  4. [Vorstellung] Meine zweite Visualisierung
    6.4k
vistemplate
1.3k Beiträge 148 Kommentatoren 670.9k Aufrufe 157 Beobachtet
  • opossumO opossum
    Hallo, @Negalein ,
    hast Du das Blockly von oben genommen? Da habe ich etwas ergänzt.
    EDIT: Kuddel war schneller 😀
      <variables>
        <variable id="r$ug7+)#=~i}8RU2kgZ(" type="">result</variable>
      </variables>
      <block id="8G-t1R$2*5D,dzJ+=Z/)" type="schedule" x="-12" y="38">
        <field name="SCHEDULE">0 * * * *</field>
        <statement name="STATEMENT">
          <block id="Sl#pk4ynUi?qtGg$cE[g" type="comment">
            <field name="COMMENT">ioBroker Version</field>
            <next>
              <block id="!R8mB:{en(uJ^pcv:[x-" type="exec">
                <mutation with_statement="true"></mutation>
                <field name="WITH_STATEMENT">TRUE</field>
                <field name="LOG"></field>
                <value name="COMMAND">
                  <shadow id="v]l$N@4P}O26I3a-q-h?" type="text">
                    <field name="TEXT">iobroker version</field>
                  </shadow>
                </value>
                  <block id="][GYoQ$TpSK^1z+Y1)io" type="control">
                    <mutation delay_input="false"></mutation>
                    <field name="OID">javascript.0.Versionen.JS-Controller</field>
                    <value name="VALUE">
                      <block id="^mDY7*B6ucov9?$`tyWW" type="variables_get">
                        <field id="r$ug7+)#=~i}8RU2kgZ(" name="VAR" variabletype="">result</field>
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block id="H%;3a-me1U9t}!fx~0y~" type="comment">
                    <field name="COMMENT">Node Version</field>
                    <next>
                      <block id="*{Wr/}G!6rw|w(ts:Ubr" type="exec">
                          <shadow id="1e4e9U(dN%k7nOplwh/t" type="text">
                            <field name="TEXT">node -v</field>
                          </shadow>
                        </value>
                          <block id="`vkk(uG/q|f.RsbQJ6-F" type="control">
                            <field name="OID">javascript.0.Versionen.Node</field>
                              <block id=",@I94/CPiw]|fzeEmZIN" type="variables_get">
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                          <block id=":rYml-k#oiHgEwv`2(YH" type="comment">
                            <field name="COMMENT">NPM Version</field>
                            <next>
                              <block id="NsFDRm/4E?3a;yAjP2~M" type="exec">
                                  <shadow id="Pq@ZNpd%kQM$SihLxwc%" type="text">
                                    <field name="TEXT">npm -v</field>
                                  </shadow>
                                </value>
                                  <block id="Z;/822T:KaNxR6lSS-HN" type="control">
                                    <field name="OID">javascript.0.Versionen.NPM</field>
                                      <block id="Ur~}G^ol^zYpeaK0SPS0" type="variables_get">
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block id="_VHco8o-RQ%}k1^}(Jv9" type="comment">
                                    <field name="COMMENT">NODEJS Version</field>
                                    <next>
                                      <block id="e(R]V[00Lw|/XxZ6jMF|" type="exec">
                                          <shadow id="}IaR=aRj??^,}JP(X!Y." type="text">
                                            <field name="TEXT">nodejs -v</field>
                                          </shadow>
                                        </value>
                                          <block id="G;4.63b:Q0I1]np?7V!}" type="control">
                                            <field name="OID">javascript.0.Versionen.NodeJS</field>
                                              <block id="BrlBksXsDJLiI+4MI!Y-" type="variables_get">
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    Hardy6
    #1087
    Ich komme einfach nicht weiter...möchte gerne die Versionen von JS-Controller - NPM - Node - Node.js per Blockly (das von @Kuddel aus diesem Thread ) auslesen. Node und NPM funktionieren.
    Aber bei JS-Controller kommt eine
    FM:"Error. Please start the ioBroker commandline with the correct Windows startmenu shortcut. Aborting..."
    Ich habe dazu auch dieses hier gefunden...
    @Stabilostick sagte in Update-Anleitung für Windows (js-controller):
    @P-A-L-A-D-I-N sagte in Update-Anleitung für Windows (js-controller):
    Und, hast Du das gemacht????
    Ich wiederhole mich noch einmal:
    Führe „iobroker“ Kommandos bitte in der Kommandozeile aus, die Du speziell für die gewählte Instanz im Startmenü unter „iobroker“ findest! Dann bist du gleich im richtigen Ordner.
    werde aber nicht schlau draus. - Wie gebe ich den Pfad im Blockly richtig an?
    mein ioBroker läuft unter windows unter dem Namen SmartHome
    Hab schon einiges probiert, aber nix funktioniert, entweder o.g. FM oder gar kein Wert landet in javascript.0.versionen.JS-Controller (habe versionen klein angelegt und auch entsprechend ausgewählt)
    auf der Windows Console läuft der Befehl "iobroker version" einwandfrei.
    und das auslesen von node.js bringt ebenfalls keinen Wert unter: javascript.0.Versionen.NodeJS
    schätze mal hier ist auch was mit dem Pfad zu tun, oder?
    • H Hardy6
      K Online
      K Online
      Kuddel
      #1088
      @Hardy6 poste mal ein Screenshot von deinem Blockly Skript und deinen Javascript Einstellungen
      H 1 Antwort Letzte Antwort
      • K Kuddel
        Hardy6
        #1089
        var result;
        schedule("*/1 */1 * * *", function () {
          // ioBroker Version
          exec('C:\\Windows\\system32\\cmd.exe /K "C:\\Program Files\\iobroker\\SmartHome\\iobroker version"', function (error, result, stderr) {
              setState("javascript.0.versionen.JS-Controller"/*JS-Controller*/, result);
          // Node Version
          exec('node -v', function (error, result, stderr) {
              setState("javascript.0.versionen.Node"/*Node*/, result);
          // NPM Version
          exec('npm -v', function (error, result, stderr) {
              setState("javascript.0.versionen.NPM"/*NPM*/, result);
          // NODEJS Version
          exec('nodejs -v', function (error, result, stderr) {
              setState("javascript.0.versionen.NodeJS"/*NodeJS*/, result);
        • H Hardy6
          var result;
            // ioBroker Version
            // Node Version
            // NPM Version
            // NODEJS Version
          K Online
          K Online
          Kuddel
          #1090
          @Hardy6 muss der pfad zu iobroker unter windows mit angegeben werden ?
          unter linux reicht als befehl "iobroker version"
          geht das bei windows nicht ?
          • K Kuddel
            Hardy6
            schrieb am zuletzt editiert von Hardy6
            #1091
            @Kuddel also auf der Konsole unter Windows läuft das im entsprechenden Verzeichnis hier "SmartHome" einwandfrei
            gebe ich im Blockly nur "iobroker version" in den Befehlstext kommt auch o.a. FM
            Was mich wundert ist die Tatsache, das die anderen beiden Befehle im Blockly (npm -v und node -v) funktionieren.
            EDIT: habe die PATH Variable auf dem ioBroker Windows angepasst, doch dieselbe FM kommt wieder
            • H Offline
              Hardy6
              #1092
              var result;
                // ioBroker Version
                exec('iobroker version', function (error, result, stderr) {
                // Node Version
                // NPM Version
                // NODEJS Version
              @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
              auf der Konsole nicht , aber scheinbar über den EXEC Befehl aber eben nur auffällig bei "ioBroker-Befehlen"
              • H Hardy6
                var result;
                  // ioBroker Version
                  // Node Version
                  // NPM Version
                  // NODEJS Version
                K Online
                K Online
                Kuddel
                #1093
                @Hardy6 habe leider kein Windows System und kann daher nicht testen
                • K Kuddel
                  Nachdem ich mit der ersten Version meiner VIS nicht mehr zufreiden war, hab ich mich daran gemacht, alles einmal komplett neu zu machem.
                  Die Seiten sind alle fpr mein Galaxy Tab A erstellt worden.
                  Vielen Dank an @Annuit20 , der ebenfalls seine komplette VIS zur Verfügung gestellt hat. An dieser konnte ich mich orientieren und mir einige Ideen abgucken.
                  Ich denke so richtig fertig ist man ja nie, aber ein Bisschen habe ich schon geschafft….
                  Damit alles korrekt dargestellt wird, müssen folgende Widgets installiert sein:
                  Für die Icons wird des Weiteren der Adapter "icons-mfd-png" benötigt.
                  Skripte
                  Alle Objekte, mit denen ich in meinen Skripten arbeite, können mit einem Javascript erstellt werden:
                  objekte.txt
                  Hier sind alle meine Skirpte als komplett Export aus der Scriptengine
                  2020-03-17-scripts.zip
                  Danke an @Kaiman55 für den Test-Import.
                  Anleitung Skript Import:
                  1. Download der Datei "2020-03-17-scripts.zip"
                  2. Eigene Skripte in Zip Datei exportieren
                  3. Beide Archive entpacken und dann die Skripte / Gruppen in einem gemeinsamen Archiv zusamfenühren
                  4. Import des neu erstellten Archis
                  VIS-Export 06.11.19:
                  2019-11-06-VIS.zip
                  Hier meine Icons
                  Meine_Icons.zip
                  Workaround für das Hochladen der kompletten VIS
                  1. Meine_Icons.zip entpacken
                  2. 2019-11-06-VIS.zip entpacken
                  3. Die beiden VIS-Datein und die den Icons Ordner zu einem neuen Zip Archiv zusammefügen
                  4. Das neue Zip archiv importieren
                  hofmannha
                  #1094
                  @Kuddel
                  Hallo Kuddel,
                  Deine Visualisierung hat es mir angetan. Die beste Visualisierung die ich bisher gesehen habe. Ich benutze dein Projekt um mir Anregungen zu holen für meine Visualisierung.
                  Eine Frage dazu. Auf deiner Übersichtsseite oben links hast Du eine Wetteranzeige. Wie kriege ich das Icon vom Adapter dasWetter hin?
                  • H hofmannha
                    @Kuddel
                    Hallo Kuddel,
                    K Online
                    K Online
                    Kuddel
                    #1095
                    @hofmannha woran genau scheiterst du gerade ?
                    Wenn du mein Widget übernimmst, musst du eigentlich nur die IP adresse ändern.
                    Widget:
                    [{"tpl":"tplStatefulImage8","data":{"oid":"daswetter.0.NextDays.Location_1.Day_1.Wetter_Symbol_id","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","count":"19","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/1.png","src_1":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/1.png","src_2":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/2.png","src_3":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/3.png","src_4":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/4.png","src_5":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/5.png","src_6":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/6.png","src_7":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/7.png","src_8":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/8.png","src_9":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/9.png","src_10":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/10.png","src_11":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/11.png","src_12":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/12.png","src_13":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/13.png","src_14":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/14.png","src_15":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/15.png","src_16":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/16.png","src_17":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/17.png","src_18":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/18.png","src_19":"http://192.168.4.30:8082/adapter/daswetter/icons/tiempo-weather/galeria1/19.png","src_20":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/20.png","src_21":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/21.png","src_22":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/22.png","src_23":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/23.png","src_24":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/24.png","src_25":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/25.png","src_26":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/25.png","src_27":"http://192.168.4.30:8082/vis.0/VIS/Meine_Icons/Mond/25.png","name":"Symbol"},"style":{"left":"65px","top":"90px","z-index":"10","width":"120px","height":"120px"},"widgetSet":"basic"}]
                    Am besten den kompletten Widget-Export in einen Editor deiner Wahl einfügen und dann suchen und ersetzen.
                    Erstze meine IP (192.168.4.30) durch deine ioBroker-IP
                    H 2 Antworten Letzte Antwort
                    • K Kuddel
                      Widget:
                      hofmannha
                      #1096
                      @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                      Hallo Kuddel,
                      vielen Dank. Genau so habe ich es gemacht.
                      H K 2 Antworten Letzte Antwort
                      • H hofmannha
                        Hallo Kuddel,
                        hofmannha
                        #1097
                        @hofmannha
                        es funktioniert. Danke
                        • H hofmannha
                          Hallo Kuddel,
                          K Online
                          K Online
                          Kuddel
                          #1098
                          @hofmannha aber funktioniert trotzdem nicht?
                          dann schaue mal ob, der pfad zu den icons passt. am besten per ssh anmelden und in folgendem Verzeichnis gucken:
                          /opt/iobroker/iobroker-data/files/daswetter.admin/icons
                          • K Kuddel
                            Widget:
                            hofmannha
                            #1099
                            @Kuddel
                            Hallo Kuddel,
                            ich brauche noch ein mal deine Hilfe. Ich komme mit dem Müllkalender nicht klar. Die Zahl für Haumüll stimmt,
                            aber die Zahlen für Altpapier und Gelber Sack von -1 stimmen nicht. Ich sehe einfach den Fehler nicht.
                            Screenshots sind angehängt.
                            K opossumO 2 Antworten Letzte Antwort
                            • H hofmannha
                              @Kuddel
                              Hallo Kuddel,
                              K Online
                              K Online
                              Kuddel
                              #1100
                              @hofmannha ich bin mittlerweile vom Javascript weg und habe für diese Anzeige den TrashSchedule installiert.
                              TrashSheduler
                              Konfig:
                              Finde ich einfacher, als mit dem Javascript
                              • H hofmannha
                                @Kuddel
                                Hallo Kuddel,
                                opossumO Offline
                                opossumO Offline
                                opossum
                                #1101
                                @hofmannha sagte in [Vorstellung] Meine zweite Visualisierung:
                                @Kuddel
                                Hallo Kuddel,
                                ich brauche noch ein mal deine Hilfe. Ich komme mit dem Müllkalender nicht klar. …
                                ich glaube, wenn Du den Kalender nicht lange genug in die Zukunft abfragst, dann kommt die -1, weil er keine Daten findet. So war es zumindest bei mir. Aber auch ich bin auf den TrashSchedule umgeschwenkt, der funktioniert bei mir zuverlässig.
                                https://www.schlepper-petersdorf.de
                                • K Kuddel
                                  TrashSheduler
                                  Konfig:
                                  hofmannha
                                  #1102
                                  @Kuddel
                                  Hallo Kuddel,
                                  herzlichen Dank. Probiere ich aus.
                                  • H hofmannha
                                    @Kuddel
                                    Hallo Kuddel,
                                    hofmannha
                                    #1103
                                    @hofmannha
                                    Hallo Kuddel,
                                    der Adapter funktioniert. Du hast Recht er ist wesentlich einfacher. Nun das aber..
                                    Ich bekomme einfach keine Werte für Altpapier und gelber Sack. Bio und Restmüll funktionieren. Hast Du einen Rat?
                                    • H hofmannha
                                      @hofmannha
                                      Hallo Kuddel,
                                      K Online
                                      K Online
                                      Kuddel
                                      #1104
                                      @hofmannha der Mülltyp ist überall gleich benannt ?
                                      Zeig mal bitte einen Auszug aus deinem Kalender und von der TrashScheduler Konfig.
                                      • K Kuddel
                                        hofmannha
                                        #1105
                                        @Kuddel
                                        Hallo Kuddel,
                                        • H hofmannha
                                          @Kuddel
                                          Hallo Kuddel,
                                          K Online
                                          K Online
                                          Kuddel
                                          #1106
                                          @hofmannha versuch es mal mit "genuer Treffer".
                                          Also noch " in Dittlenburg" hinzufügen
                                          H 4 Antworten Letzte Antwort
