  4. Zigbee Error
Zigbee Error
logzigbee cc2531 cc2530
6 Beiträge 3 Kommentatoren 629 Aufrufe 2 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    Systemdata Bitte Ausfüllen
    Hardwaresystem: HP Client
    Arbeitsspeicher: 8GB
    Festplattenart: SDD
    Betriebssystem: Debian 9
    Node-Version: v10.18.1
    Nodejs-Version: v10.18.1
    NPM-Version: 6.13.6
    Installationsart: Manuell
    Image genutzt: Nein
    Hallo Freunde Im Log habe ich ab und an diese Fehlermeldungen obwohl alles funktioniert.
    Woran kann das liegen?
    stack/adapter/zStackAdapter.js:5:58)
    zigbee.0	2020-02-15 22:23:37.587	error	at Generator.next (<anonymous>)
    zigbee.0	2020-02-15 22:23:37.587	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:595:27)
    zigbee.0	2020-02-15 22:23:37.587	error	(16946) Error on send command to 0x8418260000008036. Error: Error: Data request failed with error: 'No network route' (205)
    zigbee.0	2020-02-15 22:22:52.451	error	at listOnTimeout (timers.js:263:5)
    zigbee.0	2020-02-15 22:22:52.451	error	at tryOnTimeout (timers.js:300:5)
    zigbee.0	2020-02-15 22:22:52.451	error	at ontimeout (timers.js:436:11)
    zigbee.0	2020-02-15 22:22:52.451	error	at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
    zigbee.0	2020-02-15 22:22:52.451	error	(16946) Error on send command to 0x8418260000073d7b. Error: Error: Timeout - 14724 - 3 - 86 - 8 - 11 after 15000ms
    zigbee.0	2020-02-15 22:22:37.453	error	at Timer.processTimers (timers.js:223:10)
    zigbee.0	2020-02-15 22:22:37.453	error	at listOnTimeout (timers.js:263:5)
    zigbee.0	2020-02-15 22:22:37.453	error	at tryOnTimeout (timers.js:300:5)
    zigbee.0	2020-02-15 22:22:37.453	error	at ontimeout (timers.js:436:11)
    zigbee.0	2020-02-15 22:22:37.453	error	at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
    zigbee.0	2020-02-15 22:22:37.453	error	(16946) Error on send command to 0x8418260000073d7b. Error: Error: Timeout - 14724 - 3 - 85 - 6 - 11 after 15000ms
    error	(16946) Error on send command to 0x841826000006cd03. Error: Error: Data request failed with error: 'No network route' (205) at ZStackAdapter.<anonymo
    Gruß OSR
    Plattform
    • ostseereiterO ostseereiter
      Festplattenart: SDD
      NPM-Version: 6.13.6
      Image genutzt: Nein
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @ostseereiter
      Die Suchfunktion hätte davon einige posts gefunden.
      Die Meldung kommt immer dann wenn der Koordinator auf den Versuch ein Gerät zu schalten keine Antwort bekommt. Du hast also ein Endgerät welches keine gute Netzverbindung besitzt.
      A.
      ostseereiterO 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @ostseereiter
        A.
        ostseereiter
        @Asgothian ok das ist natürlich nicht schön obwohl das nicht sein kann eigentlich. das trifft auch immer wieder andere Geräte.Die Verbindung müsste eigentlich immer 100 Prozent sein bei meinen 30 Geräten in einer 1 zimmer Wohnung. Also vielleicht setzt der Adapter aus oder ab und an der Stick oder sehe ich das falsch?
        Gruß OSR
        Plattform
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @ostseereiter Das siehst du falsch.
          Neben dem Abstand sind halt auch Funkstörungen für abgebrochene Kommunikation verantwortlich. Auch ein Benutzer, der genau zwischen Aktor und Sender sitzt dämpft die 2.4ghz Zigbee Wellen gut.
          A.
            A.
            ostseereiter
            @Asgothian ok na vielleicht hole ich noch ne usb Verlängerung und hänge den Stick höher.
            Gruß OSR
            Plattform
              mantus
              schrieb am zuletzt editiert von mantus
              @Asgothian said in Zigbee Error:
              ich habe genau das selbe problem, aber nur mit meinen Led Treibern, die verlieren ständig die verbindung und gehen dann wieder über stunden offline, dann sind sie wieder mit 30 linkquality im netz und dann sind sie wieder weg.
              Ich weiss einfach nicht mehr weiter, das zigbee netzwerk ist sowas von unzuverlässig was das angeht, das ich schon überlege alles weg zu werfen und mit knx oder so zu machen.
              Ich habe schon eine strecke aus 2 stück CC2530 gebaut .... also CC2531 Stick vom iobroker mit USB verlängerungskabel, direkt hinter der wand dann der CC2530 numer eins ..... dann 2m weiter der 2. CC2530 und dann direkt in einer Unterputzdose der GLEDOPTO Ledtreiber der 90% der Zeit keinen Empfang hat ..... ich habe es schon mit 2 verschiedenen GL-C-008 und mit einem GL-C-009 versucht, bei allen dasselbe verhalten .... sie pairen sich zwar aber gehen dann nach kurzer zeit offline .... kommen dann stunden später vieleicht mal wieder ... und verschwinden dann wieder .....
              hat irgend jemand einen Tip? der Aqara Bewegungesmelder direkt daneben läuft 1A ohne Probleme seit dem ersten Tag.
              with my hue bridge without iobroker and no CC2530 and CC2531 it worked just fine
