  4. Komplet absturz
    6.7k
Komplet absturz
absturz
37 Beiträge 7 Kommentatoren 4.8k Aufrufe 6 Beobachtet
  • P pfuhsy
    @Jan1
    nix
    pi@ioBroker-Rock:~$ cd /opt/iobroker
    pi@ioBroker-Rock:/opt/iobroker$ iobroker start
    pi@ioBroker-Rock:/opt/iobroker$ iobroker status
    iobroker is not running on this host.
    No iobroker host is running.
    Objects type: file
    States  type: file
    @pfuhsy
    Mit
    tail -f /opt/iobroker/log/iobroker.current.log
    schauen was passiert, wenn du in einer anderen Konsole den iobroker startest.
    Zuvor ein
    iobroker fix
    schadet vielleicht auch nicht.
    P 1 Antwort Letzte Antwort
      @pfuhsy
      Mit
      Zuvor ein
      iobroker fix
      pfuhsy
      @Thomas-Braun
      B.js:1993:32)
          at runCallback (timers.js:705:18)
          at tryOnImmediate (timers.js:676:5)
          at processImmediate (timers.js:658:5)
      2020-06-01 20:25:13.134  - info: host.ioBroker-Rock iobroker _restart
      2020-06-01 20:25:13.145  - error: host.ioBroker-Rock _design/system missing - call node iobroker.js setup
      2020-06-01 20:25:13.155  - info: host.ioBroker-Rock terminated
      2020-06-01 20:25:14.093  - info: host.ioBroker-Rock iobroker Starting node restart.js
      2020-06-01 20:25:15.906  - info: host.ioBroker-Rock iobroker.js-controller version 2.2.9 js-controller starting
      2020-06-01 20:25:15.922  - info: host.ioBroker-Rock Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-06-01 20:25:15.923  - info: host.ioBroker-Rock hostname: ioBroker-Rock, node: v10.19.0
      2020-06-01 20:25:15.927  - info: host.ioBroker-Rock ip addresses: 192.168.1.110 fe80::f777:1c02:d801:d955
      2020-06-01 20:25:16.050  - info: host.ioBroker-Rock connected to Objects and States
      2020-06-01 20:25:16.053  - error: Cannot find view "system"
      2020-06-01 20:25:16.089  - error: Cannot find view "system"
      2020-06-01 20:25:16.091  - error: Cannot find view "system"
      2020-06-01 20:25:16.115  - error: host.ioBroker-Rock uncaught exception: Cannot read property 'rows' of undefined
      2020-06-01 20:25:16.119  - error: host.ioBroker-Rock TypeError: Cannot read property 'rows' of undefined
          at objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/main.js:1529:34)
          at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileD
      • P pfuhsy
        @Thomas-Braun
        B.js:1993:32)
        @pfuhsy
        iobroker update
        iobroker upgrade
        iobroker upgrade self
          @pfuhsy
          iobroker update
          iobroker upgrade
          pfuhsy
          @Thomas-Braun
          Sah nach 5min. immer noch so aus. Hab dann mit Strg+c abgebrochen und Upgrade ausgeführt. Oder bin ich da zu ungeduldig?
          pi@ioBroker-Rock:~$ iobroker update
          Error: Object "system.config" not found
          ^C
          pi@ioBroker-Rock:~$
          pi@ioBroker-Rock:~$ iobroker upgrade
          No repositories defined.
          25
          pi@ioBroker-Rock:~$ iobroker upgrade self
          Cannot get repository under "undefined"
          • P pfuhsy
            @Thomas-Braun
            ^C
            pi@ioBroker-Rock:~$
            25
            @pfuhsy sagte in Komplet absturz:
            • P pfuhsy
              @Thomas-Braun
              ^C
              pi@ioBroker-Rock:~$
              25
              @pfuhsy
              Installiers neu. Da sind so wie ich das sehe einige Dateien korrupt.
                @pfuhsy
                pfuhsy
                @Thomas-Braun
                Ich probiers nochmal mit den fixer dann gebe ich es auf.
                Kannst Du mir erklären was da passiert ist? Das ist doch nicht normal.
                • P Offline
                  pfuhsy
                  Selbes Ergebniss wie oben. Sehr frustiertend!!!
                  • P pfuhsy
                    @Thomas-Braun
                    Was soll der fixer bringen?
                    der korrigiert die Rechte des Users iobroker unter dem alles läuft.
                    Du hast aber defekte Dateien - warum auch immer.
                    So fehlt z.B. deine Konfiguration und das Update kann nicht durchgeführt werden, weil gar kein Repo definiert ist.
                    Nur mal so aus Neugier:
                    Was siehst du wenn du im admin ganz oben auf den Schraubenschlüssel klickst?
                      pfuhsy
                      @Homoran sagte in Komplet absturz:
                      Stop. Ich hab nicht nur das Netzwerkkabel gezogen, sondern den USB-Anschnluss meiner Alarmanlage mit eingesteckt. Das dürfte aber funktionieren, weil ich in ein identischen System es am laufen hatte. Oder könnte das tasächlich das Problem verursacht haben ?
                      Kann ich mal ausprobieren, wenn es wieder läuft.
                      • P pfuhsy
                        @Thomas-Braun
                        @pfuhsy
                        Vermutlich im laufenden Betrieb das System hart ausgeschaltet oder das Dateisystem verabscheidet sich gerade.
                        dmesg
                        kann evtl. auch weiterhelfen.
                        • P Offline
                          pfuhsy
                          Jetzt hab ich die Karte schon raus und restore gerade. Nochmal. Sehr frustiertend 😠
                          • P pfuhsy
                            wenn die Alarmanlage über den USB auch mit Strom versorgt wird kann das schon sein.
                              pfuhsy
                              Nicht die komplette Anlage die hat ihre eigene Versorung, aber der Konverter CP2101. Ich hatte aber eine Brücke drin, die die beiden 5V über den Konverter verbindet. Ich trenne den mal :-)
                              • P pfuhsy
                                und wenn der zuviel Strom zieht bricht die Spannungsversorgung für den Pi zusammen und du hast die gleichen Folgen, wie wenn du den Stecker im laufenden Betrieb ziehst -> Dateischäden
                                • P Offline
                                  pfuhsy
                                  Also war der Fehler zwischen den Ohren. Danke.
                                  • P pfuhsy
                                    @pfuhsy ist nur eine Möglichkeit, ich weiß nicht wieviel der zieht.
                                    • P Offline
                                      pfuhsy
                                      Normalerweise nicht besonders viel.
                                        Jedenfalls würde ich sowas nicht im laufenden Betrieb machen.
                                        • P Offline
                                          pfuhsy
                                          Da denkt man bei USB kann das ncht passier und dann sowas. Bei der HW bei der ich es getestet habe will das ohne Probleme. Ich restore erstmal dann gehe ich das mal etwas sanfter an.
