </mutation>
        <field name="NAME">licht</field>
        <statement name="STACK">
          <block type="control" id="[kMf8tsqa}]pzsWgc}7d">
            <value name="VALUE">
              <block type="variables_get" id="56ulmY5]a8tH$hXRBL2v">
                <field name="VAR" id="V?nEV]cj4WnZ?x!]ubau">ein</field>
              </block>
            </value>
            <next>
              <block type="control" id="^xkbo?tiC=~uLCvAAL@M">
                  <block type="variables_get" id="0k%P)K@CM$|}5C@Ne,fh">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    K 2 Antworten Letzte Antwort
    • buggybeastB Offline
      buggybeastB Offline
      buggybeast
      Ach du kacke 🤣🤣🤣
      Und ich dachte sonoff‘s wären was mit Audio. Lautsprecher oder so.
      Tja hab halt keine.
      @paul53 dein Skript ist echt cool. Verstehe ich leider gar nicht. Verschachtelte Funktion oder so? Wie ist denn da der Weg beim ausführen? Erst oben und dann rechts oder umgekehrt?
      • buggybeastB buggybeast
        Ach du kacke 🤣🤣🤣
        Tja hab halt keine.
        @buggybeast sagte:
        Die Funktion licht(ein) wird an 5 Stellen aufgerufen: Beim Script-Start (oben) und in jedem Trigger.
          @Kodo_sh sagte:
            <variables>
            </variables>
              </mutation>
              <value name="ARG0">
                  <value name="A">
                        </shadow>
                      </value>
                        </shadow>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                        </shadow>
                        </block>
                      </value>
                        </shadow>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                      </mutation>
                      <value name="ARG0">
                        </block>
                      </value>
                    </block>
                  </statement>
                  <next>
                          </mutation>
                          <value name="ARG0">
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                              </mutation>
                              <value name="ARG0">
                                </block>
                              </value>
                            </block>
                          </statement>
                          <next>
                                  </mutation>
                                  <value name="ARG0">
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
              <mutation>
              </mutation>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </xml>
          Kodo_sh
          Vielen Dank für die Hilfe.
          Schaut auf den ersten Blick recht kompliziert aus aber auch Logisch.
          Werde es heute mal testen.
          Alex
            @Kodo_sh sagte:
              <variables>
              </variables>
                </mutation>
                <value name="ARG0">
                    <value name="A">
                          </shadow>
                        </value>
                          </shadow>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                          </shadow>
                          </block>
                        </value>
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                        </mutation>
                        <value name="ARG0">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                            </mutation>
                            <value name="ARG0">
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                                </mutation>
                                <value name="ARG0">
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <next>
                                    </mutation>
                                    <value name="ARG0">
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
                <mutation>
                </mutation>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </xml>
            Kodo_sh
            Hi Paul,
            Abends schaltet jetzt alles wie es soll.
            Auch das Ausschalten um 23:30 klappt.
            Jedoch morgens stimmt etwas nicht.
            Einschalten klappt, aber die zwei sonoff schalten dann nicht zum Sonnenaufgang ab.
            Ich kann es mir nicht nicht erklären.
            Die Astro Funktion klappt sonst einwandfrei.
            Habe noch eine Aussenlampe die von Sonnenaufgang bis Sonnenuntergang leuchtet und immer zuverlässig schaltet.
            Alex
            • K Kodo_sh
              Hi Paul,
              Alex
              @Kodo_sh
              Poste mal den von Blockly erzeugten Javascript-Code ohne die letzte Zeile in Code tags.
              • UweRLPU Offline
                UweRLPU Offline
                UweRLP
                Ist Sonnenaufgang vor 5:20 Uhr?
                • UweRLPU UweRLP
                  @UweRLP sagte:
                  Ja, bei mir um 4:50 Uhr. Das ist der Grund, weshalb nicht ausgeschaltet wird. Es sollte also um 5:20 nicht eingeschaltet werden.
                    @UweRLP sagte:
                    Kodo_sh
                    Ja das klingt logisch.
                    Das der Sonnenaufgang schon so früh ist war mir nicht bewusst.
                    Werde es dann mal auf Sonnenaufgang ende setzen. Wo finde eich die aktuellen Zeiten die die Astrofunktion nutzt?
                    Alex
                    • K Kodo_sh
                      Alex
                      @Kodo_sh sagte:
                      Das ist auch nur 5 Minuten später als Sonnenaufgang.
                      @Kodo_sh sagte in Blockly Hilfe benötigt Zeit/Astro Kombi:
