  4. Was ist in meinen Netzwerk los?
    5.7k
security
1 Beiträge 1 Kommentatoren 219 Aufrufe 4 Beobachtet
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    schrieb am zuletzt editiert von sissiwup
    ich möchte gerne wissen, was in meinen Netzwerk los ist, d.h. wann kommt ein neues Devices hinzu, wann wird eine neue IP-Adresse generiert etc.
    Ich generiere mir bei neuen devices eine Push-Nachricht.
    Dafür braucht mein ein wenig Skript (hier python):
    from getmac import get_mac_address
    import csv
    import socket
    import pandas as pd
    import threading
    import datetime
    import os
    import requests
    akt = datetime.datetime.now()
    def get_vendor(mac):
        sst = mac[0:8]
        name = names.get(sst)
        if name is None:
            return "? => ?"
        return name
    def pushOver(txt):
        title = "Geraet ! "
        message = "Neues Geraet im Haus \n" + txt + "\n" + akt.strftime("%Y-%m-%d %H:%M:%S") + " !"
        r = requests.post("https://api.pushover.net/1/messages.json", data={
            "token": "--token--",
            "user": "--user--",
            "title": title,
            "message": message,
            "priority": 1
    names = {}
    with open('oui.csv') as csv_file:
        csv_reader = csv.reader(csv_file, delimiter=',')
        for ar in csv_reader:
            search = ar[1][0:2] + ":" + ar[1][2:4] + ":" + ar[1][4:6]
            search = search.lower()
            names[search] = ar[2] + " => " + ar[3]
    aktip = {}
    macetc = {}
    allmac = {}
    with open('my.csv') as csv_file:
            aktip[ar[0]] = ar[1]
            macetc[ar[1]] = ar
    with open('mymac.csv') as csv_file:
            allmac[ar[0]] = ar
    class ip_check(threading.Thread):
        def __init__(self, ip):
            threading.Thread.__init__(self)
            self.ip = ip
            self.__name = ""
            self.__company = ""
            self.__mac = ""
            self.__newdev = True
            self.__newip = True
            self.__newmac = True
            self.__newipmac = True
        def run(self):
            self.__mac = get_mac_address(ip=self.ip)
            if (self.__mac is not None) and (self.__mac != "00:00:00:00:00:00"):
                self.__company = get_vendor(self.__mac)
                try:
                    self.__name = socket.gethostbyaddr(self.ip)[0]
                except:
                    self.__name = "?.local"
                smac = aktip.get(self.ip)
                if smac is not None:
                    self.__newdev = False
                    self.__newip = False
                    if smac == self.__mac:
                        self.__newipmac = False
                line = allmac.get(self.__mac)
                if line is not None:
                    self.__newmac = False
                    if line[3] == self.ip:
        def status(self):
            if self.found():
                return "" + self.ip + " " + self.__mac + " " + self.__name + " " + self.__company
            else:
                return "?"
        def getLanList(self):
            if self.found():
                txt = self.ip + " " + self.__name
                txt = txt + " " + self.__name.split(".")[0]
                return txt
            else:
                return ""
        def devStat(self):
            stat = "old mac+ip";
            if self.__newdev:
                stat = "new       "
            if self.__newmac:
                stat = "new mac   "
                if self.__newip:
                    stat = "new mac+ip"
            else:
                if self.__newip:
                    stat = "new     ip"
            return stat
        def devOk(self):
            return self.devStat() == "old mac+ip"
        def doPush(self):
            if self.devStat() == "new mac   ":
                return True
            if self.devStat() == "new mac+ip":
                return True
            return False
        def getmac(self):
            return self.__mac
        def getcsv(self):
            if self.found():
                return [self.ip, self.__mac, self.__name, self.__company]
            else:
                return []
        def getAllMac(self):
            if self.found():
                return [self.__mac, self.__name, self.__company, self.ip]
            else:
                return []
        def found(self):
            if (self.__mac is None) or (self.__mac == "00:00:00:00:00:00"):
                return False
            else:
                return True
    check_results = []
    for i in range(1, 255):
        ip = "192.168.1." + str(i)
        ipp = "192.168.1." + ("000" + str(i))[-3:]
        current = ip_check(ip)
        check_results.append(current)
        current.start()
    with open('my.csv', 'w') as csv_file:
        csv_writer = csv.writer(csv_file, delimiter=',', quoting=csv.QUOTE_ALL)
        for el in check_results:
            el.join()
            if el.found():
                allmac[el.getmac()] = el.getAllMac()
                try:
                    macetc.pop(el.getmac())
                except Exception as e:
                    sub = 0
                if el.devOk() == False:
                    print(akt.strftime("%Y-%m-%d %H:%M:%S") + ":" + el.devStat() + " " + el.status())
                if el.doPush() == True:
                    pushOver(el.status())
                csv_writer.writerow(el.getcsv())
                # print(el.getLanList())
    for el in macetc:
        if el is not None:
            val = macetc.get(el)
            print(akt.strftime("%Y-%m-%d %H:%M:%S") + ":DEL        " + " ".join(val) + "<br>")
    if os.path.exists("mymac.csv"):
        os.remove("mymac.csv")
    with open('mymac.csv', 'w') as csv_file:
        for ar in allmac:
            val = allmac.get(ar)
            csv_writer.writerow(val)
    # ende = datetime.datetime.now()
    # print("Start: " + akt.strftime("%Y-%m-%d %H:%M:%S") + " Dauer:" + str(ende - akt))
    df = pd.read_csv('my.csv', names=['IP', 'MAC', 'Name', 'Hersteller'])
    # Save to file
    df.to_html('mydev.html')
    Hier die DB für MAC->Hersteller:
    oui.csv
    Und hier ein wenig Shell-Skript, um die Ergebnisse aufzuhübschen:
    #!/bin/bash
    logfile=/var/skripte/startGetNet.log
    echo "$(date) Starte getNet" >> $logfile
    cd /var/skripte
    python3 -u getnet.py >> $logfile
    echo "<html><head>" > /var/www/html/mydev.html
    echo "<title>WH:Devices</title>" >> /var/www/html/mydev.html
    echo "<meta http-equiv='refresh' content='60'>" >> /var/www/html/mydev.html
    echo "</head><body>" >> /var/www/html/mydev.html
    echo "<h2>Devices - $(date)</h2>" >> /var/www/html/mydev.html
    #more mydev.html >> /var/www/html/mydev.html
    #grep -v getNet $logfile | tail -100 | sort -r >> /var/www/html/mydev.html
    if [ -f "${logfile}" ]
    then
    	printf "<h3>NEW Logfile</h3><table border=\"1\">" >> /var/www/html/mydev.html
    	printf "<tr><th>Datum</th><th>Zeit</th><th>OP</th><th>IP</th><th>MAC</th><th>Name</th><th>Hersteller</th></tr>" >> /var/www/html/mydev.html
    	grep "new mac\|new     ip" $logfile | tail -10 | sort -r | sed "s/\(^[0-9-]*\) \([0-9:]*\):\([ a-zA-Z+]*\)\([0-9.]*\) \([0-9a-z:]*\) \([.?a-zA-Z0-9_-]*\) /\1<\/td><td>\2<\
    /td><td>\3<\/td><td>\4<\/td><td>\5<\/td><td>\6<\/td><td>/g" | while read line
    	do
    		printf "<tr><td>${line}</td></tr>" >> /var/www/html/mydev.html
    	done
    	printf "</table>" >> /var/www/html/mydev.html
    fi
    echo "<h3>Liste</h3>" >> /var/www/html/mydev.html
    then
    	printf "<h3>CHANGE Logfile</h3><table border=\"1\">" >> /var/www/html/mydev.html
    	grep -v getNet $logfile | tail -100 | sort -r | sed "s/\(^[0-9-]*\) \([0-9:]*\):\([ a-zA-Z+]*\)\([0-9.]*\) \([0-9a-z:]*\) \([.?a-zA-Z0-9_-]*\) /\1<\/td><td>\2<\/td><td>\3<
    	do
    	done
    fi
    echo "</body></html>" >> /var/www/html/mydev.html
    Was ist anzupassen:
    Verzeichnisse in Shell-Skipt
    Token für pushover
    Die python Datei und das oui,csv liegen im gleichen Verzeichnis.
    Ist mit python 3.7 erstellt worden.
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
