  4. Node.js: Cannot find module
    5.4k
12 Beiträge 2 Kommentatoren 3.0k Aufrufe
  • C Offline
    Communicate
    seit gestern ist mein iobroker (inkl. vis) nur sporadisch erreichbar.
    Im Log wiederholt sich folgender Fehler ständig:
    host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
    Hat jemand ne Idee, warum das so spontan kommen kann und wie ich das beheben könnte?
    Dominic
    • HomoranH Offline
      HomoranH Offline
      Kam das wirklich spontan, oder nach einem update?
      UND:
      @Communicate:
      host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module) `
      da müsste auch noch stehen welches modul
      • C Offline
        Communicate
        es kam spontan und danach habe ich dann per iobroker upgrade alles aktualisiert.
        So sieht das Log aus:
        raspberrypi 2015-09-28 20:47:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:47:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:47:04 info host.raspberrypi instance system.adapter.admin.1 started with pid 9292
        raspberrypi 2015-09-28 20:46:34 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:46:34 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:46:29 info host.raspberrypi instance system.adapter.admin.1 started with pid 9291
        raspberrypi 2015-09-28 20:45:59 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:45:59 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:45:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9290
        raspberrypi 2015-09-28 20:45:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:45:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:45:19 info host.raspberrypi instance system.adapter.admin.1 started with pid 9289
        raspberrypi 2015-09-28 20:44:49 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:44:49 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:44:39 info host.raspberrypi instance system.adapter.admin.1 started with pid 9288
        raspberrypi 2015-09-28 20:44:09 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:44:09 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:44:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:44:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:44:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9287
        raspberrypi 2015-09-28 20:43:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:43:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:43:26 info host.raspberrypi instance system.adapter.admin.1 started with pid 9286
        raspberrypi 2015-09-28 20:42:56 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:42:56 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:42:46 info host.raspberrypi instance system.adapter.admin.1 started with pid 9285
        raspberrypi 2015-09-28 20:42:16 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:42:16 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:42:06 info host.raspberrypi instance system.adapter.admin.1 started with pid 9284
        raspberrypi 2015-09-28 20:41:36 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:41:36 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:41:28 info host.raspberrypi instance system.adapter.admin.1 started with pid 9283
        raspberrypi 2015-09-28 20:40:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:40:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:40:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9282
        raspberrypi 2015-09-28 20:40:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:40:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:40:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
        raspberrypi 2015-09-28 20:40:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
        raspberrypi 2015-09-28 20:39:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:39:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:39:44 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:39:44 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:39:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9280
        raspberrypi 2015-09-28 20:39:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:39:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:38:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9279
        raspberrypi 2015-09-28 20:38:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:38:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:38:21 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
        raspberrypi 2015-09-28 20:38:20 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
        raspberrypi 2015-09-28 20:37:50 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:37:50 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:37:38 info host.raspberrypi instance system.adapter.admin.1 started with pid 9277
        raspberrypi 2015-09-28 20:37:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:37:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:37:02 info host.raspberrypi instance system.adapter.admin.1 started with pid 9276
        raspberrypi 2015-09-28 20:36:32 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:36:32 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:36:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9275
        raspberrypi 2015-09-28 20:35:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:35:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:35:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:35:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:35:50 info host.raspberrypi instance system.adapter.admin.1 started with pid 9274
        raspberrypi 2015-09-28 20:35:20 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:35:20 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:35:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9273
        raspberrypi 2015-09-28 20:34:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:34:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:34:33 info host.raspberrypi instance system.adapter.admin.1 started with pid 9272
        raspberrypi 2015-09-28 20:34:03 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:34:03 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:33:57 info host.raspberrypi instance system.adapter.admin.1 started with pid 9271
        raspberrypi 2015-09-28 20:33:27 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:33:27 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:33:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9270
        raspberrypi 2015-09-28 20:32:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:32:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:32:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9269
        raspberrypi 2015-09-28 20:32:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:32:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:31:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9268
        raspberrypi 2015-09-28 20:31:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:31:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:31:16 info host.raspberrypi instance system.adapter.admin.1 started with pid 9267
        raspberrypi 2015-09-28 20:30:46 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:30:46 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:30:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9266
        raspberrypi 2015-09-28 20:30:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:30:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:29:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9265
        raspberrypi 2015-09-28 20:29:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:29:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:29:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
        raspberrypi 2015-09-28 20:29:13 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
        raspberrypi 2015-09-28 20:28:43 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:28:43 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:28:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9263
        raspberrypi 2015-09-28 20:28:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:28:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:28:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9262
        raspberrypi 2015-09-28 20:27:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:27:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:27:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9261
        raspberrypi 2015-09-28 20:26:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:26:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:26:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9260
        raspberrypi 2015-09-28 20:26:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:26:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:26:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9259
        raspberrypi 2015-09-28 20:25:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:25:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        raspberrypi 2015-09-28 20:25:38 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
        raspberrypi 2015-09-28 20:25:38 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:25:26 info instance system.adapter.admin.1 started with pid 9258
        host-raspberrypi 2015-09-28 20:24:56 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:24:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:24:49 info instance system.adapter.admin.1 started with pid 9257
        host-raspberrypi 2015-09-28 20:24:19 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:24:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:24:07 info instance system.adapter.admin.1 started with pid 9256
        host-raspberrypi 2015-09-28 20:23:37 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:23:37 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:23:33 info instance system.adapter.admin.1 started with pid 9255
        host-raspberrypi 2015-09-28 20:23:03 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:23:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:22:59 info instance system.adapter.admin.1 started with pid 9254
        host-raspberrypi 2015-09-28 20:22:29 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:22:29 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:22:25 info instance system.adapter.admin.1 started with pid 9253
        host-raspberrypi 2015-09-28 20:21:55 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:21:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:21:49 info instance system.adapter.admin.1 started with pid 9252
        host-raspberrypi 2015-09-28 20:21:19 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:21:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:21:14 info instance system.adapter.admin.1 started with pid 9251
        host-raspberrypi 2015-09-28 20:20:44 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:20:44 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:20:38 info instance system.adapter.admin.1 started with pid 9250
        host-raspberrypi 2015-09-28 20:20:08 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:20:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:20:01 info instance system.adapter.admin.1 started with pid 9249
        host-raspberrypi 2015-09-28 20:19:31 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:19:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:19:27 info instance system.adapter.admin.1 started with pid 9248
        host-raspberrypi 2015-09-28 20:18:57 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:18:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:18:53 info instance system.adapter.admin.1 started with pid 9247
        host-raspberrypi 2015-09-28 20:18:23 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:18:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:18:19 info instance system.adapter.admin.1 started with pid 9246
        host-raspberrypi 2015-09-28 20:17:49 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:17:49 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:17:40 info instance system.adapter.admin.1 started with pid 9245
        host-raspberrypi 2015-09-28 20:17:10 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:17:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:17:06 info instance system.adapter.admin.1 started with pid 9244
        host-raspberrypi 2015-09-28 20:16:36 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:16:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:16:32 info instance system.adapter.admin.1 started with pid 9233
        host-raspberrypi 2015-09-28 20:16:02 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:16:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:15:57 info instance system.adapter.admin.1 started with pid 9232
        host-raspberrypi 2015-09-28 20:15:27 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:15:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:15:22 info instance system.adapter.admin.1 started with pid 9231
        host-raspberrypi 2015-09-28 20:14:52 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:14:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:14:48 info instance system.adapter.admin.1 started with pid 9230
        host-raspberrypi 2015-09-28 20:14:18 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:14:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:14:08 info instance system.adapter.admin.1 started with pid 9229
        host-raspberrypi 2015-09-28 20:13:38 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:13:38 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:13:33 info instance system.adapter.admin.1 started with pid 9228
        host-raspberrypi 2015-09-28 20:13:03 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:13:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:12:59 info instance system.adapter.admin.1 started with pid 9227
        host-raspberrypi 2015-09-28 20:12:28 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:12:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:12:25 info instance system.adapter.admin.1 started with pid 9226
        host-raspberrypi 2015-09-28 20:11:54 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:11:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:11:50 info instance system.adapter.admin.1 started with pid 9225
        host-raspberrypi 2015-09-28 20:11:20 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:11:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:11:10 info instance system.adapter.admin.1 started with pid 9224
        host-raspberrypi 2015-09-28 20:10:40 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:10:40 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:10:36 info instance system.adapter.admin.1 started with pid 9223
        host-raspberrypi 2015-09-28 20:10:06 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:10:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:10:01 info instance system.adapter.admin.1 started with pid 9222
        host-raspberrypi 2015-09-28 20:09:31 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:09:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:09:26 info instance system.adapter.admin.1 started with pid 9221
        host-raspberrypi 2015-09-28 20:08:56 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:08:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:08:51 info instance system.adapter.admin.1 started with pid 9220
        host-raspberrypi 2015-09-28 20:08:21 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:08:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:08:09 info instance system.adapter.admin.1 started with pid 9219
        host-raspberrypi 2015-09-28 20:07:39 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:07:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:07:34 info instance system.adapter.admin.1 started with pid 9218
        host-raspberrypi 2015-09-28 20:07:04 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:07:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:07:00 info instance system.adapter.admin.1 started with pid 9217
        host-raspberrypi 2015-09-28 20:06:30 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:06:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:06:25 info instance system.adapter.admin.1 started with pid 9216
        host-raspberrypi 2015-09-28 20:05:55 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:05:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:05:51 info instance system.adapter.admin.1 started with pid 9215
        host-raspberrypi 2015-09-28 20:05:20 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:05:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:05:11 info instance system.adapter.admin.1 started with pid 9214
        host-raspberrypi 2015-09-28 20:04:41 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:04:41 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:04:36 info instance system.adapter.admin.1 started with pid 9213
        host-raspberrypi 2015-09-28 20:04:06 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:04:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:04:02 info instance system.adapter.admin.1 started with pid 9212
        host-raspberrypi 2015-09-28 20:03:32 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:03:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:03:28 info instance system.adapter.admin.1 started with pid 9211
        host-raspberrypi 2015-09-28 20:02:58 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:02:58 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:02:51 info instance system.adapter.admin.1 started with pid 9209
        host-raspberrypi 2015-09-28 20:02:21 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:02:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:02:17 info instance system.adapter.admin.1 started with pid 9208
        host-raspberrypi 2015-09-28 20:01:46 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:01:46 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:01:38 info instance system.adapter.admin.1 started with pid 9207
        host-raspberrypi 2015-09-28 20:01:08 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:01:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:01:03 info instance system.adapter.admin.1 started with pid 9206
        host-raspberrypi 2015-09-28 20:00:33 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 20:00:33 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 20:00:29 info instance system.adapter.admin.1 started with pid 9205
        host-raspberrypi 2015-09-28 19:59:59 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:59:59 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:59:54 info instance system.adapter.admin.1 started with pid 9204
        host-raspberrypi 2015-09-28 19:59:23 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:59:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:59:18 info instance system.adapter.admin.1 started with pid 9203
        host-raspberrypi 2015-09-28 19:58:48 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:58:48 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:58:40 info instance system.adapter.admin.1 started with pid 9202
        host-raspberrypi 2015-09-28 19:58:10 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:58:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:58:05 info instance system.adapter.admin.1 started with pid 9201
        host-raspberrypi 2015-09-28 19:57:35 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:57:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:57:31 info instance system.adapter.admin.1 started with pid 9200
        host-raspberrypi 2015-09-28 19:57:01 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:57:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:56:57 info instance system.adapter.admin.1 started with pid 9199
        host-raspberrypi 2015-09-28 19:56:27 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:56:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:56:23 info instance system.adapter.admin.1 started with pid 9198
        host-raspberrypi 2015-09-28 19:55:53 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:55:53 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:55:48 info instance system.adapter.admin.1 started with pid 9197
        host-raspberrypi 2015-09-28 19:55:18 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:55:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:55:06 info instance system.adapter.admin.1 started with pid 9196
        host-raspberrypi 2015-09-28 19:54:36 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:54:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:54:32 info instance system.adapter.admin.1 started with pid 9195
        host-raspberrypi 2015-09-28 19:54:02 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:54:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:53:58 info instance system.adapter.admin.1 started with pid 9194
        host-raspberrypi 2015-09-28 19:53:28 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:53:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:53:24 info instance system.adapter.admin.1 started with pid 9193
        host-raspberrypi 2015-09-28 19:52:54 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:52:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:52:48 info instance system.adapter.admin.1 started with pid 9192
        host-raspberrypi 2015-09-28 19:52:18 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:52:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:52:09 info instance system.adapter.admin.1 started with pid 9191
        host-raspberrypi 2015-09-28 19:51:39 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:51:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:51:34 info instance system.adapter.admin.1 started with pid 9190
        host-raspberrypi 2015-09-28 19:51:04 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:51:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:50:58 info instance system.adapter.admin.1 started with pid 9189
        host-raspberrypi 2015-09-28 19:50:28 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:50:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:50:24 info instance system.adapter.admin.1 started with pid 9188
        host-raspberrypi 2015-09-28 19:49:54 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:49:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:49:49 info instance system.adapter.admin.1 started with pid 9187
        host-raspberrypi 2015-09-28 19:49:19 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:49:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:49:13 info instance system.adapter.admin.1 started with pid 9186
        host-raspberrypi 2015-09-28 19:48:43 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:48:43 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:48:37 info instance system.adapter.admin.1 started with pid 9185
        host-raspberrypi 2015-09-28 19:48:07 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:48:07 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:48:02 info instance system.adapter.admin.1 started with pid 9184
        host-raspberrypi 2015-09-28 19:47:32 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:47:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:47:27 info instance system.adapter.admin.1 started with pid 9183
        host-raspberrypi 2015-09-28 19:46:57 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:46:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:46:52 info instance system.adapter.admin.1 started with pid 9182
        host-raspberrypi 2015-09-28 19:46:22 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:46:22 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:46:17 info instance system.adapter.admin.1 started with pid 9181
        host-raspberrypi 2015-09-28 19:45:47 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:45:47 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:45:40 info instance system.adapter.admin.1 started with pid 9180
        host-raspberrypi 2015-09-28 19:45:10 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:45:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:45:05 info instance system.adapter.admin.1 started with pid 9179
        host-raspberrypi 2015-09-28 19:44:35 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:44:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:44:31 info instance system.adapter.admin.1 started with pid 9178
        host-raspberrypi 2015-09-28 19:44:01 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:44:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:43:57 info instance system.adapter.admin.1 started with pid 9177
        host-raspberrypi 2015-09-28 19:43:27 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:43:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:43:22 info instance system.adapter.admin.1 started with pid 9176
        host-raspberrypi 2015-09-28 19:42:52 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:42:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:42:47 info instance system.adapter.admin.1 started with pid 9175
        host-raspberrypi 2015-09-28 19:42:17 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:42:17 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:42:09 info instance system.adapter.admin.1 started with pid 9174
        host-raspberrypi 2015-09-28 19:41:39 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:41:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:41:32 info instance system.adapter.admin.1 started with pid 9173
        host-raspberrypi 2015-09-28 19:41:02 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:41:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:40:58 info instance system.adapter.admin.1 started with pid 9172
        host-raspberrypi 2015-09-28 19:40:28 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:40:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:40:24 info instance system.adapter.admin.1 started with pid 9171
        host-raspberrypi 2015-09-28 19:39:54 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:39:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:39:49 info instance system.adapter.admin.1 started with pid 9170
        host-raspberrypi 2015-09-28 19:39:19 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:39:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:39:09 info instance system.adapter.admin.1 started with pid 9169
        host-raspberrypi 2015-09-28 19:38:39 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:38:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:38:35 info instance system.adapter.admin.1 started with pid 9168
        host-raspberrypi 2015-09-28 19:38:05 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:38:05 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:38:00 info instance system.adapter.admin.1 started with pid 9167
        host-raspberrypi 2015-09-28 19:37:30 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:37:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:37:24 info instance system.adapter.admin.1 started with pid 9166
        host-raspberrypi 2015-09-28 19:36:54 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:36:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:36:43 info instance system.adapter.admin.1 started with pid 9165
        host-raspberrypi 2015-09-28 19:36:12 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:36:12 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:36:06 info instance system.adapter.admin.1 started with pid 9164
        host-raspberrypi 2015-09-28 19:35:36 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:35:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:35:32 info instance system.adapter.admin.1 started with pid 9163
        host-raspberrypi 2015-09-28 19:35:02 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:35:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:34:58 info instance system.adapter.admin.1 started with pid 9162
        host-raspberrypi 2015-09-28 19:34:28 info Restart adapter system.adapter.admin.1 because enabled
        host-raspberrypi 2015-09-28 19:34:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
        host-raspberrypi 2015-09-28 19:34:23 info instance system.adapter.admin.1 started with pid 9161
        host-raspberrypi 2015-09-28 19:33:53 info Restart adapter system.adapter.admin.1 because enabled
        • HomoranH Offline
          HomoranH Offline
          mach mal ein reboot
          • C Offline
            Communicate
            so, log einträge sind weg. Ich hatte auf einmal eine zweite admin instanz.
            Was auch immer ich gemacht habe, dass die auf einmal da war…
            • C Offline
              Communicate
              kommando zurück. jetzt kann ich gar nicht mehr auf iobroker zugreifen:
              Diese Webseite ist nicht verfügbar.
              ERR_CONNECTION_REFUSED
              auch ein reboot hat nichts gebracht :-(
              • C Offline
                Communicate
                jetzt siehts so aus, als hätte ich gar keine admin instanz mehr.
                Und owohl die VIS instanz ja da ist, kann ich vis auch nicht mehr aufrufen :-(
                ps -A | grep io
                17 ? 00:00:00 bioset
                20 ? 00:00:00 rpciod
                23 ? 00:00:00 nfsiod
                35 ? 00:00:00 DWC Notificatio
                2043 ? 00:00:11 io.js-controlle
                2325 ? 00:00:09 io.web.0
                2375 ? 00:00:08 io.hm-rega.0
                2376 ? 00:00:07 io.hm-rpc.0
                2378 ? 00:00:06 io.vis.0
                • HomoranH Offline
                  HomoranH Offline
                  reboot!
                  und wenn danach immer noch kein admin da ist:
                  cd /opt/iobroker
                  iobroker stop
                  npm install iobroker.admin
                  iobroker start
                  • C Offline
                    Communicate
                    reboot hatte ich schon durch.
                    admin neu isntallieren probiere ich gerade
                    • C Offline
                      Communicate
                      das klappt leider auch nicht mehr:
                      dules/utf-8-validate
                      node-gyp rebuild
                      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
                      CXX(target) Release/obj.target/validation/src/validation.o
                      SOLINK_MODULE(target) Release/obj.target/validation.node
                      SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                      COPY Release/validation.node
                      make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
                      ! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                      node-gyp rebuild
                      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
                      CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                      SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                      SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                      COPY Release/bufferutil.node
                      make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
                      ! > utf-8-validate@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                      node-gyp rebuild
                      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
                      make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
                      ! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                      node-gyp rebuild
                      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
                      make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
                      npm ERR!
                      npm ERR! Additional logging details can be found in:
                      npm ERR! /opt/iobroker/npm-debug.log
                      npm ERR! not ok code 0
                      und hier die npm-debug.log:
                      root@raspberrypi:/opt/iobroker# tail /opt/iobroker/npm-debug.log
                      6592 error npm-@googlegroups.com6593 error System Linux 3.18.11+
                      6594 error command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin"
                      6595 error cwd /opt/iobroker
                      6596 error node -v v0.10.22
                      6597 error npm -v 1.3.14
                      6598 error path /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/lib/permuteDomain.js
                      6599 error code ENOENT
                      6600 error errno 34
                      6601 verbose exit [ 34, true ]/npm-@googlegroups.com
                      • HomoranH Offline
                        HomoranH Offline
                        Da fehlt ihm eine Datei.
                        Versuch es mal mit:
                        cd /opt/iobroker
                        npm cache clean
                        npm install iobroker.admin --production
                        Wenn das nicht klappt, hat mir bei einem solchen Problem mit einem anderen Adapter der Tip von versteckt geholfen, alles im Verzeichnis /tmp zu installieren und dann rüberzukopieren
                        …oder plattmachen
                        • C Offline
                          Communicate
                          scheint erstmal geklappt zu haben. aber merkwürdig ists trotzdem…
