  4. [gelöst] - javascript update 4.5.1 fehler
javascript update
18 Beiträge 3 Kommentatoren 629 Aufrufe 4 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    kann javascript nicht nach 4.5.1 updaten - soweit ich log erstehe will es eine node 0.8.17 version ????
    folgender fehler ( habe heute ung. 19 adapter upgedatet und es war sonst kein fehler dabei - nur bei javascript
    2270 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    2271 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    2271 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    2271 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    2271 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
    2272 warn enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package.json'
    2273 verbose enoent This is related to npm not being able to find a file.
    2274 warn enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/socketwatcher/package.json'
    2275 verbose enoent This is related to npm not being able to find a file.
    2276 warn enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/fsevents/package.json'
    2277 verbose enoent This is related to npm not being able to find a file.
    2278 verbose stack Error: Unsupported engine for words@0.1.3: wanted: {"node":"0.8.17"} (current: {"node":"10.19.0","npm":"6.13.7"})
    2278 verbose stack     at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/index.js:14:14)
    2278 verbose stack     at module.exports.isInstallable (/usr/lib/node_modules/npm/lib/install/validate-args.js:60:3)
    2278 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    2278 verbose stack     at ret (eval at makeNodePromisifiedEval (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promisify.js:184:12), <anonymous>:13:39)
    2278 verbose stack     at actions.(anonymous function) (/usr/lib/node_modules/npm/lib/install/actions.js:52:17)
    2278 verbose stack     at execAction (/usr/lib/node_modules/npm/lib/install/actions.js:191:18)
    2278 verbose stack     at Object.gotValue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/reduce.js:155:18)
    2278 verbose stack     at Object.gotAccum (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/reduce.js:144:25)
    2278 verbose stack     at Object.tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    2278 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    2278 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    2278 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    2278 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    2278 verbose stack     at Promise._fulfill (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:643:18)
    2278 verbose stack     at Promise._resolveCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:437:57)
    2279 verbose pkgid words@0.1.3
    2280 verbose cwd /
    2281 verbose Linux 5.0.21-5-pve
    2282 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript@4.5.1" "--loglevel" "error" "--prefix" "/opt/iobroker"
    2283 verbose node v10.19.0
    2284 verbose npm  v6.13.7
    2285 error code ENOTSUP
    2286 error notsup Unsupported engine for words@0.1.3: wanted: {"node":"0.8.17"} (current: {"node":"10.19.0","npm":"6.13.7"})
    2287 error notsup Not compatible with your version of node/npm: words@0.1.3
    2288 error notsup Not compatible with your version of node/npm: words@0.1.3
    2288 error notsup Required: {"node":"0.8.17"}
    2288 error notsup Actual:   {"npm":"6.13.7","node":"10.19.0"}
    2289 verbose exit [ 1, true ]
    • Thomas BraunT Online
      Versuch mal
      npm i words
        Versuch mal
        npm i words
        liv-in-skyL Offline
        liv-in-skyL Offline
        @Thomas-Braun
        dann kommt das
        root@iobroker59 14:01:50  /opt/iobroker   >
        npm i word
        npm ERR! code ENOTSUP
        npm ERR! notsup Unsupported engine for word@0.2.4: wanted: {"node":">= 0.6.0 < 0.7.0"} (current: {"node":"10.19.0","npm":"6.13.7"})
        npm ERR! notsup Not compatible with your version of node/npm: word@0.2.4
        npm ERR! notsup Required: {"node":">= 0.6.0 < 0.7.0"}
        npm ERR! notsup Actual:   {"npm":"6.13.7","node":"10.19.0"}
        npm ERR!     /home/iobroker/.npm/_logs/2020-05-01T12_02_33_689Z-debug.log
        harrymH 1 Antwort Letzte Antwort
        • liv-in-skyL liv-in-sky
          @Thomas-Braun
          dann kommt das
          npm i word
          harrymH Offline
          harrymH Offline
          harrym
          schrieb am zuletzt editiert von harrym
          @liv-in-sky versuch mal npm i words.js (aktuell ist die Version 0.4.3)
          ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
          • harrymH harrym
            liv-in-skyL Offline
            liv-in-skyL Offline
            @harrym
            mit
            npm i words.js
            kommt etwas mehr - viele warnungen
            root@iobroker59 14:02:59  /opt/iobroker   >
             npm i words.js
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/iobroker.js-controller/node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package.json'
            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/socketwatcher/package.json'
            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/fsevents/package.json'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: abbrev@1.1.1 (node_modules/chokidar/node_modules/fsevents/node_modules/abbrev):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/abbrev' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.abbrev.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ansi-regex@2.1.1 (node_modules/chokidar/node_modules/fsevents/node_modules/ansi-regex):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/ansi-regex' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.ansi-regex.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: aproba@1.2.0 (node_modules/chokidar/node_modules/fsevents/node_modules/aproba):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/aproba' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.aproba.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: balanced-match@1.0.0 (node_modules/chokidar/node_modules/fsevents/node_modules/balanced-match):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/balanced-match' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.balanced-match.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: chownr@1.1.4 (node_modules/chokidar/node_modules/fsevents/node_modules/chownr):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/chownr' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.chownr.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: code-point-at@1.1.0 (node_modules/chokidar/node_modules/fsevents/node_modules/code-point-at):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/code-point-at' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.code-point-at.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concat-map@0.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/concat-map):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/concat-map' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.concat-map.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: console-control-strings@1.1.0 (node_modules/chokidar/node_modules/fsevents/node_modules/console-control-strings):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/console-control-strings' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.console-control-strings.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: core-util-is@1.0.2 (node_modules/chokidar/node_modules/fsevents/node_modules/core-util-is):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/core-util-is' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.core-util-is.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: deep-extend@0.6.0 (node_modules/chokidar/node_modules/fsevents/node_modules/deep-extend):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/deep-extend' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.deep-extend.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: delegates@1.0.0 (node_modules/chokidar/node_modules/fsevents/node_modules/delegates):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/delegates' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.delegates.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: detect-libc@1.0.3 (node_modules/chokidar/node_modules/fsevents/node_modules/detect-libc):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/detect-libc' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.detect-libc.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fs.realpath@1.0.0 (node_modules/chokidar/node_modules/fsevents/node_modules/fs.realpath):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/fs.realpath' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.fs.realpath.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: has-unicode@2.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/has-unicode):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/has-unicode' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.has-unicode.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: inherits@2.0.4 (node_modules/chokidar/node_modules/fsevents/node_modules/inherits):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/inherits' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.inherits.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ini@1.3.5 (node_modules/chokidar/node_modules/fsevents/node_modules/ini):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/ini' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.ini.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: isarray@1.0.0 (node_modules/chokidar/node_modules/fsevents/node_modules/isarray):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/isarray' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.isarray.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: minimist@1.2.5 (node_modules/chokidar/node_modules/fsevents/node_modules/minimist):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/minimist' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.minimist.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ms@2.1.2 (node_modules/chokidar/node_modules/fsevents/node_modules/ms):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/ms' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.ms.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: npm-normalize-package-bin@1.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/npm-normalize-package-bin):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/npm-normalize-package-bin' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.npm-normalize-package-bin.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: number-is-nan@1.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/number-is-nan):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/number-is-nan' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.number-is-nan.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: object-assign@4.1.1 (node_modules/chokidar/node_modules/fsevents/node_modules/object-assign):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/object-assign' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.object-assign.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-homedir@1.0.2 (node_modules/chokidar/node_modules/fsevents/node_modules/os-homedir):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/os-homedir' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.os-homedir.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-tmpdir@1.0.2 (node_modules/chokidar/node_modules/fsevents/node_modules/os-tmpdir):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/os-tmpdir' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.os-tmpdir.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: path-is-absolute@1.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/path-is-absolute):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/path-is-absolute' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.path-is-absolute.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: process-nextick-args@2.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/process-nextick-args):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/process-nextick-args' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.process-nextick-args.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safe-buffer@5.1.2 (node_modules/chokidar/node_modules/fsevents/node_modules/safe-buffer):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/safe-buffer' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.safe-buffer.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safer-buffer@2.1.2 (node_modules/chokidar/node_modules/fsevents/node_modules/safer-buffer):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/safer-buffer' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.safer-buffer.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sax@1.2.4 (node_modules/chokidar/node_modules/fsevents/node_modules/sax):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/sax' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.sax.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: semver@5.7.1 (node_modules/chokidar/node_modules/fsevents/node_modules/semver):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/semver' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.semver.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: set-blocking@2.0.0 (node_modules/chokidar/node_modules/fsevents/node_modules/set-blocking):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/set-blocking' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.set-blocking.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: signal-exit@3.0.2 (node_modules/chokidar/node_modules/fsevents/node_modules/signal-exit):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/signal-exit' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.signal-exit.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: strip-json-comments@2.0.1 (node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-comments):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-comments' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.strip-json-comments.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: util-deprecate@1.0.2 (node_modules/chokidar/node_modules/fsevents/node_modules/util-deprecate):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/util-deprecate' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.util-deprecate.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: wrappy@1.0.2 (node_modules/chokidar/node_modules/fsevents/node_modules/wrappy):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/wrappy' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.wrappy.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: yallist@3.1.1 (node_modules/chokidar/node_modules/fsevents/node_modules/yallist):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/yallist' -> '/opt/iobroker/node_modules/chokidar/node_modules/fsevents/node_modules/.yallist.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: abbrev@1.1.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/abbrev):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/abbrev' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.abbrev.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ansi-regex@2.1.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ansi-regex):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ansi-regex' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.ansi-regex.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: aproba@1.2.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/aproba):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/aproba' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.aproba.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: balanced-match@1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/balanced-match):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/balanced-match' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.balanced-match.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: chownr@1.1.4 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/chownr):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/chownr' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.chownr.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: code-point-at@1.1.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/code-point-at):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/code-point-at' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.code-point-at.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concat-map@0.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/concat-map):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/concat-map' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.concat-map.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: console-control-strings@1.1.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/console-control-strings):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/console-control-strings' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.console-control-strings.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: core-util-is@1.0.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/core-util-is):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/core-util-is' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.core-util-is.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: deep-extend@0.6.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/deep-extend):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/deep-extend' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.deep-extend.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: delegates@1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/delegates):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/delegates' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.delegates.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: detect-libc@1.0.3 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/detect-libc):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/detect-libc' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.detect-libc.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fs.realpath@1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/fs.realpath):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/fs.realpath' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.fs.realpath.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: has-unicode@2.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/has-unicode):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/has-unicode' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.has-unicode.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: inherits@2.0.4 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/inherits):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/inherits' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.inherits.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ini@1.3.5 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ini):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ini' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.ini.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: isarray@1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/isarray):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/isarray' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.isarray.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: minimist@1.2.5 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/minimist):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/minimist' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.minimist.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ms@2.1.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ms):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ms' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.ms.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: npm-normalize-package-bin@1.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/npm-normalize-package-bin):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/npm-normalize-package-bin' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.npm-normalize-package-bin.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: number-is-nan@1.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/number-is-nan):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/number-is-nan' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.number-is-nan.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: object-assign@4.1.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/object-assign):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/object-assign' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.object-assign.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-homedir@1.0.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/os-homedir):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/os-homedir' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.os-homedir.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-tmpdir@1.0.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/os-tmpdir):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/os-tmpdir' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.os-tmpdir.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: path-is-absolute@1.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/path-is-absolute):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/path-is-absolute' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.path-is-absolute.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: process-nextick-args@2.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/process-nextick-args):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/process-nextick-args' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.process-nextick-args.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safe-buffer@5.1.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/safe-buffer):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/safe-buffer' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.safe-buffer.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safer-buffer@2.1.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/safer-buffer):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/safer-buffer' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.safer-buffer.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sax@1.2.4 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/sax):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/sax' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.sax.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: semver@5.7.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/semver):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/semver' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.semver.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: set-blocking@2.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/set-blocking):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/set-blocking' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.set-blocking.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: signal-exit@3.0.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/signal-exit):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/signal-exit' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.signal-exit.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: strip-json-comments@2.0.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-comments):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-comments' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.strip-json-comments.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: util-deprecate@1.0.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/util-deprecate):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/util-deprecate' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.util-deprecate.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: wrappy@1.0.2 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/wrappy):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/wrappy' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.wrappy.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: yallist@3.1.1 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/yallist):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/yallist' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.yallist.DELETE'
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + words.js@0.4.3
            added 3 packages from 1 contributor in 17.558s
            40 packages are looking for funding
              run `npm fund` for details
            den javascript adapter kann ich aber trotzdem nicht installieren
            diesen fehler habe ich auch schon lange in der vis
              liv-in-skyL Offline
              die neue fehlermeldung bei installieren/updaten von javascript
              2269 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
              2280 verbose cwd /opt/iobroker
                liv-in-skyL Offline
                @liv-in-sky sagte in javascript update 4.5.1 fehler:
                hat niemand einen tipp, wie ich dieses " for words@0.1.3: wanted:" wiedr wegbekomme - es könnte sein, dass ich mal words im setup der instanz hatte und dies noch irgendwo im system drinsteht
                wäre dabkbar für jeden hinweis
                gefunden habe ich z.b einen eintrag in diesem file unter dependencies :
                /opt/iobroker/node_modules/iobroker.javascript/package.json
                wie deinstalliert man sowas ?
                  @liv-in-sky Welches System hast du da? Debian?
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @Thomas-Braun ja - proxmox container
                      @liv-in-sky
                      lsb_release -a
                        @liv-in-sky
                        lsb_release -a
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @Thomas-Braun sagte in javascript update 4.5.1 fehler:
                        lsb_release -a
                        root@iobroker59 11:12:57  /opt/iobroker/node_modules/iobroker.javascript/node_modules/words   >
                        lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Debian
                        Description:    Debian GNU/Linux 9.9 (stretch)
                        Release:        9.9
                        Codename:       stretch
                          lsb_release -a
                          lsb_release -a
                          Release:        9.9
                          Codename:       stretch
                          @liv-in-sky
                          Nicht als root anmelden!
                          Als einfacher user im Verzeichnis /opt/iobroker:
                          npm uninstall words
                            @liv-in-sky
                            npm uninstall words
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @Thomas-Braun in einem bestimmten verzeichnis - unter /opt/iobroker habe ich das schon mal versucht
                              @liv-in-sky
                              Was sagt die Konsole denn? Ich habe keine Glaskugel.
                                @liv-in-sky
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @Thomas-Braun
                                output wenn ich javascript update nach dem ich unter /opt/iobroker den befehl "npm uninstall words" ausführe
                                Update javascript from @4.4.3 to @4.5.1
                                NPM version: 6.13.7
                                npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                npm ERR!
                                 code ENOTSUPnpm ERR! notsup Unsupported engine for words@0.1.3: wanted: {"node":"0.8.17"} (current: {"node":"10.19.0","npm":"6.13.7"})npm ERR! notsup Not compatible with your version of node/npm: words@0.1.3npm ERR! notsup Not compatible with your version of node/npm: words@0.1.3npm ERR! notsup Required: {"node":"0.8.17"}npm ERR! notsup Actual:   {"npm":"6.13.7","node":"10.19.0"}
                                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-02T09_18_22_058Z-debug.log
                                das ist der output beim deinstallieren von words
                                npm uninstall words
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/iobroker.js-controller                                              /node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":                                              "darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_mo                                              dules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os"                                              :"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/chokidar/node_modules/                                              fsevents):
                                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package                                              .json'
                                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/socketwatcher/pa                                              ckage.json'
                                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js2fs/n                                              ode_modules/fsevents/package.json'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: abbrev@1.1.1 (node_modules/chokidar/node_modules/fse                                              vents/node_modules/abbrev):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/abbrev' -> '/opt/iobroker/node_modules/c                                              hokidar/node_modules/fsevents/node_modules/.abbrev.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ansi-regex@2.1.1 (node_modules/chokidar/node_modules                                              /fsevents/node_modules/ansi-regex):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/ansi-regex' -> '/opt/iobroker/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/.ansi-regex.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: aproba@1.2.0 (node_modules/chokidar/node_modules/fse                                              vents/node_modules/aproba):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/aproba' -> '/opt/iobroker/node_modules/c                                              hokidar/node_modules/fsevents/node_modules/.aproba.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: balanced-match@1.0.0 (node_modules/chokidar/node_mod                                              ules/fsevents/node_modules/balanced-match):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/balanced-match' -> '/opt/iobroker/node_m                                              odules/chokidar/node_modules/fsevents/node_modules/.balanced-match.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: chownr@1.1.4 (node_modules/chokidar/node_modules/fse                                              vents/node_modules/chownr):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/chownr' -> '/opt/iobroker/node_modules/c                                              hokidar/node_modules/fsevents/node_modules/.chownr.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: code-point-at@1.1.0 (node_modules/chokidar/node_modu                                              les/fsevents/node_modules/code-point-at):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/code-point-at' -> '/opt/iobroker/node_mo                                              dules/chokidar/node_modules/fsevents/node_modules/.code-point-at.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concat-map@0.0.1 (node_modules/chokidar/node_modules                                              /fsevents/node_modules/concat-map):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/concat-map' -> '/opt/iobroker/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/.concat-map.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: console-control-strings@1.1.0 (node_modules/chokidar                                              /node_modules/fsevents/node_modules/console-control-strings):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/console-control-strings' -> '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/.console-control-strings.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: core-util-is@1.0.2 (node_modules/chokidar/node_modul                                              es/fsevents/node_modules/core-util-is):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/core-util-is' -> '/opt/iobroker/node_mod                                              ules/chokidar/node_modules/fsevents/node_modules/.core-util-is.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: deep-extend@0.6.0 (node_modules/chokidar/node_module                                              s/fsevents/node_modules/deep-extend):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/deep-extend' -> '/opt/iobroker/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/.deep-extend.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: delegates@1.0.0 (node_modules/chokidar/node_modules/                                              fsevents/node_modules/delegates):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/delegates' -> '/opt/iobroker/node_module                                              s/chokidar/node_modules/fsevents/node_modules/.delegates.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: detect-libc@1.0.3 (node_modules/chokidar/node_module                                              s/fsevents/node_modules/detect-libc):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/detect-libc' -> '/opt/iobroker/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/.detect-libc.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fs.realpath@1.0.0 (node_modules/chokidar/node_module                                              s/fsevents/node_modules/fs.realpath):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/fs.realpath' -> '/opt/iobroker/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/.fs.realpath.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: has-unicode@2.0.1 (node_modules/chokidar/node_module                                              s/fsevents/node_modules/has-unicode):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/has-unicode' -> '/opt/iobroker/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/.has-unicode.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: inherits@2.0.4 (node_modules/chokidar/node_modules/f                                              sevents/node_modules/inherits):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/inherits' -> '/opt/iobroker/node_modules                                              /chokidar/node_modules/fsevents/node_modules/.inherits.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ini@1.3.5 (node_modules/chokidar/node_modules/fseven                                              ts/node_modules/ini):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/ini' -> '/opt/iobroker/node_modules/chok                                              idar/node_modules/fsevents/node_modules/.ini.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: isarray@1.0.0 (node_modules/chokidar/node_modules/fs                                              events/node_modules/isarray):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/isarray' -> '/opt/iobroker/node_modules/                                              chokidar/node_modules/fsevents/node_modules/.isarray.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: minimist@1.2.5 (node_modules/chokidar/node_modules/f                                              sevents/node_modules/minimist):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/minimist' -> '/opt/iobroker/node_modules                                              /chokidar/node_modules/fsevents/node_modules/.minimist.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ms@2.1.2 (node_modules/chokidar/node_modules/fsevent                                              s/node_modules/ms):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/ms' -> '/opt/iobroker/node_modules/choki                                              dar/node_modules/fsevents/node_modules/.ms.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: npm-normalize-package-bin@1.0.1 (node_modules/chokid                                              ar/node_modules/fsevents/node_modules/npm-normalize-package-bin):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/npm-normalize-package-bin' -> '/opt/iobr                                              oker/node_modules/chokidar/node_modules/fsevents/node_modules/.npm-normalize-package-bin.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: number-is-nan@1.0.1 (node_modules/chokidar/node_modu                                              les/fsevents/node_modules/number-is-nan):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/number-is-nan' -> '/opt/iobroker/node_mo                                              dules/chokidar/node_modules/fsevents/node_modules/.number-is-nan.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: object-assign@4.1.1 (node_modules/chokidar/node_modu                                              les/fsevents/node_modules/object-assign):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/object-assign' -> '/opt/iobroker/node_mo                                              dules/chokidar/node_modules/fsevents/node_modules/.object-assign.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-homedir@1.0.2 (node_modules/chokidar/node_modules                                              /fsevents/node_modules/os-homedir):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/os-homedir' -> '/opt/iobroker/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/.os-homedir.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-tmpdir@1.0.2 (node_modules/chokidar/node_modules/                                              fsevents/node_modules/os-tmpdir):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/os-tmpdir' -> '/opt/iobroker/node_module                                              s/chokidar/node_modules/fsevents/node_modules/.os-tmpdir.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: path-is-absolute@1.0.1 (node_modules/chokidar/node_m                                              odules/fsevents/node_modules/path-is-absolute):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/path-is-absolute' -> '/opt/iobroker/node                                              _modules/chokidar/node_modules/fsevents/node_modules/.path-is-absolute.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: process-nextick-args@2.0.1 (node_modules/chokidar/no                                              de_modules/fsevents/node_modules/process-nextick-args):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/process-nextick-args' -> '/opt/iobroker/                                              node_modules/chokidar/node_modules/fsevents/node_modules/.process-nextick-args.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safe-buffer@5.1.2 (node_modules/chokidar/node_module                                              s/fsevents/node_modules/safe-buffer):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/safe-buffer' -> '/opt/iobroker/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/.safe-buffer.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safer-buffer@2.1.2 (node_modules/chokidar/node_modul                                              es/fsevents/node_modules/safer-buffer):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/safer-buffer' -> '/opt/iobroker/node_mod                                              ules/chokidar/node_modules/fsevents/node_modules/.safer-buffer.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sax@1.2.4 (node_modules/chokidar/node_modules/fseven                                              ts/node_modules/sax):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/sax' -> '/opt/iobroker/node_modules/chok                                              idar/node_modules/fsevents/node_modules/.sax.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: semver@5.7.1 (node_modules/chokidar/node_modules/fse                                              vents/node_modules/semver):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/semver' -> '/opt/iobroker/node_modules/c                                              hokidar/node_modules/fsevents/node_modules/.semver.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: set-blocking@2.0.0 (node_modules/chokidar/node_modul                                              es/fsevents/node_modules/set-blocking):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/set-blocking' -> '/opt/iobroker/node_mod                                              ules/chokidar/node_modules/fsevents/node_modules/.set-blocking.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: signal-exit@3.0.2 (node_modules/chokidar/node_module                                              s/fsevents/node_modules/signal-exit):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/signal-exit' -> '/opt/iobroker/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/.signal-exit.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: strip-json-comments@2.0.1 (node_modules/chokidar/nod                                              e_modules/fsevents/node_modules/strip-json-comments):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-comments' -> '/opt/iobroker/n                                              ode_modules/chokidar/node_modules/fsevents/node_modules/.strip-json-comments.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: util-deprecate@1.0.2 (node_modules/chokidar/node_mod                                              ules/fsevents/node_modules/util-deprecate):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/util-deprecate' -> '/opt/iobroker/node_m                                              odules/chokidar/node_modules/fsevents/node_modules/.util-deprecate.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: wrappy@1.0.2 (node_modules/chokidar/node_modules/fse                                              vents/node_modules/wrappy):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/wrappy' -> '/opt/iobroker/node_modules/c                                              hokidar/node_modules/fsevents/node_modules/.wrappy.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: yallist@3.1.1 (node_modules/chokidar/node_modules/fs                                              events/node_modules/yallist):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/chokidar/node_modules/fsevents/node_modules/yallist' -> '/opt/iobroker/node_modules/                                              chokidar/node_modules/fsevents/node_modules/.yallist.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: abbrev@1.1.1 (node_modules/iobroker.js2fs/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/abbrev):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/abbrev' -> '                                              /opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.                                              abbrev.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ansi-regex@2.1.1 (node_modules/iobroker.js2fs/node_m                                              odules/chokidar/node_modules/fsevents/node_modules/ansi-regex):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ansi-regex'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modul                                              es/.ansi-regex.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: aproba@1.2.0 (node_modules/iobroker.js2fs/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/aproba):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/aproba' -> '                                              /opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.                                              aproba.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: balanced-match@1.0.0 (node_modules/iobroker.js2fs/no                                              de_modules/chokidar/node_modules/fsevents/node_modules/balanced-match):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/balanced-mat                                              ch' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_m                                              odules/.balanced-match.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: chownr@1.1.4 (node_modules/iobroker.js2fs/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/chownr):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/chownr' -> '                                              /opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.                                              chownr.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: code-point-at@1.1.0 (node_modules/iobroker.js2fs/nod                                              e_modules/chokidar/node_modules/fsevents/node_modules/code-point-at):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/code-point-a                                              t' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_mo                                              dules/.code-point-at.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concat-map@0.0.1 (node_modules/iobroker.js2fs/node_m                                              odules/chokidar/node_modules/fsevents/node_modules/concat-map):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/concat-map'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modul                                              es/.concat-map.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: console-control-strings@1.1.0 (node_modules/iobroker                                              .js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/console-control-strings):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/console-cont                                              rol-strings' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fseven                                              ts/node_modules/.console-control-strings.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: core-util-is@1.0.2 (node_modules/iobroker.js2fs/node                                              _modules/chokidar/node_modules/fsevents/node_modules/core-util-is):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/core-util-is                                              ' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_mod                                              ules/.core-util-is.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: deep-extend@0.6.0 (node_modules/iobroker.js2fs/node_                                              modules/chokidar/node_modules/fsevents/node_modules/deep-extend):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/deep-extend'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modu                                              les/.deep-extend.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: delegates@1.0.0 (node_modules/iobroker.js2fs/node_mo                                              dules/chokidar/node_modules/fsevents/node_modules/delegates):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/delegates' -                                              > '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_module                                              s/.delegates.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: detect-libc@1.0.3 (node_modules/iobroker.js2fs/node_                                              modules/chokidar/node_modules/fsevents/node_modules/detect-libc):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/detect-libc'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modu                                              les/.detect-libc.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fs.realpath@1.0.0 (node_modules/iobroker.js2fs/node_                                              modules/chokidar/node_modules/fsevents/node_modules/fs.realpath):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/fs.realpath'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modu                                              les/.fs.realpath.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: has-unicode@2.0.1 (node_modules/iobroker.js2fs/node_                                              modules/chokidar/node_modules/fsevents/node_modules/has-unicode):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/has-unicode'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modu                                              les/.has-unicode.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: inherits@2.0.4 (node_modules/iobroker.js2fs/node_mod                                              ules/chokidar/node_modules/fsevents/node_modules/inherits):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/inherits' ->                                               '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules                                              /.inherits.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ini@1.3.5 (node_modules/iobroker.js2fs/node_modules/                                              chokidar/node_modules/fsevents/node_modules/ini):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ini' -> '/op                                              t/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.ini                                              .DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: isarray@1.0.0 (node_modules/iobroker.js2fs/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/isarray):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/isarray' ->                                               '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/                                              .isarray.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: minimist@1.2.5 (node_modules/iobroker.js2fs/node_mod                                              ules/chokidar/node_modules/fsevents/node_modules/minimist):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/minimist' ->                                               '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules                                              /.minimist.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ms@2.1.2 (node_modules/iobroker.js2fs/node_modules/c                                              hokidar/node_modules/fsevents/node_modules/ms):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/ms' -> '/opt                                              /iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.ms.D                                              ELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: npm-normalize-package-bin@1.0.1 (node_modules/iobrok                                              er.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/npm-normalize-package-bin):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/npm-normaliz                                              e-package-bin' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsev                                              ents/node_modules/.npm-normalize-package-bin.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: number-is-nan@1.0.1 (node_modules/iobroker.js2fs/nod                                              e_modules/chokidar/node_modules/fsevents/node_modules/number-is-nan):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/number-is-na                                              n' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_mo                                              dules/.number-is-nan.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: object-assign@4.1.1 (node_modules/iobroker.js2fs/nod                                              e_modules/chokidar/node_modules/fsevents/node_modules/object-assign):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/object-assig                                              n' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_mo                                              dules/.object-assign.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-homedir@1.0.2 (node_modules/iobroker.js2fs/node_m                                              odules/chokidar/node_modules/fsevents/node_modules/os-homedir):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/os-homedir'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modul                                              es/.os-homedir.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: os-tmpdir@1.0.2 (node_modules/iobroker.js2fs/node_mo                                              dules/chokidar/node_modules/fsevents/node_modules/os-tmpdir):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/os-tmpdir' -                                              > '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_module                                              s/.os-tmpdir.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: path-is-absolute@1.0.1 (node_modules/iobroker.js2fs/                                              node_modules/chokidar/node_modules/fsevents/node_modules/path-is-absolute):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/path-is-abso                                              lute' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node                                              _modules/.path-is-absolute.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: process-nextick-args@2.0.1 (node_modules/iobroker.js                                              2fs/node_modules/chokidar/node_modules/fsevents/node_modules/process-nextick-args):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/process-next                                              ick-args' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/                                              node_modules/.process-nextick-args.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safe-buffer@5.1.2 (node_modules/iobroker.js2fs/node_                                              modules/chokidar/node_modules/fsevents/node_modules/safe-buffer):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/safe-buffer'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modu                                              les/.safe-buffer.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: safer-buffer@2.1.2 (node_modules/iobroker.js2fs/node                                              _modules/chokidar/node_modules/fsevents/node_modules/safer-buffer):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/safer-buffer                                              ' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_mod                                              ules/.safer-buffer.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sax@1.2.4 (node_modules/iobroker.js2fs/node_modules/                                              chokidar/node_modules/fsevents/node_modules/sax):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/sax' -> '/op                                              t/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.sax                                              .DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: semver@5.7.1 (node_modules/iobroker.js2fs/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/semver):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/semver' -> '                                              /opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.                                              semver.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: set-blocking@2.0.0 (node_modules/iobroker.js2fs/node                                              _modules/chokidar/node_modules/fsevents/node_modules/set-blocking):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/set-blocking                                              ' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_mod                                              ules/.set-blocking.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: signal-exit@3.0.2 (node_modules/iobroker.js2fs/node_                                              modules/chokidar/node_modules/fsevents/node_modules/signal-exit):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/signal-exit'                                               -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modu                                              les/.signal-exit.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: strip-json-comments@2.0.1 (node_modules/iobroker.js2                                              fs/node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-comments):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/strip-json-c                                              omments' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/n                                              ode_modules/.strip-json-comments.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: util-deprecate@1.0.2 (node_modules/iobroker.js2fs/no                                              de_modules/chokidar/node_modules/fsevents/node_modules/util-deprecate):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/util-depreca                                              te' -> '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_m                                              odules/.util-deprecate.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: wrappy@1.0.2 (node_modules/iobroker.js2fs/node_modul                                              es/chokidar/node_modules/fsevents/node_modules/wrappy):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/wrappy' -> '                                              /opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/.                                              wrappy.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: yallist@3.1.1 (node_modules/iobroker.js2fs/node_modu                                              les/chokidar/node_modules/fsevents/node_modules/yallist):
                                npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/opt/iobrok                                              er/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/yallist' ->                                               '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents/node_modules/                                              .yallist.DELETE'
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-tempe                                              rature-sensor):
                                up to date in 16.086s
                                43 packages are looking for funding
                                • liv-in-skyL liv-in-sky
                                  @Thomas-Braun
                                  NPM version: 6.13.7
                                  npm ERR!
                                  npm uninstall words
                                  @liv-in-sky
                                  In /opt/iobroker
                                  npm i words
                                    @liv-in-sky
                                    In /opt/iobroker
                                    npm i words
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    npm i words
                                    npm i words
                                    npm ERR! code ENOTSUP
                                    npm ERR!     /home/iobroker/.npm/_logs/2020-05-02T09_27_45_641Z-debug.log
                                    root@iobroker59 11:27:45  /opt/iobroker   >
                                      npm i words
                                      npm i words
                                      @liv-in-sky Du bist ja immer noch root!
                                      Ich bin dann raus.
