  4. Vis-google-fonts
  • Weihnachtsangebot 2025! 🎄
    2.5k
Vis-google-fonts
20 Beiträge 10 Kommentatoren 5.9k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Hat jemand schon vis-google-fonts ausprobiert?
    https://github.com/ioBroker/ioBroker.vis-google-fonts
    Die Schriften kann man überall (wo es geht :D ) verwenden.
    [{"tpl":"tplJquiButtonLink","data":{"visibility-cond":"==","visibility-val":1,"buttontext":
    "jqui - static Button Link","padding":"5"},"style":{"left":"16px",
    "top":"40px","font-family":"","width":"219px","height":"60px"},
    "widgetSet":"jqui"},{"tpl":"tplHtml","data":{"visibility-cond":"==","visibility-val":1,
    "refreshInterval":"0","html":"basic - static HTML"},"style":{"left":"16px","top":"15px",
    "font-family":"RubikMonoOne-Regular","width":"273px","height":"20px"},"widgetSet":"basic"},
    {"tpl":"tplMetroTileNav","data":{"visibility-cond":"==","visibility-val":1,"hover":"true",
    "transform":"true","label":"Navigation","bg_class":"bg-indigo",
    "bg_class_active":"bg-magenta","badge_bg_class":"bg-cyan",
    "badge_bg_class_active":"bg-teal","icon_badge":"icon-file","brand_bg_class":
    "ribbed-steel","brand_bg_class_active":"ribbed-indigo","icon_class":"icon-new"},
    "style":{"left":"16px","top":"104px","font-family":""},"widgetSet":"metro"},
    {"tpl":"tplValueString","data":{"oid":"dev6","visibility-cond":"==","visibility-val":1},
    "style":{"left":"21px","top":"252px","width":"113px","height":"24px","font-family":"Bangers"},
    "widgetSet":"basic"}]
    Für metro und jqui braucht man CSS:
    /* jqui */
    #visview_DemoView .ui-widget {
        font-family: Pacifico;
    /* metro */
    #visview_DemoView .label {
        font-family: Jura-Medium;
    Bitte nur View-name in "#visview_DemoView" anpassen.
    • P Offline
      pix
      Hallo Bluefox,
      vielen Dank für den Adapter. Ich habe gestern Abend meine Views von Futura auf RobotoCondensed-Regular, Futura; umgestellt. Wenn der Adapter nicht lädt oder Probleme macht, geht immer noch Futura.
      Heute habe ich auch die Metro Widgets umgestellt. Allerdings gibt es einige, bei denen noch eine andere Schrift verwendet wird. Sieh mal hier: 261_bildschirmfoto_2015-11-19_um_10.04.06.jpg
      "Bad Heizung" ist gut, die Daten darüber sind noch die alte Schrift.
      Wie stelle ich die um?
      Pix
      • BluefoxB Offline
        BluefoxB Offline
        @pix:
        Hallo Bluefox,
        Heute habe ich auch die Metro Widgets umgestellt. Allerdings gibt es einige, bei denen noch eine andere Schrift verwendet wird. Sieh mal hier: filename="Bildschirmfoto 2015-11-19 um 10.04.06.jpg" index="1">~~
        Pix `
        Falls du metro verwendest:
        .metro .tile-content * {
            font-family: RobotoCondensed-Regular;
        Oder das.
        .metro .tile-content td {
        Sollte schneller sein.
        • P Offline
          Pman
          Bei mir funktioniert deine css Beispieler super im vis-Editor, allerdings wird das css nicht gespeichert wie mir scheint. Im View werden die Änderungen nach dem verlassen des Editors nicht angezeigt und wenn ich den Editor wieder öffne ist das css weg.
          • P Offline
            pix
            Hallo Bluefox,
            es klappt noch nicht so richtig:
            Dieser Code (rot, damit man schnell sieht, wo die Formatierung greift):````
            color: red;
            ergibt dann dies:
             ![261_bildschirmfoto_2015-11-19_um_14.35.20.jpg](/assets/uploads/files/261_bildschirmfoto_2015-11-19_um_14.35.20.jpg)  ![261_bildschirmfoto_2015-11-19_um_14.39.03.jpg](/assets/uploads/files/261_bildschirmfoto_2015-11-19_um_14.39.03.jpg)
            Das "g" habe ich angefügt, um den Unterschied zwischen den Schriften zu zeigen.
            Standard Schriftart für die ganze View (Reiter View/Schriftart) ist auch RobotoCondensed-Regular. Font-Family in Widget-Einstellungen ist leer (übernimmt ja die Einstellungen der View).
            Beim Widget Metro - Tile String wird der Datenpunkt Inhalt ID noch nicht formatiert (Datenpunkt Zustand ID aber schon).
            Beim Inhalt des DWD-Widgets ändert sich auch noch nix.
            Gruß,
            Pix
            • P Offline
              Pman
              @pix:
              Gruß,
              Pix `
              Das Beispiel von bluefox war glaube ich auf das andere Heating Tile (ohne Popup) bezogen, da ist die html Struktur etwas anders.
              • blauholstenB Offline
                blauholsten
                Bei mir mag es leider nicht wirklich klappen! Es kommt im "Front-Family" Menü keine Vorschau wie man bei bluefox seinem ersten Bild sehen kann…
                671_unbenannt.png :oops: :oops: :oops:
                - Alarm Adapter
                • BluefoxB Offline
                  BluefoxB Offline
                  @blauholsten:
                  filename="Unbenannt.PNG" index="0">~~ :oops: :oops: :oops: `
                  Was für ein Browser und OS?
                    BaBooN
                    nabend,
                    bei mir wurde erst übernommen als ich bei CSS "Projekt" statt "Global" ausgewählt habe.
                    Mein Problem ist allerdings dass die größere Schrift auf alle Views übernommen wird und nicht nur bei einzelnen Widgets, ist das normal?
                    Dadurch passt die Schrift nicht mehr bei allen Widegts und ist abgeschnitten =(
                    anbei mal meine Views.
                    Wär nett wenn ihr auch meine Views kommentiert. Bin absoluter Neuling und kämpfe noch oft :roll:
                      blauholsten
                      @Bluefox:
                      @blauholsten:
                      filename="Unbenannt.PNG" index="0">~~ :oops: :oops: :oops: Was für ein Browser und OS?
                      ViS auf Win10 und Chrome…..ioBroker läuft auf PI2
                      - Alarm Adapter
                        blauholsten
                        @BaBooN:
                        nabend,
                        bei mir wurde erst übernommen als ich bei CSS "Projekt" statt "Global" ausgewählt habe. `
                        Bei mir leider nicht….
                        - Alarm Adapter
                        • V Offline
                          V Offline
                          vore
                          Hallo!
                          Hat da jemand was rausfinden können? Ich möchte gerne die Sschriftart für meine Metro Tiles global umstellen, aber selbst mit dem CSS Code (oben) passiert nichts.
                          Was muss kann ich machen?
                          Vore
                          • BluefoxB Offline
                            BluefoxB Offline
                            @vore:
                            Hallo!
                            Vore `
                            • V Offline
                              V Offline
                              vore
                              Hallo!
                              Noch eine Frage: wie kann ich die Schriftgröße beim "Bool Switch" einstellen? Das ist dann "Voranstellen HTML".
                              Vore
                              • BluefoxB Offline
                                BluefoxB Offline
                                @vore:
                                Hallo!
                                Vore `
                                [{"tpl":"tplMetroValueBoolSwitch","data":{"oid":"nothing_selected",
                                "visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,
                                "signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png",
                                "signals-icon-size-0":0,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==",
                                "signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-horz-1":0,
                                "signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":
                                "/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":
                                false,"html_prepend":"OFF",
                                "html_append":"ON"},
                                "style":{"left":"228px","top":"153px","font-family":"Candal"},"widgetSet":"metro"}]
                                  tomdeboom
                                  ich bräuchte mal euere Hilfe. iobroker läuft bei mir auf einem raspberry, und wenn ich die Schrift installieren möchte bekomme ich jedesmal diese Meldung:
                                  ~~![](</s><URL url=)<link_text text="http://forum.iobroker.net/download/file ... d36cdc4713">http://forum.iobroker.net/download/file.php?mode=view&id=20445&sid=2cf6d2f3e00f9bc972dc8dd36cdc4713</link_text>" />
                                  Die Schriften finde ich aber auf meinem Raspberry:
                                  ~~![](</s><URL url=)<link_text text="http://forum.iobroker.net/download/file ... d36cdc4713">http://forum.iobroker.net/download/file.php?mode=view&id=20446&sid=2cf6d2f3e00f9bc972dc8dd36cdc4713</link_text>" />
                                  Im iobroker vis bekomme ich sieh aber nicht angezeigt, wo liegt mein Fehler?
                                  Vielen Dank für euere Hilfe!
                                  <size size="85">CCU2 | QNAP TVS-473 64GB | VM Lubunto iBroker | Echo 2\. Gen. | LAN/Wifi | 18 Geräte</size>
                                  • HomoranH Offline
                                    HomoranH Offline
                                    Hast du vis neu gestartet?
                                    und den Browsercache gelöscht?
                                      tomdeboom
                                      Vergessen…........
                                      Vielen Dank Rainer das war es... :D
                                      • P Offline
                                        Pert
                                        Seitdem ich 2 ioBroker laufen habe (Multihost), werden die Fonts bei mir nicht mehr angezeigt.
                                        Kann das jemand nachvollziehen?
                                        Thx
                                          michihorn
                                          Hallo
                                          ich möchte gerne im Metro "Tile State Val Badge Number" die "Number ID" in Größe und Farbe ändern.
                                          Aber nur ein bestimmtes und nicht alle Metros
                                          Meine View heißt "Haus"
                                          das Widget heißt "w00157"
                                          Hatte gehofft das das so klappte:
                                          #visview_Haus .number_oid {
                                              color: red !important;
                                          Leider klappt es nicht. Kann mir jemand helfen?
                                          Michael
                                          32.7k
                                          82.4k
