  4. iobroker auf BananaPi M1 startet nach Update nicht mehr
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
startet nicht error
20 Beiträge 4 Kommentatoren 945 Aufrufe 3 Beobachtet
  • K Kuki
    OK, hier Feedback:
    Ich hab's als root gemacht und es scheint funktioniert haben, da wie Weboberfläche wieder erreichbar ist, auch wenn einige Warnungen (aber immerhin keine Fehler) kamen.
    root@Bananapi:/home/io# cd /opt/iobroker
    root@Bananapi:/opt/iobroker# npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.2
    npm version >= 5: disabling package-lock
    > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
    > node scripts/postinstall
    Greenlock and ACME.js v3 are on the way!
    Watch for updates at https://indiegogo.com/at/greenlock
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN notsup Unsupported engine for pidusage@2.0.18: wanted: {"node":">=8"} (current: {"node":"6.12.2","npm":"6.14.2"})
    npm WARN notsup Not compatible with your version of node/npm: pidusage@2.0.18
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.3 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.js-controller@1.5.14
    added 100 packages from 80 contributors, removed 478 packages, moved 24 packages and audited 3441 packages in 330.678s
    found 110 vulnerabilities (54 low, 8 moderate, 48 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    Somit jetzt schon: VIELEN LIEBEN DANK! 👍
    Ist die Nutzung des Fixers komplex/irgendwo beschrieben oder einfach ausführen und schauen, was passiert?
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @Kuki Ich würde folgende Vorgehensweise vorschlagen:
    1. Komplettes System-Backup!
    2. Node.js updaten, mindestens auf Version 10 oder 12, siehe Seitenleiste
    3. JS-Controller updaten (kein Ahnung warum du noch 1.x bekommst?!):
      cd /opt/iobroker
      npm i iobroker.js-controller@stable
    4. Fixer ausführen: iobroker fix
    5. Freuen, dass es läuft oder Backup einspielen und hier berichten.
      Kuki
      schrieb am zuletzt editiert von Kuki
      erledigt
      vorher: v6.12.2
      Update via: npm install npm@latest -g
      nachher: 6.14.2
      Ist es so ausreichend vom Versionsstand oder soll ich vor Schritt 3 und 4 noch andere node-Update-Methode versuchen?!
      Denn wenn ich hier (https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-für-alle-im-stable/2) lese, sollte für den Update ja mind. Version 8 von node da sein ... nur wie kann ich höher updaten als das, was ich oben erreichte?
        Kuki
        Unter Verwendung der Schritte (bis ausschließlich Fixer-Einsatz!) aus https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten habe ich nodejs nun auf v6.17.1 upgedated.
        Reicht diese Version für Schritt 3 (JS-Controller updaten)? Ich weiß nicht, was Du oben mit "siehe Seitenleiste" meinst.
        • K Kuki
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @Kuki sagte in iobroker auf BananaPi M1 startet nach Update nicht mehr:
          Hmm... 🤔
          @AlCalzone sagte in iobroker auf BananaPi M1 startet nach Update nicht mehr:
            Kuki
            Ah ok, diese Box habe ich nicht gesehen (schon seit langem nicht mehr auf der Home-Seite gewesen).
            Aber anscheinend wird nichts aus meinem node-Update:
            login as: io
            io@192.168.0.95's password:
             ____                                  ____  _
            | __ )  __ _ _ __   __ _ _ __   __ _  |  _ \(_)
            |  _ \ / _` | '_ \ / _` | '_ \ / _` | | |_) | |
            | |_) | (_| | | | | (_| | | | | (_| | |  __/| |
            |____/ \__,_|_| |_|\__,_|_| |_|\__,_| |_|   |_|
            Welcome to ARMBIAN 5.36 user-built Debian GNU/Linux 8 (jessie) 4.13.16-sunxi
            System load:   1.55 0.92 0.36   Up time:       2 min
            Memory usage:  11 % of 999MB    IP:            192.168.0.95
            CPU temp:      35°C
            Usage of /:    72% of 3.5G
            [ General system configuration (beta): armbian-config ]
            Last login: Fri Mar  6 13:37:18 2020 from acera515.fritz.box
            io@Bananapi:~$ cd /opt/iobroker
            io@Bananapi:/opt/iobroker$ iobroker stop
            iobroker controller daemon is not running
            io@Bananapi:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
            [sudo] password for io:
            ## Installing the NodeSource Node.js 10.x repo...
            ## Populating apt-get cache...
            + apt-get update
            Ign http://httpredir.debian.org jessie InRelease
            Hit http://httpredir.debian.org jessie-updates InRelease
            Ign http://httpredir.debian.org jessie-backports InRelease
            Hit http://security.debian.org jessie/updates InRelease
            Hit https://deb.nodesource.com jessie InRelease
            Hit http://httpredir.debian.org jessie Release.gpg
            Ign http://httpredir.debian.org jessie-backports Release.gpg
            Ign http://httpredir.debian.org jessie-backports/main armhf Packages/DiffIndex
            Ign http://httpredir.debian.org jessie-backports/contrib armhf Packages/DiffIndex
            Ign http://httpredir.debian.org jessie-backports/non-free armhf Packages/DiffIndex
            Get:1 http://apt.armbian.com jessie InRelease [178 B]
            Ign http://apt.armbian.com jessie InRelease
            Get:2 http://apt.armbian.com jessie Release.gpg [178 B]
            Ign http://apt.armbian.com jessie Release.gpg
            Get:3 http://apt.armbian.com jessie Release [178 B]
            Get:4 http://httpredir.debian.org jessie-updates/main armhf Packages [20 B]
            Get:5 http://apt.armbian.com jessie/main armhf Packages/DiffIndex [178 B]
            Ign http://apt.armbian.com jessie/main armhf Packages/DiffIndex
            Get:6 http://httpredir.debian.org jessie-updates/contrib armhf Packages [20 B]
            Get:7 http://httpredir.debian.org jessie-updates/non-free armhf Packages [20 B]
            Get:8 http://httpredir.debian.org jessie-updates/contrib Translation-en [14 B]
            Get:9 http://httpredir.debian.org jessie-updates/main Translation-en [14 B]
            Get:10 http://httpredir.debian.org jessie-updates/non-free Translation-en [14 B]
            Get:11 http://apt.armbian.com jessie/utils armhf Packages/DiffIndex [178 B]
            Ign http://apt.armbian.com jessie/utils armhf Packages/DiffIndex
            Get:12 http://apt.armbian.com jessie/jessie-desktop armhf Packages/DiffIndex [178 B]
            Ign http://apt.armbian.com jessie/jessie-desktop armhf Packages/DiffIndex
            Get:13 http://apt.armbian.com jessie/jessie-desktop Translation-en_US [178 B]
            Get:14 http://apt.armbian.com jessie/jessie-desktop Translation-en [178 B]
            Get:15 http://security.debian.org jessie/updates/main armhf Packages [737 kB]
            Hit https://deb.nodesource.com jessie/main Sources
            Get:16 http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8 [178 B]
            Get:17 http://apt.armbian.com jessie/main Translation-en_US [178 B]
            Get:18 http://apt.armbian.com jessie/main Translation-en [178 B]
            Get:19 http://apt.armbian.com jessie/main Translation-en_US.UTF-8 [178 B]
            Get:20 http://apt.armbian.com jessie/utils Translation-en_US [178 B]
            Get:21 http://apt.armbian.com jessie/utils Translation-en [178 B]
            Get:22 http://apt.armbian.com jessie/utils Translation-en_US.UTF-8 [178 B]
            Get:23 http://security.debian.org jessie/updates/non-free armhf Packages [4.243 B]
            Get:24 http://security.debian.org jessie/updates/main Translation-en [387 kB]
            Get:25 http://security.debian.org jessie/updates/non-free Translation-en [11,8 kB]
            Get:26 http://apt.armbian.com jessie/main armhf Packages [178 B]
            Get:27 https://deb.nodesource.com jessie/main armhf Packages [1.005 B]
            Hit http://security.debian.org jessie/updates/contrib armhf Packages
            Hit http://security.debian.org jessie/updates/contrib Translation-en
            Get:28 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
            Get:29 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Get:30 http://apt.armbian.com jessie/utils armhf Packages [178 B]
            Get:31 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
            Get:32 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
            Get:33 http://apt.armbian.com jessie/jessie-desktop armhf Packages [178 B]
            Get:34 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Get:35 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
            Get:36 http://apt.armbian.com jessie/jessie-desktop Translation-en_US [178 B]
            Get:37 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
            Get:38 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Get:39 http://apt.armbian.com jessie/jessie-desktop Translation-en [178 B]
            Get:40 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
            Get:41 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
            Get:42 http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8 [178 B]
            Get:43 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Get:44 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
            Get:45 http://apt.armbian.com jessie/main Translation-en_US [178 B]
            Get:46 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
            Ign https://deb.nodesource.com jessie/main Translation-en_US
            Get:47 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Get:48 http://apt.armbian.com jessie/main Translation-en [178 B]
            Get:49 https://deb.nodesource.com jessie/main Translation-en_US.UTF-8 [162 B]
            Ign https://deb.nodesource.com jessie/main Translation-en_US.UTF-8
            Ign http://httpredir.debian.org jessie-backports/contrib Translation-en_US
            Get:50 http://apt.armbian.com jessie/main Translation-en_US.UTF-8 [178 B]
            Get:51 http://apt.armbian.com jessie/utils Translation-en_US [178 B]
            Ign http://httpredir.debian.org jessie-backports/contrib Translation-en_US.UTF-8
            Ign http://httpredir.debian.org jessie-backports/main Translation-en_US
            Get:52 http://apt.armbian.com jessie/utils Translation-en [178 B]
            Ign http://httpredir.debian.org jessie-backports/main Translation-en_US.UTF-8
            Ign http://httpredir.debian.org jessie-backports/non-free Translation-en_US
            Get:53 http://apt.armbian.com jessie/utils Translation-en_US.UTF-8 [178 B]
            Hit http://httpredir.debian.org jessie/main armhf Packages
            Get:54 http://apt.armbian.com jessie/main armhf Packages [178 B]
            Hit http://httpredir.debian.org jessie/contrib armhf Packages
            Hit http://httpredir.debian.org jessie/non-free armhf Packages
            Get:55 http://apt.armbian.com jessie/utils armhf Packages [178 B]
            Hit http://httpredir.debian.org jessie/contrib Translation-en
            Hit http://httpredir.debian.org jessie/main Translation-en
            Get:56 http://apt.armbian.com jessie/jessie-desktop armhf Packages [178 B]
            Hit http://httpredir.debian.org jessie/non-free Translation-en
            Ign http://httpredir.debian.org jessie-backports/non-free Translation-en_US.UTF-8
            Get:57 http://apt.armbian.com jessie/jessie-desktop Translation-en_US [178 B]
            Err http://httpredir.debian.org jessie-backports/main armhf Packages
              404  Not Found [IP: 151.101.14.133 80]
            Err http://httpredir.debian.org jessie-backports/contrib armhf Packages
            Get:58 http://apt.armbian.com jessie/jessie-desktop Translation-en [178 B]
            Err http://httpredir.debian.org jessie-backports/non-free armhf Packages
            Get:59 http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8 [178 B]
            Get:60 http://apt.armbian.com jessie/main Translation-en_US [178 B]
            Get:61 http://apt.armbian.com jessie/main Translation-en [178 B]
            Get:62 http://apt.armbian.com jessie/main Translation-en_US.UTF-8 [178 B]
            Get:63 http://apt.armbian.com jessie/utils Translation-en_US [178 B]
            Get:64 http://apt.armbian.com jessie/utils Translation-en [178 B]
            Get:65 http://apt.armbian.com jessie/utils Translation-en_US.UTF-8 [178 B]
            Get:66 http://apt.armbian.com jessie/main armhf Packages [178 B]
            Get:67 http://apt.armbian.com jessie/utils armhf Packages [178 B]
            Get:68 http://apt.armbian.com jessie/jessie-desktop armhf Packages [178 B]
            Get:69 http://apt.armbian.com jessie/jessie-desktop Translation-en_US [178 B]
            Get:70 http://apt.armbian.com jessie/jessie-desktop Translation-en [178 B]
            Get:71 http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8 [178 B]
            Get:72 http://apt.armbian.com jessie/main Translation-en_US [178 B]
            Get:73 http://apt.armbian.com jessie/main Translation-en [178 B]
            Get:74 http://apt.armbian.com jessie/main Translation-en_US.UTF-8 [178 B]
            Get:75 http://apt.armbian.com jessie/utils Translation-en_US [178 B]
            Get:76 http://apt.armbian.com jessie/utils Translation-en [178 B]
            Get:77 http://apt.armbian.com jessie/utils Translation-en_US.UTF-8 [178 B]
            Get:78 http://apt.armbian.com jessie/main armhf Packages [178 B]
            Err http://apt.armbian.com jessie/main armhf Packages
            Get:79 http://apt.armbian.com jessie/utils armhf Packages [178 B]
            Err http://apt.armbian.com jessie/utils armhf Packages
            Get:80 http://apt.armbian.com jessie/jessie-desktop armhf Packages [178 B]
            Err http://apt.armbian.com jessie/jessie-desktop armhf Packages
            Get:81 http://apt.armbian.com jessie/jessie-desktop Translation-en_US [178 B]
            Ign http://apt.armbian.com jessie/jessie-desktop Translation-en_US
            Get:82 http://apt.armbian.com jessie/jessie-desktop Translation-en [178 B]
            Get:83 http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8 [178 B]
            Ign http://apt.armbian.com jessie/jessie-desktop Translation-en_US.UTF-8
            Get:84 http://apt.armbian.com jessie/main Translation-en_US [178 B]
            Ign http://apt.armbian.com jessie/main Translation-en_US
            Get:85 http://apt.armbian.com jessie/main Translation-en [178 B]
            Get:86 http://apt.armbian.com jessie/main Translation-en_US.UTF-8 [178 B]
            Ign http://apt.armbian.com jessie/main Translation-en_US.UTF-8
            Get:87 http://apt.armbian.com jessie/utils Translation-en_US [178 B]
            Ign http://apt.armbian.com jessie/utils Translation-en_US
            Get:88 http://apt.armbian.com jessie/utils Translation-en [178 B]
            Get:89 http://apt.armbian.com jessie/utils Translation-en_US.UTF-8 [178 B]
            Ign http://apt.armbian.com jessie/utils Translation-en_US.UTF-8
            Get:90 http://apt.armbian.com jessie/main armhf Packages [178 B]
              HttpError404
            Get:91 http://apt.armbian.com jessie/utils armhf Packages [178 B]
              HttpError404
            Get:92 http://apt.armbian.com jessie/jessie-desktop armhf Packages [178 B]
              HttpError404
            Fetched 1.005 B in 20s (48 B/s)
            W: Failed to fetch http://httpredir.debian.org/debian/dists/jessie-backports/main/binary-armhf/Packages  404  Not Found [IP: 151.101.14.133 80]
            W: Failed to fetch http://httpredir.debian.org/debian/dists/jessie-backports/contrib/binary-armhf/Packages  404  Not Found [IP: 151.101.14.133 80]
            W: Failed to fetch http://httpredir.debian.org/debian/dists/jessie-backports/non-free/binary-armhf/Packages  404  Not Found [IP: 151.101.14.133 80]
            W: Failed to fetch http://apt.armbian.com/dists/jessie/main/binary-armhf/Packages  HttpError404
            W: Failed to fetch http://apt.armbian.com/dists/jessie/utils/binary-armhf/Packages  HttpError404
            W: Failed to fetch http://apt.armbian.com/dists/jessie/jessie-desktop/binary-armhf/Packages  HttpError404
            E: Some index files failed to download. They have been ignored, or old ones used instead.
            Error executing command, exiting
            io@Bananapi:/opt/iobroker$ sudo apt-get install -y nodejs
            Reading package lists... Done
            Building dependency tree
            nodejs is already the newest version.
            0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
            "nodejs is already the newest version." somit müsste ich anscheinend erst Mal die apt-Quellen ändern und das System auf Armbian Stretch upgraden etc .... mal sehen, ob das klappt.
            • K Kuki
              login as: io
               ____                                  ____  _
              CPU temp:      35°C
              + apt-get update
                HttpError404
                HttpError404
                HttpError404
              Jan1
              @Kuki
              und warum auf Stretch, wenn Du Dir schon die Mühe machst? Buster ist aktuell, oder willst von uralt auf alt wechseln?
                Kuki
                @Jan1
                Weil ich diese Anleitung gefunden habe (https://forum.armbian.com/topic/5840-upgrade-jessie-to-stretch/). Läuft noch, es scheint aber momentan zu funktionieren. Ob ich danach noch auf Buster upgrade, mal sehen. Erst Mal noch vorher der Versuch, node upzugraden.
                J HomoranH 2 Antworten Letzte Antwort
                • K Kuki
                  @Jan1
                  Jan1
                  @Kuki
                  Buster hat 10 eh mit drin, kannst also das Upgrade sparen oder gleich auf 12 hoch.
                  Die Anleitung ist von 2017 😁
                  • K Kuki
                    @Jan1
                    @Kuki
                    Ich habe spaßeshalber auch versucht einige meiner Installationen von Jessie über stretch auf Buster zu bringen oder direkt auf Buster.
                    Der Aufwand ist definitiv enorm, der Erfolg war nicht überall gegeben.
                    Mein weiteres Vorgehen war:
                    • Backup ziehen
                    • neue SD-Karte (ist immer gut!)
                    • Neuinstallation
                    • Restore des Backups
                    • Fertig!
                      @Kuki
                      • Backup ziehen
                      • Neuinstallation
                      • Fertig!
                      Jan1
                      @Homoran
                      wäre mein nächster Vorschlag gewesen, da der Aufwand einer Neuinstallation eher gering ausfällt, man aber sicher sein kann, keine alten Fehler mehr mit drin zu haben ;-)
                        Kuki
                        @Jan1 und @Homoran
                        Ich lasse es derweil auf Stretch. Danke für Eure Tipps! Vielleicht dann in ein paar Wochen eine Neuinstallation dann auf Buster. Mal sehen.
                        @AlCalzone
                        2. Erledigt. node ist auf v10.19.0
                        3. Hat einige Fehler geworfen, siehe Log, ist aber anscheinend geglückt. Im Webinterface wird Installed: 2.2.9 angezeigt.
                        login as: io
                         ____                                  ____  _
                        Welcome to ARMBIAN 5.36 user-built Debian GNU/Linux 9 (stretch) 4.13.16-sunxi
                        Linux Bananapi 4.13.16-sunxi #20 SMP Fri Nov 24 19:50:07 CET 2017 armv7l
                        System load:   1.57 0.42 0.14   Up time:       0 min
                        Memory usage:  15 % of 992MB    IP:            192.168.0.95
                        CPU temp:      46°C
                        Usage of /:    81% of 3.5G
                        Last login: Sun Mar  8 14:17:34 2020 from 192.168.0.100
                        io@Bananapi:~$ top
                        top - 14:27:33 up 1 min,  1 user,  load average: 3,47, 1,00, 0,35
                        Tasks: 101 total,   6 running,  95 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 87,2 us, 12,8 sy,  0,0 ni,  0,0 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
                        KiB Mem :  1016576 total,   394460 free,   441092 used,   181024 buff/cache
                        KiB Swap:   131068 total,   131068 free,        0 used.   551296 avail Mem
                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                         1107 root      20   0  173172  87188  25440 R  46,3  8,6   0:17.61 iobroker.j+
                         1327 root      20   0   95344  39340  24804 S  31,7  3,9   0:03.22 node
                         1345 root      20   0   88436  32004  23956 R  31,7  3,1   0:01.67 node
                         1334 root      20   0   91120  35972  24088 R  30,1  3,5   0:02.56 node
                         1296 root      20   0  141736  45904  24888 S  15,2  4,5   0:04.30 node
                         1130 root      20   0  160152  70036  25252 R  14,6  6,9   0:11.97 io.admin.0
                         1239 root      20   0  173360  82628  25088 S   8,7  8,1   0:11.28 io.javascr+
                         1373 root      20   0   80840  23104  20860 R   7,8  2,3   0:00.24 node
                           15 root      20   0       0      0      0 S   6,5  0,0   0:05.04 kworker/1:0
                          113 root      20   0       0      0      0 S   1,6  0,0   0:01.91 mmcqd/0
                          604 redis     20   0   33484   4640   1800 S   1,6  0,5   0:00.64 redis-serv+
                         1238 io        20   0    8988   3168   2728 R   1,0  0,3   0:00.40 top
                            8 root      20   0       0      0      0 S   0,3  0,0   0:00.21 rcu_sched
                          205 root      20   0   24528   3840   3424 S   0,3  0,4   0:01.57 systemd-jo+
                          726 mysql     20   0  621624  64648  11276 S   0,3  6,4   0:00.84 mysqld
                         1215 io        20   0    9656   3336   2628 S   0,3  0,3   0:00.03 sshd
                         1281 root      20   0  132692  45616  24924 S   0,3  4,5   0:05.28 node
                        io@Bananapi:~$ top
                        top - 14:28:10 up 2 min,  1 user,  load average: 4,80, 1,67, 0,60
                        Tasks: 148 total,   5 running, 100 sleeping,   0 stopped,  43 zombie
                        %Cpu(s): 80,2 us, 18,0 sy,  0,0 ni,  0,0 id,  0,3 wa,  0,0 hi,  1,4 si,  0,0 st
                        KiB Mem :  1016576 total,   192224 free,   623248 used,   201104 buff/cache
                        KiB Swap:   131068 total,   131068 free,        0 used.   369168 avail Mem
                         1497 root      20   0   88640  34372  24192 R  74,0  3,4   0:02.96 npm
                         1399 root      20   0  135508  39868  25564 R  25,3  3,9   0:06.25 io.info.0
                         1107 root      20   0  213256 128508  25444 S  11,7 12,6   0:27.08 iobroker.j+
                         1373 root      20   0  150208  48764  25700 R  10,1  4,8   0:09.08 io.alexa2.0
                           15 root      20   0       0      0      0 S   9,7  0,0   0:07.86 kworker/1:0
                         1239 root      20   0  195084 106852  25088 R   6,8 10,5   0:15.76 io.javascr+
                          377 root      20   0   88172  12968  10868 S   5,5  1,3   0:00.95 NetworkMan+
                          604 redis     20   0   33484   4820   1800 S   4,2  0,5   0:01.49 redis-serv+
                          325 message+  20   0    5312   2672   2312 S   3,2  0,3   0:00.64 dbus-daemon
                         1130 root      20   0  181656  93932  25316 S   3,2  9,2   0:20.84 io.admin.0
                         1281 root      20   0  156788  57028  25744 S   1,6  5,6   0:08.37 io.cloud.0
                         1450 io        20   0    9120   3080   2644 R   1,6  0,3   0:00.25 top
                         1296 root      20   0  142920  48012  25904 S   1,3  4,7   0:05.62 io.pushbul+
                         1334 root      20   0  134348  47560  24960 S   1,0  4,7   0:06.59 io.harmony+
                          205 root      20   0   24528   3840   3424 S   0,6  0,4   0:01.75 systemd-jo+
                           14 root      20   0       0      0      0 S   0,3  0,0   0:00.11 ksoftirqd/1
                          113 root      20   0       0      0      0 S   0,3  0,0   0:02.36 mmcqd/0
                        io@Bananapi:~$ su
                        Password:
                        root@Bananapi:/home/io# iobroker stop
                        Stopping iobroker controller daemon...
                        iobroker controller daemon stopped.
                        No "killall.sh" script found. Just stop.
                        root@Bananapi:/opt/iobroker# npm i iobroker.js-controller@stable
                        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                        > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                        NPM version: 6.13.4
                        > bufferutil@1.1.0 install /opt/iobroker/node_modules/bufferutil
                        > node-gyp rebuild
                        make: Entering directory '/opt/iobroker/node_modules/bufferutil/build'
                          CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                        In file included from ../node_modules/nan/nan.h:82:0,
                                         from ../src/bufferutil.cc:16:
                        ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Integer; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                        ../node_modules/nan/nan_new.h:29:66: warning: ‘v8::Local<v8::Integer> v8::Value::ToInteger() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         To<v8::Integer>(v8::Handle<v8::Integer> i) { return i->ToInteger(); }
                        In file included from ../src/bufferutil.cc:7:0:
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:10052:16: note: declared here
                         Local<Integer> Value::ToInteger() const {
                        ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                        ../node_modules/nan/nan_new.h:34:64: error: no matching function for call to ‘v8::Integer::ToInt32()’
                         To<v8::Int32>(v8::Handle<v8::Integer> i)   { return i->ToInt32(); }
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2437:43: note: candidate: v8::MaybeLocal<v8::Int32> v8::Value::ToInt32(v8::Local<v8::Context>) const
                           V8_WARN_UNUSED_RESULT MaybeLocal<Int32> ToInt32(Local<Context> context) const;
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2437:43: note:   candidate expects 1 argument, 0 provided
                        In file included from /root/.cache/node-gyp/10.19.0/include/node/v8.h:26:0,
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2450:30: note: candidate: v8::Local<v8::Int32> v8::Value::ToInt32(v8::Isolate*) const
                                         Local<Int32> ToInt32(Isolate* isolate) const);
                        /root/.cache/node-gyp/10.19.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                           declarator __attribute__((deprecated(message)))
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2450:30: note:   candidate expects 1 argument, 0 provided
                        ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
                        ../node_modules/nan/nan_new.h:39:65: error: no matching function for call to ‘v8::Integer::ToUint32()’
                         To<v8::Uint32>(v8::Handle<v8::Integer> i)  { return i->ToUint32(); }
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2435:44: note: candidate: v8::MaybeLocal<v8::Uint32> v8::Value::ToUint32(v8::Local<v8::Context>) const
                           V8_WARN_UNUSED_RESULT MaybeLocal<Uint32> ToUint32(
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2435:44: note:   candidate expects 1 argument, 0 provided
                        In file included from ../node_modules/nan/nan_new.h:189:0,
                                         from ../node_modules/nan/nan.h:82,
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:49:38: error: no matching function for call to ‘v8::BooleanObject::New(bool&)’
                           return v8::BooleanObject::New(value).As<v8::BooleanObject>();
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:5035:23: note: candidate: static v8::Local<v8::Value> v8::BooleanObject::New(v8::Isolate*, bool)
                           static Local<Value> New(Isolate* isolate, bool value);
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:5035:23: note:   candidate expects 2 arguments, 1 provided
                        ../node_modules/nan/nan_implementation_12_inl.h:49:60: error: expected primary-expression before ‘>’ token
                        ../node_modules/nan/nan_implementation_12_inl.h:49:62: error: expected primary-expression before ‘)’ token
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::RegExp>::return_t NanIntern::Factory<v8::RegExp>::New(v8::Handle<v8::String>, v8::RegExp::Flags)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:158:40: warning: ‘static v8::Local<v8::RegExp> v8::RegExp::New(v8::Local<v8::String>, v8::RegExp::Flags)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                           return v8::RegExp::New(pattern, flags);
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:5110:38: note: declared here
                                                Local<RegExp> New(Local<String> pattern, Flags flags));
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:166:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                           return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:1510:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason)
                           static V8_WARN_UNUSED_RESULT MaybeLocal<Script> Compile(
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:1510:51: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:1537:51: note: candidate: static v8::MaybeLocal<v8::Script> v8::ScriptCompiler::Compile(v8::Local<v8::Context>, v8::ScriptCompiler::StreamedSource*, v8::Local<v8::String>, const v8::ScriptOrigin&)
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:1537:51: note:   candidate expects 4 arguments, 2 provided
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:173:69: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:206:42: error: no matching function for call to ‘v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*&, v8::String::NewStringType, int&)’
                                 v8::String::kNormalString, length);
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2802:51: note: candidate: static v8::MaybeLocal<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::NewStringType, int)
                           static V8_WARN_UNUSED_RESULT MaybeLocal<String> NewFromOneByte(
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2802:51: note:   no known conversion for argument 3 from ‘v8::String::NewStringType’ to ‘v8::NewStringType’
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:217:66: error: no matching function for call to ‘v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*&)’
                           return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2861:21: note: candidate: static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalOneByteStringResource*)
                               Local<String> NewExternal(Isolate* isolate,
                        /root/.cache/node-gyp/10.19.0/include/node/v8config.h:346:48: note: in definition of macro ‘V8_DEPRECATE_SOON’
                         #define V8_DEPRECATE_SOON(message, declarator) declarator
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2861:21: note:   no known conversion for argument 2 from ‘v8::String::ExternalStringResource*’ to ‘v8::String::ExternalOneByteStringResource*’
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:237:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
                           return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
                        ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                        ../node_modules/nan/nan_implementation_12_inl.h:244:10: error: ‘CompileUnbound’ is not a member of ‘v8::ScriptCompiler’
                        In file included from ../src/bufferutil.cc:16:0:
                        ../node_modules/nan/nan.h: In function ‘uint32_t NanUInt32OptionValue(v8::Local<v8::Object>, v8::Handle<v8::String>, uint32_t)’:
                        ../node_modules/nan/nan.h:248:43: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               ? optionsObj->Get(opt)->Uint32Value()
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2477:47: note: declared here
                           V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                        ../node_modules/nan/nan.h: At global scope:
                        ../node_modules/nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
                         NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
                        ../node_modules/nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
                         NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
                        ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
                        ../node_modules/nan/nan.h:289:39: error: ‘class v8::Isolate’ has no member named ‘IdleNotification’; did you mean ‘IdleNotificationDeadline’?
                             return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
                        ../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
                               v8::Isolate::GCEpilogueCallback callback
                        ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                        ../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
                             , v8::GCType gc_type_filter = v8::kGCTypeAll) {
                        ../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
                               v8::Isolate::GCEpilogueCallback callback) {
                        ../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
                        ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
                               v8::Isolate::GCPrologueCallback callback
                        ../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                        ../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
                        ../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
                               v8::Isolate::GCPrologueCallback callback) {
                        ../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
                        ../node_modules/nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
                             const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
                        ../node_modules/nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
                        ../node_modules/nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
                        ../node_modules/nan/nan.h:570:42: error: ‘data’ was not declared in this scope
                               _NanWeakCallbackInfo<T, P> *info = data.GetParameter();
                        ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
                             , node::smalloc::FreeCallback callback
                        ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
                        ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
                                 v8::Isolate::GetCurrent(), data, length, callback, hint);
                        ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
                        ../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
                             return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
                        In file included from ../src/bufferutil.cc:10:0:
                        /root/.cache/node-gyp/10.19.0/include/node/node_buffer.h:68:40: note:   initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
                         NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
                        ../node_modules/nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
                        ../node_modules/nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
                             return node::Buffer::New(v8::Isolate::GetCurrent(), size);
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
                        ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
                             return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
                        ../node_modules/nan/nan.h:710:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                             return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
                        ../node_modules/nan/nan.h:717:74: error: no matching function for call to ‘v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*)’
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::UnboundScript>)’:
                        ../node_modules/nan/nan.h:723:48: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             return script->BindToCurrentContext()->Run();
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:1271:51: note: declared here
                           V8_DEPRECATED("Use maybe version", Local<Value> Run());
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanRunScript(v8::Handle<v8::Script>)’:
                        ../node_modules/nan/nan.h:729:24: warning: ‘v8::Local<v8::Value> v8::Script::Run()’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             return script->Run();
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::Function>, int, v8::Handle<v8::Value>*)’:
                        ../node_modules/nan/nan.h:738:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                 v8::Isolate::GetCurrent(), target, func, argc, argv));
                        In file included from ../src/bufferutil.cc:8:0:
                        /root/.cache/node-gyp/10.19.0/include/node/node.h:177:50: note: declared here
                                         NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                        /root/.cache/node-gyp/10.19.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                             __attribute__((deprecated(message))) declarator
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, v8::Handle<v8::String>, int, v8::Handle<v8::Value>*)’:
                        ../node_modules/nan/nan.h:747:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                 v8::Isolate::GetCurrent(), target, symbol, argc, argv));
                        /root/.cache/node-gyp/10.19.0/include/node/node.h:170:50: note: declared here
                        ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> NanMakeCallback(v8::Handle<v8::Object>, const char*, int, v8::Handle<v8::Value>*)’:
                        ../node_modules/nan/nan.h:756:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                                 v8::Isolate::GetCurrent(), target, method, argc, argv));
                        /root/.cache/node-gyp/10.19.0/include/node/node.h:163:50: note: declared here
                        ../node_modules/nan/nan.h: In member function ‘v8::Handle<v8::Value> NanCallback::Call_(v8::Isolate*, v8::Handle<v8::Object>, int, v8::Handle<v8::Value>*) cons ’:
                        ../node_modules/nan/nan.h:1569:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                        ../node_modules/nan/nan.h:398:59: note: in definition of macro ‘NanEscapeScope’
                         # define NanEscapeScope(val) scope.Escape(_NanEnsureLocal(val))
                        ../node_modules/nan/nan.h: In function ‘void* _NanRawString(v8::Handle<v8::Value>, Nan::Encoding, size_t*, void*, size_t, int)’:
                        ../node_modules/nan/nan.h:2164:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                                 v8::String::Value value(toStr);
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2916:51: note: declared here
                             V8_DEPRECATED("Use Isolate version", explicit Value(Local<v8::Value> obj));
                        ../node_modules/nan/nan.h:2198:38: warning: ‘v8::String::Value::Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                        ../node_modules/nan/nan.h: In constructor ‘NanTap::NanTap(v8::Handle<v8::Value> ’:
                        ../node_modules/nan/nan.h:2292:41: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             NanAssignPersistent(t_, t->ToObject());
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:10046:15: note: declared here
                         Local<Object> Value::ToObject() const {
                        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
                        ../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                             NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
                        /root/.cache/node-gyp/10.19.0/include/node/node.h:372:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
                         inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
                        /root/.cache/node-gyp/10.19.0/include/node/node.h:386:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
                         inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
                        ../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                             NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
                        ../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                             NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
                        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Merge(const v8::FunctionCallbackInfo<v8::Value>&)’:
                        ../src/bufferutil.cc:49:49: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             Local<Object> bufferObj = args[0]->ToObject();
                        ../src/bufferutil.cc:56:51: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               Local<Object> src = array->Get(i)->ToObject();
                        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Unmask(const v8::FunctionCallbackInfo<v8::Value>&)’:
                        ../src/bufferutil.cc:67:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             Local<Object> buffer_obj = args[0]->ToObject();
                        ../src/bufferutil.cc:69:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             Local<Object> mask_obj = args[1]->ToObject();
                        ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Mask(const v8::FunctionCallbackInfo<v8::Value>&)’:
                        ../src/bufferutil.cc:88:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ../src/bufferutil.cc:89:48: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        ../src/bufferutil.cc:91:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             Local<Object> output_obj = args[2]->ToObject();
                        ../src/bufferutil.cc:92:51: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             unsigned int dataOffset = args[3]->Int32Value();
                        /root/.cache/node-gyp/10.19.0/include/node/v8.h:2478:46: note: declared here
                           V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                        ../src/bufferutil.cc:93:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             unsigned int length = args[4]->Int32Value();
                        bufferutil.target.mk:103: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
                        make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
                        make: Leaving directory '/opt/iobroker/node_modules/bufferutil/build'
                        gyp ERR! build error
                        gyp ERR! stack Error: `make` failed with exit code: 2
                        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
                        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                        gyp ERR! System Linux 4.13.16-sunxi
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
                        gyp ERR! node -v v10.19.0
                        gyp ERR! node-gyp -v v5.0.5
                        gyp ERR! not ok
                        > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                        > node-gyp rebuild
                        make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                          COPY Release/unix_dgram.node
                        make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                        > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/utf-8-validate
                        > node-gyp rebuild
                        make: Entering directory '/opt/iobroker/node_modules/utf-8-validate/build'
                          CXX(target) Release/obj.target/validation/src/validation.o
                                         from ../src/validation.cc:15:
                        In file included from ../src/validation.cc:7:0:
                        In file included from ../src/validation.cc:15:0:
                        In file included from ../src/validation.cc:10:0:
                        In file included from ../src/validation.cc:8:0:
                        ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
                        ../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
                             NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
                        ../src/validation.cc: In static member function ‘static void Validation::IsValidUTF8(const v8::FunctionCallbackInfo<v8::Value>&)’:
                        ../src/validation.cc:132:50: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                        validation.target.mk:103: recipe for target 'Release/obj.target/validation/src/validation.o' failed
                        make: *** [Release/obj.target/validation/src/validation.o] Error 1
                        make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'
                        gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
                        gyp ERR! not ok
                        > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
                        object system.certificates updated
                        object 0_userdata.0.example_state created
                        object 0_userdata.0 created
                        object alias.0 created
                        ioBroker configuration updated
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.4 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                        npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
                        + iobroker.js-controller@2.2.9
                        added 242 packages from 654 contributors, removed 85 packages, updated 38 packages, moved 14 packages and audited 3773 packages in 350.477s
                        8 packages are looking for funding
                          run `npm fund` for details
                        found 109 vulnerabilities (43 low, 12 moderate, 54 high)
                           │      New minor version of npm available! 6.13.4 → 6.14.2       │
                           │   Changelog: https://github.com/npm/cli/releases/tag/v6.14.2   │
                           │               Run npm install -g npm to update!                │
                        1. "iobroker fix" klappt nicht, listet nur die iobroker-Hilfe/Parameter auf. Soll ich "curl -sL https://iobroker.net/fix.sh | bash -" versuchen?
                        • K Kuki
                          @Jan1 und @Homoran
                          @AlCalzone
                          login as: io
                           ____                                  ____  _
                          CPU temp:      46°C
                          io@Bananapi:~$ top
                          io@Bananapi:~$ top
                          io@Bananapi:~$ su
                          Password:
                          NPM version: 6.13.4
                          > node-gyp rebuild
                          gyp ERR! not ok
                          > node-gyp rebuild
                          > node-gyp rebuild
                          gyp ERR! not ok
                          den Befehl gibt es ja auch nicht
                          wäre richtig
                            Kuki
                            @Homoran
                            Siehe AlCalzones Beitrag oben, da schreibt er den Befehl selbst und dieser wird auch in der iobroker-Parameter-Hilfe genannt.
                            Aber ich versuche nun den o.g. Curl/bash-Befehl als root und berichte dann hier wieder.
                            DAnke!
                              Kuki
                              Fixer ist sauber durchgelaufen. Ich bin also nun wieder "up to date", was iobroker angeht. DANKE!
                                wäre richtig
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @Homoran sagte in iobroker auf BananaPi M1 startet nach Update nicht mehr:
                                Doch! Allerdings muss die Installation dazu halbwegs aktuell sein, bzw. ein halbwegs aktueller Fixer muss 1x gelaufen sein. Im vorliegenden Fall muss(te) also 1x der curl-Befehl von Hand abgesetzt werden.
