  4. Gelöst: [Tester] kein Aufruf von http://RPi2-1:8081/#javascript möglich
4 Beiträge 2 Kommentatoren 1.1k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    2016-05-07 13:37:10.287  - info: host.RPi2-1 object change system.adapter.javascript.0
    2016-05-07 13:37:10.289  - info: host.RPi2-1 stopInstance system.adapter.javascript.0
    2016-05-07 13:37:10.290  - info: host.RPi2-1 stopInstance system.adapter.javascript.0 killing pid 775
    2016-05-07 13:37:10.351  - info: host.RPi2-1 instance system.adapter.javascript.0 terminated with code 0 (OK)
    2016-05-07 13:37:12.829  - info: host.RPi2-1 instance system.adapter.javascript.0 started with pid 1040
    2016-05-07 13:37:18.313  - info: javascript.0 starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.javascript
    2016-05-07 13:37:18.366  - info: javascript.0 requesting all states
    2016-05-07 13:37:18.375  - info: javascript.0 requesting all objects
    2016-05-07 13:37:18.848  - info: javascript.0 received all states
    2016-05-07 13:37:19.010  - info: javascript.0 received all objects
    • BluefoxB Offline
      BluefoxB Offline
      @derAuge:
      Wenn du jetzt so was aufrufst:
      cd /opt/iobroker
      iobroker stop javascript
      node node_modules/iobroker.javascript/javascript.js --force --logs
      Da sollte es mehr Fehlermeldungen sein.
      • derAugeD Offline
        derAugeD Offline
        derAuge
        @Bluefox:
        Code: Alles auswählen
        cd /opt/iobroker
        node node_modules/iobroker.javascript/javascript.js –force --logs
        Da sollte es mehr Fehlermeldungen sein. `
        da startet leider garnichts.
        System neu gestartet
        ` > root@RPi2-1:/opt/iobroker# uname -a && node -v && nodejs -v && npm -v
        Linux RPi2-1 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
        v4.4.3
        v0.10.29
        2.15.1 `
        pi@RPi2-1:~ $ su
        Passwort:
        root@RPi2-1:/home/pi# cd /opt/iobroker/
        root@RPi2-1:/opt/iobroker# ps -A | grep " io.*"
        root@RPi2-1:/opt/iobroker# ./start.sh
        Starting iobroker controller daemon...
        iobroker controller daemon started. PID: 713
          713 ?        00:00:11 iobroker.js-con
          722 ?        00:00:11 io.admin.0
          727 ?        00:00:08 io.sql.0
          732 ?        00:00:07 io.web.0
          743 ?        00:00:05 io.history.0
        root@RPi2-1:/opt/iobroker# node node_modules/iobroker.javascript/javascript.js --force --logs
        • derAugeD Offline
          derAugeD Offline
          derAuge
          Lösung:
          über den Schalter Admin muss die Anzeige von "Skript" aktiviert werden. Danach geht es
          Jürgen
          82.9k
