  4. Nach Update läuft nichts mehr!
    6.6k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.6k Aufrufe 9 Beobachtet
  • S SaschaS
    @Jan1 @Thomas-Braun
    pi@raspberrypi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
    library: loaded
    Library version=2020-04-12
    ioBroker or some processes are still running:
     io.discovery.0
     io.history.0
     io.javascript.0
     io.web.0
     io.cloud.0
     io.info.0
     io.deconz.0
     io.tankerkoenig.0
     io.ble.0
    Please stop them first and try again!
    Wieso laufen denn da noch Dienste?
    pi@raspberrypi:/opt/iobroker $ iobroker stop
    iobroker controller daemon is not running
    Wie kille ich die jetzt am saubersten?
    #90
    @SaschaS
    sudo pkill io
      @SaschaS
      sudo pkill io
      SaschaS
      #91
      @Thomas-Braun
      nach
      sudo pkill io
      laufen immer noch Dienste
      pi@raspberrypi:/opt/iobroker $ ps auxww | grep io
      root        12  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/0]
      root        15  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/1]
      root        20  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/2]
      root        25  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/3]
      root        41  0.0  0.0      0     0 ?        I<   10:39   0:00 [rpciod]
      root        43  0.0  0.0      0     0 ?        I<   10:39   0:00 [xprtiod]
      root        47  0.0  0.0      0     0 ?        I<   10:39   0:00 [nfsiod]
      root        62  0.0  0.0      0     0 ?        I<   10:39   0:00 [DWC Notificatio]
      message+   350  0.0  0.3   6512  3472 ?        Ss   10:39   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
      iobroker 16869 30.8 11.5 186284 109716 ?       Dsl  11:04   0:08 iobroker.js-controller
      iobroker 16920  9.9  4.5 120552 42908 ?        Sl   11:04   0:02 io.discovery.0
      iobroker 16990 21.0  6.5 140452 62140 ?        Sl   11:04   0:03 io.history.0
      iobroker 17030 45.6 10.8 181700 103192 ?       Sl   11:04   0:05 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/main.js 0 info
      pi       17155  0.0  0.0   4772   576 pts/0    S+   11:04   0:00 grep --color=auto io
        SaschaS
        #92
        Und das werden immer mehr...wieso starten die denn jetzt alle durch?
        iobroker 16869 25.7 10.4 175232 99196 ?        Dsl  11:04   0:22 iobroker.js-controller
        iobroker 16920  2.8  4.5 120552 42936 ?        Sl   11:04   0:02 io.discovery.0
        iobroker 16990  7.1  3.7 128760 35148 ?        Sl   11:04   0:05 io.history.0
        iobroker 17030 20.8 14.2 211672 134692 ?       Sl   11:04   0:15 io.javascript.0
        iobroker 17237 12.1  4.5 135500 42748 ?        Rl   11:04   0:06 io.stiebel-isg.0
        iobroker 17248  7.9  4.2 133872 40160 ?        Sl   11:04   0:04 io.web.0
        iobroker 17254  7.3  3.9 131960 37660 ?        Sl   11:04   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.cloud/main.js 0 info
        iobroker 17261  5.3  4.5 121004 43076 ?        Sl   11:04   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
        iobroker 17339  7.5  5.1 131932 49248 ?        Sl   11:04   0:03 io.deconz.0
        iobroker 17699 21.6  4.7 131708 45304 ?        Sl   11:05   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.tankerkoenig/main.js 0 info
        iobroker 17706 22.6  5.1 132704 49024 ?        Sl   11:05   0:03 io.ical.0
        iobroker 17716 21.6  4.0 131016 38792 ?        Sl   11:05   0:03 io.ble.0
        pi       17888  0.0  0.0   4772   524 pts/0    S+   11:05   0:00 grep --color=auto io
        • S SaschaS
          @Thomas-Braun
          nach
          sudo pkill io
          #93
          @SaschaS
          sudo kill 16869 16920 16990
            @SaschaS
            SaschaS
            #94
            @Thomas-Braun said in Nach Update läuft nichts mehr!:
            Der scheint verdammt hartnäckig zu sein
            pi@raspberrypi:/opt/iobroker $ sudo kill 16869
            iobroker 16869 16.7 10.2 199612 97400 ?        Dsl  11:04   0:40 iobroker.js-controller
            pi       19863  0.0  0.0   4772   552 pts/0    S+   11:08   0:00 grep --color=auto io
            • S SaschaS
              SaschaS
              schrieb am zuletzt editiert von SaschaS
              #95
              Und jetzt hat er eine neue PID...ich raff's nicht..wieso startet der denn immer wieder?
              iobroker 20224 20.6 14.5 229260 137796 ?       Rsl  11:08   0:15 iobroker.js-controller
              iobroker 20266  3.2  4.5 120552 42844 ?        Sl   11:08   0:02 io.discovery.0
              iobroker 20341  7.1  3.9 130108 37164 ?        Sl   11:09   0:04 io.history.0
              iobroker 20380 14.9  9.5 184116 91028 ?        Sl   11:09   0:09 io.javascript.0
              iobroker 20708 11.9  5.1 132532 49252 ?        Sl   11:09   0:04 /usr/bin/node /opt/iobroker/node_modules/iobroker.stiebel-isg/main.js 0 info
              iobroker 20714  7.0  4.4 120504 42040 ?        Sl   11:09   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.vis/main.js 0 info
              iobroker 20720  9.4  3.8 131212 36564 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.web/main.js 0 info
              iobroker 20726  9.0  4.7 131444 45024 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.cloud/main.js 0 info
              iobroker 20728  7.5  4.5 120544 43120 ?        Sl   11:09   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
              iobroker 20745  9.2  4.8 131288 45548 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.deconz/main.js 0 info
              iobroker 20792 11.3  3.9 131792 37300 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.tankerkoenig/main.js 0 info
              pi       21089  0.0  0.0   4772   548 pts/0    S+   11:10   0:00 grep --color=auto io
                SaschaS
                #96
                @Jan1 Jetzt übrigens nicht mehr über die Weboberfläche erreichbar..Aber ist auch kein Wunder, da io.admin sich nicht wie aus Geisterhand von alleine startet..
                • S SaschaS
                  #97
                  @SaschaS
                  iobroker stop
                  sudo killall iobroker
                  Wenn das nicht fruchtet:
                  sudo kill -9 PID
                  PID weißt du ja wie du die bekommst.
                    @SaschaS
                    iobroker stop
                    sudo kill -9 PID
                    SaschaS
                    #98
                    @Thomas-Braun
                    Das Problem ist doch gerade, dass nach jedem kill der iobroker.js-controller wieder auftaucht..
                    pi@raspberrypi:/opt/iobroker $ sudo killall iobroker
                    iobroker: Kein Prozess gefunden
                    iobroker 24294 11.6  7.7 170944 73416 ?        Rsl  11:14   0:36 iobroker.js-controller
                    iobroker 24334  0.9  4.4 120548 42532 ?        Sl   11:14   0:02 io.discovery.0
                    iobroker 24405  3.0  3.7 129788 35732 ?        Sl   11:14   0:09 io.history.0
                    iobroker 24447  8.1 11.5 200760 109760 ?       Sl   11:14   0:24 io.javascript.0
                    iobroker 25571  6.2  6.4 145400 61484 ?        Sl   11:15   0:15 io.stiebel-isg.0
                    iobroker 25582  1.8  4.2 134016 40080 ?        Sl   11:15   0:04 io.web.0
                    iobroker 25588  3.1  7.8 155956 74028 ?        Sl   11:15   0:07 io.cloud.0
                    iobroker 25591  1.1  4.5 120868 42888 ?        Sl   11:15   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
                    iobroker 25602  2.4  4.3 134352 41060 ?        Sl   11:15   0:06 io.deconz.0
                    iobroker 25613  1.5  4.0 132196 37988 ?        Sl   11:15   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.tankerkoenig/main.js 0 info
                    iobroker 25620  5.8  4.6 135784 44408 ?        Sl   11:15   0:14 io.ble.0
                    iobroker 28191  0.0  0.0      0     0 ?        Z    11:19   0:00 [sh] <defunct>
                    pi       28194  0.0  0.0   4772   560 pts/0    S+   11:19   0:00 grep --color=auto io
                    pi@raspberrypi:/opt/iobroker $ sudo kill -9 24294
                    iobroker 24405  3.8  5.3 131160 50456 ?        Sl   11:14   0:13 io.history.0
                    pi       28986  0.0  0.0   4772   536 pts/0    S+   11:20   0:00 grep --color=auto io
                    pi@raspberrypi:/opt/iobroker $ sudo kill -9 24405
                    kill: (24405): Kein passender Prozess gefunden
                    iobroker 29172  119  6.4 147356 61188 ?        Rsl  11:20   0:03 iobroker.js-controller
                    iobroker 29208  0.0  0.0      0     0 ?        Z    11:20   0:00 [sh] <defunct>
                    iobroker 29210  0.0  0.0      0     0 ?        Z    11:20   0:00 [sh] <defunct>
                    iobroker 29212  0.0  0.0      0     0 ?        Z    11:20   0:00 [sh] <defunct>
                    pi       29215  0.0  0.0   4772   524 pts/0    S+   11:20   0:00 grep --color=auto io
                    • S SaschaS
                      @Thomas-Braun
                      #99
                      @SaschaS
                      sudo -u iobroker kill -15 -1
                        @SaschaS
                        SaschaS
                        #100
                        @SaschaS
                        pi@raspberrypi:/opt/iobroker $ sudo -u iobroker kill -15 -1
                        Speicherzugriffsfehler
                          SaschaS
                          #101
                          Ich würde ja gerne wieder sudo systemctl stop iobroker verwenden. Aber das findet @Jan1 ja nicht so prickelnd bzw. veraltet :-D
                          Thomas BraunT J 2 Antworten Letzte Antwort
                          • S SaschaS
                            #102
                            @SaschaS Das kannst du aber mal probieren.
                              SaschaS
                              #103
                              @SaschaS said in Nach Update läuft nichts mehr!:
                              Das Stehaufmännchen ist besiegt! Warum das jetzt funktioniert, verstehe ich nicht. Vielleicht habt ihr Ideen.
                              Ich würde jetzt den Fixer laufen lassen.
                              pi@raspberrypi:/opt/iobroker $ sudo systemctl stop iobroker
                              root        12  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/0]
                              root        15  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/1]
                              root        20  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/2]
                              root        25  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/3]
                              root        41  0.0  0.0      0     0 ?        I<   11:23   0:00 [rpciod]
                              root        43  0.0  0.0      0     0 ?        I<   11:23   0:00 [xprtiod]
                              root        47  0.0  0.0      0     0 ?        I<   11:23   0:00 [nfsiod]
                              root        62  0.0  0.0      0     0 ?        I<   11:23   0:00 [DWC Notificatio]
                              message+   354  0.1  0.3   6516  3504 ?        Ss   11:23   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
                              pi        4563  0.0  0.0   4772   544 pts/0    S+   11:27   0:00 grep --color=auto io
                              pi        4650  0.0  0.0   4772   532 pts/0    S+   11:27   0:00 grep --color=auto io
                              • S SaschaS
                                Jan1
                                #104
                                @SaschaS
                                Das war eben mal zwischen durch nötig, wobei Deine alte Installation da vielleicht immer noch drauf besteht ;-)
                                • S SaschaS
                                  #105
                                  @SaschaS Ja, lass den Fixer mal laufen.
                                  • S SaschaS
                                    Jan1
                                    #106
                                    @SaschaS
                                    Fixer schadet nie und bei solch komischen Dingern ist das immer ne Option.
                                      SaschaS
                                      #107
                                      Fixer läuft..
                                      Was wollten wir danach noch einmal machen?
                                      Das upgrade, richtig?
                                      • S SaschaS
                                        Fixer läuft..
                                        #108
                                        @SaschaS
                                        iobroker update
                                        iobroker upgrade
                                        • S SaschaS
                                          Fixer läuft..
                                          Jan1
                                          #109
                                          @SaschaS
                                          Kannst dann mal die Updates direkt über den Admin versuchen?
