  4. Skript bringt rflink zum reboot - nur warum? :-/
    5.7k
blockly
7 Beiträge 2 Kommentatoren 344 Aufrufe 1 Beobachtet
  • padrinoP Online
    padrinoP Online
    padrino
    schrieb am zuletzt editiert von padrino
    hab' hier ein (wie ich finde) wirklich einfaches Blockly (hab mal alles raus gestrippt und nur den Crashgrund über gelassen).
    Wird es getriggert, veranlasst es den rflink adapter neu zu starten. :(
    Sehe leider nicht, wieso...
    Vielleicht sieht ja jemand mehr als ich...
    Der Neustart im Log:
    rflink.0	2019-11-23 14:41:30.626	info	Connected
    rflink.0	2019-11-23 14:41:30.612	info	Serial port opened
    rflink.0	2019-11-23 14:41:29.933	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rflink, node: v8.11.4
    host.raspberrypi	2019-11-23 14:41:28.639	info	instance system.adapter.rflink.0 started with pid 19974
    host.raspberrypi	2019-11-23 14:40:58.614	info	Restart adapter system.adapter.rflink.0 because enabled
    host.raspberrypi	2019-11-23 14:40:58.614	error	instance system.adapter.rflink.0 terminated with code 0 (OK)
    host.raspberrypi	2019-11-23 14:40:58.614	error	Caught by controller[0]: at processImmediate [as _immediateCallback] (timers.js:745:5)
    host.raspberrypi	2019-11-23 14:40:58.613	error	Caught by controller[0]: at tryOnImmediate (timers.js:768:5)
    host.raspberrypi	2019-11-23 14:40:58.613	error	Caught by controller[0]: at runCallback (timers.js:810:20)
    host.raspberrypi	2019-11-23 14:40:58.613	error	Caught by controller[0]: at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3429:38)
    host.raspberrypi	2019-11-23 14:40:58.613	error	Caught by controller[0]: at Adapter.emit (events.js:214:7)
    host.raspberrypi	2019-11-23 14:40:58.613	error	Caught by controller[0]: at emitTwo (events.js:126:13)
    host.raspberrypi	2019-11-23 14:40:58.612	error	Caught by controller[0]: at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.rflink/main.js:146:9)
    host.raspberrypi	2019-11-23 14:40:58.612	error	Caught by controller[0]: at writeCommand (/opt/iobroker/node_modules/iobroker.rflink/main.js:181:66)
    host.raspberrypi	2019-11-23 14:40:58.612	error	Caught by controller[0]: at Object.encodeValue (/opt/iobroker/node_modules/iobroker.rflink/admin/parse.js:243:30)
    host.raspberrypi	2019-11-23 14:40:58.612	error	Caught by controller[0]: at Object.ID (/opt/iobroker/node_modules/iobroker.rflink/admin/parse.js:112:27)
    host.raspberrypi	2019-11-23 14:40:58.611	error	Caught by controller[0]: TypeError: Cannot read property 'toString' of undefined
    Das Blockly:
    ... als Javascript
    var temp_temp;
    on({id: "rflink.0.channels.InoValley_SM200_1.TEMP"/*InoValley_SM200_ 1 Temperature*/, change: "ne"}, function (obj) {
      var value = obj.state.val;
      temp_temp = (obj.state ? obj.state.val : "");
      setState("rflink.0.channels.InoValley_SM200_1.TEMP_fixed"/*TEMP_fixed*/, temp_temp);
    Der Datenpunkt "InoValley_SM200_ 1 Temperature" (von rflink angelegt):
      "from": "system.adapter.rflink.0",
      "ts": 1550502448006,
      "common": {
        "name": "InoValley_SM200_ 1 Temperature",
        "role": "value.temperature",
        "unit": "C°",
        "type": "number",
        "read": true,
        "write": true
      "native": {
        "brand": "InoValley_SM200",
        "attr": "TEMP",
        "ID": 418,
        "offset": 0
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "rflink.0.channels.InoValley_SM200_1.TEMP",
      "type": "state"
    Und der Datenpunkt "TEMP_fixed" (von mir angelegt):
      "_id": "rflink.0.channels.InoValley_SM200_1.TEMP_fixed",
      "type": "state",
      "common": {
        "name": "TEMP_fixed",
        "role": "",
        "type": "number",
        "read": true,
        "write": true,
        "desc": "Manuell erzeugt",
        "unit": "°C"
      "native": {},
      "ts": 1574287787498,
      "acl": {
        "object": 1636,
        "state": 1636,
    • padrinoP padrino
      Das Blockly:
      ... als Javascript
      var temp_temp;
        "common": {
          "unit": "C°",
          "type": "number",
          "read": true,
          "write": true
        "native": {
          "attr": "TEMP",
          "ID": 418,
          "offset": 0
        "acl": {
          "object": 1636,
          "state": 1636
        "type": "state"
        "type": "state",
        "common": {
          "role": "",
          "type": "number",
          "read": true,
          "write": true,
          "unit": "°C"
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      @padrino
      Man soll keine eigenen Datenpunkte unter "fremden" Instanzen erstellen !
      padrinoP 2 Antworten Letzte Antwort
        @padrino
        padrinoP Online
        padrinoP Online
        padrino
        Hm, aber davon habe ich im rflink eine Menge, und das ganz ohne Probleme. 😇
        Wie z.B. (nur BAT, HUM und TEMP sind original):
          @padrino
          padrinoP Online
          padrinoP Online
          padrino
          Und wie soll man sowas ☝ aufgeräumt hin bekommen, wenn man es nicht an Ort und Stelle packen soll? :(
          • padrinoP padrino
            @padrino sagte:
            Und wie soll man sowas aufgeräumt hin bekommen
            Mit createState() unter javascript.0 oder manuell / per Skript unter 0_userdata.0.
              @padrino sagte:
              padrinoP Online
              padrinoP Online
              padrino
              Das fühlt sich für mich aber auch nicht aufgeräumt an. :(
              So muss ich ja auch die ganzen Strukturen der Adapter meinerseits klonen...
              Übrigens, eben festgestellt, wenn ich den "steuere" Befehl in "aktualiere" ändere, dann crasht der rflink adapter nicht und startet nicht neu.
              • padrinoP padrino
                @padrino sagte :
                Wenn Du damit leben kannst ? Eigene Datenpunkte sollte man immer mit "aktualisiere" schreiben.
