  2. English
  3. ioBroker general
  4. Homematic & iobroker which adapters to use as of now
    2.7k
    2.9k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
homematicccu2alexaiotada
11 Beiträge 5 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • R Offline
    RobinNoRobot
    Hi all,
    I am using Homematic CCU2, some Amazon Echo Dot`s and IOBROKER on RasPI 3 with Raspbian.
    my usecase for IOBROKER is to execute voice commands on Amazon Alexa executing Programs on my CCU2. Like "Alexa swith light on" and many more.
    In the very past I used web adapter and cloud adapter, then web server and cloud adapter, now it seems cloud adapter is telling me to use the IOT adapter...As I am not so deep in all this - can anybody tell me, what is the recent proposal which adapters to use for this case as of now? Many posts I find are years old andoutdated.
    Thanks a lot.
    br,
    Robin
    • wendy2702W Online
      wendy2702W Online
      You have to use IOT Adapter.
      • R Offline
        RobinNoRobot
        Hi Wendy,
        means in total, if I would install in a greenfield....iot adapter additionally to the cloud adapter, web server, ReGaHSS and RPC or does it replace anything?
        are you aware if there is any recent tutorial for this case?
        Thanks, Robin
        P.S. I am not using Homematic IP (!)
        • R RobinNoRobot
          Hi Wendy,
          Thanks, Robin
          @RobinNoRobot Only iot connects to Amazon now.
          If your cloud-adaptor is not being used for connections to other clouds you should disable or even deinstall 'cloud'
          • R Offline
            RobinNoRobot
            schrieb am zuletzt editiert von RobinNoRobot
            top. disabled cloud, configured iot - is on green now.
            but don't get the account connection done on amazon side, it opens the login window of iobroker, I enter the account emailaddress and pw....alsways repplies that these data are wrong - same data on the iot adapter side have been accepted and are working. Ican also login with these at iobroker pro site.
            • wendy2702W Online
              wendy2702W Online
              I remember that the login with IOT has been changed.
              As I‘m not using IOT Adapter i need to search for procedure.
              R 1 Antwort Letzte Antwort
              • R RobinNoRobot
                wendy2702W Online
                wendy2702W Online
                @RobinNoRobot Where are you coming from? Are you English native speaker?
                • wendy2702W wendy2702
                  RobinNoRobot
                  @wendy2702 Deutschland...
                    RobinNoRobot
                    @wendy2702 Hi Wendy, nochmal ich, nur falls ich mich schlecht ausgedrückt haben. Ich muss die Kontodaten beim IOT Adapter ja 2 Mal eintragen.-...einmal im Adapter selber, das klappt und die Verbindung steht. Dann muss ich ja auf die Alexa Amazon Seite gehen und dort den IOT Skill unter Skills aktivieren...und dort dann die Kontoverknüpfung durchführen. Und genau dieser Schritt funktioniert nicht, dabei kommt immer die o.g. Fehlermeldung dass die Logindaten nicht valid sind.
                    Ich bin etwas ratlos. Könnt ihr helfen?
                    • R RobinNoRobot
                      wendy2702W Online
                      wendy2702W Online
                      @RobinNoRobot kennst du diese Anleitung:
                      https://www.iobroker.net/#de/documentation/cloud/iot.md
                      • R Offline
                        RobinNoRobot
                        Hi wendy...super, danke. genau sowas habe ich gesucht.
                        Grund, dass es bei mir nicht funktionierte war, dass ich mit dem Passwort mit dem ich registriert war und nicht mir dem aus der Email gearbeitet habe.
                        Jetzt funktioniert es.
                        Vielen Dank!
