  4. [Gelöst] RPI4 Javascript Error: Cannot find module canvas
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
errorcanvasnpm errorpi4
19 Beiträge 7 Kommentatoren 3.8k Aufrufe 7 Beobachtet
  • ElzersharkE Elzershark
    Mist.. Vergessen zu schreiben.. Egal was man macht mit iobroker.. immer das im Ordner machen...
    cd /opt/iobroker
    Patchwork 3001P Offline
    Patchwork 3001
    @Elzershark okay dachte schon ich mach was falsch eventuell ein tut dafür?
    • ElzersharkE Offline
      ElzersharkE Offline
      Elzershark
      Erstmal testen ob's stimmt :)
      https://www.youtube.com/c/Elzershark
      https://t.me/joinchat/BD87n3xMU0QzYmUy
      https://www.facebook.com/elzershark
      Patchwork 3001P 1 Antwort Letzte Antwort
        Patchwork 3001
        @Elzershark leider immer noch fehler
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ npm install canvas@2.6.1 --unsafe-perm --production --save --prefix
        npm WARN invalid config prefix=true
        npm WARN invalid config Must be a valid filesystem path
        canvas@2.6.1 install /opt/iobroker/node_modules/canvas
        node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz
        node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@10.19.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
        Package pixman-1 was not found in the pkg-config search path.
        Perhaps you should add the directory containing `pixman-1.pc'
        to the PKG_CONFIG_PATH environment variable
        No package 'pixman-1' found
        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp ERR! configure error
        gyp ERR! stack Error: `gyp` failed with exit code: 1
        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.19.97-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v10.19.0
        gyp ERR! node-gyp -v v5.0.5
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        node-pre-gyp ERR! System Linux 4.19.97-v7l+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v10.19.0
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
          ElzersharkE Offline
          Elzershark
          cd /opt/iobroker
          sudo npm install canvas --unsafe-perm --production --save --prefix
          sudo chown -R iobroker /opt/iobroker
            cd /opt/iobroker
            Patchwork 3001
            @Elzershark danke für die Hilfe aber es kommt immer noch Error wie oben im log
            • C Offline
              CruziX
              Sollte man Module nicht über die Einstellungen der Script Engine installieren?
              W 1 Antwort Letzte Antwort
              • Patchwork 3001P Patchwork 3001
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @Patchwork-3001 sagte in RPI4 Javascript Error: Cannot find module canvas:
                https://github.com/Automattic/node-canvas/issues/1065
                liegt wohl am canvas selbst
                Meine Adapter und Widgets
                Links im Profil
                • C CruziX
                  W Offline
                  W Offline
                  WurstDLX
                  @CruziX
                  Das habe ich ja zuerst versucht, aber da schreit auch schon das Log von iobroker, dass er das module nicht finden kann. Daher habe ich es per Konsole versucht.
                  AsgothianA C 2 Antworten Letzte Antwort
                  • W WurstDLX
                    @CruziX
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @WurstDLX
                    hast du hier mal geschaut ob du die zum übersetzen notwendigen Pakete installiert hast ? Ohne wird es nicht gehen.
                    A.
                    • OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      Das Modul ist deswegen nicht da, weil es nicht installiert werden kann. Ich bin den Issue nur mal drübergeflogen, aber es scheinen Bedingungen zu geben, die davon wieder abhängige Pakete nicht richtig kompilieren lassen.
                      Man braucht nicht immer davon ausgehen, das alle Pakete Fehlerfrei sind
                      Ich hab mir dein log nochmal angeschaut.
                      Hier versucht er eine ein vorkompiliertes Paket runterzuladen, welches aber für deine Architektur (arm) nicht gibt.
                      Deswegen will er es selbst kompilieren.
                      Das scheitert aber daran, das ein anderes notwendige Paket nicht richtig konfiguriert wurde
                      Perhaps you should add the directory containing pixman-1.pc' to the PKG_CONFIG_PATH environment variable No package 'pixman-1' found gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error:gyp` failed with exit code: 1
                      Alles andere sind Folgefehler.
                      Lese dir den oben verlinkten Issue bei canvas auf github durch, da stehen evtl. Fehlerbehebungsmöglichkeiten drin.
                      Links im Profil
                        ElzersharkE Offline
                        Elzershark
                        schrieb am zuletzt editiert von Elzershark
                        Lad mein Tool nochmal runter und repariere mal (3 und dann die 1)
                        (Neu überarbeitet)
                        Dann
                        cd /opt/iobroker
                        Wenn irgendwie Möglich, keine sudo Befehle (mehr) machen
                          sabphil22
                          schrieb am zuletzt editiert von sabphil22
                          Hänge mich mal hier dran. Habe das selbe Problem bei identischer Hardware.
                          @Elzershark was meinst du mit "3 und dann die 1"?
                          Habe bisher kein Erfolg gehabt?
                          Edit:
                          @WurstDLX probier mal das folgende. Hat bei mir geholfen.
                          Hab es mit dem Beitrag von Foxriver fixen können:
                          https://forum.iobroker.net/topic/26900/hinzufuegen-von-roomba-adapter-wirft-fehler/2
                          • S sabphil22
                            Edit:
                            W Offline
                            W Offline
                            WurstDLX
                            @sabphil22
                            Danke dir! Der Beitrag von Foxriver76
                            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                            sudo npm install canvas --unsafe-perm=true
                            hat geholfen. Es wurden bei der Installation ein Haufen an warnings wegen "cast" Fehlern ausgespuckt und auch iobroker-log meldete beim Starten des Skripts viele Fehler (siehe unten), aber canvas macht kein Problem. Das Skript führt die canvas Aufrufe wieder auf und erstellt eine Karte.
                            Mich störten zwar ein wenig diese Meldungen, aber vllt sind sie eher minor issues :)
                            Vielen Dank euch!!!
                            javascript.0	2020-02-17 22:29:14.995	info	(25026) Start javascript script.js.Xiaomi.RoborockMap
                            javascript.0	2020-02-17 22:29:14.943	info	(25026) received all states
                            javascript.0	2020-02-17 22:29:14.907	info	(25026) received all objects
                            javascript.0	2020-02-17 22:29:14.403	info	(25026) requesting all objects
                            javascript.0	2020-02-17 22:29:14.399	info	(25026) requesting all states
                            javascript.0	2020-02-17 22:29:14.278	info	(25026) found 0 vulnerabilities
                            javascript.0	2020-02-17 22:29:14.276	info	(25026) 3 packages are looking for funding run `npm fund` for details
                            javascript.0	2020-02-17 22:29:14.135	info	(25026) + canvas@2.6.1 added 73 packages from 36 contributors and audited 117 packages in 59.459s
                            javascript.0	2020-02-17 22:29:13.845	info	(25026) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/canvas/build“ wird verlassen
                            javascript.0	2020-02-17 22:29:13.826	info	(25026) COPY Release/canvas.node
                            javascript.0	2020-02-17 22:29:13.508	info	(25026) SOLINK_MODULE(target) Release/obj.target/canvas.node
                            javascript.0	2020-02-17 22:29:12.974	info	(25026) CXX(target) Release/obj.target/canvas/src/register_font.o
                            javascript.0	2020-02-17 22:29:12.727	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:29:12.703	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:29:12.637	error	(25026) In file included from ../../nan/nan.h:54, from ../src/backend/Backend.h:6, from ../src/Backends.h:3, from ../src/init.cc:17: ../src/init.cc:
                            javascript.0	2020-02-17 22:29:12.355	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/Backends.h:3, from ../src/init.cc:17: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(N
                            javascript.0	2020-02-17 22:29:10.650	info	(25026) CXX(target) Release/obj.target/canvas/src/init.o
                            javascript.0	2020-02-17 22:29:09.784	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:29:09.758	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/ImageData.h:5, from
                            javascript.0	2020-02-17 22:29:09.637	error	(25026) In file included from ../src/ImageData.h:5, from ../src/ImageData.cc:3: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h:2298:62:
                            javascript.0	2020-02-17 22:29:08.279	info	(25026) CXX(target) Release/obj.target/canvas/src/ImageData.o
                            javascript.0	2020-02-17 22:29:05.953	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:29:05.928	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Image.h:8, from ../
                            javascript.0	2020-02-17 22:29:05.497	error	(25026) In file included from ../src/Image.h:8, from ../src/Image.cc:3: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h:2298:62: warning:
                            javascript.0	2020-02-17 22:29:03.978	info	(25026) CXX(target) Release/obj.target/canvas/src/Image.o
                            javascript.0	2020-02-17 22:29:01.377	info	(25026) CXX(target) Release/obj.target/canvas/src/color.o
                            javascript.0	2020-02-17 22:29:01.090	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:29:01.065	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:29:00.818	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/Canvas.h:5, from ../src/closure.h:5, from ../src/closure.cc:1: ../../nan/nan.h:
                            javascript.0	2020-02-17 22:28:59.388	info	(25026) CXX(target) Release/obj.target/canvas/src/closure.o
                            javascript.0	2020-02-17 22:28:53.929	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:53.904	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:53.073	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/Canvas.h:5, from ../src/CanvasRenderingContext2d.h:6, from ../src/CanvasRenderi
                            javascript.0	2020-02-17 22:28:51.414	info	(25026) CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                            javascript.0	2020-02-17 22:28:49.605	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:49.580	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/CanvasPattern.h:6,
                            javascript.0	2020-02-17 22:28:49.154	error	(25026) In file included from ../src/CanvasPattern.h:6, from ../src/CanvasPattern.cc:3: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h:2
                            javascript.0	2020-02-17 22:28:47.637	info	(25026) CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                            javascript.0	2020-02-17 22:28:46.877	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:46.853	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/CanvasGradient.h:5,
                            javascript.0	2020-02-17 22:28:46.616	error	(25026) In file included from ../src/CanvasGradient.h:5, from ../src/CanvasGradient.cc:3: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h
                            javascript.0	2020-02-17 22:28:45.219	info	(25026) CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                            javascript.0	2020-02-17 22:28:40.846	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:40.822	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:40.695	error	(25026) ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wc
                            javascript.0	2020-02-17 22:28:40.692	error	(25026) ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wc
                            javascript.0	2020-02-17 22:28:40.687	error	(25026) ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/Canvas.cc:415:26: warning: comparison of integer expression
                            javascript.0	2020-02-17 22:28:40.042	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/Canvas.h:5, from ../src/Canvas.cc:3: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Na
                            javascript.0	2020-02-17 22:28:38.490	info	(25026) CXX(target) Release/obj.target/canvas/src/Canvas.o
                            javascript.0	2020-02-17 22:28:38.258	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:38.234	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:37.986	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/Backends.h:3, from ../src/Backends.cc:1: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorke
                            javascript.0	2020-02-17 22:28:36.542	info	(25026) CXX(target) Release/obj.target/canvas/src/Backends.o
                            javascript.0	2020-02-17 22:28:34.585	error	(25026) ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len,
                            javascript.0	2020-02-17 22:28:34.584	error	(25026) ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’: ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different si
                            javascript.0	2020-02-17 22:28:34.150	info	(25026) CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                            javascript.0	2020-02-17 22:28:33.561	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:33.537	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:33.216	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/backend/SvgBackend.h:3, from ../src/backend/SvgBackend.cc:1: ../../nan/nan.h: In function ‘void
                            javascript.0	2020-02-17 22:28:31.739	info	(25026) CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                            javascript.0	2020-02-17 22:28:31.164	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:31.140	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:30.890	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/backend/PdfBackend.h:3, from ../src/backend/PdfBackend.cc:1: ../../nan/nan.h: In function ‘void
                            javascript.0	2020-02-17 22:28:29.464	info	(25026) CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                            javascript.0	2020-02-17 22:28:29.008	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:28.983	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:28.872	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/backend/ImageBackend.h:3, from ../src/backend/ImageBackend.cc:1: ../../nan/nan.h: In function ‘v
                            javascript.0	2020-02-17 22:28:27.496	info	(25026) CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                            javascript.0	2020-02-17 22:28:26.952	error	(25026) /home/iobroker/.cache/node-gyp/10.19.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P
                            javascript.0	2020-02-17 22:28:26.928	error	(25026) In file included from /home/iobroker/.cache/node-gyp/10.19.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/backend/Backend.h:6,
                            javascript.0	2020-02-17 22:28:26.817	error	(25026) In file included from ../src/backend/Backend.h:6, from ../src/backend/Backend.cc:1: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan
                            javascript.0	2020-02-17 22:28:25.425	info	(25026) CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                            javascript.0	2020-02-17 22:28:25.407	info	(25026) COPY Release/canvas-postbuild.node
                            javascript.0	2020-02-17 22:28:25.199	info	(25026) SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                            javascript.0	2020-02-17 22:28:25.196	info	(25026) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/canvas/build“ wird betreten
                            javascript.0	2020-02-17 22:28:22.309	error	(25026) WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v64-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not
                            javascript.0	2020-02-17 22:28:22.308	error	(25026) node-pre-gyp
                            javascript.0	2020-02-17 22:28:21.914	error	(25026) WARN Using request for node-pre-gyp https download
                            javascript.0	2020-02-17 22:28:21.913	error	(25026)
                            javascript.0	2020-02-17 22:28:21.911	error	(25026) node-pre-gyp
                            javascript.0	2020-02-17 22:28:21.138	info	(25026) > canvas@2.6.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/canvas > node-pre-gyp install --fallback-to-build
                            javascript.0	2020-02-17 22:28:13.277	info	(25026) npm install canvas --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                            javascript.0	2020-02-17 22:28:13.186	info	(25026) found 0 vulnerabilities
                            javascript.0	2020-02-17 22:28:13.183	info	(25026) 1 package is looking for funding run `npm fund` for details
                            javascript.0	2020-02-17 22:28:13.153	info	(25026) + xmlhttprequest@1.8.0 added 9 packages from 33 contributors and audited 12 packages in 1.729s
                            javascript.0	2020-02-17 22:28:04.148	info	(1523) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            javascript.0	2020-02-17 22:28:04.147	info	(1523) terminating
                            javascript.0	2020-02-17 22:28:04.145	info	(1523) Stop script script.js.Xiaomi.AqaraCube
                            javascript.0	2020-02-17 22:28:04.142	info	(1523) Got terminate signal TERMINATE_YOURSELF
                            • W WurstDLX
                              @CruziX
                              CruziX
                              @WurstDLX sagte in RPI4 Javascript Error: Cannot find module canvas:
                              @CruziX
                              Die Probleme hatte ich auch, hab gedacht, dass ich irgendwas falsch mache 😅
