  4. [GELÖST][Frage] JSON-Datei auslesen?
    5.4k
33 Beiträge 6 Kommentatoren 11.8k Aufrufe 3 Beobachtet
  • VardaaranV Offline
    VardaaranV Offline
    Vardaaran
    muss nochmals nerven :oops:
    Was muss ich deswegen tun?
    ! ` > javascript.0 2017-05-15 14:24:41.213 warn Wrong type of javascript.0.variablen.lmair1.sensoren.owm.weather_id: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.213 warn Wrong type of javascript.0.variablen.lmair1.sensoren.owm.rain: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.212 warn Wrong type of javascript.0.variablen.lmair1.sensoren.owm.wind: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.212 warn Wrong type of javascript.0.variablen.lmair1.sensoren.owm.humidity: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.212 warn Wrong type of javascript.0.variablen.lmair1.sensoren.owm.temperature: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.212 warn Wrong type of javascript.0.variablen.lmair1.sensoren.internal.temperature: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.212 warn Wrong type of javascript.0.variablen.lmair1.sensoren.os_selected.outside: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:41.211 warn Wrong type of javascript.0.variablen.lmair1.sensoren.os_selected.inside: 'string'. Please fix, while deprecated and will not work in next versions.
    javascript.0 2017-05-15 14:24:40.145 info script.js.susy.lmair1.sensorenauslesen: registered 0 subscriptions and 1 schedule
    javascript.0 2017-05-15 14:24:40.145 info Start javascript script.js.susy.lmair1.sensorenauslesen `
    • paul53P Offline
      Wenn die Datenpunkte vom Typ 'number' sind, dann parseFloat() anwenden. Beispiel:
                  setState('variablen.lmair1.sensoren.owm.temperature', parseFloat(result.owm.temperature));  // Temperatur in Datenpunkt
        VardaaranV Offline
        Vardaaran
        @paul53:
        1A! VIELEN DANK!! :D
        • H Offline
          hanschris
          Vardaan, könntest du so nett sein und einmal dein komplettes Skript posten? Ich habe nämlich auch einen Lightmanager und würde die Daten in ioBroker einlesen lassen.
          Vielen Dank! :D
            VardaaranV Offline
            Vardaaran
            @hanschris:
            Vielen Dank! :D `
            Natürlich sehr gerne:
            var logOn = false; // Skript Logausgabe ein- (true) / ausschalten (false). Fehler werden immer ausgegeben.
            var forecreation = false; // Default: false. true: Datenpunkte werden überschrieben (wenn z.B. Bezeichnungen geändert wurden)
            var http = require('http'); // Node Module http verwenden
            var RQoptions = { // URL, die abgefragt, bzw. gesendet werden soll
            host: '192.168.0.131',
            path: '/weather.json',
            port: 80,
            auth: 'XYZLAN:12345', // UNBEDINGT ANPASSEN!
            method: 'GET',
            headers: {
            'User-Agent' : 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_4) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36',
            'content-Type': 'text/plain',
            'Accept' : 'application/json, text/javascript'
            ! // Datenpunkte anlegen:
            // Datenpunkt-Variablen:
            var idVariablenDP;
            var dpGruppe;
            var dpPunkt;
            // --- GRUPPE "os selected"
            var dpGruppe = "os_selected";
            var dpPunkt = "inside";
            var idVariablenDP = "variablen.lmair1.sensoren." + dpGruppe + "." + dpPunkt; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
            createState(idVariablenDP, 0, forecreation, { // Datenpunkt wird angelegt
            name: dpPunkt, // <-- !!!!!
            desc: dpPunkt + ' von ' + dpGruppe, // <-- !!!!!
            type: 'number',
            def: 0.0,
            role: 'value'
            var dpPunkt = "outside";
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "internal"
            var dpGruppe = "internal";
            var dpPunkt = "temperature";
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel1"
            var dpGruppe = "channel1";
            type: 'number',
            def: 0.0,
            role: 'value'
            var dpPunkt = "humidity";
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel2"
            var dpGruppe = "channel2";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel3"
            var dpGruppe = "channel3";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel4"
            var dpGruppe = "channel4";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel5"
            var dpGruppe = "channel5";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel6"
            var dpGruppe = "channel6";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel7"
            var dpGruppe = "channel7";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel8"
            var dpGruppe = "channel8";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel9"
            var dpGruppe = "channel9";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "channel10"
            var dpGruppe = "channel10";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            // --- GRUPPE "owm"
            var dpGruppe = "owm";
            type: 'number',
            def: 0.0,
            role: 'value'
            type: 'number',
            def: 0.0,
            role: 'value'
            var dpPunkt = "wind";
            type: 'number',
            def: 0.0,
            role: 'value'
            var dpPunkt = "rain";
            type: 'number',
            def: 0.0,
            role: 'value'
            var dpPunkt = "weather_id";
            type: 'number',
            def: 0.0,
            role: 'value'
            ! // Funktionen:
            function DatenAuslesen() {
            var req = http.get(RQoptions, function(res) {
            if(logOn) log('STATUS: ' + res.statusCode); // Statuscode
            if(logOn) log('HEADERS: ' + JSON.stringify(res.headers)); // Header (Rückmeldung vom Webserver)
            // Buffer the body entirely for processing as a whole.
            var bodyChunks = [];
            var chunkLine = 0;
            res.on('data', function(chunk) {
            chunkLine = chunkLine + 1;
            if(logOn) log("Zeilennummer: " + chunkLine+ " ,Inhalt: " + chunk);
            // Hier können die einzelnen Zeilen verarbeitet werden...
            bodyChunks.push(chunk);
            }).on('end', function() {
            if(logOn) log("ARRAY mit den einzelnen Zeilen: " + bodyChunks);
            if(logOn) log("ARRAY Länge: " + bodyChunks.length);
            ! var body = Buffer.concat(bodyChunks);// erhaltene Daten
            ! if(logOn) log('BODY: ' + body); // ...und/oder das Gesamtergebnis.
            DatenVerarbeiten(body); // Abrufen der Bearbeitungs-Funktion
            req.on('error', function(e) { // Fehler abfangen
            log('ERROR: ' + e.message,"warn");
            return("error");
            function DatenVerarbeiten(result) {
            var json = JSON.parse(result);
            if (json !== null) {
            	// GRUPPE "os selected"
            	setState("javascript.0.variablen.lmair1.sensoren.os_selected.inside", parseFloat(json["os selected"].inside));
            	setState("javascript.0.variablen.lmair1.sensoren.os_selected.outside", parseFloat(json["os selected"].outside));
            	// GRUPPE "internal"
            	setState("javascript.0.variablen.lmair1.sensoren.internal.temperature", parseFloat(json.internal.temperature));
            	// GRUPPE "channel1"
            	setState("javascript.0.variablen.lmair1.sensoren.channel1.temperature", parseFloat(json.channel1.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel1.humidity", parseFloat(json.channel1.humidity));
            	// GRUPPE "channel2"
            	setState("javascript.0.variablen.lmair1.sensoren.channel2.temperature", parseFloat(json.channel2.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel2.humidity", parseFloat(json.channel2.humidity));
            	// GRUPPE "channel3"
            	setState("javascript.0.variablen.lmair1.sensoren.channel3.temperature", parseFloat(json.channel3.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel3.humidity", parseFloat(json.channel3.humidity));
            	// GRUPPE "channel4"
            	setState("javascript.0.variablen.lmair1.sensoren.channel4.temperature", parseFloat(json.channel4.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel4.humidity", parseFloat(json.channel4.humidity));
            	// GRUPPE "channel5"
            	setState("javascript.0.variablen.lmair1.sensoren.channel5.temperature", parseFloat(json.channel5.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel5.humidity", parseFloat(json.channel5.humidity));
            	// GRUPPE "channel6"
            	setState("javascript.0.variablen.lmair1.sensoren.channel6.temperature", parseFloat(json.channel6.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel6.humidity", parseFloat(json.channel6.humidity));
            	// GRUPPE "channel7"
            	setState("javascript.0.variablen.lmair1.sensoren.channel7.temperature", parseFloat(json.channel7.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel7.humidity", parseFloat(json.channel7.humidity));
            	// GRUPPE "channel8"
            	setState("javascript.0.variablen.lmair1.sensoren.channel8.temperature", parseFloat(json.channel8.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel8.humidity", parseFloat(json.channel8.humidity));
            	// GRUPPE "channel9"
            	setState("javascript.0.variablen.lmair1.sensoren.channel9.temperature", parseFloat(json.channel9.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel9.humidity", parseFloat(json.channel9.humidity));
            	// GRUPPE "channel10"
            	setState("javascript.0.variablen.lmair1.sensoren.channel10.temperature", parseFloat(json.channel10.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.channel10.humidity", parseFloat(json.channel10.humidity));
            	// GRUPPE "owm"
            	setState("javascript.0.variablen.lmair1.sensoren.owm.temperature", parseFloat(json.owm.temperature));
            	setState("javascript.0.variablen.lmair1.sensoren.owm.humidity", parseFloat(json.owm.humidity));
            	setState("javascript.0.variablen.lmair1.sensoren.owm.wind", parseFloat(json.owm.wind));
            	setState("javascript.0.variablen.lmair1.sensoren.owm.rain", parseFloat(json.owm.rain));
            	setState("javascript.0.variablen.lmair1.sensoren.owm.weather_id", parseFloat(json.owm["weather id"]));
            } else {
            	log ("Fehler beim Einlesen der Daten.");
            ! // Beim Skriptstart die Werte auslesen:
            setTimeout(DatenAuslesen, 1000);
            ! // Werte automatisch aktualisieren:
            schedule('*/2 * * * *', DatenAuslesen); // alle 2 Minuten
            Habe hier alle Daten der Datei ausgelesen.
            Du musst die Zugangsdaten des LMAir, die Pfade der Datenpunkte und den Intervall (ganz unten) natürlich nach Deinen Wünschen/Vorgaben anpassen.
            • H Offline
              hanschris
              Grandios! Vielen Dank - funktioniert einwandfrei.
              Dürfte ich die unverschämte Frage stellen und mich erkundigen, ob du für die params.json auch schon ein ähnliches Skript erstellt hast und dieses zur Verfügung stellen magst? Würde mich für die Zustände der Marker intereissieren.
                VardaaranV Offline
                Vardaaran
                @hanschris:
                Dürfte ich die unverschämte Frage stellen und mich erkundigen, ob du für die params.json auch schon ein ähnliches Skript erstellt hast und dieses zur Verfügung stellen magst? Würde mich für die Zustände der Marker intereissieren. `
                Wieso Unverschämt?
                Zum auslesen der Marker nutze ich dieses Skript:
                // Startvariablen:
                ! var logOn = false; // Skript Logausgabe ein- (true) / ausschalten (false). Fehler werden immer ausgegeben.
                path: '/params.json',
                port: 80,
                auth: 'XYZ:12345', // HIER WIEDER UNBEDINGT ANPASSEN!
                method: 'GET',
                headers: {
                var stringMARKERgesamt = "0000000000000000000000000000000000000000000000000000000000000000";
                // Marker:
                var idMarker1 = "variablen.lmair1.01_pc-101"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker1, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 01',
                desc: 'PC-101-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker2 = "variablen.lmair1.02_tv"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker2, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 02',
                desc: 'TV-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker3 = "variablen.lmair1.03_reboot"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker3, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 03',
                desc: 'Reboot-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker4 = "variablen.lmair1.04_nacht"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker4, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 04',
                desc: 'Nacht-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker5 = "variablen.lmair1.05_daemmerung"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker5, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 05',
                desc: 'Dämmerungs-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker6 = "variablen.lmair1.06_tageslicht"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker6, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 06',
                desc: 'Tageslicht-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker7 = "variablen.lmair1.07_ruhemodus-arbeitszimmer"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker7, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 07',
                desc: 'Ruhemodus-Arbeitszimmer-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker8 = "variablen.lmair1.08_ruhemodus-schlafzimmer"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker8, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 08',
                desc: 'Ruhemodus-Schlafzimmer-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker9 = "variablen.lmair1.09_stromausfall"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker9, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 09',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker10 = "variablen.lmair1.10_deckenlampe-schlafzimmer"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker10, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 10',
                desc: 'Schlafzimmer-Deckenlampe-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker11 = "variablen.lmair1.11_deckenzusatzlampen-schlafzimmer"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker11, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 11',
                desc: 'Schlafzimmer-Deckenzusatzlampen-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                var idMarker12 = "variablen.lmair1.12_deckenlampe-arbeitszimmer"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idMarker12, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir Marker 12',
                desc: 'Arbeitszimmer-Deckenlampe-Marker von LMair1',
                type: 'boolean',
                def: false,
                role: 'value'
                ! // Manueller Button:
                var idButton = "alexa.lmair1-markerauslesen"; // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                createState(idButton, 0, forecreation, { // Datenpunkt wird angelegt
                name: 'LMAir 1 Marker auslesen',
                desc: 'Marker von LMAir 1 auslesen',
                type: 'boolean',
                role: 'button'/,
                smartName: {
                de: 'LMAir 1 Marker auslesen'
                ! // Funktionen:
                // Daten abfragen:
                var chunkLine = 0;
                    return("error");
                ! // Daten verarbeiten:
                    stringMARKERgesamt = json["marker state"];
                    var wertMARKERvon = 1;
                    var wertMARKERbis = 12;
                    var stringMARKERkurz = stringMARKERgesamt.slice(wertMARKERvon-1, wertMARKERbis);
                    var wertDURCHLAUF = 1;
                    while (wertDURCHLAUF <= wertMARKERbis) {
                        var wertMARKERaktuell = stringMARKERgesamt.slice(wertDURCHLAUF-1, wertDURCHLAUF);
                        wertMARKERaktuell = parseFloat(wertMARKERaktuell);
                        WertePruefen(wertMARKERaktuell, wertDURCHLAUF);
                        wertDURCHLAUF++;
                } else {
                ! // Werte überprüfen und anpassen:
                function WertePruefen (MarkerWERT, MarkerNR) {
                if (MarkerWERT === 1) {
                MarkerWERT = true;
                } else if (MarkerWERT === 0) {
                MarkerWERT = false;
                } else {
                log ("Marker-Wert fehlerhaft");
                switch (MarkerNR) {
                    case 1:
                        idMARKERaktuell = "javascript.0." + idMarker1;          // Marker 01
                        break;
                    case 2:
                        idMARKERaktuell = "javascript.0." + idMarker2;          // Marker 02
                        break;
                    case 3:
                        idMARKERaktuell = "javascript.0." + idMarker3;          // Marker 03
                        break;
                    case 4:
                        idMARKERaktuell = "javascript.0." + idMarker4;          // Marker 04
                        break;
                    case 5:
                        idMARKERaktuell = "javascript.0." + idMarker5;          // Marker 05
                        break;
                    case 6:
                        idMARKERaktuell = "javascript.0." + idMarker6;          // Marker 06
                        break;
                    case 7:
                        idMARKERaktuell = "javascript.0." + idMarker7;          // Marker 07
                        break;
                    case 8:
                        idMARKERaktuell = "javascript.0." + idMarker8;          // Marker 08
                        break;
                    case 9:
                        idMARKERaktuell = "javascript.0." + idMarker9;          // Marker 09
                        break;
                    case 10:
                        idMARKERaktuell = "javascript.0." + idMarker10;         // Marker 10
                        break;
                    case 11:
                        idMARKERaktuell = "javascript.0." + idMarker11;         // Marker 11
                        break;
                    case 12:
                        idMARKERaktuell = "javascript.0." + idMarker12;         // Marker 12
                        break;
                    default:
                        log ("fehlerhafter Marker");
                        break;
                if (idMARKERaktuell !== null) {
                    if (getState(idMARKERaktuell).val !== MarkerWERT) setState(idMARKERaktuell, MarkerWERT);
                } else {
                    log ("Markerpfad fehlerhaft");
                ! // Start und Intervall:
                setTimeout(DatenAuslesen, 1000); // Beim Skriptstart die Werte auslesen
                schedule('*/1 * * * *', DatenAuslesen); // alle 1 Minuten
                ! // Button-Aktivierung:
                on({id: "javascript.0." + idButton, change:'any'}, function (dp) {
                DatenAuslesen();
                Geht aktuell nur bis Marker 12. Müsste sich aber ohne größere Probleme erweitern lassen.
                Für Fragen oder bei Problemen stehe ich gerne zur Verfügung!
                • H Offline
                  hanschris
                  Hey,
                  vielen Dank für das Skript. Funktioniert einwandfrei! Auch das Erweitern hat geklappt.
                  Ich habe die Aktualisierung für die Marker auf 2 Sekunden herabgesetzt. So kann man den Änderungen der Zustände quasi live zusehen.
                    VardaaranV Offline
                    Vardaaran
                    @hanschris:
                    Ich habe die Aktualisierung für die Marker auf 2 Sekunden herabgesetzt. So kann man den Änderungen der Zustände quasi live zusehen. `
                    Sehr gerne!
                    Habe ich auch überlegt. Wollte dem LMAir aber nicht so viel zumuten. Wirklich wichtige Marker, bei der es auf jede Sekunde ankommt - aktualisiere ich über den simple-api-Adapter direkt in einer Szene o.Ä. über den LMAir.
                    Außerdem habe ich die Funktion zum aktualisieren noch über einen Schalter zugänglich gemacht. So kann diese auch außerhalb der Admin-Oberfläche - z.B. vom LMAir - angestoßen werden…
                    • v522533V Offline
                      v522533V Offline
                      v522533
                      ich muss dieses alte Thema nochmal ausgraben. Funktioniert dieses Skript noch mit dem lighmanager air? ich suche eine möglichkeit den status von z.b. einem licht in der vis anzeigen zu lassen, auch wenn es ausserhalb von iobroker geschalten wurde.
                      Danke schonmal.
                      Gruß Chris
                      • Bernd 0B Offline
                        Bernd 0B Offline
                        Bernd 0
                        schrieb am zuletzt editiert von Bernd 0
                        ich hoffe ihr könnt mir weiterhelfen.
                        Ich habe einen Link zu einem JSON Datensatz.
                        https://api.solcast.com.au/rooftop_sites/bf92-b91e-170c-f1e9/estimated_actuals?format=json
                        Diese Daten würde ich gerne in den IOBroker laden und anschließend visaulisieren.
                        Leider habe ich überhaupt keine Ahnung, wie ich das schaffe :)
                        Probiert hätte ich es mit o.g. Anleitung so:
                        --> Unter Scripte, neues Script, Java-Script
                        var request = require('request');
                        var link = 'https://api.solcast.com.au/rooftop_sites/bf92-b91e-170c-f1e9/estimated_actuals?format=json';
                        function Solcast() {
                            request(link, function(error,response, body) {
                                if(error) log('Fehler request: ' + error, 'error');
                                else {
                                    var result = JSON.parse(body);
                                    setState('Estimate.Gen'), result.pv_estimate);  //
                                    setState('Estimate.ten'), result.pv_estimate10);
                                    setState('Estimate.ninty'), result.pv_estimate90);
                                    setState('Period.End'), result.period_end);
                        schedule('*/5 * * * *', Solcast);  // alle 5 Minuten
                        Bekomme aber auch eine Fehlermeldung:
                        javascript.0 (1013) script.js.Solcast compile failed: at script.js.Solcast:9
                        Was möchte ich erreichen?
                        Das folgende Chart von Solcast in meiner VIS.
                        Dort kann man dann erkennen, welche prognostizierte Leistung die PV Anlage die nächsten 3 Tage bringt.
                        Vielleicht habt ihr einen Tipp für mich.
                        Vielen Dank
