  4. JavaScript
  5. [gelöst]JSON.parse Problem mit WienerLinien Daten
    1.0k
    6.1k
javascript
5 Beiträge 2 Kommentatoren 808 Aufrufe 1 Beobachtet
    Stephan66
    schrieb am zuletzt editiert von Stephan66
    Ich habe nun folgendes Problem. Die Wiener Linien stellen mit einem Aufruf (z.B. Abfahrtsdaten77A-Lusthaus JSON Daten für den Abfahrtsmonitor zur Verfügung.
    {"data":{"monitors":[{"locationStop":{"type":"Feature","geometry":{"type":"Point","coordinates":[16.4401136,48.1934097]},"properties":{"name":"60200818","title":"Lusthaus, Aspernallee","municipality":"Wien","municipalityId":90001,"type":"stop","coordName":"WGS84","attributes":{"rbl":2139}}},"lines":[{"name":"77A","towards":"Rennweg S","direction":"R","platform":"2","richtungsId":"2","barrierFree":true,"realtimeSupported":true,"trafficjam":false,"departures":{"departure":[{"departureTime":{"timePlanned":"2020-02-02T18:27:00.000+0100","timeReal":"2020-02-02T18:27:00.000+0100","countdown":8}},{"departureTime":{"timePlanned":"2020-02-02T18:37:00.000+0100","timeReal":"2020-02-02T18:37:00.000+0100","countdown":18}},{"departureTime":{"timePlanned":"2020-02-02T18:47:00.000+0100","timeReal":"2020-02-02T18:47:00.000+0100","countdown":28}},{"departureTime":{"timePlanned":"2020-02-02T18:57:00.000+0100","timeReal":"2020-02-02T18:57:00.000+0100","countdown":38}},{"departureTime":{"timePlanned":"2020-02-02T19:07:00.000+0100","timeReal":"2020-02-02T19:07:00.000+0100","countdown":48}},{"departureTime":{"timePlanned":"2020-02-02T19:17:00.000+0100","timeReal":"2020-02-02T19:17:00.000+0100","countdown":58}},{"departureTime":{"timePlanned":"2020-02-02T19:27:00.000+0100","timeReal":"2020-02-02T19:27:00.000+0100","countdown":68}}]},"type":"ptBusCity","lineId":477}],"attributes":{}}]},"message":{"value":"OK","messageCode":1,"serverTime":"2020-02-02T18:18:38.000+0100"}}
    Sind also die Rohdaten.
    mit folgendem Code
    on({id: "parser.0.WL77A", change: 'any'}, function(obj) {
    var gasStation = JSON.parse(obj.state.val);
    if (!Array.isArray(gasStation) ) {
    log ("Array nicht angelegt!");
    return;
    if (gasStation.length === 0) {
    log ("Array hat Länge 0");
    return;
    var myStation = obj.data.monitors[0].locationStop.properties.title;
    log ("Station: " + myStation);
    komme ich nur bis: Array nicht angelegt!
    Da klappt das parsen wohl nicht.
    Im Adapter habe ich wie folgt eingestellt:
    ![Bild Text](3ef11c63-731c-4db8-b089-8f43f4a49bfc-grafik.png Bild Link)
    Was mache ich da falsch?
    • S Stephan66
      mit folgendem Code
      return;
      return;
      @Stephan66 sagte:
      Der "Umweg" über den Parser-Adapter ist nicht nötig, da man den JSON direkt per request() von der Webseite einlesen kann. Welche Werte brauchst Du ?
        Stephan66
        Vielen Dank für die rasche Antwort.
        Benötigt werden nur die Daten von departure: "0"-"3" TimePlanned, TimeReal und countdown.
        Also eigentlich nur diese 12 Werte. Sollten dann in Datenpunkte geschrieben werden - dürfte aber dann das geringere Problem sein.
        • S Stephan66
          @Stephan66 sagte:
          Anstelle von log in Datenpunkte schreiben:
          const url = 'https://www.wienerlinien.at/ogd_realtime/monitor?rbl=2139';
          function abfahrten() {
              request(url, function(error, response, result) {
                  let zeiten = JSON.parse(result).data.monitors[0].lines[0].departures.departure;
                  let anzahl = zeiten.length;
                  if(anzahl > 4) anzahl = 4;
                  for(let i = 0; i < anzahl; i++) {
                      log(zeiten[i].departureTime.timePlanned);
                      log(zeiten[i].departureTime.timeReal);
                      log(zeiten[i].departureTime.countdown);
          schedule('* * * * *', abfahrten); // jede Minute
            Stephan66
            @paul53 sagte in JSON.parse Problem mit WienerLinien Daten:
            Super. Klappt. Vielen Dank.
            Da habe ich wohl über zu viele Ecken gedacht.
            Ich bastle dann mal weiter.
