  4. [gelöst]Hilfe bei Widget
    5.1k
vis
20 Beiträge 3 Kommentatoren 810 Aufrufe 2 Beobachtet
  • Dominik F.D Dominik F.
    @Glasfaser
    Dieses springt nicht auf die Mainseite, jedoch werden dort nur 3 Elemente angezeigt und es lässt sich nix scrollen, bzw nicht mit dem finger über touch
    GlasfaserG Offline
    GlasfaserG Offline
    @Dominik-F
    Teste mal den
    [{"tpl":"tplJquiSelectList","data":{"oid":"spotify-premium.0.player.playlist.trackList","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{spotify-premium.0.player.playlist.trackListNumber}","texts":"{spotify-premium.0.player.playlist.trackListString}","height":"100","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"487px","top":"92px","width":"329px","height":"100px"},"widgetSet":"jqui"}]
      @Dominik-F sagte in Hilfe bei Widget:
      @Glasfaser
      Habe alle Views kontrolliert, der Haken ist nur auf meiner Startseite gesetzt
      Nimm den mal zum testen da auch raus.
      Der Haken prüft auf Änderung der Auflösung (man kann für verschiedene Auflösungen mehrere Haken setzen und der View, der tatsächlichen Auflösung am nächsten kommt wird geöffnet.
      Wenn das Widget (ich habe es jetzt nicht getestet) irrtümlich von dem Adapter als View erkannt wird, springt es sofort auf den default
      Dominik F.D Offline
      Dominik F.D Offline
      Dominik F.
      @Homoran
      Genau das war die Lösung. Gibt es eine Möglichkeit das das Widget nicht vom Adapter als View erkannt wird? Oder macht das insgesamt keinen Unterschied ob ich auf der Mainseite bei Default n Haken hab oder nicht?
        @Homoran
        ich kannte so etwas nur bei einem View in Widget
        Mach bitte dazu ein Issue bei vis auf - Danke
        Ich nehme an, dass bei einem Widget mit einer eingabemöglichkeit der Focus kurzfristig wechselt.
        • GlasfaserG Glasfaser
          @Dominik-F
          Teste mal den
          Dominik F.D Offline
          Dominik F.D Offline
          Dominik F.
          schrieb am zuletzt editiert von Dominik F.
          @Glasfaser
          gleiches wie bei dem anderen. Es funktioniert jetzt erst mal mit dem ersten Widget von mir.
          @Homoran
          wie mache ich so ein issue auf?
          Im Hintergrund sieht man auch, wie die View kurzzeitig eine andere Auflösung oder wie man das am besten nennt hat, auf jedenfall ändert sich etwas im Hintergrund
          HomoranH GlasfaserG 2 Antworten Letzte Antwort
            @Glasfaser
            @Homoran
            Hier:
            https://github.com/ioBroker/ioBroker.vis/issues
              @Glasfaser
              @Homoran
              GlasfaserG Offline
              GlasfaserG Offline
              @Glasfaser
              Das war dein Widget , habe nur die Breite eingetragen !
              Ich denke mal das Feld was öffnet geht über dein Rand , deshalb öffnet er die Main Seite .
              Wo hast du Ihn denn platziert !?
                @Glasfaser
                Dominik F.D Offline
                Dominik F.D Offline
                Dominik F.
                @Glasfaser
                Hab ihn oben links in der Ecke plaziert. 20px von links und 85px von oben
                  @Glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Dominik-F
                  Dann verstehe ich aber dein beigestelltes Widget nicht !?
                  Das hat andere Wert !
                    @Dominik-F
                    Dominik F.D Offline
                    Dominik F.D Offline
                    Dominik F.
                    @Glasfaser
                    ich hatte das aus der Adapterseite herauskopiert und bei mir woanders hingesetzt. Dachte es wäre eher ein generelles Problem. Ohne CSS konnte ich nicht scrollen, mit CSS gings auf die Mainseite.... Über Vis Runtime am Laptop funktionierte es jedoch immer richtig.
                    Hier ist das aus meiner View:
                    [{"tpl":"tplJquiSelectList","data":{"oid":"spotify-premium.0.player.playlist.trackList","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{spotify-premium.0.player.playlist.trackListNumber}","texts":"{spotify-premium.0.player.playlist.trackListString}","height":"100","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":true,"class":"mdui-select"},"style":{"left":"20px","top":"85px","width":"200px","font-size":"medium"},"widgetSet":"jqui"}]
                      @Glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Dominik-F
                      Sieht schon anders aus : CSS Class mdui-select war auch eingetragen
                      Letzter Versuch :
                      [{"tpl":"tplJquiSelectList","data":{"oid":"spotify-premium.0.player.playlist.trackList","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{spotify-premium.0.player.playlist.trackListNumber}","texts":"{spotify-premium.0.player.playlist.trackListString}","height":"100","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":"mdui-select","no_style":true},"style":{"left":"287px","top":"73px","width":"232px","height":"28px","z-index":"100"},"widgetSet":"jqui"}]
                        @Dominik-F
                        Letzter Versuch :
                        Dominik F.D Offline
                        Dominik F.D Offline
                        Dominik F.
                        @Glasfaser
                        gleiches Verhalten wie bei meinem, ohne Default Haken passt es, mit Haken gehts ab zur Mainseite. Auch das Verhalten des Hintergrundes ist gleich, aber das stört nicht weiter weil wenn ich ein Element auswähle ist alles so wie es sein soll
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @Dominik-F
                          OK …… war ein Versuch wert .
                          Dann mache wie Homoran angegeben , ein Issue auf !
                            @Dominik-F
                            Dominik F.D Offline
                            Dominik F.D Offline
                            Dominik F.
                            @Glasfaser
                            Ich danke dir trotzdem für deine Hilfe und Unterstützung!
                            Eine Frage hätte ich noch.....die Liste die sich öffnet, kann man die in der Größe variieren? Es wäre optisch schöner, wenn die Liste etwas größeren Abstand von oben und unten hat. Um genau zu sein 85px von oben und 90 px von unten. Die liste hätte dann eine Höhe von 794px.
                            Da es über CSS läuft schätze ich, dass man hierbei was ändern muss? Hab mal Testweise was geändert was ich für richtig hielt aber klappte nicht.
                               select
                            .mdui-select  {
                              z-index:2;
                              font-weight:normal !important;
                              text-shadow:none !important;
                              text-align: left !important;
                              letter-spacing: 0px !important;
                            .mdui-select select  {
                              color : rgba(255,255,255,1);
                              height: 100% !important;
                              font-size:1em !important;
                              background: rgba(0,0,0,0);
                              border: none;
                              outline: none;
                              border-bottom : 2px solid rgba(255,255,255,0.54);
                              width:100%;
                            .vis_container_edit .mdui-select select {
                              pointer-events: none;
                            .mdui-select select option {
                              background: #212121 !important;
                              font-size:1.5em !important;
                            .mdui-select:before {
                              position: absolute;
                              top: calc(50% - 0.22em);
                              right: 0.22em;
                              width: 0px;
                              height: 0px;
                              padding: 0px;
                              content: "";
                              border-left: .4em solid transparent;
                              border-right: .4em solid transparent;
                              border-top: .4em solid #FFFFFF;
                            .mdui-runtime.mdui-notouch .mdui-select select:hover,
                            .mdui-select select:focus {
                              border-bottom-color : #2196F3;
                              box-shadow: 0 0 0 1000px rgba(255,255,255,0.2) inset;
                              transition: all 0.3s ease;
